Need help! 04 Audi A8l won't start
MrBanks
Connecticut, USA
C?ID=359777
Here's a short description of what happened, bought the car last year, 1 owner, 82,000 miles and it was well maintained (owner bought same car but 2017) anyways everything was working fine and then I parked the car in my garage over the winter so this year around March I decided to turn the car on but the battery was dead, so I bought a new one but no from the dealership, it's a agm and it's suppose to be a direct fit. So I ran my Ross-tech tool to register the battery, I added a number in the serial number to trick the car into to think that I put a new battery and it worked the battery level shows 100%. I can turn the switch on and everything lights up but the car won't start or crank at all. Also windows go down but won't go up. I checked all the fuses and they're good.
Sunday,10,November,2019,14:04:14:19032
VIN: WAUML44E84N017656   License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
          47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E84N017656   Mileage: 134170km-83369miles
Address 01: Engine
   Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0110
   Revision: 00000001    Serial number:        0027415
   Shop #: WSC 02313 785 00200
   VCID: 2411EE5FE2DF5AA78E1-8070
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 17.0°C
                    T.B. Angle: 60.0°
                    Voltage: 10.08 V
18005 - Powertrain Databus
            P1597 - 000 - Missing Message from Level Control System (J197) - Intermittent
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 17.0°C
                    T.B. Angle: 60.0°
                    Voltage: 10.08 V
18289 - Powertrain Data Bus: Missing Message
            P1881 - 000 - Acceleration Request
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 17.0°C
                    T.B. Angle: 60.0°
                    Voltage: 10.08 V
16944 - System Voltage
            P0560 - 000 - Malfunction - Intermittent
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 17.0°C
                    T.B. Angle: 60.0°
                    Voltage: 10.08 V
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 N
   Component: ESP 5.7 allrad  H44 0500
   Coding: 0007597
   Shop #: WSC 02313 000 00000
   VCID: 221DE847F8CB5497FCD-8076
02083 - Message for Delay Request
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 A
   Component:     FBS AUDID3  H03 0140
   Revision: 01403903    Serial number: AUX3Z0CD531291
   Coding: 0263168
   Shop #: WSC 02311 785 00200
   VCID: 58E98AAFEE17CE47D29-800C
                    Fault Frequency: 0
                    Reset counter: 166
                    Mileage: 134176 km
                    Date: 2003.10.08
                    Time: 00:41:22
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H07  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 3940448
   Shop #: WSC 00000 785 00200
   VCID: 2313ED43E7D15D9FF7B-8076
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 729 B    HW: 4E0 035 729
   Component: Interfacebox    H43 0150
   Revision: 00000000    Serial number: 346L/037508758
   Coding: 0000103
   VCID: 270BF95393E9B1BFAB3-8072
   Subsystem 1 - Part No: 4E0 910 609 A
   Component: Bedienteil MMI  H42 0020
   Subsystem 2 - Serial number: 301DR047536949
   Subsystem 3 - Serial number: 7407.04.040000000000010085ÿ
   Subsystem 4 - Serial number: 010085ÿ
                    Reset counter: 206
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 00:15:27
                    Bin. Bits: 00000000
                    Bin. Bits:  0100000
                    Bin. Bits:      000
   Part No SW: 4E0 910 043     HW: 4E0 820 043 A
   Component: KLIMAAUTOMAT    016 0240
   Revision: 00000022    Serial number: 00000000033022
   Coding: 1085697
   VCID: 5AED90A7901BDC57E4D-800E
            014 - Defective
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
   Component: ILM Fahrer      H11 0100
   Coding: 0111113
   VCID: 2A0D006780FB8CD7B4D-807E
   Subsystem 1 - Part No: 4E1 910 113 B
   Component: Wischer WWS D3  H30 0360
   Coding: 00000036
   Shop #: WSC 02313
                    Reset counter: 206
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 00:00:26
01308 - Control Module for Roof Electronics (J528)
                    Reset counter: 206
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 00:05:15
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBE7173786
   VCID: 1B63D5A3DFA1655F3FB-804E
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Coding: 0012241
   VCID: 6597B35BA96563AF59F-8030
   Component: Lenkradmodul    H04 0080
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 950 B
   Component: KOMBIINSTR. VDO H44 0090
   Revision: D15         Serial number: AUDID3CD006652
   Coding: 0016233
   Shop #: WSC 08310 444 92086
   VCID: 5CE196BF9A2F2267F61-8008
Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
   Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
   Component: Gateway         H07 0030
   Revision: 07          Serial number: 0200503C011191
   Coding: FCFE7BDD1B2304
