Vin numbers added to hex-net
premium
Norway
C?ID=247892
Did a scan with my hex-net today. Got a question about adding the vin to the device.. Did press "yes", but my car is already added to the hex-net. Now i have used 2/10 Vins on the same car..
possible for rosstech to remove one of the vin numbers? Do you have to add the vin number every time i use the hex? Can i use it on 10 different cars?
Santos
VINs cannot be deleted once they are stored. Are there any parts retrofitted to this car?
premium
Norway
C?ID=247892
Nope! Same car, same vin. Never used the hex on any other car.. 2/10 vin left! :(
DV52
C?ID=194404
hmm.........my apology for hijacking this thread, but Santos' question raises an interesting dilemma for VIN limited VCDS devices - perhaps?
I'm not sure if it applies universally, but as I have discovered from my "Frankenstein" mk7 test bench which uses 2nd hand modules from different vehicles, the VIN that VCDS reports in the auto-scan is the one that's recorded in the hex17 module (not the VIN that's in the CAN Gateway. or the VIN in the ECU, or the VIN in the hex09 module).
Now in normal cars, it's reasonable to assume that the one VIN is ubiquitous throughout ALL modules that identify the car's chassis - but specifically, is the VIN in the auto-scan, the VIN that's registered in VIN limited VCDS devices? If not, from which module is this VIN taken?
And perhaps more importantly for Santos' question (and assuming that the auto-scan VIN is used in VIN limited devices) - what happens if the Instrument cluster is changed and a VIN limited VCDS device is used to change channels/coding BEFORE Component Protection is removed? This question is particularly relevant (I think) given the reply "VINs cannot be deleted once they are stored".
premium
Norway
C?ID=247892
Got this from the scan i did today..
#hndoc:?docid=00005796&xt=hnh:77A7EFDE53C17E2BE36E016C3D708592244DE4777178AE2B90E597E45CA74A39
Tue,Dec,17,2019,11:00:02
VCDS Mobile 0.4513.0.4
VIN: EEPR0M-READ-ERR0R
Scan: 01 02 03 08 09 13 15 16 17 18 19 1B 29 36 39 3C 42 44 46 47
52 5F 69 6C 6D 74 81 82 8B A5 AC BB BC CF D6 D7
BB-Door Rear Drv Side -- Status: OK 0000
BC-Door Rear Pass Side -- Status: OK 0000
Address 01: Engine  (CSWB: J623)	Labels: None
	Part No SW: 8W0 907 311 B	HW: 059 907 309 F
	Component: 3.0l V6 TDI   H21 0003
	Revision: C7H21---
	Coding: 3225403A0576050324380000000000000000000000000000
	Shop #: WSC 36834 003 1048576
	ASAM Dataset: EV_ECM30TDI0118W0907311B 001004
	ROD: EV_ECM30TDI0118W0907311B.rod
	VCID: 362FB5DB40D2F5C22B0EF4-8063
No fault codes found.
