2014 Audi A6 - ABS Brakes
MRDAMO666
England
C?ID=380337
Hi all,
I have got a warning light showing on my dash for the 'ABS Brakes'.
I had initially had the light come on not long after purchase (but outside warranty) and upon checking the pads were well worn and indeed needed changing which they duly were.
However, after changing the light went out, but returned shortly after.
Now it appears, disappears at random points, typically coming on (but not always) as I leave the driveway in the morning.
The brake fluid is present (and not reducing) and the car is braking correctly (evenly), so have a feeling that its going to be a faulty sensor but unsure.
Any help to identify source of the problem would be appreciated.
Thank you!
Sunday,10,November,2019,11:00:08:46541
VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
                Address 03: ABS Brakes       Labels: 4G0-907-379-V1.clb
Control Module Part Number: 4G0 907 379 L    HW: 4G0 907 379 L
  Component and/or Version: ESP PREMIUM   H09 0450
           Software Coding: 06A09F016005F9809B00
            Work Shop Code: WSC 02391 785 00200
              ASAM Dataset: EV_ESPPremiAU57X 004039 (AU57)
                      VCID: 3A2D323E3CD4C507C73-806E
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Ldm_ApbFailureState]
                    Reset counter: 159
                    Mileage: 68417 km
                    Date: 2019.10.30
                    Time: 13:27:46
                    VzRef: 01
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 08
                    Uz: A7
0692 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SCL_EPB_Spannkraft_Error]
                    Reset counter: 159
                    Mileage: 68417 km
                    Date: 2019.10.30
                    Time: 13:27:46
                    VzRef: 01
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 06
                    Uz: A6
Ashraf6119
C?ID=174194
If you could post a full autoscan would be helpful to see what other modules have faults codes..........
I have also seen your other post regarding the DPF fault also full scan in that post would help.
MRDAMO666
England
C?ID=380337
Beginners fault......will go and grab one now. Cheers
MRDAMO666
England
C?ID=380337
Full scan this time....Cheers
Sunday,15,December,2019,11:45:46:46541
VIN: WAUZZZ4G3EN182843   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F 62
          72 AC
VIN: WAUZZZ4G3EN182843   Mileage: 70539km-43830miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FE    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8243
   Revision: 85H23---
   Coding: 0A194012242401080000
   Shop #: WSC 56882 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021FE 002007
   ROD: EV_ECM20TDI01104L906021FE_002.rod
   VCID: 6D87C9623D1AA2BF121-8038
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0551
   Coding: 03B83046000000000000
   VCID: 7AADF23E7CD40507873-802E
   Serial number: 0214000122868001
   Part No SW: 4G0 820 043 BA    HW: 4G0 820 043 BA
   Component: KLIMA 2 ZONEN H14 0096
   Serial number: 01071400111268
   Coding: 3421090821
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 5F9BA3AAC7B6C02F90D-800A
   Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
   Revision: 19012002    Serial number: 00000001555361
   Coding: 2600201040349F600481008000001D0C0F9D830827090201000004606100
   VCID: 6D87C9623D9AA2BF121-8038
   Component: WWS57X 140621  H37 0080
   Serial number:         140630055157
   Coding: 0045F7
   Serial number: 22844189
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 23 06 2014  00001518
   Serial number: 3828C637000000000001
   Revision: 11001001    Serial number: 61061419000341
   Coding: 08C206
   VCID: 71BFD5122122465F369-8024
   Revision: --------    Serial number: 003JG00JL4UQ
   Coding: 3032343631324E303235554A305234473053
   VCID: 3635260E08CC216723B-8062
   Serial number: 3575HRB405F2M4PG0P3O
   Serial number: 3585HRB40632M4PG408+
   Serial number: 3515JRB405J2SIIA21EK
   Serial number: 3525JRB405L2SIIAA83R
   Serial number: 3554VRB401A52MDSOH85
   Serial number: 3564VRB401A52MDSQ8PG
   Revision: 00000000    Serial number: 20140707000312
   Coding: 000014
   VCID: 30391016EA280F57797-8064
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
   Component: MDieGb        H43 0411
   Revision: 27450259    Serial number: 658020714592022
   Coding: 33A40A000B412600010000
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3FDB432A27F6E02FF0D-806A
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung / Adaption]
                    Reset counter: 184
                    Mileage: 70539 km
                    Date: 2019.12.14
                    Time: 15:01:47
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Revision: --------    Serial number: 00000001466281
   Coding: 00CD074400
   VCID: 72BDDA1E24247D47CF3-8026
   Serial number: 9617223703
   Voltage stabilizer:
   Serial number: 140208000000000006FB
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA720AY5GP
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33331F1A1BBE344F045-8066
   Coding: 011C16004001620002080002
   VCID: 47CB5BCA7FA6A8EF48D-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0025714666
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0339889791
   Coding: 011B062280B900408320080400010E470000000000000000000000000000
   Revision: CJ007001    Serial number: 00000000120361
   VCID: 1D67D9A28DBA923FC21-8048
   VCID: 46D556CE78ACB1E7B3B-8012
   Revision: --------    Serial number: 00000001123019
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070962FD9A62BF521-8078
   Serial number: 140707-0002-088
   Coding: 112196101000A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H55 0801
   Coding: 0101000101415B47082B060301020100000000
   VCID: 270BFB4ADFE648EFA8D-8072
   Subsystem 1 - Part No: 8X0 919 884 G
   Component: P24-50-13.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464F30E2668186
   Subsystem 3 - Part No SW: 4G2 919 710 B    HW: 4G2 919 710 B
   Serial number: 90349NG9000AH
   VCID: 49CF5DF269B25E9F5E9-801C
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 141681459
   ROD: EV_RDCMA00100_008.rod
   VCID: 2B03077AC38E6C8F4C5-807E
End----(Elapsed Time: 01:39, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Confusing. Have you cleared the faults? Because I see nothing relevant in the full scan.