   VCID: 2615F45794E3A8B7905-8072
                    Reset counter: 166
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 00:31:37
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0263168
   XXXXXXXXXXX ELV                 XXXX
                    Fault Frequency: 0
                    Reset counter: 166
                    Mileage: 134176 km
                    Date: 2003.10.08
                    Time: 00:41:22
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   VCID: 2517F35BE9E5A3AF99F-8070
8 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
                    Fault Frequency: 162
                    Reset counter: 199
                    Mileage: 126926 km
                    Date: 2004.09.17
                    Time: 14:28:12
                    Fault Status: 11100100
                    Reset counter: 166
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 00:09:43
01398 - Signal from Central Locking: Doors Open
                    Reset counter: 206
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 00:09:28
                    Fault Status: 11101000
                    Reset counter: 166
                    Mileage: 133022 km
                    Date: 2003.10.08
                    Time: 00:01:32
00774 - Level Control System Sensor; Rear Left (G76)
                    Fault Status: 11101100
                    Reset counter: 166
00775 - Level Control System Sensor; Rear Right (G77)
                    Reset counter: 166
                    Reset counter: 166
01769 - Sensor for Vehicle Leveling; Front Right (G289)
                    Reset counter: 166
   Component: Sitzmemory FS  H07  0060
   Coding: 4071522
   Part No SW: 4E0 910 887 A    HW: 4E0 919 887 C
   Component: MNS US          H42 0150
   Revision: 00000000    Serial number: 355AM047514483
   VCID: 2B0305638F0195DF4FB-807E
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H01 0090
   Serial number: 00000333000055
   Coding: 0003973
   VCID: 1D67DBBBC1B56B6FC1F-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 801
   Component: Türsteuer.FS BRM005 0110
   Coding: 0028196
   VCID: 5EE59CB78C333077985-800A
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H03 0030
   Revision: 00300003    Serial number:  W040312160082
   Coding: 0064542
   Subsystem 1 - Part No: 4E0 907 719
   Component: Neigungssensor  H02 0020
6 Faults Found:
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 166
                    Mileage: 89639 km
                    Date: 2004.01.09
                    Time: 13:39:36
                    Fault Frequency: 51
                    Reset counter: 166
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 00:05:26
01501 - Bulb for Blinkers; Rear Left (M6)
                    Fault Frequency: 177
                    Reset counter: 166
02198 - Bulb for Tail Light 2; Left (M49)
                    Fault Frequency: 202
                    Reset counter: 166
01134 - Alarm Horn (H12)
                    Fault Frequency: 11
                    Reset counter: 166
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 22:12:32
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 118
                    Reset counter: 166
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 B    HW: 4E0 035 223 B
   Component: DSP-High D3/AUX H13 0200
   Revision: Dev_D01     Serial number: 00000000678358
   Coding: 0000016
   VCID: 1C61D6BFDAAF6267361-8048
00003 - Control Module
                    Fault Frequency: 0
                    Reset counter: 0
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H08 0020
   Revision:             Serial number: 00000000030715
   Coding: 0010111
   VCID: 1E65DCB7CCB37077D85-804A
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H02 0030
   Subsystem 2 - Serial number: VK4978T0A72E
                    Reset counter: 166
                    Mileage: 134176 km
                    Date: 2003.10.08
                    Time: 00:31:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 802
   Component: Türsteuer.BF BRM005 0110
   Coding: 0028196
02111 - Motor for Window Regulator
                    Reset counter: 166
                    Mileage: 134176 km
                    Date: 2003.10.08
                    Time: 00:16:12
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000532
                    Fault Frequency: 90
                    Reset counter: 166
                    Mileage: 134176 km
                    Date: 2003.10.08
                    Time: 00:02:17
                    Voltage: 10.25 V
                    Count: 241
02596 - Rear Brake Pads Worn
                    Fault Status: 01111000
                    Reset counter: 166
                    Voltage: 11.18 V
                    Count: 61
                    Reset counter: 206
                    Voltage: 0.00 V
                    Count: 188
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   VCID: 629DA847B84B1497BCD-8036
                    Reset counter: 0
                    Mileage: 134184 km
                    Date: 2003.10.08
                    Time: 00:58:34