Address 02: Auto Trans  (J217)	Labels: None
	Part No SW: 8W1 927 155 K	HW: 0CK 927 156 AA
	Component: 0CL 30TDI RdW H04 0001
	Revision: --H04---
	ASAM Dataset: EV_TCMDL382021 002023
	ROD: EV_TCMDL382021_AU49.rod
	VCID: 48D3CB233A26733249C2BA-801D
Address 03: ABS Brakes  (J104)	Labels:
	Part No SW: 8W0 907 379 F	HW: 8W0 907 379 D
	Component: ESP9 Premium  H09 0593
	Coding: 0CAA2C9928A32A96D6A34896008058A2E6A5DA303414546B12001A4567A55B
	Shop #: WSC 06334 790 00001
	ASAM Dataset: EV_ESP9BOSCHAU49X 012014
	ROD: EV_ESP9BOSCHAU49X_012.rod
Address 08: Auto HVAC  (E87)	Labels: None
	Part No SW: 8W0 820 043 G	HW: 8W0 820 043 G
	Component: Klima Zone 3  H32 0071
	Coding: 2618401D5548410D02000100880000000000000000000000000000000000
	Shop #: WSC 06335 790 00001
	ROD: EV_AirCondiBHTCAU491.rod
	VCID: 3731B8DF47D80CCA3038C1-8062
	Subsystem 1 - 	Part No SW: 4M1-820-021
	Component: J216 FLuftV  H05 0001
	Serial Number: 00000000000000866124
	Subsystem 2 -
Address 09: Cent. Elect.  (J519)	Labels: None
	Part No SW: 8W0 907 063 BG	HW: 8W0 907 063 BG
	Component: BCM1 MLBevo   H13 0248
	Coding: 07501943C13900CD010D511958BF88F9130B31080000000000000000600016810A4502ABA2B70A
	ASAM Dataset: EV_BCM1BOSCHAU736 016006
	ROD: EV_BCM1BOSCHAU736_016.rod
	VCID: 81459607D99C027A4E1C2F-80D4
	Subsystem 1 - 	Part No SW: 8W1-955-119	Labels: 1Kx-955-119.clb
	Component: WWS491 160420043 0813
	Serial Number: 894353?0301611104922
	Coding: 5BC7F7
	Subsystem 2 - 	Part No SW: 81A-955-555
	Component: G397_RLFSS   H06 0001
	Serial Number: 20011757X81A95555500
	Coding: 02005D
	Subsystem 3 - 	Part No SW: 4M0-941-531-AB
	Component: E1 - LDS     H06 0008
	Serial Number: 23 02 2016  00258405
	Subsystem 4 - 	Part No SW: 8W0-857-511
	Component: Y7_InnenspiegH09 0002
	Serial Number: GX1CE128031611520214
	Coding: 030000
	Subsystem 5 - 	Part No SW: 8W0-947-135-BQ
	Component: J528-Dachele H14 0130
	Serial Number: B10146803
	Subsystem 6 - 	Part No SW: 8W0-925-301-BG
	Component: SL-B9/Q5NF   H15 0010
	Serial Number: 2615000152473004
Address 13: Auto Dist. Reg  (J428)	Labels: None
	Part No SW: 8W0 907 561 B	HW: 8W0 907 561
	Component: LRR4          H09 0220
	Coding: 3477FFFB58FFEC0A949880A0
	ASAM Dataset: EV_ACCBOSCHAU49X 002018
	ROD: EV_ACCBOSCHAU49X_002.rod
	VCID: 3D3DAAF765E4269AEA7403-8068
2153 - Databus
Address 15: Airbags  (J234)	Labels: 8W0-959-655.clb
	Part No SW: 8W0 959 655 B	HW: 8W0 959 655 B
	Component: Airbag10.44   H73 0086
	Coding: AACCF0C00C800000985400F3C04C00000000
	ASAM Dataset: EV_AirbaAU10BPAAU736 005012
	ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
	Subsystem 1 - 	Part No SW: 4M0-980-945
	Component: BeltPretRevFL205 2033
	Serial Number: 8W0857705A0152Q01466
	Coding: 88001B
	Subsystem 2 - 	Part No SW: 4M0-980-946
	Component: BeltPretRevFR205 2033
	Serial Number: 8W0857706A0152Q01082
	Coding: 88001B
	Subsystem 3 - 	Part No SW: --------------
	Component: SideSensor_Df1E2 0887
	Serial Number: 3577Y00B51F3438132B.
