Cant get ac sytem to charge (compressor wont kick on)
Railroader
C?ID=247142
I have a 2015 Audi S3 8v with 43k miles on it, about 3 weeks ago I replaced the engine on the car, I did the work, pulled the bad motor out through the front and replace the engine. When I removed the engine I set the ac compressor off to the side and disconnected lines at the condenser so I could pull the core out as a whole, I unhooked the the wiring harness and from the block itself instead of just unplugging it from the ecu, I did it like that only because I have aftermarket MPI installed and didnt want to unhook all those wires. A/c worked fine prior to engine removal, put the good motor in and hooked up all the wiring and now I cant get the a/c to charge, compressor wont kick on when trying to fill, I vac the system down. I get 2 codes, 1 for high pressure sensor no signal and ac first run in. Need your help. Sorry I forgot how to add scan Ill have to go back and fix
Tuesday,07,January,2020,10:14:18:30521
VCDS Version: 19.6.2.0 (x64)
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 55
          5F 6C A9 BB BC
VIN: WAUFFGFFXF1077035   Mileage: 71990km-44732miles
A9-Struct. Borne Sound -- Status: Cannot be reached 0100
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0602
   Revision: --H13---
   Coding: 0A1D00322426000E3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
   ROD: EV_ECM20TFS0208V0906259K.rod
   VCID: 489F1C7BF3C4C20F2F-801C
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4903
   Revision: 03253104    Serial number: TFK01409241359
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 53A53B173A8271D74A-8006
          P1734 00 [002] - -
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 62734000003093
   Coding: 31FF6B9254270A730177030341C8698CD62A5080C08296B6024100D88207
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   Revision: 00021000    Serial number: 0349814246
   Coding: 030C0C
   VCID: 3A7B76B3BD28A09FA9-806E
   Revision: 20026000    Serial number: 00000000470162
   Coding: 03000014010000000000000000001400
   VCID: 33655B979A4251D76A-8066
   Serial number: FA988357000000000001
262658 - High Pressure Sensor
          B10AE 31 [009] - No Signal
                    Reset counter: 219
                    Mileage: 71990 km
                    Date: 2020.01.07
                    Time: 09:59:14
                    Outside air temperature: 20.5 °C
                    Engine speed: 766.00 /min
                    Temperature after evaporator: 24.9 °C
                    System run time-Terminal 15 on: 253 s
524545 - AC Compressor First Run-In
          B109E F0 [009] - Not Performed
                    Reset counter: 219
                    Mileage: 71990 km
                    Date: 2020.01.07
                    Time: 09:59:13
   Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
   Component: BCM MQBAB HNA H18 0137
   Serial number: 01011428800483
   Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7AFBB6B3FDA8609FE9-802E
   Component: WWS371 141004  042 0585
   Serial number:         141021125002
   Coding: 0A47F7
   Serial number: 23336452
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
   Serial number: 08 08 2014  00001063
   Serial number: 00000000000060812115
   Sun Roof:
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST0000754G00000
   Coding: 101F00
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331428205581
   Coding: 0030150011
   VCID: 428B0E53D5F8E85FF1-8016
   Part No SW: 8V0 907 376 C    HW: 8V0 907 376 C
   Component: DAEMPFUNGS-SG H08 0066
   Serial number:       220914038
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
   VCID: 4189015FD0FEF347E8-8014
   Serial number: 003GCR00VDBR
   Coding: 9DCCFCC0000000005000001AC24800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 479D1F47FEDACD7726-8012
   Belt Pretensioner left:
   Component: BeltPretRevFL  H36 0350
   Serial number: 34178311B22101440278
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H36 0350
   Serial number: 34178312B22101470632
   Coding: 333135
   Occupant Detection:
   Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
   Serial number: 6940000Y1400018PTT0L
   Coding: 303230
   Subsystem 4 - Part No SW: -----------    HW: 480 002 310 14
   Serial number: 357000000005C289611G
   Subsystem 5 - Part No SW: -----------    HW: 480 002 310 14
   Serial number: 35800000000613896118
   Subsystem 6 - Part No SW: -----------    HW: 480 401 610 14
   Serial number: 3510002C918166B572C5
   Subsystem 7 - Part No SW: -----------    HW: 480 401 610 14
   Serial number: 3520002C718166B2B12.