01310 - Level Control System Control Module (J197)
                    Fault Frequency: 0
                    Reset counter: 206
                    Mileage: 134184 km
                    Date: 2003.10.08
                    Time: 00:58:35
02233 - Left Headlight Power Output Stage (J667)
                    Fault Frequency: 0
                    Reset counter: 40
                    Mileage: 134184 km
                    Date: 2003.10.08
                    Time: 01:01:25
                    Fault Frequency: 0
                    Reset counter: 40
                    Mileage: 134184 km
                    Date: 2003.10.08
                    Time: 01:01:27
00070 - Starting Battery Voltage
                    Fault Frequency: 0
                    Reset counter: 40
                    Mileage: 134184 km
                    Date: 2003.10.08
                    Time: 01:01:42
   Part No SW: 4E0 910 541 B    HW: 4E0 035 541
   Component: TUNER EU/US/RDW H41 0220
   Revision: 00000000    Serial number: 304AG047557161
   VCID: 1F1BE1B3CBB9797FD33-804A
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 B    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0240
   Revision: 00000000    Serial number: 00000005832723
   Shop #: WSC 01405 444 54257
   Subsystem 1 - Part No: 000 915 105 DL
   Component: von VA0  310314E04G
   Coding: 303030393135313035444C56413033313033313445303447
                    Reset counter: 166
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 00:40:03
02275 - Quiescent Current Stage 4
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 00:40:03
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 801 A
   Component: Türsteuer.HL BRM005 0110
   Coding: 0028196
   VCID: 5DE79BBB81352B6F81F-8008
                    Reset counter: 166
                    Mileage: 134176 km
                    Date: 2003.10.08
                    Time: 00:16:48
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01 0210
   Coding: 0212127
   VCID: 5F9BA1B38B39397F933-800A
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 166
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 00:33:06
                    Voltage: 11.30 V
                    (no units): 27.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01477 - System Switched Off
                    Reset counter: 206
                    Mileage: 134178 km
                    Date: 2003.10.08
                    Time: 00:16:29
                    Temperature: 8.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM005 0110
   Coding: 0028196
Address 75: Telematics        Labels: None
   Part No SW: 4E0 910 616     HW: 4E0 035 616 A
   Component: Telematik USA1      0070
   Revision: 00000004    Serial number: 0000ATD3007465
   Coding: 0000005
   VCID: 6099A24FB6570687AA9-5160
01531 - Emergency Battery
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H11 0010
   Revision: --.--.--    Serial number: 00000400900235
   Coding: 0001208
   VCID: 211FE74BFDCD4F8FE57-8074
End----------(Elapsed Time: 02:07, VBatt start/end: 12.4V/12.4V)-----------
004 - No Signal/Communication[/QUOTE]
Vehicle Identification No.WAUML44E84N017656
ModelAudi A8L qu. 4.2
A8Q
Date of production20.01.2004
Model year2004
Sales type4E851L
Engine CodeBFM
Transmission CodeGQF
Emission standard0GMEmission standard LEV 1
Hello OP and welcome to the VCDS forum.
Engine control module 0x01 is offline........
Did you check terminal outputs at engine control module directly using WD in RTFB yet?
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
PART NUMBERDESCRIPTIONREMARKMODEL
4E0 910 560 A https://www.ebay.com/itm/331518281721Control unit for petrol engine
BFM
MrBanks
Connecticut, USA
C?ID=359777
A8Q
Model year2004
Sales type4E851L
Engine CodeBFM
BFM
[/QUOTE]
Thanks for the response and I didn't RTFB cause I didn't had access nor didn't I know how to find a WD for these type of cars lol. I'm new to euro cars and besides you can get any WD book in any auto part store for any car other than euro cars. Anyways let's get back to business, my friend helped me out and yes the ECM is fried so my question is, do I need to send you my ECM first or make the ebay purchase first from the link you sent me?
Also I didn't check terminal outputs at engine control module
:D
Thanks for the response and I didn't RTFB cause I didn't had access nor didn't I know how to find a WD for these type of cars lol. I'm new to euro cars and besides you can get any WD book in any auto part store for any car other than euro cars. Anyways let's get back to business, my friend helped me out and yes the ECM is fried so my question is, do I need to send you my ECM first or make the ebay purchase first from the link you sent me?​
How do you know it's fried if you did not test stuff?
I'd rather you diagnose it and tell me how you know it's fried please?
Pictures if a visual was determined?
You can use link or contact form in my signature for direct secure purchases.
Agreed -- it would be entirely premature to purchase a replacement ECU without doing more considerably more testing.
