Hi Guys I know this has been gone over a million times but I have read every post on every page and I still cant get this to work, I have a b7 S4 that we have fitted a cruise control stalk into and have coded it in the (correct) way following every possible option I can find and I still have no luck, I can go in through vcds and view that all the buttons for the cruise are working which they are and same for the brake switch (which is new) oh and its and auto, I have one fault code showing that was already in the car before the retro fit and clears but comes back as soon as engine is started even without touching the throttle but so far have not found the source of this. has any one got any other ideas, I tried to do a throttle adaption but it does not allow me to do it the way that the ross-tech web site suggests. here is the auto scan from the car. Thanks
Monday,30,December,2019,11:07:41:22271
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: License Plate:
67 69 75 76 77
VIN: Mileage: 249090km-154777miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E3 910 560 HW: 4E0 907 560
Component: 4.2L V8/5V A 0020
Revision: --H01--- Serial number:
Coding: 0011771
Shop #: WSC 06335 000 00000
VCID: 6582AF58AC37396734-8030
Readiness: 0110 1101
Part No SW: 8E1 910 156 M HW: 09L 927 156 B
Component: AG6 09L 4,2 MPI RdW 0030
Revision: --H01--- Serial number: 4283918
Coding: 0000001
VCID: 312A0B08A87FA5C718-8064
006273 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request
(no units): 30.0
(no units): 108.0
Temperature: 18.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Coding: 0004902
VCID: 2E101074B941BA3F05-807A
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 3233
Coding: 00000
VCID: 6C94DA7C1EDD082F6B-513C
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 10021
Shop #: WSC 06335
VCID: 3D322738352751A78C-4B00
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H13 4230
Revision: 91H13423 Serial number: 0036M0G65PA7
Coding: 0030612
VCID: 3B3629207A335F97B2-806E
Subsystem 1 - Serial number: 6332DRB404B08F1BX
Subsystem 2 - Serial number: 6342DRB404A8CD36/
Subsystem 3 - Serial number: 6352ARB402100C300
Subsystem 4 - Serial number: 6362ARB401F3543ES
Subsystem 5 - Serial number: 63729RB402076F9E-
Subsystem 6 - Serial number: 63829RB402076FC8Y
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 04142
Shop #: WSC 06335
VCID: 41CA5BC849DF3547E8-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 983 HW: 8E0 920 983
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0007418
Shop #: WSC 00999 444 64523
VCID: 6C94DA7C4EDD082F6B-5160
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007418
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
VCID: 6B96D9601BD30F1762-50F4
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 07151
Shop #: WSC 06335
VCID: 79BAF328618FAD87E0-4B00
Subsystem 1 - Part No: 8E2959802F
Component: Tõrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E2959801F
Component: Tõrsteuer.BF BRM 0606
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000005
VCID: 3D322738642751A78C-8068
End----(Elapsed Time: 05:15, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
