Help with clearing fault code in battery regulator after crash happend.
Ahmad
C?ID=261056
Friday,17,January,2020,09:04:46:23990
VIN: WAUK2AF21KN078968   License Plate: AUDI A6 2019
Mileage: 1530km-950mi   Repair Order:
Chassis Type: F2-AU58 (4K0)
Scan: 01 02 03 09 15 16 17 19 22 36 3C 42 44 46 52 5F 61 6C 75 81
          A5 BB BC C4 CA CC CF D6 D7 DE
VIN: WAUK2AF21KN078968   Mileage: 1530km-950miles
C4-DC/DC Converter -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DLZA)       Labels: None
   Part No SW: 4K0 907 559 A    HW: 06M 907 309 G
   Component: V6 3.0l TFSI  H11 0004
   Revision: B8H11000
   Coding: 0A6500322326010E34286000000400000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0114K0907559A 001004
   ROD: EV_ECM30TFS0114K0907559A.rod
   VCID: 3326C9799A68DED76A-8066
Readiness: 1110 0101
Address 02: Auto Trans (J217)       Labels:| 0CJ-927-156.clb
   Part No SW: 4K0 927 153 M    HW: 0HL 927 156 B
   Component: 0HL 30TFSINAR H01 0003
   Revision: --H01---    Serial number: 0000002040
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU58.rod
   VCID: 373EFD698E1032F756-8062
   Manual Transmission Fluid Pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041190016003184
   Part No SW: 4K0 907 379 Q    HW: 4K0 907 379 F
   Component: ESP9 Plus     H06 0853
   Coding: 58AA159729A90B9E11A74897208552D2F439881AA894D08812044A4B2F9C11
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 43C699B9CAC86E57FA-8016
   Part No SW: 4N0 907 063 GG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0653
   Coding: 07000363E0081CCD070C87081CAE9C2A130B37110006009701000A0039321A01086108324257050800000303000300180002000004010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 79BA3B51F884E487E0-802C
   Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000001811260402856
   Coding: 7DC727
   Serial number: 22366204X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K1 941 501 C    HW: 4K1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 14S29.01.1900690081
   Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600368Z01EB02
   Coding: 250000
   Subsystem 5 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE129101823310472
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 E    HW: 4K0 947 135 E
   Component: Dachmodul  H42 0413
   Serial number: C00165649
   Coding: 0D0104
   Electrically Adjustable Steering Column:
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA135691000060547814
   Coding: 0A0700
405507 - Functional Limitation due to Energy Management
          B10CD 00 [009] - -
          [Function limitation due to energy management system]
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 17:52:49
                    average_Voltage_terminals: 11.10 V
                    Outside air temperature sensor-Resistance: 0.00 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 9.00 °C
                    interior_temperature: 11.50 °C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
   Part No SW: 4N0 959 655 K    HW: 4N0 959 655 K
   Component: AirbagVW31    H02 2720
   Serial number: 003YUM00ZNX8
   Coding: BFCCF0C000C00000A000003FF20D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 44C49AA5CFC6696FC3-8010
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
   Component: BeltPretRevFL  H10 0115
   Serial number: 00AI2019020384800000
   Coding: 04F001
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
   Component: BeltPretRevFR  H10 0115
   Serial number: 00AI2019011402000000
   Coding: 04F001
   Occupant Detection:
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J19000AWH5X00
   Coding: 303134
   Subsystem 4 - Part No SW: -----------    HW: 480 002 201 19
   Serial number: 35700000000B545CC63U
   Subsystem 5 - Part No SW: -----------    HW: 480 002 201 19
   Serial number: 35800000000F0435773H
   Subsystem 6 - Part No SW: -----------    HW: 480 032 501 19
   Serial number: 351001C18405B1F11D73
   Subsystem 7 - Part No SW: -----------    HW: 480 032 501 19
   Serial number: 352001C18F6AEDE01A8.