Oh... And this is just one of the reasons why we respect Jack and put up with some of his antics.
He has the exact ECU that the OP might need, but he doesn't want the OP to throw money at the problem without a reasonable level of confidence that doing so will actually improve his situation.
Thank you Uwe....
Yup..... I may joke around about stuff, sometimes almost intolerable my stupid sarcasm, however, I don't mess around when it comes to diagnosis!
People don't understand me, it's out of love for all people I joke or try to make you see my or another approach angle.
If you ask a question again I already clearly answered like in the CAT filing his nails to scratch me thread and you try to dismiss or ask for a magic answers to try and circumvent a test or self verifiable information path and try to trade off my life experience instead, you will be in for a bad time.
You have me here for absolutely free & for VCDS related major systems or even in some cases comprehensive guidance above the actual RTFB on mechanical or inadequate explanation of how something functions.
That said I have an expectation that you, especially if a shop or industry tech have done their job too & if you have not I will break your balls so you never forget and actually learn something.
It is always with this intent I roll.
Now if you are seeking to circumvent a safety or SMOG system or what I deem an unreasonable retrofit hiding in the spirit of aforementioned, expect my apprehension or reveling in your failure!
MrBanks
Connecticut, USA
C?ID=359777
Thank you Uwe....
I apologized, and I did saw your sarcasm lol I just didn't reply with the right response. I really appreciated the help and I went ahead and bought the erWin and tomorrow I'm going to be testing everything out and I'll keep you post it.
Did you measure for terminal 15, 30 and 31 yet at ecu plug directly?
Hey what's this crap below?
3 : +12V ( term.15 )
1 : GND ( term. 31 )
2 : GND ( term. 31 )
21 : +12V ( term. 30 )
43 : K Line
60 : CAN High
58 : CAN Low
MrBanks
Connecticut, USA
C?ID=359777
43 : K Line
60 : CAN High
58 : CAN Low
I didn't cause my friend checked my scan and said my ecu was fried and I know, I know that was a stupid move from my part cause I should've checked everything before coming to a conclusion but I learned my lesson and ready to learn :)
Tomorrow I will check everything step by step...
MrBanks
Connecticut, USA
C?ID=359777
43 : K Line
60 : CAN High
58 : CAN Low
Hi Mr Jack. I traced everything regarding my problem and found the ECU to be fried. I opened it and took a picture. Now you might ask what cause it, so here's a short description of what i think happened, I installed an aftermarket air ride that i had lying around from my previous car after my factory air suspension on the A8L went bad. I put a remote wire with an "add-a-fuse" into fuse#17 Radiator Fan Electronics (Fuse Location, Instrument Panel Right) but I think I put it the wrong way causing a short.
Q8F0dSs
Show the collective in WD and a picture of visual damage in ECU could you please?
That was fast, so now the WD and did you trace back the pin with DVOM to verify and qualify yet the assumption until sure?
PREPARE TO QUALIFY YOUR INDUCED FOD!
You can commence a purchase if you like and send in core for data transfer & so unit is plug and play.
Let's verify why for sure this happened and not speculate okay?
MrBanks
Connecticut, USA
C?ID=359777
Ok I will double check to make sure that's the problem and I'll get back to you tomorrow. And once again thank you very much for your help
I can back trace it & too give you insight as to what happened when unit is in my custody, however, since you have the car it would be wise to verify.
I'm thinking not related to air ride or fuse 17 to do that, however, I will have a look at WD myself when in front of a RTFB.
Working on breadboard now on other project, so tied up in test phase and infrared camera observation while overwhelming drivers to see what is sporadic.
Those burned up diode circuits correlate to pins 26 and 2.
Now PIN T81/2 we know from aforementioned is GROUND!
PIN T81/26 is OP?
See I know what PIN 26 goes to, however, we need to see if you know?
HINT ( GXX? ) HINT :p
Additionally PIN 26 in illustration below is 62 and an inverse typo, did you know that?
Now what circuits would draw such a large current and not pop a fuse in an ME7.1.1 platform when observing the WD and are using ground to be completed through the controller?
MrBanks
Connecticut, USA
C?ID=359777
PIN T81/26 is OP?
T81/2=GROUND
T81/26=G70 (Mass Air Flow (MAF) Sensor). It draws large current or am i wrong? sorry I'm just learning lol
T40/66=V7 (Coolant Fan)
T40/104=V177 (Coolant Fan 2)
Also i just found out that the MAF sensor plug was unplug if that counts.
