A1 GB 2019 Lane Assisst
chb
C?ID=361330
The LA can be switched off an on again by the small switch on the tip of the direction indicator switch. If on, it activates at ~65 km/h. However, on every new start of the ignition/engine, it is in state on again, activating at ~65 km/h. Is it possible to code it such that it is per default off after ignition or even remembers the last state of before turing the engine off?
I had no success with Unit A5 (camera) -> entering access priviledge -> function 10
-> channel "On-position of LA" (maybe worse translation of German "Einschaltzustand Suprhalteassistent") -> adjustment "menu"
or
-> channel "personalizing intervention momemt with terminal 15" ("Personalisierung Eingriffszeitpunkt bei Kl.15") ->
adjustment "last known"
Both are already stored default values, where LA is turned on automatically after ignition on and I find no respective setting within the car menu.
My anonymized autoscan (in German) is:
VCDS Version: AIB 19.6.1.0  HEX-NET xx: 0.xxxx.x
Datenstand: 20190806 DS308.0
www.vcds.de
Fahrzeug-Ident.-Nr.: XXXXXXXXXXXXXX   KFZ-Kennzeichen:
Kilometerstand: 830km   Reparaturauftrag:
Fahrzeugtyp: GB-AU27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 75 A5
Fahrzeug-Ident.-Nr.: xxxxxxxxxxxxx   Kilometerstand: 830km
03-Bremsenelektronik -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
75-Telematik -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-DADA)       Labeldatei: Keine
   Teilenummer SW: 05E 906 018 AB    HW: 05E 907 309
   Bauteil: R4 1.5l TFS   H22 6086
   Revision: 81H22000
   Codierung: 0225003223041D0800000000000000000000000000000000
   Betriebsnr.: WSC 00049 770 00163
   ASAM Datensatz: EV_ECM15TFS01105E906018AB 003002
   ROD: EV_ECM15TFS011_AU27.rod
   VCID: E5823838E45F7B678A-80B0
Adresse 02: Getriebe (J743)       Labeldatei: DRV\0CW-927-769.clb
   Teilenummer SW: 0CW 300 043 D    HW: 0AM 927 769 E
   Bauteil: GSG DQ200G2_M H05 1605
   Revision: 00005008    Seriennummer:
   Codierung: 0014
   ASAM Datensatz: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: B83CA14C036D368FE1-80EC
Adresse 03: Bremsenelektronik (J104)       Labeldatei: Keine
   Teilenummer SW: 2Q0 614 517 AG    HW: 2Q0 614 517 N
   Bauteil: ESC_base_vFGS H23 0242
   Seriennummer:
   Codierung: 42094D4F354742AFB200AC1A37E123A649125126336A24582454285445ECC46592488A64CC56241A242A142AA24DD2423DB24B42BC
   ASAM Datensatz: EV_Brake1BOSCHESPMQBA0 004036
   ROD: EV_Brake1BOSCHESPMQBA0.rod
   VCID: F3A656605A8B95D714-80A6
Adresse 08: Klima-/Heizungsel. (E87)       Labeldatei:* Keine
   Teilenummer SW: 83A 820 047 A    HW: 83A 820 047 A
   Bauteil: AC Manuell el H04 0020
   Revision: 20026000    Seriennummer:
   Codierung: 230000040000000010000000000000000000000000000000
   ASAM Datensatz: EV_AirCondiFrontManAU326 001003
   ROD: EV_AirCondiFrontManAU326_AU27.rod
   VCID: A2086324B5F14C5F2F-80F6
Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\5Q0-937-08X-V2.clb
   Teilenummer SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Bauteil: BCM MQBAB M+  H38 0273
   Seriennummer:
   Codierung: 000000000000000000000000000000000000000000000000000000000000
   ASAM Datensatz: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_AU27.rod
   VCID: FCB47D5C77D5DAAF45-80A8
