03 Brake Security Access Code needed
AudiA32016
C?ID=386038
I have a 2016 Audi A3 8V 1.8t FWD
I'm just trying to reset the 03 ABS to factory default settings but I need the security access code to do it.
Does anyone know the correct code for my car?
So I've been searching around and I think it is 40168, but I don't want to play guessing games and would prefer if someone confirmed.
But I might go ahead and try if no one replies soon.
I found a document called kodowania 8v.pdf and its a document on vcds with known procedures and codes. But it lists like 11 codes for the ABS brakes.....
And they don't know what function corresponds to the codes....
So this is scaring me, because they say it will lock you out for 1 hour of ignition on time every time you put in the wrong code and there are so many codes..... I don't know if I feel like experimenting with this. Those are a lot of potential hours of experimenting.
Or if anyone knows the code to just change 03 basic setting let me know please. I might not have to reset everything to factory default.
Why? In what way have you changed it from factory settings?
FWIW, VAG uses extremely confusing terminology in with some of these things. We've seen cases where "Reset to factory settings" wipes out the parameterization of a module, and I can pretty much guarantee that you don't want to do that.
AudiA32016
C?ID=386038
It has a fault says basic settings lost steering angle sensor. But it's in the 03 Brakes section.
It actually has a lot of little faults, but like last time, all the faults had a root cause, it was steering angle sensor calibration.
I'm just trying to clean up all the faults related to this.
My steering angle sensor fault from 44 steering assist is fixed and fine now, shows no faults after calibrating.
All the dashlights are gone, the parking sensors and everything works. Car drives fine and no one would really know it has faults.
But it was just bothering me that the ABS still has the fault.
AudiA32016
C?ID=386038
Ok I did some more reading and I found this
https://www.audiworld.com/forums/a8-s8-d3-platform-discussion-60/steering-angle-sensor-2915165/
He seemed to have a similar fault as me, G85 gone wrong in the 03 ABS brakes.
He claimed to use 40168 in his procedure and it cleared his codes when he 0'd out the steering angle from there as well.
Any thoughts? It's not the same model as my car but he is using vcds and seems like mine would be pretty much the same. At least the same process or similar for clearing the faults, not too sure about the security access code, it could differ from model to model from what I've heard but they generally seem to be the same?
Lucky me I ran into a tough problem.....the 03 brake security access is mysterious on the 8v....
AudiA32016
C?ID=386038
Ok I know I seem like I'm rambling but I'm just thinking out loud and throwing out ideas.
But I think I found something interesting.
http://www.hirscheautomotive.com/wp...07_HI_InstallationGuides_VAG_Installation.pdf
This is a EPS install guide, and if you go to page 6 it tells you to calibrate G85 in both 44 steering assist and 03 ABS brake.
They use security access 40168 for BOTH 44 steering assist and 03 ABS here, and they give a rather obscure calibration process but that's not the point. The point is, they used the same security access code to enter basic settings on both 44 and 03. So is it the same on my car? I used 19249 for my 44 steering assist basic settings on my 8V...
So I do KNOW 19249 WORKS for basic settings in 44 steering assist, since I already did all that and the vcds helper balloon shows it...but there is no balloon for 03 ABS security access, so I'm wondering if that might be the key for 03 ABS basic setting access code on the Audi 8V? I think I've read a few places that 40168 did not work on their 8V(I've even read all the codes don't work), and I've read some that it did work(I think), so I'm reluctant to try it. But right now I think I've narrowed it down to these 2 SA codes. 19249 or 40168 I don't know, it could be totally something else for all I know, but I've never seen anyone suggest using 19249 for the 03 ABS basic setting access code, so it's a new idea, based on what I read in the EPS instructions, that's my reasoning for bringing this up....
Well, even if you're just guessing, or if you're replying to tell me it's a bad idea to even try, I'd appreciate something....or just wish me luck that I don't strand myself lol.... but hey I did figure out that last problem in good time, read up on some others who ended up at the dealer doing the exact same thing.... I'm about to solve all these peoples problems....if I dare tomorrow....
