2004 TOUAREG V6 3.2L CRANKS BUT NO START
Davethewave1
C?ID=386480
Good morning everyone,
I am new to the forum & VCDS family and I am excited to both help with others problems and hopefully get some guidance on some of mine.
My car is a 2004 VW Touareg V6 3.2L gasoline that I bought used recently knowing that it had bad fuel pumps. It had the typical start for 30 seconds and die.
I replaced both fuel pumps and the fuel filter housing and everything ran perfectly on the car.
However, recently as my wife was driving our son to preschool the car mysteriously died while she was driving and would not restart. Cranks but no start.
I had the car towed home and charged the battery over night.
Went out the Touareg the next morning and started fine after a few cranks. I drove it no a short trip and it died a few blocks away and again would crank but not restart.
After towing it home and doing some investigation I noticed that the under hood fuse/relay panal had a pool of water because the cover was not secured properly.
I vacuumed out the water & dried it out over several days and closed the lid.
Now the car still will crank but not start and it will only crank if I let it sit in the key on / car off position until the EPC and Check engine light come on.
Also, the fuel pumps do not prime when I open the driver's door as they should. I can prime them manually so I know that they are still good.
Any idea of computer issues or relays that may cause this problem? I will post two scans that I took recently. The first is after the car died, but I had not cleared the codes and the second is after it died twice & I cleared the codes to get a fresh car scan as the car sits not.
THANK YOU ALL VERY MUCH IN ADVANCE AND HAVE A GREAT DAY!!!
FIRST SCAN:
Saturday,16,November,2019,15:49:59:54382
Dealer/Shop Name: Dave and Joey's Bone-Yard
VIN: WVGBC77L34D064021   License Plate: 854KHL
Mileage: 252670km-157001mi   Repair Order: 001
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGBC77L34D064021   Mileage: 252670km-157001miles
Address 01: Engine        Labels: 022-906-032-BMX.lbl
   Part No SW: 022 906 032 BF    HW:
   Component: MOTRONIC ME7.1.1G   9779
   Coding: 0000133
   Shop #: WSC 19226 444 59215
   VCID: 50F97738A6FE7567197-5160
10 Faults Found:
17069 - ECM Power Relay Control Circuit
            P0685 - 004 - Open Circuit
16660 - Fuel Injector #6 (N84)
            P0276 - 002 - Short to Ground - Intermittent
17833 - EVAP Purge Valve (N80)
            P1425 - 002 - Short to Ground - Intermittent
16645 - Fuel Injector #1 (N30)
            P0261 - 002 - Short to Ground - Intermittent
16651 - Fuel Injector #3 (N32)
            P0267 - 002 - Short to Ground - Intermittent
16657 - Fuel Injector #5 (N83)
            P0273 - 002 - Short to Ground - Intermittent
17880 - EVAP Leak Detection Pump
            P1472 - 002 - Short to Ground - Intermittent
17843 - Secondary Air Pump Relay (J299)
            P1435 - 002 - Short to Ground - Intermittent
16654 - Fuel Injector #4 (N33)
            P0270 - 002 - Short to Ground - Intermittent
17457 - Bank1; Exhaust Cam Adjustment Valve 1 (N318)
            P1049 - 002 - Short to Ground - Intermittent
Readiness: 0110 1101
   Part No: 09D 927 750 BD
   Component: AL 600 6Q           0582
   Coding: 0004153
   Shop #: WSC 19419 444 53362
   VCID: 71BFD2BC0DB45C6F369-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 D
   Component: ESP ALLRAD MK25     0108
   Coding: 0014337
   Shop #: WSC 31414 000 00000
   VCID: 3A2D35901042DF37C73-5160
65534 - Unknown Error Code
            015 - Cannot Be Tested at this Time - MIL ON
   Part No SW: 3D0 909 135 K    HW: 5WK 470 25
   Component:    Kessy            6400
   Coding: 0000232
   VCID: 2D070ECCD10C788F521-5160
6 Faults Found:
00166 - Access/Start Authorization Switch (E415)
00172 - Key 2 not learned
00087 - Terminal 30 for Starting Relevant Consumers
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 H
   Component: CLIMAtronic R/L   X 3716
   Coding: 0000030
   VCID: 353726AC395C304F2A1-5160
00898 - Control Circuit A/C compressor
            013 - Check DTC Memory
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 K
   Component:                     2703
   Coding: 0101599
   Shop #: WSC 19400 444 85723
   VCID: 44D14B68628699C7ADF-5160
02088 - Lights for Auxiliary High Beams
   Part No: 3D0 909 601 C
   Component: 05 Airbag 8.4E++H01 0352
   Revision: BB36963     Serial number: 00009760
   Coding: 0012341
   VCID: 2313E8F487C8BEFFF45-5160
   Subsystem 1 - Part No: 7L0 959 339 B
   Component: BF-Gewichtsens. 005 0006
                    Date: 2063.15.31
                    Time: 31:60:00
                    Date: 2063.15.31
                    Time: 31:60:00
00532 - Supply Voltage B+
                    Fault Frequency: 15
                    Reset counter: 39
                    Date: 2063.15.31
                    Time: 31:60:00
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000031
   VCID: 40D94778769E85E7897-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 970 RX