   Subsystem 8 - Part No SW: -----------    HW: 480 031 701 19
   Component: FrontSensor_D  002 0149
   Serial number: 355001C18F5AA960791L
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 031 701 19
   Component: FrontSensor_P  002 0149
   Serial number: 356001C18F52ED905A8V
   Part No SW: 4N0 907 129 H    HW: 4N0 907 129 H
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 3620F06D891ACBFF4D-8062
   Part No SW: 4K0 920 870 C    HW: 4K0 920 870 C
   Component: TBenUS------- H07 0187
   Coding: 8BE620C3A888D7050203E1609880080008002000
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 2C14D2054756812F2B-8078
   Part No SW: 4K0 907 468 J    HW: 4K0 907 468 C
   Component: Gateway       H05 0207
   Serial number: 1MF03028983501
   Coding: 020100050004064054960000005B0132CC3A000710000000097D078E10000000
   ASAM Dataset: EV_Gatew31xAU65x 003170
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 3B36E159B2381697B2-806E
   Subsystem 1 - Part No SW: 4K0 951 523 J    HW: 4K0 951 523 J
   Component: E221__MFL  H06 0003
   Serial number: 00000000000000000000
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 74186312001901230841
8519683 - Energy Management Active
          U140B 00 [009] - -
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 17:52:39
                    EM_vehicle_state: 20 10
                    Static current shutdown level: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
9502727 - Databus
          [BMS_No_Component_Function]
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 17:44:12
                    48V activation restriction-Airbag control module: active
                    48V activation restriction-Engine Electronics: not active
                    48V activation restriction-Roll stabilization: not active
                    48V activation restriction-48 V activation restriction due to open circuit: not active
                    48V activation restriction-48 V activation restriction due to deactivation: not active
                    48V activation restriction-Battery Energy Control Module 2: not active
                    48V activation restriction-DC/DC Converter Control Module: not active
                    48V activation restriction-Control module for auxiliary air heater: not active
                    48V activation restriction-Electrical Charger: not active
9502735 - Databus
          [DCDC_No_Component_Function]
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 17:44:12
9502755 - 48V System
          C124E F0 [009] - Locked after Crash Active
          [Airbag_CrashTyp_Historie_Hard]
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 17:44:12
Address 22: AWD (J492)       Labels:* None
   Part No SW: 4K0 927 755     HW: 0CJ 927 749 A
   Component: C8_DL4_N_SD2H01 0008
   Serial number: 18300A2950
   Coding: 110C0000
   ASAM Dataset: EV_AWDCQUOD31 001052
   ROD: EV_AWDCQUOD31.rod
   VCID: 72A80C7DA5F297DFA1-8026
   Part No SW: 4M4 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0044
   Serial number: 00000359503719
   Coding: 005C1A400000B4010003010101010000000000000000000000000000004000
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   Part No SW: 4N0 907 566 F    HW: 4N0 907 566 A
   Component: MRR_HR H12 0266
   Coding: 0F1B00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651_AU58.rod
   VCID: 393AFB51B8042487A0-806C
   Part No SW: 4M1 959 793 D    HW: 4M1 959 793 D
   Component: TSG FS001 0188
   Serial number: YE007RKJ07368
   Coding: 001FDB0052001480A001A030
   VCID: 40CC96B5DBDE754FE7-8014
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Coding: 94002001010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 312AC3716074ECC718-8064
   Part No SW: 4N0 907 064 CD    HW: 4N0 907 064 D
   Component: BCM2 MLBevo H14 0163
   Coding: 0134000049A000C0650FA0006C01000203024000810026502F0400000B04823F001E0101000011
   ASAM Dataset: EV_BCM2CONTIAU651 009009
   ROD: EV_BCM2CONTIAU651_009_AU58.rod
   VCID: 73A60979DAE89ED7AA-8026
   Ignition key:
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000046262633
   Subsystem 3 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11423447
   Part No SW: 4M1 959 792 D    HW: 4M1 959 792 D
   Component: TSG BFS001 0188
   Serial number: YE007SA809057
   Coding: 001FDB005E001480A001A030
   VCID: 3FCE9549A6200AB79E-806A
   Part No SW: 4K0 035 202 B    HW: 4K0 035 202 A
   Component: MU-H-LNS-US   046 9816
   Coding: 01850102FF0A000041220001061C00302F0006E403F00804CE
   ROD: EV_MUHigGen2pALPI_AU27.rod
   VCID: 1D720FC10CEC78A7AC-8048
   Subsystem 1 - Part No: V03 959 804 C
   Component: MIB2P_NA_Q118  0286
   Subsystem 2 - Part No SW: 4K0 919 604 A    HW: 4K0 919 604 A
   Component: DU AU58x Std  H42 0144
   Serial number: INX00110111800070289
   Component: Gracenote2  3006
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 A    HW: 4K1 919 616 A