AudiA32016
C?ID=386038
Tuesday,03,December,2019,14:02:04:63944
VIN:    License Plate:
Mileage: 27288km-16955mi   Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F 6C BB BC
VIN:    Mileage: 27288km-16955miles
Address 01: Engine (J623-CNSB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 0A1D00122424000F2000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001004
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 3FDB448E07F2207FF0D-806A
17178 - Databus
          U1123 00 [040] - Received Error Message
                    Mileage: 27136 km
                    Date: 2019.11.25
                    Time: 22:03:31
                    Coolant temperature: 96 °C
                    Intake air temperature: 53 °C
                    Voltage terminal 30: 12.773 V
                    Unlearning counter according OBD: 36
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
   Part No SW: 0D9 300 042 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4907
   Revision: 06253104    Serial number: TFK01511142120
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 196FCA16B9162E4F2E9-804C
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 63215000001376
   Coding: 13FF6A9234260A74017C020681C929C8562C5080408194B4024100548208
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: 79AFEA965956CE4F8E9-802C
6 Faults Found:
0295 - Steering angle sensor
          B1168 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 65
                    Mileage: 26733 km
                    Date: 2019.11.09
                    Time: 13:50:06
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 65
                    Mileage: 26733 km
                    Date: 2019.11.09
                    Time: 13:58:30
8277 - Databus
          U1122 00 [009] - Implausible Message
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 1
                    Mileage: 26733 km
                    Date: 2019.11.09
                    Time: 13:53:25
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 253
                    Mileage: 25859 km
                    Date: 2019.10.07
                    Time: 14:54:36
16412 - Display for Tire Pressure Monitoring
                    Reset counter: 65
                    Mileage: 26733 km
                    Date: 2019.11.09
                    Time: 13:50:16
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 65
                    Mileage: 26733 km
                    Date: 2019.11.09
                    Time: 13:50:16
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000804853
   Coding: 03000014010000000000000000001400
   VCID: 323D1DBAC4A0FD170F3-8066
   Serial number: 2C084AD7000000000001
   Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061533101029
   Coding: 04141A42C04122F541C04004511007000000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7F5B048E4772E07FB0D-802A
   Component: WWS371 151106  043 0585
   Serial number:         151118183555
   Coding: 0A47F7
   Serial number: 60999007
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 17 09 2015  00001675
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000034027844
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000ON2ER00000
   Coding: 101F00
   Revision: --------    Serial number: 39391533008979
   Coding: 0010150011
   VCID: 43D3487E6B1A449F945-8016
13637426 - Databus
                    Reset counter: 65
                    Mileage: 27136 km
                    Date: 2019.11.25
                    Time: 21:59:21
   Serial number: 003GCR044M24
   Coding: 9DCCFCC0000000005000001AC24800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47CB5C6E5F2268BF48D-8012
   Belt Pretensioner left:
   Component: BeltPretRevFL  H36 0350
   Serial number: 34230167A30111541026
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H36 0350
   Serial number: 34230168A30111551108
   Coding: 333135
   Occupant Detection:
   Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
   Serial number: 694000000000001F0WAY
   Coding: 303332
   Subsystem 4 - Part No SW: -----------    HW: 480 000 411 15
   Serial number: 357000000001C599371J
   Subsystem 5 - Part No SW: -----------    HW: 480 000 411 15
   Serial number: 358000000004D84C971V
   Subsystem 6 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3510002991E34431513P
   Subsystem 7 - Part No SW: -----------    HW: 480 402 411 15
   Serial number: 35200029B1E2431592B+
   Subsystem 8 - Part No SW: -----------    HW: 480 401 509 15
   Serial number: 3550002A31CB0C21A3C6
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 401 509 15
   Serial number: 3560002A31CB0C23D10+
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 65
                    Mileage: 26733 km
                    Date: 2019.11.09
                    Time: 13:50:06
   Part No SW: 8V0 953 521 EP    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 26111504220022
   Coding: A018
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 0C41A34206C4CBE7A5F-8058
   Part No SW: 8V0 920 960 M    HW: 8V0 920 960 M
   Component: KOMBI         H03 6423
   Coding: 0BF419092B80D7050200A8001800000000000000
   VCID: 45D75666652E7AAFBA1-8010
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 24111510520552
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   ROD: EV_GatewConti_013.rod
   Serial number: 23 11 2015  F0068820
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 171015BJH0224A
   Coding: 00100B204000048000000002
