Monday,02,December,2019,21:07:31:57077
-- Windows Based VAG/VAS Emulator Running on Windows XP x86
Version: 19.6.2.0
VIN: WAUZZZ8P84A056462 License Plate:
Mileage: 237110km-147333mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P84A056462 Mileage: 237110km-147333miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
03- Brakes -- Status: Malfunction 1010
15-Airbags -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 1010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L 0000SG 5334
Revision: 12345678 Serial number: AUX7Z0C6FNT0DV
Coding: 0000072
Shop #: 01286 386 08256
VCID: 27560A959633E177C6-8072
19781 - Power Supply Terminal 15
P3325 - 000 - Implausible - Intermittent
Torque: 0.0 Nm
Voltage: 12.84 V
Bin. Bits: 00000000
Bin. Bits: 0
(no units): 1.0
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Torque: 0.0 Nm
Voltage: 12.62 V
Bin. Bits: 00000000
Bin. Bits: 11100000
(no units): 0.0
16486 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low
RPM: 840 /min
Torque: 42.0 Nm
Voltage: 14.36 V
Bin. Bits: 00000111
Mass Air / Rev.: 850.0 mg/str
Mass Air / Rev.: 0.0 mg/str
17903 - Switch-Over Valve for Cooler (N345)
P1495 - 000 - Open or Short to Ground - Intermittent
Torque: 202.0 Nm
Voltage: 6.16 V
Bin. Bits: 00000000
17911 - Load Signal from Alternator Term. DF
P1503 - 000 - Implausible Signal
Torque: 0.0 Nm
Voltage: 11.93 V
Bin. Bits: 00000000
(no units): 1.0
Readiness: 0 1 0 0 1
Address 03: Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Coding: 0055942
Shop #: 06435 000 00000
VCID: 336EEEC552EB9DD76A-8066
013 - Check Memory - Intermittent
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH14 0180
Revision: 138254 Serial number: 8P0820043H
VCID: 3162E4CDA8F7AFC718-8064
Reset counter: 218
Voltage: 7.40 V
Fault Status: 00101001
Reset counter: 218
Temperature: -50.0°C
Voltage: 8.40 V
Load: 9.0 %
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 218
Reset counter: 178
Mileage: 223600 km
Date: 2017.11.11
Time: 03:54:00
Temperature: 18.5°C
01273 - Fresh Air Blower (V2)
Reset counter: 218
Mileage: 237118 km
Date: 2019.11.27
Time: 00:01:56
Temperature: 5.0°C
Speed: 325.0 km/h
(no units): 202.0
(no units): 32.0
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000000119363
Coding: 01884F00A2141000000000000000000000
Shop #: 00000 000 00000
VCID: 3B7EC6E57ABB5597B2-806E
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0011602
VCID: 458AA01D0C7F1367D4-8010
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 009 0030
Coding: 0000012
Shop #: 06435 551 00000
VCID: 3064E1C9A3FDA6CF17-8064
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
Component: KOMBIINSTR. VDO H25 0080
Revision: D05 Serial number: 2246CD05000107
Coding: 0004403
Shop #: 00783 067 57207
VCID: 3C7CC5F97FB552AFBB-8068
007 - Short to Ground
Fault Status: 00000011
Reset counter: 178
Mileage: 237118 km
Date: 2019.11.27
Time: 00:01:33
014 - Defective
Reset counter: 178
00003 - Control Module
014 - Defective
Mileage: 150981 km
Date: 2013.01.21
Time: 14:58:48
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103721A350
Coding: 3D0F0B42070101
VCID: 264807919139F87FFD-8072
8 Faults Found:
01304 - Radio
Reset counter: 178
Mileage: 235903 km
Date: 2019.11.01
Time: 09:06:31
Fault Status: 00101011
Fault Frequency: 15
Reset counter: 208
Mileage: 236058 km
Date: 2019.11.06
Time: 17:00:10
Fault Frequency: 24
Reset counter: 218
Mileage: 237058 km
Date: 2019.11.27
Time: 06:50:49
Fault Frequency: 31
Reset counter: 218
Mileage: 237058 km
Date: 2019.11.27
Time: 06:50:49
Reset counter: 218
Mileage: 237058 km
Date: 2019.11.27
Time: 06:50:49
Fault Frequency: 17
Reset counter: 217
Mileage: 237058 km
01312 - Powertrain Data Bus
Fault Status: 00101110
Reset counter: 217
Mileage: 237058 km
Date: 2019.11.27
Time: 11:33:42
01316 - Control Module
Reset counter: 217
Mileage: 237058 km
Date: 2019.11.27
Time: 11:35:14
Revision: D05 Serial number: AUX7Z0C6FNT0DV
Shop #: 00762 210 91493
01176 - Key
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 3972DCED70876787A0-806C
Address 44: Steering Assist Labels: 1Kx-909-143-GEN1.clb
Part No: 1K1 909 143 L
Component: EPS_ZFLS Kl.7 0402
00625 - Vehicle Speed Signal
004 - No Signal/Communication - Intermittent - MIL ON
Mileage: 7080 km
Temperature: 8.0°C
Voltage: 8.20 V
Voltage: 12.20 V
Mileage: 7040 km
Temperature: 9.0°C
Voltage: 12.40 V
Voltage: 12.20 V
00750 - Warning Lamp
Mileage: 7040 km
Temperature: 9.0°C
Voltage: 12.40 V
Voltage: 12.20 V
Mileage: 7040 km
Temperature: 9.0°C
Voltage: 12.40 V
Voltage: 12.10 V
00573 - Steering Torque Sensor (G269)
Mileage: 7080 km
Torque: 10.0 Nm
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 188800186D288505485AC63000
Shop #: 00186 785 00200
VCID: 79F21CED3007A787E0-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
00323 - Vehicle Inclination Sensor (G384)
00849 - S-contact at Ignition/Starter Switch (D)
01179 - Incorrect Key Programming
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001041884
VCID: 70E421C9637DE6CF57-8024
Reset counter: 218
Mileage: 237082 km
Date: 2063.15.31
Time: 31:63:63
Temperature: 4.0°C
Raw, Form. N/A: 000 000 000
Reset counter: 218
Mileage: 237082 km
Date: 2063.15.31
Time: 31:63:63
Temperature: 4.0°C
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
VCID: 3A70C3E175816C9FA9-806E
Address 56: Radio
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: -Element 0404
Revision: 00600000 Serial number:
VCID: 2B5EF6A58ADBC51722-807E
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 01:58)--------------------------
