- Joined
- Apr 9, 2014
- Messages
- 2,309
- Reaction score
- 2,257
- Location
- Tartu, Estonia
- VCDS Serial number
- C?ID=195131
Although not supported by VCDS, it can access module. But because of missing asam for 17 and 19 doesn't populate installation list.
I tried making my own autoscan list but there are still missing modules like:
*Rear End Module
*Telematics Module
*Slide Door Right maybe(how does this car have slide door???)
*Stopwatch
*PCM/CDR
*Amplifier
*Headlight Central
Using Xdiag I was able to read/clear faults.
*Rear End Module
*Telematics Module
*Stopwatch
*PCM/CDR
*Amplifier
*Headlight Central
Wednesday,11,December,2019,11:33:48:39429
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4513.4
Dealer/Shop Name: Tarfor OÜ
VIN: WP1ZZZ95ZFL License Plate: 245TMP
Mileage: Repair Order: 8867
Chassis Type: 95-N/A (95 - Porsche Macan )
Scan: 01 02 03 06 08 09 0D 10 15 16 17 18 19 22 32 34 36 40 42 44
46 47 51 52 53 55 61 62 65 65 69 6C 6D 72 75 AC
VIN: WP1ZZZ95ZFL
Address 01: Engine (J623-CTBA) Labels: None
Part No SW: 95B 907 401 G HW: 059 907 309 A
Component: 3.0TDI EDC17 X14 0007
Revision: 58X14---
Coding: 2F65401A853E01034000
Shop #: WSC 90465 176 797740
ASAM Dataset: EV_ECM30TDI01195B907401G 001007
ROD: EV_ECM30TDI011_AU73.rod
VCID: AC147C9AC791B22F95-80F8
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 95B 927 156 HW: 0B5 927 156 K
Component: PDK 30TDI RdW H02 0007
Revision: --H02---
Coding: 100001
Shop #: WSC 00256 168 00001
ASAM Dataset: EV_TCMDL501021 001019
ROD: EV_TCMDL501021.rod
VCID: EE90B692310D803FFB-80BA
Address 03: ABS Brakes (J104) Labels:* None
Part No SW: 95B 907 379 D HW: 95B 907 379
Component: MK25A H37 0810
Revision: -------- Serial number: 405440010EC815
Coding: 7B7C326C33868267DE7D4C69CC6341703703
ASAM Dataset: EV_MK25AXT 009001
ROD: EV_ESPMK25A00800.rod
VCID: B73E53F60ED701F7E8-80E2
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 7PP 959 760 F HW: 7PP 959 760 F
Component: MEM-BFS X14 2500
Revision: S0000000 Serial number: 00000145427697
Coding: 22001200AF00400000005700000000002020
VCID: E18ADDAEF8D32F4776-80B4
Part No SW: 95B 907 040 K HW: 95B 907 040 K
Component: BKE_VORN 52 0820
Revision: 02K80000 Serial number: 017312381
Coding: 2880822908000000
ASAM Dataset: BKE__ 040005
ROD: N/A
VCID: AF2E6B96F687C937B0-80FA
Component: 0000000000
No ASAM data for: "BKE__" ()
Address 09: Cent. Elect. Labels: None
Part No SW: 7PP 907 064 HJ HW: 7PP 907 064 HJ
Component: BCM_VORNE D50 2900
Revision: 00000000
Coding: 02000001617D00354C0F4815A03E2121313100EC3E0000000007079F
ASAM Dataset: BCM_VORNE 020030
ROD: N/A
VCID: A30697A6AA4F7D5724-80F6
No ASAM data for: "BCM_VORNE" (VW52)
12656661 - ROD - Unknown Error Code
- 00 [127]
Confirmed - Not Tested Since Memory Clear
Fault Frequency: 146
Reset counter: 2
Mileage: 786432 km
Date: 2115.03.14
Time: 17:14:00
Address 0D: Slide Door, Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000093429147
Coding: 012E002000A0730203880000
VCID: C8DC200A7B297E0F91-809C
02123 - Door Warning Light / Entry Light
Reset counter: 138
Mileage: 148729 km
Date: 2019.12.11
Time: 11:33:21
Address 10: Park/Steer Assist (----) Labels: None
Part No SW: 95B 919 475 C HW: 95B 919 475 C
Component: ParkAssistant H08 0002
Revision: -------- Serial number: 11961406700691
Coding: 00002D
ASAM Dataset: ParkAssistant8K 080005
ROD: N/A
VCID: B6205EF209DDF8FFF3-80E2
No ASAM data for: "ParkAssistant8K" ()
Address 15: Airbags (J234) Labels:* None
Part No SW: 95B 959 655 C HW: 95B 959 655 C
Component: VW10Airbag60F 002 0090
Revision: -------- Serial number: 003L20004JMS
Coding: 000000000000000000000000000000003046
ASAM Dataset: EV_AirbaVW10BPAVW526 002128
VCID: BA384AC23DC51C9F17-80EE
Serial number: 3575HRB40652BDG08O2.
