The LA can be switched off an on again by the small switch on the tip of the direction indicator switch. If on, it activates at ~65 km/h. However, on every new start of the ignition/engine, it is in state on again, activating at ~65 km/h. Is it possible to code it such that it is per default off after ignition or even remembers the last state of before turing the engine off?
I had no success with Unit A5 (camera) -> entering access priviledge -> function 10
-> channel "On-position of LA" (maybe worse translation of German "Einschaltzustand Suprhalteassistent") -> adjustment "menu"
or
-> channel "personalizing intervention momemt with terminal 15" ("Personalisierung Eingriffszeitpunkt bei Kl.15") ->
adjustment "last known"
Both are already stored default values, where LA is turned on automatically after ignition on and I find no respective setting within the car menu.
My anonymized autoscan (in German) is:
Thank you,
Chris
or
VCDS Version: AIB 19.6.1.0 HEX-NET xx: 0.xxxx.x
Datenstand: 20190806 DS308.0
www.vcds.de
Fahrzeug-Ident.-Nr.: XXXXXXXXXXXXXX KFZ-Kennzeichen:
Kilometerstand: 830km Reparaturauftrag:
Fahrzeugtyp: GB-AU27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 75 A5
Fahrzeug-Ident.-Nr.: xxxxxxxxxxxxx Kilometerstand: 830km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
75-Telematik -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-DADA) Labeldatei: Keine
Teilenummer SW: 05E 906 018 AB HW: 05E 907 309
Bauteil: R4 1.5l TFS H22 6086
Revision: 81H22000
Codierung: 0225003223041D0800000000000000000000000000000000
Betriebsnr.: WSC 00049 770 00163
ASAM Datensatz: EV_ECM15TFS01105E906018AB 003002
ROD: EV_ECM15TFS011_AU27.rod
VCID: E5823838E45F7B678A-80B0
Kein(e) Fehlercode(s) gefunden.
Adresse 02: Getriebe (J743) Labeldatei: DRV\0CW-927-769.clb
Teilenummer SW: 0CW 300 043 D HW: 0AM 927 769 E
Bauteil: GSG DQ200G2_M H05 1605
Revision: 00005008 Seriennummer:
Codierung: 0014
ASAM Datensatz: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW27.rod
VCID: B83CA14C036D368FE1-80EC
Adresse 03: Bremsenelektronik (J104) Labeldatei: Keine
Teilenummer SW: 2Q0 614 517 AG HW: 2Q0 614 517 N
Bauteil: ESC_base_vFGS H23 0242
Seriennummer:
Codierung: 42094D4F354742AFB200AC1A37E123A649125126336A24582454285445ECC46592488A64CC56241A242A142AA24DD2423DB24B42BC
ASAM Datensatz: EV_Brake1BOSCHESPMQBA0 004036
ROD: EV_Brake1BOSCHESPMQBA0.rod
VCID: F3A656605A8B95D714-80A6
Adresse 08: Klima-/Heizungsel. (E87) Labeldatei:* Keine
Teilenummer SW: 83A 820 047 A HW: 83A 820 047 A
Bauteil: AC Manuell el H04 0020
Revision: 20026000 Seriennummer:
Codierung: 230000040000000010000000000000000000000000000000
ASAM Datensatz: EV_AirCondiFrontManAU326 001003
ROD: EV_AirCondiFrontManAU326_AU27.rod
VCID: A2086324B5F14C5F2F-80F6
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\5Q0-937-08X-V2.clb
Teilenummer SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Bauteil: BCM MQBAB M+ H38 0273