   Component: KOMBIINSTRUMENT RB0 2035
   Coding: 0007231
   VCID: 1E65D900ACAA9317DBB-5160
00438 - Fuel Supply Sensor 2 (G169)
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B9D7B806BE5567397-5160
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879
   Component: JCI PathPoint       1700
   VCID: 04518B68220659C7EDF-5160
00926 - Terminal 30
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F5B04844BE03A1FB0D-5160
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   VCID: 6695B1E0347A8BD753B-5184
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: 77ABECA463D0025FF8D-5160
02327 - Position Sensor for Front Seat Height Adjustment (G438)
02341 - Position Sensor for Seat Fore/Aft Adjustment (G441)
            006 - Short to Plus
02328 - Position Sensor for Rear Seat Height Adjustment (G439)
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
   Part No: 3D0 909 158
   VCID: 678BBCE4337092DF68D-5160
   Part No: 7L0 959 933 E
   Component: 2K HSG              0201
   Coding: 0000085
   VCID: 3E2539800C6AF317FBB-4B1E
   Subsystem 1 - Part No: 7L0 959 701 A
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 A
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703
   Subsystem 4 - Part No: 7L0 959 704
12 Faults Found:
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 56: Radio        Labels: 7L6-035-180-56.lbl
   Part No: 7L6 035 180 B
   Component: Radio DE2           0016
   Coding: 0000401
   VCID: 2C0103C8EA16718745F-5160
00879 - Connection to Speaker Front Right
00881 - Connection to Speaker Rear Right
Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
   Part No: 7L6 907 273
   Component: Reifendruckueberw.  0052
   Coding: 0211390
   VCID: 75B7E6AC79DC704FEA1-5160
01312 - Powertrain Data Bus
Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb
   Part No: 7L0 955 119 F
   Component: Front Wiper         2416
   Coding: 0000004
   Shop #: WSC 31414 000 376832
   VCID: 372B2CA42350C25F38D-5160
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 F
   Component: DACHDISPLAY         0530
   Revision: 00600530    Serial number: 2009289.02
End----(Elapsed Time: 08:47, VBatt start/end: 12.9V/10.5V. VIgn 10.6V)-----
SECOND SCAN AS THE CAR SITS NOW:
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 19.6.2(x64) Data version: 20190930 DS308.0
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Saturday,16,November,2019,16:37:26:54382
Mileage: 252670km-157001mi Repair Order: 002
------------------------------------------------------------------------------- Address 01: Engine Labels: 022-906-032-BMX.lbl
 Coding: 0000133
------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09D-927-750.clb
 Coding: 0004153
Self-Diagnosis Log
Page 2
 Coding: 0014337
------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
 Coding: 0000232
 Component: ELV XXXX
6 Faults Found:
 005 - No or Incorrect Basic Setting / Adaptation - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 3
 Coding: 0000030
------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
 Component: 2703
 Coding: 0101599
 008 - Implausible Signal - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 4
 Coding: 0012341
 Date: 2063.15.31
 Time: 31:60:00
 Date: 2063.15.31
 Time: 31:60:00
 Fault Frequency: 15
 Reset counter: 39
 Date: 2063.15.31
 Time: 31:60:00
Self-Diagnosis Log
Page 5
 Coding: 0000031
No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
 Coding: 0007231
 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
 Coding: 0000006
 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 1C: Position Sensing Labels: 7L6-919-879.lbl
00926 - Terminal 30
 002 - Lower Limit Exceeded - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 6
 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 29: Left Light Labels: 3D0-909-157.lbl
No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None
 006 - Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 39: Right Light Labels: 3D0-909-158.lbl
Self-Diagnosis Log
Page 7
 Coding: 0000085
12 Faults Found:
00926 - Terminal 30
 008 - Implausible Signal -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 8
 Coding: 0000401
00878 - Connection to Speaker Front Left
------------------------------------------------------------------------------- Address 65: Tire Pressure Labels:. 7L6-907-273.lbl
 Coding: 0211390
------------------------------------------------------------------------------- Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
 Coding: 0000004
No fault code found. ------------------------------------------------------------------------------- Address 6E: Ctrl Head Roof Labels: None
End----(Elapsed Time: 08:39, VBatt start/end: 12.9
Looks like a bad ECU power relay or a wire to it, maybe check ECU for water ingress too?
Davethewave1
C?ID=386480
Hi Jack,
Where is the ECU power relay located? I do have a multi-meter and I can check that it is working properly.
This gives me a place to start.
Thank you very much for your help!
