- Joined
- Oct 18, 2019
- Messages
- 25
- Reaction score
- 5
- Location
- Stockholm, Sweden
- VCDS Serial number
- C?ID=372497
Hello! Car was crash on right side , owner bought complete lamp used, now have coding fault.. can some one help with long coding for right lamp..
Friday,27,December,2019,13:06:41:47312
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4G3FN050716 License Plate: HPR310
Mileage: 128512km-79853mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 20 28 34 36 3B 42 44 46 52
53 55 5F 62 69 6D 72 85 8E AC
VIN: WAUZZZ4G3FN050716 Mileage: 128512km-79853miles
Address 01: Engine (J623-CRTE) Labels: Redir Fail!
Part No SW: 4G2 907 311 C HW: 4G2 907 401
Component: 3.0TDI EDC17 H33 0007
Revision: 92H33---
Coding: 3225401A053609030000
Shop #: WSC 45108 001 1048576
ASAM Dataset: EV_ECM30TDI0114G2907311C 001007
ROD: EV_ECM30TDI0114G2907311C.rod
VCID: 2517F18E656A8B2F9A1-8070
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G0 927 166 G HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0003
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 313F15DE21A2D78F769-8064
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 27A6DE45E4657BA2BB00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FDB43E6E7F631FFF0D-806A
161024 - Tire Pressure Warning
C102D 00 [032] - -
Part No SW: 4H0 907 064 FP HW: 4H0 907 064 EP
Component: BCM2 2.0 H36 0560
Coding: 05A96F4E000000000000
VCID: 7CA1F4EAB6E0EAE795F-8028
Serial number: 3214000168199013
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0112
Serial number: 12121400040470
Coding: 361211B8250000
VCID: 6393AF962BDE351FB45-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00000968517001
Coding: 0105C01440349FE049014083800018000F9C67082E08020100000894E100170200400025030000
VCID: 71BFD5DEE1A2978F369-8024
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 141114 H37 0080
Serial number: 141126212318
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23559782
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 08 12 2014 00001271
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 6B398167000000000001
6 Faults Found:
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Fault Status: 00101100
Fault Frequency: 218
Reset counter: 137
Mileage: 126627 km
Date: 2019.11.08
Time: 18:06:09
03455 - Function Restriction due to Faults in Other Modules
Fault Frequency: 58
Reset counter: 97
Mileage: 126836 km
Date: 2019.11.13
Time: 12:41:47
Fault Frequency: 51
Reset counter: 137
Mileage: 126874 km
Date: 2019.11.15
Time: 19:30:26
01543 - Parking Aid Warning Chime (H15)
Fault Status: 00100110
Reset counter: 131
Mileage: 127900 km
Date: 2019.12.02
Time: 18:09:04
02069 - Front Parking Aid Sensors
Reset counter: 97
Mileage: 128511 km
Date: 2019.12.09
Time: 16:17:11
03384 - Windshield Washer Jet Heating
Reset counter: 137
Mileage: 128511 km
Date: 2019.12.11
Time: 14:06:26
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1002L74K
Coding: 30333130313930313935554A304C34473053
VCID: 3B2337F6F3EE2DDFDC5-806E
Serial number: 3575HRB40512OSCE40NK
Serial number: 3585HRB404R2PMQ079M9
Serial number: 3515JRB406132Q9829IU
Serial number: 3525JRB405V32Q98B1VV
Serial number: 3554VRB405F341DOM8HU
Serial number: 3564VRB405F341DOLOG2
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372NL8000JF
Coding: 0000D5
VCID: 372B2BC6CF4609BF38D-8062
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Serial number: 15 11 2014 D0046816
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G9 920 950 S HW: 4G9 920 950 S
Component: TDieRdw Nv H07 0043
Revision: 03001036 Serial number: 658281114592050
Coding: 13A622081B5100080B0600
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 40D9401A9A084E07897-8014
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 G HW: 4H0 265 105 G
Component: Standheizung H24 0260
Revision: 66006006 Serial number: 20140723055907
Coding: 5D3F01
VCID: 2615F68218EC803793B-8072
01407 - Flame Extinguished
Reset counter: 99
Mileage: 126513 km
Date: 2019.11.03
Time: 16:09:48
Temperature: 71.0°C
Temperature: 68.0°C
Voltage: 14.50 V
Full Throt
Count: 185
Temperature: 5.0°C
RPM: 1334 /min
No
Part No SW: 4G0 907 468 AE HW: 4G0 907 468 AC