   VCID: 41DF42767106568F869-8014
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0002
   VCID: 44D14B626E1443A7ADF-8010
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 111015BJA06092
   Coding: 001003204000048000000002
   VCID: 40D947727A0C5F87897-8014
   Coding: 011A000101000000
   VCID: 75B7E6A6754EAA2FEA1-8020
13705992 - Databus
          [LWI_01: Fehlerwert im Signal LWI_Lenkradwinkel]
                    Reset counter: 65
                    Mileage: 27136 km
                    Date: 2019.11.25
                    Time: 21:58:23
   Part No SW: 8V0 035 844 C    HW: 8V0 035 844
   Component: MU-S-S-US     014 0660
   Serial number: A7A00112150557
   Coding: 01730100FF0A000011220001001A00002F0001440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 392F2A9619D60E4FCE9-806C
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30EKHH
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Serial number: C1000007101500030138
          B11CF 53 [009] - Deactivated
                    Reset counter: 23
                    Mileage: 27136 km
                    Date: 2019.11.25
                    Time: 21:57:33
                    Voltage terminal 30: 12.1 V
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
   Component: MQB RVC Mid   H07 0140
   Coding: 027300010201000300
   ASAM Dataset: EV_2CamSysRearPASE 006016
   ROD: EV_2CamSysRearPASE.rod
   VCID: 303917B2CAACCF07797-8064
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 071115BK70245C
   Coding: 000003204000048000000002
   Serial number: 071115BK702741
End----------(Elapsed Time: 01:36, VBatt start/end: 12.3V/12.3V)-----------
Tuesday,03,December,2019,14:10:09:63944
VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
                Address 15: Airbags       Labels: 5Q0-959-655.clb
Control Module Part Number: 5Q0 959 655 J    HW: 5Q0 959 655 J
  Component and/or Version: AirbagVW20    010 0830
           Software Coding: 9DCCFCC0000000005000001AC24800000065
            Work Shop Code: WSC 06385 790 00016
              ASAM Dataset: EV_AirbaVW20SMEVW37X 002144 (AU37)
1050117 - Databus
                    Reset counter: 65
                    Mileage: 26733 km
                    Date: 2019.11.09
                    Time: 13:50:06
Sorry didn't post it because I was pretty sure what the main issue is.
All those little intermittent databus faults seems not as important, many went away after I recalibrated G85 in 44 steering assist.
Most of them clear easy and wont come back until later because it's intermittent.
It seems to even show a fault for not subscribing to Sirius xm radio.
Or wait it says tuner not activated, but we get free Sirius XM on holidays and mine is working?
DV52
C?ID=194404
AudiA32016: Hi. hmm...........reading your dialogue with interest (and confusion).
Not sure that sufficient background information has been provided to resolve matter - for example what happened to the car around 9th November 2019 @ about 2PM? Was the battery disconnected at this time, were any coding/channel/module-reset changes made (check the AdpLog.CSV and CodingLog.CSV in the C:\Ross-TechDS\Debug directory on your laptop).
Also not sure about the SA question - but there are a bunch of security codes for the ABS module for MQB platform vehicles (like your A3 8V) listed HERE
And, I'm not sure about the validity of the ESP install document that you posted. It seems to relate to non UDS modules - I think, so not applicable to later model vehicles like the A3.
Finally, there is a discussion about Steering angle calibration HERE for MQB platform cars (ignore reference to mk7 - the thread equally applies to A3). Most of the chat is about the hex 44 module, but there is passing reference to the DTC on the ABS module.
PS: And......forgive my impudence in asking- but I assume that you have tied clearing the DTC s after successfully calibrating G85 in the hex 44 module
AudiA32016
C?ID=386038
Yea so I think a different scantool messed it up, or it was the reset to factory I did a couple times. I fixed steering 44 problems with vcds, it had pretty much the exact same faults, but drove even worse driving the car everything was disabled, if you look at my older post I posted the scan where steering 44 G85 was messed up and caused everything to not work but now I have 0 fault for steering 44 I took care of it, parking assist drawing lines and other things that need input from G85 were disabled basically G85 caused faults in other modules because they needed SAS input I believe.
I've read others with exact same faults from steering 44 reset to factory as well....or they were using OBD11 and it was even harder to calibrate G85 with that cell phone tool for them, so they took it to the dealer.. but mostly I think it was just a lack of knowledge and know how, and they just gave up really quick.
Trying to fix abs fault now, it's not a huge deal but it bothers me, but it might be a bigger deal than I'm aware of.
I'm fairly confident it CAN be fixed, I fixed most/half my problems with steering assist 44 G85 calibration.
Actually, I'm not sure if I specifically tried clearing fault codes IN 03 ABS right after calibrating G85 in steering 44...... I did try clearing other faults for sure though, like the engine and other little intermittent databus errors. I should check the ABS, but I'm fairly certain I have already done it and it didn't clear at all for ABS.
