A3 8p electrical problems car stays running no key
Stuartwhite1989
A3 8p. 2.0 tdi 2004 I was having problems with power steering before intermittently cutting out. Now I’m having the battery draining and fan cutting in with car stone cold during night or opening door and ignition lights come on. If jump start and switch off dash lights stay on sometime and engine stays running untill I open door. Today all lights went off and stayed running no keys. Had to stall it. The windows are always steamed inside so water getting in. I thought where I washed rear seat but it’s not. I’ve looked online but can’t find any common faults is it ecu or fuse box got water in or is it like Passat get water under floor carpet
Stuartwhite1989
I have traction control light too. Looking at fuse box under bonnet under cover in one one the recess there is water. Fuses in there cover steering and engine controll. I’m thinkin water in there. Any ideas how to remover and strip to dry. I can only see a torx in the centre under cover
myounus
Northwest UK
C?ID=321059
Please post an autoscan. If you've got battery drain then you'll need to test one by one.
Stuartwhite1989
It’s not really a electric drain more of things turning on and running themselves. I think water in the fuse box under engine shorting everything. I don’t want to risk frying my Ross tech cable
Mari
C?ID=150535
Without Auto-Scan there is not much information to start with!
Stuartwhite1989
Monday,02,December,2019,21:07:31:57077
VCDS Version: 19.6.2.0
VIN: WAUZZZ8P84A056462   License Plate:
Mileage: 237110km-147333mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P84A056462   Mileage: 237110km-147333miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
15-Airbags -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 G    HW: 028 101 136 4
   Component: R4 2,0L EDC 0000SG  5334
   Revision: 12345678    Serial number: AUX7Z0C6FNT0DV
   Coding: 0000072
   Shop #: WSC 01286 386 08256
   VCID: 27560A959633E177C6-8072
19781 - Power Supply Terminal 15
            P3325 - 000 - Implausible - Intermittent
                    Torque: 0.0 Nm
                    Voltage: 12.84 V
                    Bin. Bits: 00000000
                    Bin. Bits:        0
                    (no units): 1.0
            P1570 - 000 -  - Intermittent
                    Torque: 0.0 Nm
                    Voltage: 12.62 V
                    Bin. Bits: 00000000
                    Bin. Bits: 11100000
                    (no units): 0.0
16486 - Mass Air Flow Sensor (G70)
            P0102 - 000 - Signal too Low
                    RPM: 840 /min
                    Torque: 42.0 Nm
                    Voltage: 14.36 V
                    Bin. Bits: 00000111
                    Mass Air / Rev.: 850.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
17903 - Switch-Over Valve for EGR Cooler (N345)
            P1495 - 000 - Open or Short to Ground - Intermittent
                    Torque: 202.0 Nm
                    Voltage: 6.16 V
                    Bin. Bits: 00000000
17911 - Load Signal from Alternator Term. DF
            P1503 - 000 - Implausible Signal
                    Torque: 0.0 Nm
                    Voltage: 11.93 V
                    Bin. Bits: 00000000
                    (no units): 1.0
Readiness: 0 1 0 0 1
   Part No: 1K0 907 379 D
   Coding: 0055942
   Shop #: WSC 06435 000 00000
   VCID: 336EEEC552EB9DD76A-8066
6 Faults Found:
   Part No SW: 8P0 820 043 H    HW: 8P0 820 043 H
   Component: KlimavollautomatH14 0180
   Revision: 138254      Serial number: 8P0820043H
   VCID: 3162E4CDA8F7AFC718-8064
00532 - Supply Voltage B+
                    Reset counter: 218
                    Voltage: 7.40 V
                    Fault Status: 00101001
                    Reset counter: 218
                    Temperature: -50.0°C
                    Voltage: 8.40 V
                    Load: 9.0 %
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 218
                    Reset counter: 178
                    Mileage: 223600 km
                    Date: 2017.11.11
                    Time: 03:54:00
                    Temperature: 18.5°C
01273 - Fresh Air Blower (V2)
                    Reset counter: 218
                    Mileage: 237118 km
                    Date: 2019.11.27
                    Time: 00:01:56
                    Temperature: 5.0°C
                    Speed: 325.0 km/h
                    (no units): 202.0
                    (no units): 32.0
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 A    HW: 8P0 907 279 A*
   Component: Bordnetz-SG 1.0 H27 0401
   Revision: 00000000    Serial number: 00000000119363
   Coding: 01884F00A2141000000000000000000000
   VCID: 3B7EC6E57ABB5597B2-806E
   Subsystem 1 - Part No: 8P2 955 119 C  Labels: 1TX-955-119.CLB
   Component: Wischer WWS Audi350 0180
   Coding: 16711696
Address 15: Airbags        Labels: 8P0-959-655-84.lbl
   Part No SW: 8P0 959 655 F    HW: 8P0 959 655 F
   Component: Airbag 8.4ED    H01 0130
   Coding: 0011602
   VCID: 458AA01D0C7F1367D4-8010
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 009 0030