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001531311
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001024
VCID: 73B3DFD69B3EA59FC45-8026
Serial number: 1892745203
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663 D
Component: J532_DCDCStab H23 0022
Serial number: 14101600000000000001
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Serial number: 02121400041361
Coding: 21
VCID: 3E253EE2E0FC38F7FBB-806A
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H19 0783
Coding: 008001
ASAM Dataset: EV_AirSuspe 003025
ROD: EV_AirSuspe_VW51.rod
VCID: 2F3B13A63796C17F60D-807A
C10C8 00 [008] - -
Reset counter: 137
Mileage: 128342 km
Date: 2019.12.08
Time: 12:07:48
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000127692129
VCID: 77ABEBC68FC6C9BFF8D-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA8208NUVA
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 363526C2C8CCF0B723B-8062
Component: TSG FA H03 0507
Coding: 011C16015E00620002080002
VCID: 47CB5B06BFA6793F48D-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0028262253
Coding: 101001010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 33331FD6DBBEE59F045-8066
Revision: 00002001 Serial number: 0355565371
Coding: 013A0E20A0B93081C320090420010F470000000000000000000000000000
Component: DWA-Sensor H01 0010
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 229
Mileage: 122013 km
Date: 2019.08.08
Time: 11:29:59
02616 - Fuel Tank Cap; Unlock
Reset counter: 229
Mileage: 122013 km
Date: 2019.08.08
Time: 13:12:29
Component: TSG BF H03 0507
VCID: 46D55602B8AC6037B3B-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001297417
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D0709AE3D9AB36F521-8078
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 D HW: 7P6 907 357 B
Component: MxB-ECU 001 0081
Coding: 04FA02102A600200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E02000
U1014 00 [137] - -
[Steuergeraet falsch codiert]
Reset counter: 97
Mileage: 128512 km
Date: 2019.12.27
Time: 11:28:07
5544945 - Output Stage for LED Headlamp; Right
B149B F1 [137] - Incorrectly Coded
Reset counter: 97
Mileage: 128512 km
Date: 2019.12.27
Time: 11:28:07
Part No SW: 4G1 035 182 A HW: 4G1 035 182 A
Component: RMC Cnct Plus H61 0139
Coding: 010005000165DB67093B060301010000000000
VCID: 2019E09A7AC86E07E97-8074
Subsystem 1 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464K90E2692847
Subsystem 2 - Part No SW: 4G1 919 610 E HW: 4G1 919 610 E
Serial number: 90349NKS000N4
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0507
Coding: 010814004000620002080002
VCID: 49CF5D3EA9B28F4F5E9-801C
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0137
Revision: 7B001001 Serial number: 0355441132
Coding: 0100000202000000
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 343401255
Coding: 093205C031
ROD: EV_HDSGAu571.rod
0015 - Switch in Luggage Compartment for Closing the Rear Lid
B113D 29 [008] - Signal Implausible
Reset counter: 40
Mileage: 127052 km
Date: 2019.11.16
Time: 15:47:49
Voltage terminal 30: 12.40 V
0029 - Motor 1 for rear lid
B11D9 01 [008] - Electrical Failure
Reset counter: 129
Mileage: 127858 km
Date: 2019.11.30
Time: 09:55:45
Voltage terminal 30: 14.06 V
0031 - Motor 2 for Rear Lid
B11DA 01 [008] - Electrical Failure
Reset counter: 129
Mileage: 127858 km
Date: 2019.11.30
Time: 09:55:45
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000
Coding: E2000000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C0104AA0680BA6745F-8078
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H33 0090
Serial number: 005000622611147
Coding: 04408A1C1011
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0173 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[APS_Signal_Error_Master]
Reset counter: 97
Mileage: 128511 km
Date: 2019.12.09
Time: 16:17:12
Outside air temperature: 14.5 °C
Voltage terminal 15: 14.0 V
Control Module temperature: 14.0 °C
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0010
Revision: 00000000 Serial number: 143220273
ROD: EV_RDCMA00100_008.rod
VCID: 2B0307B6038EBD5F4C5-807E
End----------(Elapsed Time: 02:04, VBatt start/end: 11.9V/11.9V)-----------