   Component: LSR-D5/C8  H33 0108
   Serial number: 00004419000002084028
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4K0 919 603 A    HW: 4K0 919 603
   Component: DU AU58x Bot  H41 0144
   Serial number: INX00120111800080184
   Media Player 1 Sub:
   Subsystem 6 - Part No SW: 4N0 035 123     HW: 4N0 035 123
   Component: DISC PLAYER  H06 0006
   Serial number: AUZ8ZCJKJ00VU5$
   Media socket:
   Subsystem 7 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
   Component: MediaConnectL  014 0133
   Serial number: 051900000996003
0532 - Subwoofer
          B106C 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 5: Unterbrechung]
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 17:44:13
                    Voltage terminal 30: 11.3 V
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 291A2B1148A49407D0-807C
40973 - Crash Shut-Down Activated
          P1609 00 [047] - -
          [Diag_F_Crash_MV_ShutOff]
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 17:44:13
Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
   Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
   Component: RVC Compact   H15 0250
   Coding: 0285010102002001C20040
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
   ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F120293
   Coding: 01C020FE4040800000
   ASAM Dataset: EV_ConBoxAU651 002004
   ROD: EV_ConBoxAU651_002.rod
   VCID: 281C2E1553AEAD0FCF-807C
   Part No SW: 4K1 713 041 H    HW: 4K1 713 041 H
   Component: GSM-LL H14 0051
   Serial number: 18.352 41294
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AA    HW: 4N0 907 107 F
   Component: zFAS Var A    H08 0291
   Coding: 02018200000000000030060000000524119D56000000000000000000000000000019000000000000000000000000000000000000000000000000800000000000000072000080003000000000000000000080400000F0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001_AU58.rod
   VCID: 7EB0284DE1AAC3BFD5-802A
   Part No SW: 4M1 959 795 D    HW: 4M1 959 795 D
   Component: TSG HFS003 0188
   Serial number: YE007RL517766
   Coding: 000FDB0000001480E000A020
   VCID: 42C89CBDD5D2675FF1-8016
   Component: TSG HBFS003 0188
   Serial number: YE007RG421377
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC19412000242
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_VW38.rod
   VCID: 75A23761D49C80E784-8020
10487040 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 17:44:11
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     005 0002
   Coding: 268040058101
   ROD: EV_SunRoofCONTIAU736_009_VW27.rod
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 N    HW: 4N0 903 028 N
   Component: BSG-HP1-65    H17 0523
   Serial number: 17011900020595
   Coding: 20000400000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0266
   Coding: 0F1B00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651_AU58.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 572 DC    HW: 4K0 941 572 D
   Component: LMS_MLBevo    H05 0031
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
   ROD: EV_LMSLeftHELLAAU58X_AU38.rod
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ASAM Dataset: EV_LMSRightHELLAAU58X 001013
   ROD: EV_LMSRightHELLAAU58X_AU38.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4K0 035 502 A    HW: 4K0 035 502 A
   Component: WLC Front     H10 0057
   Coding: 800000
   ROD: EV_Charg1MobilDevicAU651.rod
   VCID: 1F0E35C906E06AB7BE-804A
End----(Elapsed Time: 01:51, VBatt start/end: 11.1V/11.0V. VIgn 11.0V)-----
DrPeter
16.4905° S, 151.7375° W
help with clearing fault code in battery regulator after crash happend.
In the [61-Battery Regul.] controller you may want to try the Basic Settings [Reset of reversible crash shut-off].
Use the [Show Measuring Data] and select [Crash signal]
- One of three will be displayed:
not active
active
Not available
Press [Go!] You should get a [Finished Correctly] message and if successful and the "not active" will be displayed in the measuring data .
Let us know how this works for you,
drpeter
Note: This vehicle also has a 48V Battery System, so the only way to charge the 48V Battery is to drive the vehicle. Just in case there are any other issues, this may help. Do not let this battery go flat/dead, replacement batteries are very expensive and avoidable!
Ahmad
C?ID=261056
not active
active
Not available
drpeter
i did that but vcds didnt give me the pin code it need security access in case to do it , do u have the security access code?
thanks i really appreciated.
Ahmad
C?ID=261056
i still need the security code :) vcds is not providing it to me
DrPeter
There does not appear to be any documented security access 'codes' at this time, sorry :(
It maybe necessary to have someone use the ODIS/Factory scan tool and see if they can 'capture' the security access code.