   Coding: 0000012
   Shop #: WSC 06435 551 00000
   VCID: 3064E1C9A3FDA6CF17-8064
   Part No SW: 8P0 920 980 H    HW: 8P0 920 980 H
   Component: KOMBIINSTR. VDO H25 0080
   Revision: D05         Serial number: 2246CD05000107
   Coding: 0004403
   Shop #: WSC 00783 067 57207
   VCID: 3C7CC5F97FB552AFBB-8068
            007 - Short to Ground
                    Fault Status: 00000011
                    Reset counter: 178
                    Mileage: 237118 km
                    Date: 2019.11.27
                    Time: 00:01:33
            014 - Defective
                    Reset counter: 178
00003 - Control Module
            014 - Defective
                    Mileage: 150981 km
                    Date: 2013.01.21
                    Time: 14:58:48
   Part No SW: 1K0 907 530 B    HW: 1K0 907 951
   Component: Gateway         H08 0090
   Revision: 08          Serial number: 2400103721A350
   Coding: 3D0F0B42070101
   VCID: 264807919139F87FFD-8072
8 Faults Found:
01304 - Radio
                    Reset counter: 178
                    Mileage: 235903 km
                    Date: 2019.11.01
                    Time: 09:06:31
                    Fault Status: 00101011
                    Fault Frequency: 15
                    Reset counter: 208
                    Mileage: 236058 km
                    Date: 2019.11.06
                    Time: 17:00:10
                    Fault Frequency: 24
                    Reset counter: 218
                    Mileage: 237058 km
                    Date: 2019.11.27
                    Time: 06:50:49
                    Fault Frequency: 31
                    Reset counter: 218
                    Mileage: 237058 km
                    Date: 2019.11.27
                    Time: 06:50:49
                    Reset counter: 218
                    Mileage: 237058 km
                    Date: 2019.11.27
                    Time: 06:50:49
                    Fault Frequency: 17
                    Reset counter: 217
                    Mileage: 237058 km
01312 - Powertrain Data Bus
                    Fault Status: 00101110
                    Reset counter: 217
                    Mileage: 237058 km
                    Date: 2019.11.27
                    Time: 11:33:42
                    Reset counter: 217
                    Mileage: 237058 km
                    Date: 2019.11.27
                    Time: 11:35:14
   Revision: D05         Serial number: AUX7Z0C6FNT0DV
   Shop #: WSC 00762 210 91493
01176 - Key
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 A
   Component: Tuersteuerger.  H10 0010
   Coding: 0000048
   VCID: 3972DCED70876787A0-806C
Address 44: Steering Assist        Labels: 1Kx-909-143-GEN1.clb
   Part No: 1K1 909 143 L
   Component: EPS_ZFLS Kl.7       0402
00625 - Vehicle Speed Signal
                    Mileage: 7080 km
                    Temperature: 8.0°C
                    Voltage: 8.20 V
                    Voltage: 12.20 V
                    Mileage: 7040 km
                    Temperature: 9.0°C
                    Voltage: 12.40 V
                    Voltage: 12.20 V
00750 - Warning Lamp
                    Mileage: 7040 km
                    Temperature: 9.0°C
                    Voltage: 12.40 V
                    Voltage: 12.20 V
                    Mileage: 7040 km
                    Temperature: 9.0°C
                    Voltage: 12.40 V
                    Voltage: 12.10 V
00573 - Steering Torque Sensor (G269)
                    Mileage: 7080 km
                    Torque: 10.0 Nm
   Part No: 8P0 959 433
   Component:    KSG          H02 0040
   Coding: 188800186D288505485AC63000
   Shop #: WSC 00186 785 00200
   VCID: 79F21CED3007A787E0-802C
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
6 Faults Found:
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
00849 - S-contact at Ignition/Starter Switch (D)
01179 - Incorrect Key Programming
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH23 0100
   Revision: 00001       Serial number: 10000001041884
   VCID: 70E421C9637DE6CF57-8024
                    Reset counter: 218
                    Mileage: 237082 km
                    Date: 2063.15.31
                    Time: 31:63:63
                    Temperature: 4.0°C
                    Raw, Form. N/A: 000 000 000
                    Reset counter: 218
                    Mileage: 237082 km
                    Date: 2063.15.31
                    Time: 31:63:63
                    Temperature: 4.0°C
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 A
   Coding: 0000048
   VCID: 3A70C3E175816C9FA9-806E
Address 56: Radio
   Part No SW: 1K0 963 235 C    HW: 1K0 963 235 C
   Revision: 00600000    Serial number:
   VCID: 2B5EF6A58ADBC51722-807E
            014 - Defective
End-------------------------(Elapsed Time: 01:58)--------------------------
Stuartwhite1989
I have pulled the engine fuse box stripped down and found moisture and some green corrosion. Cleaned and soaked in wd40 seems to be ok at min
myounus
Northwest UK
C?ID=321059
Oh dear. Try and locate the source of the water leak and plug that too.