Davethewave1
C?ID=386480
Hi Jack,
Do I need to send you all of my info for the JPPSG directly? I followed the link to you page with the JPPSG directions and I am very pleased to have your help.
Thx
Hi Jack,
Thx
No, it's just a good path/mindset for you to follow & if looking to approach a repair or process you are unfamiliar with & for a more positive outcome.
Davethewave1
C?ID=386480
I've been doing some looking around.
Am I correct in thinking that the ecm relay is under the drivers seat in the fuse box (J329 #433 Relay)?
Please see respective RTFB and WD for component search or locations to get CONFIRMATION.
Jef
HQ
J271, located in relay position "A3", electronics box in left plenum chamber:
You need to have the factory repair manual for the vehicle you are working on. Go to Erwin, get the cheapest account, run your VIN and then "print to PDF" everything. When your account expires, you'll have all the content offline via PDF files.
Davethewave1
C?ID=386480
Good afternoon,
I am still having the same problem as posted previously. Here is a link to the other post (sorry I'm new and untalented working the forum)
https://forums.ross-tech.com/showth...2L-CRANKS-BUT-NO-START&highlight=2004+touareg
I replaced the J271 relay in the A3 position as Jeff said, but no difference. I have re-scanned the car and will include it below.
My question is could the ecu/ecm be in need of a reprogramming? If yes is this something that I can do with the VCDS software or do I need to send the unit off to a third party to have it reprogrammed (I found a company on ebay that says they will reprogram it for $180, link at bottom of post)?
Also, I opened up the foot well by the drivers left foot and inspected the wiring loom where there are several connections have common issue for water damage. There was a little corrosion and I cut and respliced the connections.
Am I correct in thinking that it could be a ecu/ecm problem (either needs reporgramming or an entirely new unit? Or is there something else that I should be looking for a different problem first?
Also things to note. The car will not start or crank at all when the key is first inserted. You must wait a minute for the EPC warning light to appear on the dash and then the car will allow you to crank. Also, a cooling fan turns on at the same time the EPC light comes on and will stay running until the key is removed.
Thanks David. Here is the link to ebay for the computer re-programming.
https://www.ebay.com/itm/Volkswagen...irated&hash=item33cf5576bd:g:PPsAAOSwUKxYmfNH
Sunday,02,February,2020,12:49:27:54382
Chassis Type: 7L - VW Touareg (2003 > 11/2006)
   Coding: 0004153
   Coding: 0014337
   Coding: 0000232
6 Faults Found:
   Coding: 0000030
   Component:                     2703
   Coding: 0101599
   Coding: 0012341
                    Date: 2063.15.31
                    Time: 31:60:00
                    Date: 2063.15.31
                    Time: 31:60:00
                    Fault Frequency: 15
                    Reset counter: 39
                    Date: 2063.15.31
                    Time: 31:60:00
   Coding: 0000031
   Coding: 0007231
   Coding: 0000006
            006 - Short to Plus
   Coding: 0000085
12 Faults Found:
00926 - Terminal 30
   Coding: 0000401
   Coding: 0211390
   Coding: 0000004
End----(Elapsed Time: 08:45, VBatt start/end: 12.9V/11.1V. VIgn 11.0V)-----
Ecu doesn't need programming or replacing yet, did you measure for ground, voltage + current for all terminals at ECU directly?
If you like I will offer an observation to determine if it will communicate for freight and donation of your choice.
Davethewave1
C?ID=386480
Hi Jack,
Thank you for replying to the thread and your help.
I just want to make sure that I understand what you are saying. Are you asking me to remove the ecu and mail it to you. Then you will test it to see if it is communicating/working properly?
Thank you again for your help.
Dave
Affirmative!
Just pay freight and whatever you elect to donate.
Standard freight is 50 and covers signed with insurance.
I will then post forensic data in forum for full disclosure.
Yeah time to help Dave he has been suffering a while now?
I can feel his frustration.....
Davethewave1
C?ID=386480
Hi Jack,
What is the address that I should ship the ECU?
If you bench test the ECU and you find that it needs to be re-programmed or repaired is this something that you can also do? Or are you offering a diagnostic test only?
I am happy to ship it to you...its mostly my wife that is the frusterated one (she has been driving a cheap temporary replacement 01 Passat that I picked up for $200) :)
Dave
Coding: 0000133
Dave take to contact form.
Indeed I can.....
Let's verify controller first....
https://europeanpartsemporium.com/contact/
Vehicle Identification No. WVGBC77L34D064021
Model Touareg
TOUA
Date of production 28.02.2004
Model year 2004
Sales type 7LABC1
Engine Code BAA
Transmission Code HAM
Emission standard 7GA Emission standard LEV 2
PART NUMBER DESCRIPTION
022 906 032 BF Control unit for petrol engine
Davethewave1
C?ID=386480
Hi Jack
I followed the link and sent my you a message through your page for European Parts Emporium.
Is there anything else that I should do before sending you the ECU tomorrow on my lunch break?
Dave