I guess I'll probably just be the guinea pig... Cars already messed up I might as well attempt to fix it. And if I happen to find success I'll let you guys know. I'm not going to rush this one though.
I'm going to go try that fault clearing, and try to poke around ABS basic settings just to look if a G85/SAS option is even there.
There are some measuring values related to the steering angle sensor in that ABS, but nothing in terms of Adaptations or Basic Settings.
AudiA32016
C?ID=386038
I just went through my logs, and I'm pretty sure it was the 44 factory reset that screwed up everything, my first scan from 11/9 shows no fault. Only 44 steering fault. It was after I did the factory reset that all these extra faults came about everywhere.
Then I finally fixed my original problem in steering 44 and have these other things still lingering here.
I only got rid of 44 steering and backup camera faults I think.
I dunno am I screwed?
Should I post my scan from 11/9 that shows much less faults?
Actually many of these faults are low priority to me, like the sat radio tuner, and park steering assist my car never had. So yea some of these things my car doesn't have and the error is just being disabled or whatever.
I'm just trying to work from most important first and I think I want to solve this abs and engine faults. They bother me a little more.
The airbag one is same but my car has a recall for faulty passenger airbag connector anyways.
It works fine right now and I'm not bringing it to the dealer.
And again I have zero dash lights coming on, no warnings, no nothing on screen.
AudiA32016
C?ID=386038
Here is today's scan, but it was scanned before I cleared faults, I need to drive it again and scan again to see if they return, but it's raining hard right now.
I noticed the 55 headlight range returned to OK, it had a fault before I believe
I went and cleared the codes from all modules, when I got to 03 Brakes they all cleared but 1 fault instantly returned, a databus or message error.
The one tiny positive thing from this ordeal is that I believe I fixed my rain sensor, it never worked from brand new, I think the reset to factory made it work, just noticed today.
Wednesday,04,December,2019,17:10:11:63944
VIN:    License Plate:
Mileage: 27336km-16985mi   Repair Order:
VIN:    Mileage: 27336km-16985miles
   Revision: --H13---
17178 - Databus
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:49
                    Engine speed: 694.75 /min
                    Normed load value: 27.5 %
                    Coolant temperature: 100 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 14.023 V
Readiness: 0010 0101
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:49
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:49
8277 - Databus
                    Reset counter: 30
                    Date: 2019.12.03
                    Time: 14:12:22
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:59
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:59
   Coding: 0A47F7
   Coding: 00006C
   Light switch:
   Sun Roof:
   Coding: 101F00
   Coding: 0010150011
13637426 - Databus
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:49
   Coding: 333135
   Coding: 333135
   Occupant Detection:
   Coding: 303332
1050117 - Databus
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:49
   Coding: A018
   Coding: 0002
                    Reset counter: 30
                    Mileage: 27288 km
                    Date: 2019.12.03
                    Time: 14:10:55
                    Voltage terminal 30: 12.0 V
End----------(Elapsed Time: 01:33, VBatt start/end: 12.3V/12.3V)-----------
Address 10: DTCs cleared
                Address 03: ABS Brakes       Labels: 5Q0-907-379-IPB-V1.clb
Control Module Part Number: 3Q0 907 379 AA    HW: 3Q0 907 379 F
  Component and/or Version: ESC           H42 0623
           Software Coding: 13FF6A9234260A74017C020681C929C8562C5080408194B4024100548208
              ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036 (AU37)
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:49
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:49
8277 - Databus
                    Reset counter: 30
                    Date: 2019.12.03
                    Time: 14:12:22
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:59
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:59
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:49
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:49
8277 - Databus
                    Reset counter: 30
                    Date: 2019.12.03
                    Time: 14:12:22
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:59
                    Reset counter: 71
                    Mileage: 27291 km
                    Date: 2019.12.03
                    Time: 16:38:59
Address 03: DTCs cleared
Address 01: DTCs cleared
Address 15: DTCs cleared
Address 5F: DTCs cleared
I also poked around 03 ABS Basic settings and there is no G85/SAS option there. So I'm stumped if this fault returns.
AudiA32016
C?ID=386038
Ok so I think most of them are gone but I barely drove the car and there is still a pesky ABS message databus error.