   Sensor für Regen- und Lichterkennung:
   Subsystem 1 - Teilenummer SW: 81A 955 559 A    HW: 81A 955 559
   Bauteil: G397_RLS  H06 0002
   Seriennummer:
   Codierung: 80004D
   Lichtschalter:
   Subsystem 2 - Teilenummer SW: 4K1 941 501 D    HW: 4K1 941 501 D
   Bauteil: E1 - LTM  H05 0053
   Seriennummer:
   Lenkstockschalter:
   Subsystem 3 - Teilenummer SW: 82A 953 521 DR    HW: 5Q1 953 549
   Bauteil: J527 SMLS MQB  004 0070
   Seriennummer:
Adresse 10: Einparkhilfe 2 (J446)       Labeldatei:| DRV\5Q0-919-294.clb
   Teilenummer SW: 5QA 919 294 C    HW: 5QA 919 294
   Bauteil: PDC 8 KanalH07 0050
   Seriennummer:
   Codierung: 0471051011
   ASAM Datensatz: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: CCD4ED9C67F5AA2FB5-8098
Adresse 13: Distanzregelung (J428)       Labeldatei:| 2Q0-907-572.clb
   Teilenummer SW: 2Q0 907 572 Q    HW: 5Q3 907 572
   Bauteil: ACCCONTIMQB   H03 0342
   Codierung: 3200000208F78728747C61450050A700000000000000000000
   ASAM Datensatz: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_AU27.rod
   VCID: C2C8C3A455B16C5F4F-8096
Adresse 15: Airbag (J234)       Labeldatei:* Keine
   Teilenummer SW: 2Q0 959 655 AM    HW: 2Q0 959 655 AM
   Bauteil: VW22Airbag    010 0351
   Revision: --------
   Codierung: 88CCC0C0000000005C5400DF000840A80065
   Betriebsnr.: WSC 00049 770 00119
   ASAM Datensatz: EV_AirbaVW22BPAVW27X 001020
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 885C118C330D860F51-80DC
   Subsystem 1 - Teilenummer SW: -----------    HW: 442 062 005 19
   Bauteil: SideSensor_Df  1E2 0887
   Seriennummer:
   Codierung: 2D2D2D
   Subsystem 2 - Teilenummer SW: -----------    HW: 442 062 005 19
   Bauteil: SideSensor_Pf  1E2 0887
   Seriennummer:
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Subsystem 3 - Teilenummer SW: -----------    HW: 442 0B1 105 19
   Bauteil: SideSensor_Dr  1C7 0148
   Seriennummer:
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Subsystem 4 - Teilenummer SW: -----------    HW: 442 0B1 205 19
   Bauteil: SideSensor_Pr  1C7 0148
   Seriennummer:
   Codierung: 2D2D2D
   Subsystem 5 - Teilenummer SW: -----------    HW: 442 133 003 19
   Bauteil: FrontSensor_D  290 118A
   Seriennummer:
   Codierung: 2D2D2D
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:* Keine-SRI3
   Teilenummer SW: 82A 920 700     HW: 82A 920 700
   Bauteil: KOMBI         H13 1712
   Codierung: 00840008618000080080A0001000000000000000
   ASAM Datensatz: EV_DashBoardVDDMQBA0 001027
   ROD: EV_DashBoardVDDMQBA0_AU27.rod
   VCID: DDF210D8CC0F33A752-8088
Adresse 19: Diagnoseinterface (J533)       Labeldatei:| DRV\3Q0-907-530-V1.clb
   Teilenummer SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Bauteil: GW MQB High   521 5366
   Seriennummer:
   Codierung: 030100F42F0857005B000248180B00000000000000000000000000000000
   ASAM Datensatz: EV_GatewNF 013025
   ROD: EV_GatewNF.rod
   VCID: EE90471431A9B83FFB-80BA
   Generator:
   Bauteil: 0-00-02-00-04
   Steuergerät für Multifunktionslenkrad:
   Subsystem 2 - Teilenummer SW: 83A 951 523     HW: 83A 951 523
   Bauteil: J453 MFL  H05 0004
   Seriennummer:
   Steuergerät für Batterieüberwachung:
   Subsystem 3 - Teilenummer SW: 2Q0 915 181     HW: 2Q0 915 181
   Bauteil: J367-BDMBOSCH  H02 2011
   Seriennummer:
Adresse 42: Türelektr. Fahrer (J386)       Labeldatei:| 5QX-959-X93-42.clb
   Teilenummer SW: 5Q4 959 393 F    HW: 5Q4 959 393 F
   Bauteil: TSG FS        006 0246
   Seriennummer:
   Codierung: 00100320E100020000001000
   ASAM Datensatz: EV_DCU2DriveSideMAXHCONT 001005
   VCID: C6C0DFB47999507F63-8092
   Türsteuergerät Fahrerseite hinten:
   Subsystem 1 - Teilenummer SW: 5Q0 959 407     HW: 5Q0 959 163
   Bauteil: FOND_FHSG_DRV  007 0010
   Seriennummer:
   Codierung: 310000
Adresse 44: Lenkhilfe (J792)       Labeldatei:* Keine
   Teilenummer SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
   Bauteil: TRW_G4L_MQBA0 611 6041
   Seriennummer:
   Codierung: 010000000100000001010201010001010000010101
   ASAM Datensatz: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: BC34BD5C37551AAF05-80E8
Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei:| 5QX-959-X92-52.clb
   Teilenummer SW: 5Q4 959 392 F    HW: 5Q4 959 392 F
   Bauteil: TSG BFS       006 0246
   Seriennummer:
   Codierung: 00100120E100020000001000
   ASAM Datensatz: EV_DCU2PasseSideMAXHCONT 001005
   VCID: C5C2D8B8449F5B676A-8090
   Türsteuergerät Beifahrerseite hinten:
   Subsystem 1 - Teilenummer SW: 5Q0 959 408     HW: 5Q0 959 164
   Bauteil: FOND_FHSG_PSG  007 0010
   Seriennummer:
   Codierung: 290000
Adresse 5F: Informationselek. I (J794)       Labeldatei:* Keine
   Teilenummer SW: 83A 035 842     HW: 83A 035 842
   Bauteil: MU-S-D-ER     742 0051
   Seriennummer:
   Codierung: 01720000BE00000041111101C00800002F0007E40170000002
   ASAM Datensatz: EV_MUStdGen2pDELP 001001
   ROD: EV_MUStdGen2pDELP.rod
   VCID: E2882324F5710C5F6F-80B6
   Anzeigeeinheit 1 für Multimediasystem:
   Subsystem 1 - Teilenummer SW: 82A 919 604 A    HW: 82A 919 604 A
   Bauteil: DU AU270 Std  H42 0133
   Seriennummer:
   Lautstärkeregler 1:
   Subsystem 2 - Teilenummer SW: 82A 919 616     HW: 82A 919 616
   Bauteil: LSR-D5/C8  H33 0108
   Seriennummer:
Adresse 75: Telematik (J949)       Labeldatei:| 5QE-035-285.clb
   Teilenummer SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Bauteil: OCULowMQBLGE  H19 0825
   Revision: --------
   Codierung: 01720601EA370A0F05109C0000354003804651
   ASAM Datensatz: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   VCID: BD32B0582C4F13A732-80E8
Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:| DRV\3Q0-980-65X-A5.clb
   Teilenummer SW: 3Q0 980 654 M    HW: 3Q0 980 654 A
   Bauteil: MQB_B_MFK     H09 0451
   Seriennummer:
   Codierung: 0402070000000401002200448146440084000E00000000
   ASAM Datensatz: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_VW12.rod
   VCID: C1CACCA850B7774756-8094
Thank you,
Chris
nirvananils
C?ID=289109
As Iam right here's actually no known solution. @hadez16 or is there anything NEW?
TBAx
C?ID=287144
You need to change the A5 module's coding: Byte 14 Bit 2-3 to "08 (Perso_HC,Last_setting)"
Disclaimer: I am not sure, if this works with the Audi A1.
chb
C?ID=361330
@TBAx Thanks, works like a charm on my A1. You are the best.
hadez16
C?ID=289891
This coding applies to all bothering new MY19 cars on MQB or MQB-A0 Platform where Lane Assist is on by ignition.
MLBevo cars (Touareg 3, A6 4K, ...) have an adaptation channel in unit A5 instead of coding to change the ignition behaviour.
