2013 Audi Q5 Hybrid Left Cornering Light Error
Treborg
C?ID=194107
I saw an "Audi Adaptive Light Defective" on the dash Tuesday, and I ran VCDS & saw that the M51 bulb for the Stationary Cornering Lamp was open-circuit. I bought a new H7 bulb and with some hassle managed to install the new bulb.
I'm still getting the same error message on the dash, and another VCDS scan last night shows the same error. I cleared all errors, and the error reappeared. The new bulb is conductive with a DVM, so it seems fine.
Is VCDS giving me the wrong error message and bulb indication?
Here's the scan from last Tuesday:
Tuesday,07,January,2020,17:30:11:47760
VCDS Version: 19.6.2.0 (x64)
VIN: WA1C8AFP7DA079130   License Plate: BURNEDOUTBULB
Mileage: 82280km-51126mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 40 42 44 46 47 51 52 53
          56 5F 62 6C 6D 72 8C
VIN: WA1C8AFP7DA079130   Mileage: 82280km-51126miles
40-AC Compressor -- Status: OK 0000
Address 01: Engine (0-MA--CHJA)       Labels: None
   Part No SW: 8R1 907 115 D    HW: 8R0 907 115 G
   Component: 2.0l R4/4V TF H57 0003
   Revision: NDH57---
   Coding: 6A2A0013442600062000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TFS0118R1907115D 002005
   ROD: EV_ECM20TFS_AU48.rod
   VCID: 3663CAFD89FDEDFF4D-8062
   Part No SW: 8R1 927 158 K    HW: 0BW 927 156 P
   Component: 0BW 20TFSIUSA H16 1001
   Revision: --H16---
   ASAM Dataset: EV_TCMAL551111 002022
   ROD: EV_TCMAL551111_002.rod
   VCID: 4683BA3DF91D7D7FDD-8012
   Part No SW: 8R0 907 379 T    HW: 8R0 907 379 T
   Component: ESP8 quattro  H09 0060
   Coding: 2D1D1C
   Shop #: WSC 48607 001 1048576
   VCID: 51A999610853AAC778-8004
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Coding: 0DC54040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 0407603587A18F6F83-8050
   Serial number: 2313000040689010
   Part No SW: 8K1 820 043 AL    HW: 8K1 820 043 AL
   Revision: C3000000    Serial number: 01080320130871
   Coding: 64C120C200
   VCID: 72EB36EDAD15B1DFA1-8026
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000566263501
   Coding: 26000091863CAFC00000480000003D0D0F1C4608E0090225000008004000010200040034000000
   Shop #: WSC 55826 001 1048576
   VCID: 7AFB1ECDF565C99FE9-802E
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 130225  H11 0050
   Serial number: 90243014130220165816
   Coding: 01DD13
   Serial number: 21062804
   Coding: 03005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002802131292
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R55JW02
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0054053656
   Coding: 0F0000
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: CD08C696000000000001
02235 - Stationary Cornering Lamp (Left) (M51)
                    Fault Status: 01101011
                    Reset counter: 42
                    Mileage: 82215 km
                    Date: 2019.12.30
                    Time: 16:09:58
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Serial number: 003GPD91CK1E
   Coding: 303634313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 479DB739FE17647726-8012
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R130000C63C
   Serial number: 6334MSME78661A6CT
   Serial number: 6344MSME76235861C
   Serial number: 6352QSME5E2C3550N
   Serial number: 6362QSME5E2C1E78+
   Serial number: 63732SME4D2D264CC
   Serial number: 63832SME462B007A/
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90372MC1001PT
   Coding: 000037
   VCID: 4385A329C22F4857FA-8016
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 981 D    HW: 8R0 920 981 D
   Revision: 00200000    Serial number: UWU381U2E
   Coding: 8BBF23000B01D705020000
   VCID: 3B75DBC9BADF3097B2-806E
   Part No SW: 8R0 907 468 K    HW: 8R0 907 468 E
   Component: GW-BEM 5CAN-M H11 0055
   Revision: 2A120022    Serial number: 2242A132200029
   Coding: 80D00AFF00
   VCID: 479DB739F617647726-8012
   Subsystem 1 - Part No SW: 8R0 915 181 A    HW: 8R0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 00000000001580143173
   Subsystem 2 - Part No SW: 8R0 915 181 B    HW: 8R0 915 181 B
   Component: J367-BDMLear2  H07 5040
   Serial number: 00000000001770349767
   Part No SW: 8R0 959 760 E    HW: 8R0 959 760 C
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000049483487
   Coding: C0581B000F0000000000
   Component: SWA Master    H04 0060
   Serial number: 0192517036
   Coding: 010211
   Shop #: WSC 06334 000 00000
   VCID: 3F8DAFD9A6C72CB79E-806A
   Component: SWA Slave  H04 0060
   Serial number: 0192496252
   Coding: 000102
Address 40: AC Compressor (J842)       Labels: 8R0-260-797.clb
   Part No SW: 8R0 260 797 C    HW: 8R0 260 797 C
   Component: ES34          H01 0001
   ASAM Dataset: EV_AirCondiCompr_ES34 S03001
   ROD: EV_AirCondiCompr_ES34.rod
   VCID: 3C77D8D5B7D137AFBB-8068
   Component: TSG FA        H02 0508
   Revision:             Serial number: 0000053762085
   Coding: 011D13205E00440004
   VCID: 4FAD9F191E67BC376E-801A
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Revision: 00001000    Serial number: 0021290518
   Coding: 000000000100
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3B75DBC9B2DF3097B2-806E
   Revision: 00002001    Serial number: 0301732617
   Coding: 0126023A20FA709584B005321004000D
   Component: GTO BF  H01 0080
   Serial number: 00000000000000646281
   Component: J245EE20SKB13  H05 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H05 0220