Friday,06,December,2019,16:46:46:63944
VIN:    License Plate:
Mileage: 27357km-16998mi   Repair Order:
VIN:    Mileage: 27357km-16998miles
   Revision: --H13---
8277 - Databus
                    Reset counter: 32
                    Date: 2019.12.04
                    Time: 17:19:31
   Coding: 0A47F7
   Coding: 00006C
   Light switch:
   Sun Roof:
   Coding: 101F00
   Coding: 0010150011
   Coding: 333135
   Coding: 333135
   Occupant Detection:
   Coding: 303332
   Coding: A018
   Coding: 0002
                    Reset counter: 32
                    Mileage: 27336 km
                    Date: 2019.12.04
                    Time: 17:22:46
                    Voltage terminal 30: 12.2 V
8277 - Databus
                    Reset counter: 32
                    Date: 2019.12.04
                    Time: 17:19:31
8277 - Databus
                    Reset counter: 32
                    Date: 2019.12.04
                    Time: 17:19:31
So yea most of the codes didn't return, thanks for the tip. But this ABS error is still bothering me.
The 5F information electronics doesn't bother me too much as I don't subscribe to sat radio.
Maybe if I fix the ABS I can come back to focus on it but it's really not something I'd cry about if I never fixed it.
I guess I might have to wait until they figure out more about the ABS security codes, I have a feeling I might need to do something in there in order for the fault to disappear.
It always returns instantly when I try to clear the ABS code.
Not too bad overall now though eh? haha it was so messed up before lol.
https://www.golfmk7.com/forums/index.php?threads/driver-steering-recommendation-disable.359687/
I found this on a forum, but I'm not sure what DSR means, I assume it's something related to ESC or electric steering....
And they never found a solution it seems.
But the issue seems identical to mine....even the 5F fault sat radio is the same.
They don't know how it happened on their cars. They were poking around I guess.
Oh wait on the first post "When I clear the code, it immediately comes back. When I reactivate DSR and clear the code, it goes away and never comes back. So I assume it has something to do with ABS brake module, ESP and DSR not playing well together when it is disabled. I have seen a couple people disable DSR on the forum, but no one mentions this? Anyone else seeing this code?"
So he says when he "reactivates DSR and clear the code, it goes away and never come back".
So my question is, What is DSR? And Where do I go in VCDS to mess with it or activate it? I suppose its supposed to be activated? Maybe it got deactivated when I did the factory to reset?
Edit:
https://www.audiworld.com/forums/q5-sq5-mki-8r-discussion-129/dsr-disable-2896894/
So I found this that explains DSR, and most people prefer it turned off it seems.
However I need to know how to turn it on and off if it can clear my fault code.
There's only one way to get rid of "Tuner for Satellite Radio -- Deactivated" and that is to activate it, i.e. buy a subscription.
I would guess that DSR = Driver Steering Recommendation. As to why your ABS thinks it's getting an implausible message, I don't know.
AudiA32016
C?ID=386038
I found the instructions. For a different model I think. But it says 2013 and newer with electric steering.
44 steering assist
coding
long coding
byte 0
bit 4
(uncheck box for Driver Steering Recommendation)
That's what it says on audizine, I guess I'll have a look, if it's a part of steering 44, then maybe it got messed with with factory reset.
On your car, Driver Steering Recommendation should be in 44's coding, Byte 0, Bit 0. However, it's already Off...
Somnus
SLC, USA
C?ID=215931
If I were to hazard a guess, and it is most definitely a guess, there is a bit in you ABS Module (Byte 23, Bit 7) that I have seen labelled as "DSR", That might be where the error is coming from.
You can try deselecting that bit, clearing codes in the ABS module, and see if that solves your issue.
Somnus
SLC, USA
C?ID=215931
As an addendum to my post above^^^:
I took a look at my own vehicle and found that Byte 23 Bit 7 is unrelated to that error message. The DSR fault shows up even if that bit is deselected.
On the bright side, now we know! :facepalm:
AudiA32016
C?ID=386038
A3 201
This is correct, I finally got around to doing this because I couldn't align my car properly.
So this is full instructions for activating/deactivating Driver Steering Recommendation on Audi A3 2016 (8V)
1. Put in Security Code for coding
The one provided by the helper balloon for coding 28183 I think....
2. Go to Coding
3. Window pops up with current code to save, write it down or save it
4. DSR is the first code in hex 00 is off and 01 is turned on
There is helper box for the coding to just intuitively click it on and when you close window it will input the hex code for you
5. Press Do it!
Should say Code accepted
DONE
I left it off because I read a lot of reviews raving about it. But personally.... I think it's a bad idea to turn it off.
It turned itself off when I did the reset to factory and I left it off because I assumed people knew what they were talking about and all saying its superior....but I disagree, I like it turned on, I think it literally changes the alignment somehow....