Seriennummer:
Codierung: 000000000000000000000000000000000000000000000000000000000000
ASAM Datensatz: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_AU27.rod
VCID: FCB47D5C77D5DAAF45-80A8
Sensor für Regen- und Lichterkennung:
Subsystem 1 - Teilenummer SW: 81A 955 559 A HW: 81A 955 559
Bauteil: G397_RLS H06 0002
Seriennummer:
Codierung: 80004D
Lichtschalter:
Subsystem 2 - Teilenummer SW: 4K1 941 501 D HW: 4K1 941 501 D
Bauteil: E1 - LTM H05 0053
Seriennummer:
Lenkstockschalter:
Subsystem 3 - Teilenummer SW: 82A 953 521 DR HW: 5Q1 953 549
Bauteil: J527 SMLS MQB 004 0070
Seriennummer:
Adresse 10: Einparkhilfe 2 (J446) Labeldatei:| DRV\5Q0-919-294.clb
Teilenummer SW: 5QA 919 294 C HW: 5QA 919 294
Bauteil: PDC 8 KanalH07 0050
Seriennummer:
Codierung: 0471051011
ASAM Datensatz: EV_EPHVA18AU3700000 009039
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: CCD4ED9C67F5AA2FB5-8098
Adresse 13: Distanzregelung (J428) Labeldatei:| 2Q0-907-572.clb
Teilenummer SW: 2Q0 907 572 Q HW: 5Q3 907 572
Bauteil: ACCCONTIMQB H03 0342
Codierung: 3200000208F78728747C61450050A700000000000000000000
ASAM Datensatz: EV_ACCMRRCONTIVW376 003015
ROD: EV_ACCMRRCONTIVW376_AU27.rod
VCID: C2C8C3A455B16C5F4F-8096
Adresse 15: Airbag (J234) Labeldatei:* Keine
Teilenummer SW: 2Q0 959 655 AM HW: 2Q0 959 655 AM
Bauteil: VW22Airbag 010 0351
Revision: --------
Codierung: 88CCC0C0000000005C5400DF000840A80065
Betriebsnr.: WSC 00049 770 00119
ASAM Datensatz: EV_AirbaVW22BPAVW27X 001020
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 885C118C330D860F51-80DC
Crashsensor für Seitenairbag Fahrerseite:
Subsystem 1 - Teilenummer SW: ----------- HW: 442 062 005 19
Bauteil: SideSensor_Df 1E2 0887
Seriennummer:
Codierung: 2D2D2D
Crashsensor für Seitenairbag Beifahrerseite:
Subsystem 2 - Teilenummer SW: ----------- HW: 442 062 005 19
Bauteil: SideSensor_Pf 1E2 0887
Seriennummer:
Codierung: 2D2D2D
Crashsensor für Seitenairbag hinten Fahrerseite:
Subsystem 3 - Teilenummer SW: ----------- HW: 442 0B1 105 19
Bauteil: SideSensor_Dr 1C7 0148
Seriennummer:
Codierung: 2D2D2D
Crashsensor für Seitenairbag hinten Beifahrerseite:
Subsystem 4 - Teilenummer SW: ----------- HW: 442 0B1 205 19
Bauteil: SideSensor_Pr 1C7 0148
Seriennummer:
Codierung: 2D2D2D
Crashsensor für Frontairbag Fahrerseite:
Subsystem 5 - Teilenummer SW: ----------- HW: 442 133 003 19
Bauteil: FrontSensor_D 290 118A
Seriennummer:
Codierung: 2D2D2D
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:* Keine-SRI3
Teilenummer SW: 82A 920 700 HW: 82A 920 700
Bauteil: KOMBI H13 1712
Codierung: 00840008618000080080A0001000000000000000
ASAM Datensatz: EV_DashBoardVDDMQBA0 001027
ROD: EV_DashBoardVDDMQBA0_AU27.rod
VCID: DDF210D8CC0F33A752-8088
Adresse 19: Diagnoseinterface (J533) Labeldatei:| DRV\3Q0-907-530-V1.clb
Teilenummer SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Bauteil: GW MQB High 521 5366
