Imran50k
New Member
evening, any help would be appreciated,
I have a Golf 2010 1.6 TDI, engine light came on fault codes as follows
i thought i had a prob with injector 2 because that is the only injector with 0 volts, but what i dont understand is why i am not getting any movement on injection amount deviation across all 4 cylinders
any help would be much appreciated also very new to using VCDS
thanks
Address 01: Engine Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 997 558 A HW: 03L 906 023 A
Component and/or Version: R4 1.6l TDI H23 9980
Software Coding: 00254014032500080000
Work Shop Code: WSC 00028 028 00024
ASAM Dataset: EV_ECM16TDI02103L997558A 003002 (VW36)
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 3B75021AB29D3B97B2-806E
9839 - Injector: Cylinder 3 (N32)
P0203 00 [237] - Circuit Malfunction
Mileage: 157714 km
Date: 2020.04.12
Time: 17:49:02
Engine speed: 820.00 /min
Normed load value: 47.5 %
Coolant temperature: 29 °C
Intake air temperature: 12 °C
Voltage terminal 30: 14.231 V
Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 0
Injector valve 2: capacity-CAPA_INJ_MAIN[1]: 31.0816 µF
Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1]: 1457.6 µAs
Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1]: 34.174 mJ
Supply voltage of analog output 1-VCC_1: 5.00 V
Supply voltage of analog output 2-VCC_2: 5.00 V
Injection valve 2: voltage-V_INJ_MAIN[1]: 46.89 V
Address 01: Engine (03L 997 558 A)
19:57:03
IDE00365-ENG99400 Injection amount deviation cylinder 1-FAC_CYL_BAL1 0.0002 mg/stroke
IDE00366-ENG101187 Injection amount deviation cylinder 2-FAC_CYL_BAL2 0.0002 mg/stroke
IDE00367-ENG101684 Injection amount deviation cylinder 3-FAC_CYL_BAL3 0.0002 mg/stroke
IDE00368-ENG103465 Injection amount deviation cylinder 4-FAC_CYL_BAL4 0.0002 mg/stroke
IDE03893-ENG101196 Injection valve 1: voltage-V_INJ_MAIN[0] 141.48 V
IDE03894-ENG104143 Injection valve 2: voltage-V_INJ_MAIN[1] 0.00 V
IDE03895-ENG101536 Injection valve 3: voltage-V_INJ_MAIN[2] 138.83 V
IDE03896-ENG102925 Injection valve 4: voltage-V_INJ_MAIN[3] 142.95 V
thanks