Also, I would avoid randomly entering codes, since these controllers do (for the most part) keep track of wrong codes and may lock you out from entering in a legitimate code.
drpeter
Ahmad
C?ID=261056
Friday,17,January,2020,11:34:38:23990
VIN: WAUK2AF21KN078968   License Plate: A676
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
   Revision: B8H11000
331520 - Function Restricted due to Insufficient Voltage
          U1400 00 [209] - -
          [PBC_LOW_BATT_ACTUATION_INHIBIT]
          MIL ON - Not Confirmed - Not Tested Since Memory Clear
   Coding: 7DC727
   Coding: 02006E
   Coding: 250000
   Coding: 0D0104
   Coding: 0A0700
196868 - Supply Voltage for Parking Aid
          B1542 16 [008] - Voltage Too Low
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:29:42
                    average_Voltage_terminals: 8.20 V
                    Outside air temperature sensor-Outside air temperature on CAN: 9.50 °C
                    interior_temperature: 12.50 °C
          B10CD 00 [008] - -
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:35:45
                    average_Voltage_terminals: 13.00 V
                    Outside air temperature sensor-Outside air temperature on CAN: 10.50 °C
67193 - Control Module for Heating Element 1
          U1238 00 [008] - No Communication
          [LHR 01: no signal/communication]
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:38:25
                    Outside air temperature sensor-Outside air temperature on CAN: 10.00 °C
                    Terminal control-Terminal 75 status: OFF
                    Terminal control-Terminal 15 status signal: OFF
                    Terminal control-Terminal 15 via CAN: OFF
                    System run time-Engine running time: 65535 s
                    System run time-Terminal 15 on: 0 s
67200 - Control Module for Heating Element 2
          U123A 00 [008] - No Communication
          [LHR 02: no signal/communication]
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:38:25
                    average_Voltage_terminals: 13.10 V
   Coding: 04F001
   Coding: 04F001
   Occupant Detection:
   Coding: 303134
9859568 - Passenger Airbag Status Indicator
          B1671 F0 [008] - Function Restriction due to Under-Voltage
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:29:56
528144 - Unknown Error Code
          C11CB F0 [008] - Unknown Error Elaboration
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:22:20
          U140B 00 [008] - -
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:35:36
                    EM_vehicle_state: 02 1C
8519684 - 12V Electrical System
          C11CB 01 [008] - Electrical Failure
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:22:20
                    12 V elec. system: error status: Stage 1
8519685 - 12V Electrical System
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:28:48
                    12 V elec. system: error status: Stage 2
9502726 - Battery Management 2
          C124F F0 [008] - Sequence Error during Operating Mode Selection
          [BMS_OPM_Failure]
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:38:56
                    48V activation restriction-Airbag control module: not active
                    48V activation restriction-Battery Energy Control Module 2: active
9502735 - Databus
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:38:59
   Coding: 110C0000
   Coding: 0F1B00
1245205 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Supply-Voltage too low]
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:29:41
                    Control Module temperature: 49 °C
                    Voltage terminal 30: 8.20 V
                    Terminal 15 status: On
                    Voltage terminal 15: Measured value not available
196660 - Motor for Window Regulator
          B1487 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:22:19
   Ignition key:
65539 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:29:43
                    Supply voltages-Supply voltage: Terminal 30: 7.989 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 8.289 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 8.240 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
                    general_additional_freeze_frame-coprocessor_spi_status: 00000000
                    general_additional_freeze_frame-dataflash_status: 00000000
                    general_additional_freeze_frame-interior_temperature: -50.0 °C
                    general_additional_freeze_frame-Operating_Status: 00000000 00000000
                    general_additional_freeze_frame-production_mode: not active
                    general_additional_freeze_frame-reset_cause: 00000000
                    general_additional_freeze_frame-Reset_counter: 0
                    general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                    general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                    general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 0A 90 00 78
                    general_additional_freeze_frame-Transport_Mode: not active
                    general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                    defect_fusi_voltage_error_freeze_frame: 00000000 00000000 00000000 00000000
131115 - Touch Sensor on Exterior Door Grip; Rear Right
          B116E 13 [009] - Open Circuit
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:29:57
                    Supply voltages-Supply voltage: Terminal 30: 10.996 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.847 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.778 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 0A 90 00 60
                    exterior_handle_sensor_freeze_frame: 00000000 00000000 00000000 00010000
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:22:19
   Volume Control 1:
   Media Player 1 Sub:
   Media socket:
1539 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Function restriction due to insufficient voltage - lower limit value not reached]
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:29:43
                    Voltage terminal 30: 8.0 V
0532 - Subwoofer
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:40:31
                    Voltage terminal 30: 12.7 V
32772 - DC/DC Converter
          P0A94 00 [047] - Inadequate Performance
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:34:40
458759 - Control Module Incorrectly Coded
          U1014 00 [008] - -
          [ECU_coded_wrong]
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:38:30
          B2005 00 [009] - -
                    Reset counter: 30
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:22:19
   Coding: 0F1B00
          U1400 00 [008] - -
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:29:41
                    Control Module temperature: 48 °C
8320 - Headlamp Range
          C1256 F0 [008] - Function Restricted due to Under-Voltage
          [leveling motor - functional limitation due to supply voltage - lower limit exceeded]
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:29:45
                    Reset counter: 70
                    Mileage: 1530 km
                    Date: 2019.09.22
                    Time: 01:29:45
   Coding: 800000
End----------(Elapsed Time: 01:55, VBatt start/end: 12.9V/12.9V)-----------
i was able to do it with odis online, but now i got another fault code on it that i cant clear , any help with that one would be much appreciated
Also, I would avoid randomly entering codes, since these controllers do (for the most part) keep track of wrong codes and may lock you out from entering in a "legitimate" code.
