Climatronic Control Module replacement 2013 Audi Q7 TDI Prestige
jmokeefe
C?ID=274124
I have installed a new Climatronic Control Module (J255) in my Q7. I ran the Basic Settings but it still will not allow any of the functions work. Is there a security access code necessary?
MartinsX
Riga, Latvia
C?ID=268515
Autoscan, please?
jmokeefe
C?ID=274124
Wednesday,20,November,2019,18:18:20:60779
VCDS Version: 19.6.2.0 (x64)
VIN: WA1VMAFE4DD003074   License Plate:
Mileage: 299890km-186343mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
          55 56 5F 62 69 6C 6D 6F 72
VIN: WA1VMAFE4DD003074   Mileage: 299890km-186343miles
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401 A    HW: 4L0 907 401 E
   Component: 3.0TDI FSA    H18 0012
   Revision: 54H18---    Serial number:
   Coding: 2A2A4012253600050000
   Shop #: WSC 44723 002 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401A 001013
   ROD: EV_ECM30TDI0114L2910401A.rod
   VCID: 224B98B035229A5F91-8076
Readiness: 0 0 0 1 1
   Part No SW: 0C8 927 750 AQ    HW: 0C8 927 750 AQ
   Component: AL1000 AISIN  001 3399
   Coding: 001378
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 7BF585D4F2080B97F2-802E
Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Component: ESP ALLRAD MK25E1   0020
   Revision: 00H02001
   Coding: 0099441
   Shop #: WSC 31414 790 00001
   VCID: 34676EE857D604EF73-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0200
   Revision: 00H08000    Serial number: 10603702016240
   Coding: 0000135
   VCID: 254183ACEC0C6D67F4-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H04 0020
   Subsystem 2 - Part No: 4F0 910 335 B
   Component: FBSAUDIC6 KSG   H03 0020
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0053
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AJ
   Component: KLIMA 4 ZONEN H15 0070
   Revision: 00---026    Serial number: 00000030251507
   Coding: 00000001
   VCID: 254183AC2C0C6D67F4-8070
                    Reset counter: 156
                    Mileage: 299899 km
                    Date: 2019.11.20
                    Time: 19:14:28
                    Bin. Bits:    01111
01487 - System Function Test
            001 - Upper Limit Exceeded
                    Fault Status: 01100001
                    Reset counter: 156
                    Mileage: 299892 km
                    Date: 2019.11.20
                    Time: 11:43:51
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 0
                    Date: 2004.12.21
                    Time: 12:00:00
                    Reset counter: 156
                    Mileage: 299892 km
                    Date: 2019.11.20
                    Time: 14:56:16
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0139123
   VCID: 6ED3BC80797A6E3F45-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55901218600142
   Coding: 25011E
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 34676EE89FD604EF73-8060
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD0A53F/
   Coding: 0014131
   VCID: 2B5575948AE85B1722-807E
   Subsystem 1 - Part No: 4L0 959 339 C
   Component: BF-Gewichtsens. H05 0040
   Subsystem 2 - Serial number: 6332QSME181C3E78T
   Subsystem 3 - Serial number: 6342QSME181C21427
   Subsystem 4 - Serial number: 6352QSME7F1A1472O
   Subsystem 5 - Serial number: 6362QSME181C0842E
   Subsystem 6 - Serial number: 63734SME2913487A2
   Subsystem 7 - Serial number: 63834SME0E150E665
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
   Component: J0527               0830
   Revision: 00H08000    Serial number: 90026121930043
   Coding: 0012242
   VCID: 285F8A989B1E700FCF-807C
   Component: E0221           H03 0030
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 985 Q    HW: 4L0 920 985 Q
   Component: KOMBIINSTR.   H35 0316
   Revision: 00000000    Serial number: NGE526J7D
   Coding: 8BD664040900CF05020205
   VCID: 428B3830DD62BA5FF1-8016
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB700037    Serial number: 3700M12705006A
   Coding: 00C303
   VCID: 3F8D31C4AE90D7B79E-806A
   Subsystem 1 - Part No SW: 8K0 915 181 D    HW: 8K0 915 181 D
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790770585
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Component: KLIMABETAETIGUNGH06 0060
   Revision: 00---010    Serial number: 00000030251613
   Coding: 0000006
   VCID: 68DFCA985B9EB00F0F-803C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 156
                    Mileage: 299899 km
                    Date: 2019.11.20
                    Time: 19:14:33
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000033124566
   Coding: 00581B00000011110000
   VCID: 326B68F06DC20ADF61-8066
Address 3C: Lane Change        Labels: None