Seriennummer:
Codierung: 030100F42F0857005B000248180B00000000000000000000000000000000
ASAM Datensatz: EV_GatewNF 013025
ROD: EV_GatewNF.rod
VCID: EE90471431A9B83FFB-80BA
Generator:
Bauteil: 0-00-02-00-04
Steuergerät für Multifunktionslenkrad:
Subsystem 2 - Teilenummer SW: 83A 951 523 HW: 83A 951 523
Bauteil: J453 MFL H05 0004
Seriennummer:
Steuergerät für Batterieüberwachung:
Subsystem 3 - Teilenummer SW: 2Q0 915 181 HW: 2Q0 915 181
Bauteil: J367-BDMBOSCH H02 2011
Seriennummer:
Adresse 42: Türelektr. Fahrer (J386) Labeldatei:| 5QX-959-X93-42.clb
Teilenummer SW: 5Q4 959 393 F HW: 5Q4 959 393 F
Bauteil: TSG FS 006 0246
Seriennummer:
Codierung: 00100320E100020000001000
ASAM Datensatz: EV_DCU2DriveSideMAXHCONT 001005
VCID: C6C0DFB47999507F63-8092
Türsteuergerät Fahrerseite hinten:
Subsystem 1 - Teilenummer SW: 5Q0 959 407 HW: 5Q0 959 163
Bauteil: FOND_FHSG_DRV 007 0010
Seriennummer:
Codierung: 310000
Adresse 44: Lenkhilfe (J792) Labeldatei:* Keine
Teilenummer SW: 2Q1 909 144 M HW: 2Q1 909 144 F
Bauteil: TRW_G4L_MQBA0 611 6041
Seriennummer:
Codierung: 010000000100000001010201010001010000010101
ASAM Datensatz: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
VCID: BC34BD5C37551AAF05-80E8
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei:| 5QX-959-X92-52.clb
Teilenummer SW: 5Q4 959 392 F HW: 5Q4 959 392 F
Bauteil: TSG BFS 006 0246
Seriennummer:
Codierung: 00100120E100020000001000
ASAM Datensatz: EV_DCU2PasseSideMAXHCONT 001005
VCID: C5C2D8B8449F5B676A-8090
Türsteuergerät Beifahrerseite hinten:
Subsystem 1 - Teilenummer SW: 5Q0 959 408 HW: 5Q0 959 164
Bauteil: FOND_FHSG_PSG 007 0010
Seriennummer:
Codierung: 290000
Adresse 5F: Informationselek. I (J794) Labeldatei:* Keine
Teilenummer SW: 83A 035 842 HW: 83A 035 842
Bauteil: MU-S-D-ER 742 0051
Seriennummer:
Codierung: 01720000BE00000041111101C00800002F0007E40170000002
ASAM Datensatz: EV_MUStdGen2pDELP 001001
ROD: EV_MUStdGen2pDELP.rod
VCID: E2882324F5710C5F6F-80B6
Anzeigeeinheit 1 für Multimediasystem:
Subsystem 1 - Teilenummer SW: 82A 919 604 A HW: 82A 919 604 A
Bauteil: DU AU270 Std H42 0133
Seriennummer:
Lautstärkeregler 1:
Subsystem 2 - Teilenummer SW: 82A 919 616 HW: 82A 919 616
Bauteil: LSR-D5/C8 H33 0108
Seriennummer:
Adresse 75: Telematik (J949) Labeldatei:| 5QE-035-285.clb
Teilenummer SW: 5NA 035 284 C HW: 5NA 035 284 C
Bauteil: OCULowMQBLGE H19 0825
Revision: --------
Codierung: 01720601EA370A0F05109C0000354003804651
ASAM Datensatz: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW27.rod
VCID: BD32B0582C4F13A732-80E8
Adresse A5: Front-/Vorfeldkamera (R242) Labeldatei:| DRV\3Q0-980-65X-A5.clb
Teilenummer SW: 3Q0 980 654 M HW: 3Q0 980 654 A
Bauteil: MQB_B_MFK H09 0451
Seriennummer:
Codierung: 0402070000000401002200448146440084000E00000000
ASAM Datensatz: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_VW12.rod
VCID: C1CACCA850B7774756-8094
Chris