drpeter
I am almost positive the Dr. meant "illegitimate" ?.......... :rolleyes:
Controllers indeed support lock out times!
No, I don't think he did. When a control module has lock-time, it will reject a legitimate/correct code as if it was an illegitimate/incorrect code. This is done to prevent "brute force" attacks from finding the correct code(s).
That is right, but but but not the way I'm thinking about it, I know I'm fucked up..... it's because even illegitimate codes or legitimate, can be entered and accepted after security access is had or a macro happens to enter it for you in the factory tester or behind the scenes before you do it manually.....oh boy inverse in the televerse :p
65535
Dana
Western PA, USA
Hi guys.
Sorry to bump such an old thread but we had a similar one today. Luckily it did not have near as many HV DTCs. I do not have permission to post the scan but it was a 2019 Q8 with the same 48V setup.
The 12V battery and various Airbags components including a 12V battery igniter of some sort were replaced before I got involved. 15-Airbags was fault-free but 75-Telematics was offline entirely.
1) I had him connect a high quality 12V battery charger and we firstly coded the 12V battery. That was straight forward per the old-school UDS instructions here: http://wiki.ross-tech.com/wiki/index.php/Battery_Replacement
2) Next, I gave him direction to remove, unplug and remove the internal back-up battery for 75-Telematics as per: https://static.nhtsa.gov/odi/tsbs/2020/MC-10176425-0001.pdf
That fixed the lack-of 75 communication and the silly thing had this DTC when it woke up:
   Serial number: redacted
   Coding: 01C020FF4040800000
   Shop #: WSC 31414 031 00001
          U1014 00 [008] - -
          [ECU_coded_wrong]
                    Reset counter: 173
                    Mileage: 20347 km
                    Date: 2022.03.08
                    Time: 14:57:34
That cleared easily.
3) Lastly, the HV stuff. We dealt with this first:​
Address 61: Battery Regul. (J1120)       Labels: 4N0-915-105.clb
          P1609 00 [047] - -
                    Mileage: 20347 km
                    Date: 2022.03.08
                    Time: 13:42:44
That was resolved via Basic Settings [*IDE06504*] Reset of reversible crash shut-off. VCDS provides the user with the needed Security Access code in the form of a pop-up balloon.
Things were looking better but 19 was still crying about:
   Coding: 020100050004064054960000005B0132DC9A004710000000097D078E10000000
   GVL: F1513C000800000082DC88008000C800110E0070000000000000000000000100
   Subsystem 1 - Part No SW: 4M8 951 523 A    HW: 4M8 951 523 A
   Component: J453 MFL  H07 0004
   Subsystem 2 - Part No SW: 4K0 915 181 A    HW: 4K0 915 181 A
9502727 - Databus
                    Reset counter: 173
                    Mileage: 20347 km
                    Date: 2022.03.08
                    Time: 14:52:06
                    48V activation restriction-Battery management 2: not active
                    48V activation restriction-Voltage converter: not active
                    48V activation restriction-Auxiliary Air Heater Control Module/PTC: not active
                    48V activation restriction-Electrical compressor: not active
                    Reset counter: 133
                    Mileage: 20347 km
                    Date: 2022.03.08
                    Time: 14:57:42
C124E F0 [009] 48V System - Locked after Crash Active was resolved via Basic Settings: [*IDE11690*] 48V system: release lock after crash
I do not believe those exact steps would have fixed the car in this thread but it should have resolved C124E.
On a side note, I had my caller keep the 12V battery charger connected for hours hoping that the DC/DC onboard charger would help top up the 48V side. That may or may not be relevant but that (A7) inverter should keep things balanced.
Internal ref to: ST?ID=102988