	Subsystem 4 - 	Part No SW: --------------
	Component: SideSensor_Pf1E2 0887
	Serial Number: 3587Y00AD1FB75E2145G
	Subsystem 5 - 	Part No SW: --------------
	Component: SideSensor_Dr1C7 0148
	Serial Number: 351770026294B6C815EH
	Subsystem 6 - 	Part No SW: --------------
	Component: SideSensor_Pr1C7 0148
	Serial Number: 35277009B1E5D983E26X
	Subsystem 7 - 	Part No SW: --------------
	Component: FrontSensor_D1C5 014A
	Serial Number: 3557500A92057271231V
	Subsystem 8 - 	Part No SW: --------------
	Component: FrontSensor_P1C5 014A
	Serial Number: 3567500A92057272229/
	Subsystem 9 - 	Part No SW: --------------
	Component: PedP_Sensor_C1C5 014A
	Serial Number: 2307500B1205BA35729/
	Subsystem 10 - 	Part No SW: --------------
	Component: PedPSensor_D2256 0887
	Serial Number: I0M9M009D1F631412399
Address 16: Steering wheel  (J527)	Labels: 4M0-907-129.clb
	Part No SW: 4M0 907 129 JE	HW: 4M0 907 129 JE
	Component: Lenks.Modul   H11 0009
	Shop #: WSC 00000 000
	ROD: EV_SMLSKLOAU736_006.rod
	VCID: 7CBB67F33E7EEF929DCAF6-8029
Address 17: Instruments  (J285)	Labels: None
	Part No SW: 8W5 920 790 C	HW: 8W5 920 790 C
	Component: FBenRDW       H15 0299
	Coding: 048481C27C98000801B369601000600000000000
	ASAM Dataset: EV_DashBoardAU736 001022
	ROD: EV_DashBoardAU736_AU49.rod
	VCID: 42C7D90B1C1A5962978678-8017
Address 18: Aux. Heat  (J364)	Labels: None
	Part No SW: 4M0 265 105 E	HW: 4M0 265 105 E
	Component: HSG           H09 0060
	Coding: 0D0F01
	ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
	ROD: EV_AuxilParkHeateEBEAU736.rod
	VCID: 29156EA7816CAA3AB68C67-807C
Address 19: CAN Gateway  (J533)	Labels: None
	Part No SW: 8W7 907 468 C	HW: 8W7 907 468 C
	Component: Gateway       H27 0298
	Revision: 4M080003
	Coding: 0301000100000E407F07000000590032D4920007120000000175078F00000000
	ASAM Dataset: EV_CGateCONTIAU491 002060
	ROD: EV_CGateCONTIAU491_002_AU49.rod
	VCID: 4BD9F42F2B50982A64E09D-801E
	Subsystem 1 - 	Part No SW: 4M0-951-523-A
	Component: J453 MFL     H06 0002
	Serial Number: 20160509160952 01995
	Subsystem 2 - 	Part No SW: 8S0-915-181-C
	Component: J367-BDMHellaH10 9070
	Serial Number: 9347640204
Address 1B: Active Steering  (J792)	Labels: None
	Part No SW: 8W0 907 144 E	HW: 8W0 907 144 C
	Component: SCU_MLBevo    H03 0706
	Coding: 40
	ASAM Dataset: EV_SCUZFLSAU49X 002014
	ROD: EV_SCUZFLSAU49X_002.rod
Address 29: Left Light  (J1018)	Labels: 4M0-907-397.clb
	Part No SW: 4M0 907 397 AD	HW: 4M0 907 397 D
	Component: LCM_MLBevo
	ROD: EV_LCMLeftHELLAAU736_AU73.rod
	VCID: 79B57EE7314CDABA86AC97-802C
Address 36: Seat Mem. Drvr  (J136)	Labels: None
	Part No SW: 4M0 959 760	HW: 4M0 959 760
	Component: MEM-FS        008 0015
	Coding: 00581B000000B0010000210101010000000000000000000000000000000000
	ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
	ROD: EV_SCMDriveSideCONTIAU736_AU73.rod
	VCID: F5ADF2D79D543EDA62842B-80A0
Address 39: Right Light  (J1023)	Labels: 4M0-907-397.clb