Serial number: 3585HRB40572B68UBPN-
Serial number: 3515RRB400U50UJIOHCN
Serial number: 3525RRB400S50T8AOH9%
Serial number: 3555YRB401E50RNAI9F1
Serial number: 3565YRB401C50RNARHIK
Address 16: Steering wheel Labels: None
Part No SW: 95B 953 507 AE HW: 95B 953 568 A
Component: KLSM 003 0600
Serial number: 90898NCE001EL
Coding: 79114A
ASAM Dataset: MA_KLSM 001002
ROD: N/A
VCID: F3A6A7E65A2FADD714-80A6
No ASAM data for: "MA_KLSM" ()
Address 17: Instruments Labels: None
Part No SW: 95B 920 904 T HW: 95B 920 904 T
Component: Kombi Cajun 008 0563
Revision: 0C009004 Serial number: 14550SA3P
Coding: 78E0DCC8B80EEE61
Shop #: WSC 47024 197 131445
ASAM Dataset: Kombiinstrument_Gen2_A2.2 000011
ROD: N/A
VCID: BC344CDA37F122AF05-80E8
No ASAM data for: "Kombiinstrument_Gen2_A2.2" ()
40960 - ROD - Unknown Error Code
- 00 [047]
Fault Frequency: 238
Reset counter: 1
Mileage: 1001728 km
Date: 2037.08.18
Time: 04:32:00
40998 - ROD - Unknown Error Code
- 00 [047]
Fault Frequency: 138
Reset counter: 2
Mileage: 955648 km
Date: 2072.09.01
Time: 04:04:16
- 00 [047]
Reset counter: 2
Mileage: 786432 km
Date: 2055.04.11
Time: 04:00:18
Address 18: Aux. Heat (J364) Labels: None
Part No SW: 95B 963 272 HW: 95B 963 272
Component: Standheizung H23 0247
Revision: 56005006 Serial number: 20130728082307
Coding: 592200
VCID: ED92B19E340B7B27C2-80B8
Address 19: CAN Gateway Labels: None
Part No SW: 95B 907 530 D HW: 95B 907 530 C
Component: zentr Gateway 424 40431100
Revision: 00000000 Serial number: 1143F500914302
Shop #: WSC 00112 137 00000
ASAM Dataset: CAN/CAN Gateway A7.0
ROD: N/A
No ASAM data for: "CAN/CAN Gateway" ()
- 00 [009]
Reset counter: 2
Mileage: 326015 km
Date: 2069.10.26
Time: 08:12:60
Address 22: AWD Labels: None
Part No SW: 95B 927 755 BG HW: 95B 927 755 B
Component: Allrad-HangOn D00 0802
Revision: IC001001 Serial number: 13351C5063
Coding: 05
ASAM Dataset: Allrad 000003
ROD: N/A
VCID: FCB48CDA7771E2AF45-80A8
No ASAM data for: "Allrad" ()
0289 - ROD - Unknown Error Code
- 00 [047]
Fault Frequency: 137
Reset counter: 2
Mileage: 323584 km
Date: 2069.10.19
Time: 12:61:12
Address 32: Differential Locks Labels: None
Part No SW: 95B 927 771 C HW: 95B 927 771 C
Component: Quersperre 6422
Revision: H03 Serial number: 408611250003
VCID: B42464FAD7A1EAEFCD-80E0
Address 34: Level Control (J197) Labels: None
Part No SW: 95B 907 553 E HW: 95B 907 553 E
Component: PASM H05 0810
Revision: 00000000 Serial number: 00000140560218
Coding: 21610000
ASAM Dataset: EV_PASMConti 001004
ROD: EV_PASMConti.rod
VCID: B22862E2E5B5E4DFDF-80E6
Component: MEM-FS X14 2500
Revision: S0000000 Serial number: 00000145577360
Coding: 22081300AF00400000005F00000000002020
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000093389951
Coding: 013F02205EA07302030D0001
VCID: FAB88AC27545DC9F57-80AE
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 95B 909 144 B HW: 95B 909 144
Component: RCEPS H40 0902
Revision: 00001000 Serial number: 0024340739
Coding: 120000000001
ASAM Dataset: EV_RCEPSAU48X 008015
ROD: EV_RCEPSAU48X_008.rod
VCID: AD12719EFC8BBB2782-80F8
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000093700364
Coding: 013F02205EA07302030D0000
Address 53: Parking Brake (----) Labels: None
Part No SW: 95B 907 801 B HW: 95B 907 801 A
Component: EPB-4 H01 0700
Revision: -------- Serial number: 30000000000870
ASAM Dataset: EV_ParkiBrake 002002
ROD: N/A
VCID: AB167F86C29FB5179C-80FE
No ASAM data for: "EV_ParkiBrake" ()
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Reset counter: 138
Mileage: 148729 km
Date: 2019.12.11
Time: 11:33:21
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 L HW: 4H0 907 383 L
Component: Anhaenger H14 0113
Serial number: 0324905545
Coding: 0100000200000000
Address 6C: Back-up Cam. (J772) Labels: None
Part No SW: 95B 980 551 F HW: 95B 980 551 F
Component: RVC Compact H06 0060
Revision: --------
Coding: 05000101010000070000A0
ASAM Dataset: EV_RearvCompaCamer 001001
ROD: EV_RearvCompaCamer.rod
Address 6D: Trunk Elect. (----) Labels:. 7N0-959-107.clb
Part No SW: 7P5 959 107 E HW: 7P5 959 107 E
Component: HDSG-Modul H01 0043
Revision: 22001001 Serial number: 057400588
Coding: 1433018003
ASAM Dataset: EV_Heckklappe 101170
ROD: N/A
VCID: C0CC382A5B19464F59-8094
No ASAM data for: "EV_Heckklappe" (VW52)
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000093435663
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H09 0010
Revision: 00000000 Serial number: 140200318
ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 04:18, VBatt start/end: 13.4V/13.4V)-----------