   Revision: 00005001    Serial number: 94813011839502
   VCID: 2D51E59174ABAE273C-8078
Address 51: Electric Drive (J841)       Labels: 06F-907-080.clb
   Part No SW: 06F 907 080 H    HW: 06F 907 080 H
   Component: MLB HYBRID    H19 0001
   Revision: --------
   ASAM Dataset: EV_DMCM030202106F907080H 001003
   ROD: EV_DMCM030202106F907080H.rod
   VCID: 2C57E89547B1A72F2B-8078
   Component: TSG BF        H02 0508
   Revision:             Serial number: 0000054093461
   VCID: 4E93821D196DB53F65-801A
   Revision: --------    Serial number: 00000001272350
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 387FC4C583E91B8F5F-806C
   Part No SW: 4G0 035 082 H    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0138
   Revision: AB001007    Serial number: 156C$0D7702883
   Coding: 020007010000000001
   VCID: 25411DB12C5B9667F4-8070
   Part No SW: 8R1 035 746 K    HW: 8R1 035 746 B
   Component: H-BNT-NA      H44 1040
   Revision: --------    Serial number: 204C+0D7566667
   Coding: 170200060005A1EF51038B4E00000403140000000000000002
   VCID: 3F8DAFD9AEC72CB79E-806A
   Subsystem 1 - Part No: 8R0 060 884 EN
   Component: NAR 2017/2018  1602
   Component: DU7 High  H42 0104
   Serial number: A130CJ0D2675021
   Serial number: 00000001436879
   Component: CD-Database  4949
   Revision:             Serial number: 0000054061364
   Coding: 010C13204000240004
   VCID: 4683BA3DF11D7D7FDD-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H07---    Serial number: 525PA8-J2ZA5M1
   Coding: 1020010
   VCID: 3467F0F55781FFEF73-8060
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Revision:             Serial number: 0000054061609
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 8R0 915 591     HW: 8R0 915 591
   Component: BMS           H08 0543
   Coding: 0A0200
   Shop #: WSC 47336 001 1048576
   ASAM Dataset: EV_BECM0722011 004016
   ROD: EV_BECM0722011_004_AU48.rod
   VCID: 78FF04C5C369DB8F9F-802C
End-------------------------(Elapsed Time: 05:07)--------------------------
I don't think so.
Official VAG German text: "Statisches Kurvenlicht links"
Official VAG English text: "Left stationary AFS"
Does the light actually work? An open circuit could have causes other than a burnt-out bulb.
Treborg
C?ID=194107
The stationary cornering lights on both sides do not work. I tested this evening after dark with someone watching as I turned both right and left onto a road. I recall that the lights come on after I start steering for the turn & have the turn signal on.
I know the bulb is good on the left side.
So, the message I'm getting from VCDS isn't the whole story of this failure. What do I do now?
Check the wiring, and the condition of the bulb holder?
Treborg
C?ID=194107
2013 Q5 Adaptation to turn on stationary turning lights
I’m trying to troubleshoot a problem with my stationary turning lights, and I’d like to turn them on via VCDS. I’ve looked and can’t find a way to do it.
Anyone know how?
Thanks!
Somewhat surprisingly, there doesn't appear to be an Output Test for those.
Treborg
C?ID=194107
Epilog: I went back in with VCDS today (after having to wipe and reload my Win 7 laptop, what a pain), and saw the following regardless of engine on or off (see scan below):
I rechecked the connectors on the back of the left headlight access panel and on the headlight itself, all OK, then I went into each module and cleared the errors. Shut the vehicle down and restarted it, now do not have the lighting error message on the dash, and the subsequent scan is clear. Whew!
Now I'm going to chase after the 03041 error - does this mean the 12V battery is dying? I've got a Hybrid, and I think the 12V battery is actually a lithium ion battery. It's in the right side of the rear cargo area.
Friday,17,January,2020,14:35:36:47760
VIN: WA1C8AFP7DA079130   License Plate: SCAN3-ENG_ON
Mileage: 82580km-51312mi   Repair Order:
VIN: WA1C8AFP7DA079130   Mileage: 82580km-51312miles
   Revision: NDH57---
   Revision: --H16---
   Coding: 2D1D1C
   Coding: 64C120C200
   Coding: 01DD13
   Coding: 03005C
   Coding: 0F0000
H05 0012
H05 0012
                    Reset counter: 42
                    Mileage: 82215 km
                    Date: 2019.12.30
                    Time: 16:09:58
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101100
                    Reset counter: 89
                    Mileage: 82348 km
                    Date: 2020.01.10
                    Time: 13:49:57
   Coding: 000037
   Coding: 80D00AFF00
                    Reset counter: 89
                    Mileage: 82348 km
                    Date: 2020.01.09
                    Time: 19:07:08
                    Bin. Bits:    10000
                    Voltage: 12.40 V
                    Count: 10
   Coding: 010211
   Coding: 000102
   Revision: --------
   Coding: 1020010
   Coding: 0A0200
End-------------------------(Elapsed Time: 05:08)--------------------------
No, 03041 is not necessarily indicative that the 12V battery is dying. It's not an uncommon code that simply indicates that your Gateway requested other systems to shed loads due to a low state-of-charge. The low state-of-charge could be due to any number of factors as simple as leaving the ignition on for too long while doing diagnostics.
I doubt the 12V battery is a Li-ion. In fact, I see no accommodation in your gateway for a Li-ion 12V battery. Take a look at Adaptation channel 04 in the Gateway to see its part number.