	ROD: EV_LCMRightHELLAAU736_AU73.rod
Address 3C: Lane Change  (J769)	Labels: None
	Part No SW: 4M0 907 566 B	HW: 4M0 907 566
	Component: MRR1Rear      H13 0230
	Revision: --------
	Coding: 1EC002
	ASAM Dataset: EV_RearRadarS1BoschAU736 001015
	VCID: 342B8FD356AEE7D2151A9E-8061
Address 42: Door Elect, Driver  (J386)	Labels: None
	Part No SW: 4M0 959 793 G	HW: 4M0 959 793 C
	Component: TSG FS        009 0052
	Coding: 005D9B215E000080000110B0
	ROD: EV_DCU2DriveSideMAXHCONT_AU73.rod
Address 44: Steering Assist  (J500)	Labels: None
	Part No SW: 8W0 909 144 F	HW: 8W0 909 144 B
	Component: EPS_MLBEVO_ZF H08 0407
	Coding: 85888380008080
	ASAM Dataset: EV_EPSZFAU49X 002015
	ROD: EV_EPSZFAU49X_002.rod
	VCID: 40C3D30312164B72819262-8015
Address 46: Central Conv.  (J393)	Labels: None
	Part No SW: 8W0 907 064 BC	HW: 8W0 907 064 C
	Component: BCM2 MLBevo   018 0327
	Coding: 01340000000000E06309A0000E00480233004000004F02502F0400000504803F001F0000000000
	ASAM Dataset: EV_BCM2HellaAU736 011012
	ROD: EV_BCM2HellaAU736_011.rod
	VCID: 7EBF6DFB2862FD82B3FECC-802B
	Subsystem 1 - 	Part No SW: 3AA-962-243-G
	Component: GEB.F.HeckoefH16 0903
	Serial Number: 84386070
Address 47: Sound System  (J525)	Labels: None
	Part No SW: 8W0 035 465	HW: 8W0 035 465
	Component: MIB2_amp_P_B9 H11 0420
	Revision: 00000001
	Coding: 0194420800AFAAAFAA0000010000
	ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
	ROD: EV_AMPMst16C2Gen2ALPI.rod
	VCID: F6AFF5DB805235C26B8E34-80A3
Address 52: Door Elect, Pass.  (J387)	Labels: None
	Part No SW: 4M0 959 792 G	HW: 4M0 959 792 C
	Component: TSG BFS       009 0052
	ROD: EV_DCU2PasseSideMAXHCONT_AU73.rod
	VCID: 41C5D607191C427A8E9C6F-8014
Address 5F: Information Electr.  (J794)	Labels: 8W-5f.clb
	Part No SW: 8W0 035 035 C	HW: 8W0 035 035 A
	Component: MU-P-LND-EU   052 0678
	Coding: 019442010000000053111102000A00332F0003E5017001009E
	ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
	VCID: 322789CBACBAE9E207E688-8067
	Subsystem 1 - 	Part No SW: V03-959-802-DE
	Component: ECE 2019     --- 0175
	Serial Number: --------------------
	Subsystem 2 - 	Part No SW: 8W0-919-605
	Component: AU49x_DU_HIGHH40 0008
	Serial Number: AUZ8Z9GBJ017YJ
	Subsystem 3 - 	Part No SW: 8W0-919-614-T
	Component: ControlUnit_HH30 0206
	Serial Number: APVAK102041600050056
Address 69: Trailer  (J345)	Labels: 5Q0-907-383.clb
	Part No SW: 4M0 907 383 D	HW: 4M0 907 383 B
	Component: Anhaenger     H20 0214
	Revision: 9A001003
	Coding: 0110000202000000
	ROD: EV_TrailFunctGener2Hella_AU73.rod
	VCID: 33298CCF53A0E0EA0C1095-8066
Address 6C: Back-up Cam.  (J928)	Labels: None
	Part No SW: 4M0 907 428 D	HW: 4M0 907 428
	Component: Areaview 2    H12 0311
	Coding: 02940201BF0FA10008404000
	ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
	ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
Address 6D: Trunk Elect.  (J605)	Labels: 5Q0-959-107.clb
	Part No SW: 4M0 959 107 A	HW: 4M0 959 107 A