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E537C80B9FA2E3F05-807A
   Subsystem 1 - Part No: 4L0 910 568 C
   Component: J0770_SWA_Slave_H02 0050
   Subsystem 2 - Serial number: 6PZ 009 014-30
   Subsystem 3 - Serial number: 5F25.06.1200H020003C910239ÿ
   Subsystem 4 - Serial number: 910239ÿ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000034145418
   Coding: 011F57205E40440004
   VCID: 489F2A18FB5E900F2F-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01790062700000
   Coding: 3569949
   VCID: 387F5AD84BBEE08F5F-806C
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004000    Serial number: 00000000023382
   Coding: 030000
   VCID: 29598F9C40144907D0-807C
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005190190320
   Coding: 0758477
   VCID: 23459DB4E23893579A-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000114757
   Coding: 0012001
   VCID: 5EB3EC4089DAFEBFF5-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000034531975
   VCID: 479D2924F6409F7726-8012
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Component: AFS 1           H01 0010
   Coding: 0000031
   Component: AFS-Modul links H07 0004
   Subsystem 2 - Part No: 7L6 941 329 A
   Component: AFS-Modul rechtsH07 0004
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156G%0C7617518
   Coding: 020007010000000000
   VCID: 214997BC3824814788-8074
   Part No SW: 4L2 035 746 A    HW: 4L2 035 746 A
   Component: H-BNT-NA      H43 0552
   Revision: --------    Serial number: 224H-0C7502945
   Coding: 180200060004E3EF510023456F632003140000000100000000
   VCID: 2C5776884FE65C2F2B-8078
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130GO0C2504239
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002030170
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000034585337
   Coding: 010E57204040230004
   VCID: 46832420F14A867FDD-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000179753559
   Coding: 0200000000000000
   VCID: 316967FC68C431C718-8064
   Part No SW: 4L0 910 441 B    HW: 4L0 907 441 B
   Component: J772__Rearview      0030
   Revision: --H07---    Serial number: 525PA8-J2740V9
   Coding: 1021201
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H57 0500
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7B6884F669C2F6B-8038
   Subsystem 2 - Serial number: .
ó
   Subsystem 3 - Serial number: RD20.07.12--H57001002G0355ÿ
   Subsystem 4 - Serial number: 2G0355ÿ
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 129056608-----
   Coding: 0003595
   VCID: 264384A0910A667FFD-8072
   Component: J_245_EE16_SKB10H12 0220
   Subsystem 2 - Part No: 4L0 910 591 A
   Component: J_394_EE16_SKB10H12 0220
   Subsystem 3 - Part No: 4L0 910 591 A
   Component: J_392_EE16_SKB10H12 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000034585319
End-------------------------(Elapsed Time: 03:43)--------------------------
rhinopower
C?ID=58979
Needs matching to the car online with Odis. Need to see a main dealer or other specialist
AIB Wolfgang
Hello
Coding should be changed from 00000001 to 00270518
262144 Bedienungs- und Anzeigeeinheit hinten -E265 mit Ansteuerung der beheizbaren Sitze hinten
8192 Heckscheibenrollo verbaut
128 Heißland
32 USA
16 Diesel
4+2 6 Zylinder Motor
But anyway there is 02084 - Component Protection stored, only your dealer can delete this online with ODIS
jmokeefe
C?ID=274124
Thanks, Wolfgang. I am curious about the coding you suggest. The previous module (same part number) was coded 0304A06. Thoughts on why it would have been different?
Jim
AIB Wolfgang
Hello
Sorry, but didn't find any coding with 0304A06 .
Only numbers are used in this modules for coding:thumbs:
NEtech
C?ID=56995
No it is long coding in his Autoscan, see coding in OP Autoscan: 00000001
I think OP, wrote wrong coding, maybe is should have been something like this: 0304A006 or 0304A036
Jef
HQ
I suspect it would be coded to 0304A036. But soft coding is the least of his worries for now...
That needs to go to the Audi dealer to sort that out. I'm guessing it only works on defrost. Once the 02095 code is sorted out, the soft coding can be quickly performed and basic settings taken care of.
jmokeefe
C?ID=274124
I mistype. Coding of previous module was 0304A036
Golftwincharged
Guyana
C?ID=320847
Dealer online only, I've had this problem recently, where the component protection was active, and the off button was constantly blinking .
jmokeefe
C?ID=274124
Is it typical that a new control unit would come with the Component Protection on it?
My understanding is that even brand-new modules need to be married to the CP constellation in the car.
That's not "theft prevention", but "dealer profit protection". :(
