VW Passat B8 '15, MIB2.5 Retrofit
vatsug
Pirate
Walking the Plank
Dear fellow Forumers,
I turn to you in a time of need. Excessive "google"-ing and internet searches have sadly yielded no answers for me. Here it is in hopes of enlisting some more experienced brain cells:
I decided to swap my old MIB for a new one with GPS and went for a "fully unlocked/activated" MIB2.5 unit with a 9" screen from EBAY.
Here is the original auto-scan before installing the new MIB.
Removed.  Data from a clone/pirate copy of VCDS is not acceptable here.
After the installation I had no funtioning ACC or Lane assist and error codes all over the place...
Luckily I managed to long code modules A5 and 5F, deriving from my original auto scan and others in the forum, so that I got back the functionality and most error codes cleared.
But there are still some codes in 5F and I have had no luck in clearing. I suspect the "fully unlocked/activated" part of the MIB - could it be it has some adaptations activated for which my car is not equipped?
Here is the current auto scan:
Nevermind the CAN-bus faults, I created them myself by adding modules while experimenting.
Also the fault under sound system was there before - the speaker needs checking.
What have me puzzled are the faults under 5F, specifically:
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
6696 - Instrument Cluster Control Module on Optical Bus
U10C0 00 [009] - No Communication
7191 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
7194 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
7197 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
7201 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
7205 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
7219 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
7223 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
7225 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
7228 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Could the aftermarket antennae be faulty? On visual check all seems fine and it is connected correctly(GPS works but doesn't have a signal).
Could the rest of the faults need some changes in adaptations?
Thanks for any help!