	Component: HDSG-Modul    H13 0155
	Revision: --------
	Coding: 05F0
	ROD: EV_DeckLidCONTIAU736_AU73.rod
	VCID: 312586C7A9BCD2FA7EFCBF-8064
Address 74: Chassis Control  (J775)	Labels: None
	Part No SW: 8W0 907 777 H	HW: 8W0 907 777 C
	Component: Fahrwerk-SG   H35 1214
	Coding: D450586958
	ASAM Dataset: EV_ChassContrContiAU426 001003
	ROD: EV_ChassContrContiAU426.rod
	VCID: 4CDBF7332E5E9F126DEAE6-8019
Address 81: Gear Shift  (J587)	Labels: None
	Part No SW: 8W1 713 041 E	HW: 8W1 713 041 E
	Component: GSM-LL        H08 0068
	Revision: 0L0D5012
	ASAM Dataset: EV_GSMWaehlZFAU736 001013
	ROD: EV_GSMWaehlZFAU736_AU49.rod
	VCID: 352DB2D75DD4FEDA2204EB-8060
Address 82: Heads Up Display  (J898)	Labels: None
	Part No SW: 8W5 919 617 B	HW: 8W5 919 617 B
	Component: HeadUpDisplay H15 1603
	Coding: 4F01C0
	ASAM Dataset: EV_HudNSEIKAU736 001015
	ROD: EV_HudNSEIKAU736.rod
	VCID: 47D1C81F37387C4A40D8B1-8012
Address 8B: Adaptive Cruise 2  (J850)	Labels: None
	Part No SW: 8W0 907 541 B	HW: 8W0 907 541
	ASAM Dataset: EV_ACC2BOSCHAU49X 002018
	ROD: EV_ACC2BOSCHAU49X_002.rod
	VCID: 3B39A4EF7BF028AAD4402D-806E
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: None
	Part No SW: 8W0 907 217 B	HW: 8W0 907 217
	Component: BVS           H14 0042
	Coding: 0404090200000402012023A7CD0000FCB0F0C020E280
	ROD: EV_BVSMLBevKOSTAAU736.rod
4195330 - Databus
Address AC: Reductant Control  (J880)	Labels: 4M0-907-355.clb
	Part No SW: 4M0 907 355 B	HW: 4M0 907 355 B
	Component: SCR-Stg-G3
	ASAM Dataset: EV_RDCMINERGAU736 005009
	ROD: EV_RDCMINERGAU736.rod
	VCID: 302383C3A2B6DBF271F2B2-8065
Address BB: Door Rear Drv Side  (J388)	Labels: None
	Part No SW: 4M0 959 795 G	HW: 4M0 959 795 C
	Component: TSG HFS       009 0052
	Coding: 000D992000000080000010A0
	ROD: EV_DCU2RearDriveMAXHCONT.rod
	VCID: 44CBDF13060E5752A5BA4E-8011
Address BC: Door Rear Pass Side  (J389)	Labels: None
	Component: TSG HBFS      009 0052
	ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CF: Lane Chge Asst 2  (J770)	Labels: None
	Part No SW: 4M0 907 590 B	HW: 4M0 907 590
	Revision: --------
	Coding: 1EC002
	ASAM Dataset: EV_RearRadarS2BoschAU736 001015
	ROD: EV_RearRadarS2BoschAU736.rod
Address D6: Light Ctrl Left 2  (A31)	Labels: None
	Part No SW: 7PP 941 571 BC	HW: 7PP 941 571 B
	Component: LED1L         H09 0008
	ROD: N/A
	VCID: 9771D85FA718ACCA90F821-80C2
	No ASAM data for: "EV_LEDModLeftMELCOAU736"
Address D7: Light Ctrl Right 2  (A27)	Labels: None
	Component: LED1R         H09 0008
	ROD: N/A
	No ASAM data for: "EV_LEDModRightMELCOAU736"
End--(Elapsed Time: 03:40, VBatt start/end: 15.0/15.0 Vign: 0.0)-
VCDS-Cloud is a service of Ross-Tech, LLC
From wherever we can find it! :)
Answered in the VIN-Limited Interface FAQ:
What if I'm swapping components from different cars?
If you're swapping components with like instrument clusters or ECUs that have different VINs stored in them, you may have to register each of the different VINs.