   Subsystem 8 - Part No SW: -----------    HW: 480 400 109 14
   Serial number: 3550002B5175A8E081ED
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 109 14
   Serial number: 3560002B5175A8E2D1FM
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 18101404400027
   Coding: A018
   ROD: EV_SMLSKLOMQB_010_AU37.rod
   VCID: 0A1BE673AD48701FF9-805E
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
   Part No SW: 8V0 920 970 S    HW: 8V0 920 970 S
   Component: KOMBI         H02 4291
   Coding: 0BED181B3B8857050201EA001800000000000000
   VCID: 4C97206BE7BC2E2F0B-8018
   Revision: --------    Serial number: 01101410802775
   Coding: 0101000830085A005B00022C980B00000001010000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72EB9E93A5D818DFA1-8026
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 17 10 2014  C0047695
131612 - No Communications with Actuator for Structural Accoustics
          U10DF 00 [009] - -
                    Fault Frequency: 40
                    Reset counter: 218
                    Mileage: 71663 km
                    Date: 2019.12.26
                    Time: 17:22:54
                    Terminal 15: On
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00004.09.14
   Coding: 0001
   VCID: 46831243F9D0D47FDD-8012
   Revision: 00000000    Serial number: 14000292251003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3467588B9F4C56EF73-8060
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Component: SWA Master    H05 0071
   Serial number: 0348367775
   Coding: 030211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 387F6CBB8324B28F5F-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0348774456
   Coding: 030211
   Serial number: 14101402090927
   Coding: 005D1F205C00048000000002
   VCID: 408F045BDBF4FA4FE7-8014
   Coding: 8102
   VCID: 377D6F878E3ABDF756-8062
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAEN900SSR%
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   Serial number: 14101403111564
   Coding: 005D17205E00048000000002
   VCID: 3F8D07A7A60A85B79E-806A
   Component: AFS-ECU       H01 0091
   Coding: 012200003F200400
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 038 B    HW: 8V0 035 038 B
   Component: MU-H-LNS-US   H43 0394
   Serial number: A302J0EB005348
   Coding: 017301020000000021220002041A00102F000225010001043E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
   Component: NAR 2015  --- 0035
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY201YBT
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000002091400030299
   Component: Gracenote  --- 3006
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
   Component: MQB RVC Mid   H07 0140
   Coding: 027300010201000300
   ASAM Dataset: EV_2CamSysRearPASE 006016
   ROD: EV_2CamSysRearPASE.rod
   VCID: 306F549B6B546ACF17-8064
Address A9: Struct. Borne Sound
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0025
   Serial number: 15101406071203
   Coding: 004D17204000048000000002
   Component: TSG HBFS      020 0025
   Serial number: 15101406071201
End-------------------------(Elapsed Time: 05:30)--------------------------
I would start by fixing whatever is causing the "High Pressure Sensor -- No Signal" fault.
Railroader
C?ID=247142
Ya I'm trying to figure that out, when you push the ac button on on the control, the light wont stay on, as soon as you release the button the light goes off, if I remember right the sensor plug is only hot when ac (botton) is on
Do you have the RTFB OP?
Isn't refrigerant required to be installed first in order to engage the PSI sensor ( AS FIRST RUN IN ) & as a GAS on high side and if it isn't, is it possible you contaminated system or the PSI sensor failed as a result & being reported on LIN?
TSB #A871679 2041717 NHTSA ID #10130183
Summary: This bulletin applies to any repair that requires replacement of the air conditioning compressor and details how to run a ODIS GFF test plan.
http://wiki.ross-tech.com/wiki/index.php/Main_Page
Railroader
C?ID=247142
Anything is possible, when I opened the system up I plugged the ports immediately,.although yes the system was open and air was introduced, when I put the cat back together I pulled a good vacuum for a good amount of time and let it sit and the vacuum held, I hooked my gauges up and hooked up to my r134a tank, started the car and push the ac to on, but light goes right out, generally once you start introducing refrigerant the system starts cycling, it took 4oz and stopped since compression never kicked on the system equalized. I always fill on the low side. Guess there could be a chance some how the sensor fail in the few weeks the car sat while I was getting the other motor ready for install. I have voltage at the sensor so I'll order a new sensor and try that. I always only charge on the low side
Did you try charging from high side yet as a GAS?
What's RTFB say?
Jef
HQ
The "High Pressure Sensor", the G805.... locate it and unplug it. *editing out my dumb@$$ mistake* :facepalm:
OK, now that I'm on my court ordered medication, lets try this again:
/1 is ground
/2 is data
/3 is power
You are going to need the factory repair manual for your vehicle. If you haven't done so already, purchase access to ERWIN, run your VIN and then print to PDF everything to do with your car.
Railroader
C?ID=247142
on my plug it appears that 1 and 3 are (ground) and 2 is power, i have 11.8v between 1&2 and 11.8 between 3&2, my test light dont light up when touched to those, test light will light when tested on battery, I do have a manual and am in the process of going through it
I believe if you RTFB the procedure it will become clear quickly.
Jef
HQ
I've corrected my stupid mistake, see above.... /3 should be a power, comes off a fuse SC34. Now if in fact /3 is direct path to ground... well, that will be an issue.
Railroader
C?ID=247142
Forgive my ignorance but what is rtfb
Railroader
C?ID=247142
Thanks Jeff I'll check it again in the morning
PetrolDave
Westbury, UK
C?ID=1423
Anything you see on here in bold underlined dark green will reveal it's definition f you hover your mouse over it :thumbs:
Railroader
C?ID=247142
Wanted to say thanks for all your help, I found the 7.5a fuse was blown and figured out how to do the first run in, my book didnt really say anything about the process or I'm just blind but I figured it out that I had to raise the rmp up to around 1k to get the process to start. Thanks again
