Golf 7 E-Brake / Auto hold Problems
matrixbike
C?ID=257276 (NRRT)
Hi there, I am into a little mind twisting problem, I had before a VW Golf 7 from 2015 and now I own a VW Golf 7 from 2013. Both of these have the same type of brake hand brake , or at least that is what I tend to believe.
The newer one I could deactivate the buckle alarm and go without any problem to use it normal, it will have the autohold function active , and it will activate the stationary brake whenever I open the driver door
On the other hand, this older one even if I deactivated the buckle alarm is won´t sleep the brake until I couple the buckle or I release the brake manually , when I don´t wear the safety belt the autohold function is not active, and the same goes for the driver door opening when I am into the manual mode, it won´t engage the stationary brake when I leave the car if I don´t activate it for my self.
It is frustrating as hell knowing that it is possible and I have to use the electronic brake like a regular hand brake . Today I came back from the VW Dealer here in Risskov Denmark , where they performed a "action" software update on the e-brake and it performs exactly the same as before.......
So my question is: has anyone encountered this problem before or is just me by being spoiled of having a newer version of the Golf and now I get stuck with this dumb one here ? Can it be done something about it ?
I have tried to deactivate buckle scan into the ABS/brake section but it won´t let me perform the action.......
Suggestions ?
Do you have scans from both cars so people can see what differences there are?
matrixbike
C?ID=257276 (NRRT)
please look on my other thread with the gateway upgrade I have posted both scans there, unfortunate I am not on my laptop now here
matrixbike
C?ID=257276 (NRRT)
found it here :
Saturday,09,November,2019,19:15:15:52660
VCDS Version: 19.6.0.6 (x64)
VIN: WVWZZZAUZEP517507   License Plate: BP38254
Mileage: 109678km-68150mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F 69
VIN: WVWZZZAUZEP517507   Mileage: 109678km-68150miles
Address 01: Engine (J623-CJZA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 H    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 7701
   Revision: WAH08---
   Coding: 01190012232415082000
   Shop #: WSC 47234 000 1048576
   ASAM Dataset: EV_ECM12TFS01104E906016H 001008
   ROD: EV_ECM12TFS01104E906016H.rod
   VCID: 275A5FAF5E20A077F4-8072
Readiness: 1110 0001
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 62603000000A63
   Coding: 04FA6AA124212973037C060041CA2520562494C06082A4F300200068C002
   VCID: 071A3F2FBEE08077D4-8052
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 02020004200100011005000000101000
   Shop #: WSC 00028 028 00024
   VCID: 66C412AB99AA797F0F-8032
   Part No SW: 5Q0 937 086 L    HW: 5Q0 937 086 L
   Component: BCM PQ37BOSCH 020 0078
   Revision: --------    Serial number: 86582808130883
   Coding: 00000846C24100DB4BE44000001C07081000000000000000000000000000
   Shop #: WSC 00028 028 00214
   ASAM Dataset: EV_BodyContrModul1UDSBosc 011005
   ROD: EV_BCMBOSCH_011.rod
   VCID: 4382EB3FCA586C57C8-8016
   Component: WWS    130804  042 0551
   Serial number:         130813143338
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Serial number: 20468359
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39291604001142
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   VCID: 3C7090C3B7A613AF89-8068
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0026C7
   Shop #: WSC 00028 028 00055
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F0AA7CFE630C8B7EC-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169667B27081370712
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169668B26081350559
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 408 13
   Serial number: 357670000006D5149D0-
   Subsystem 4 - Part No SW: -----------    HW: 480 001 408 13
   Serial number: 35867000000263A81D0T
   Subsystem 5 - Part No SW: -----------    HW: 480 402 408 13
   Serial number: 3516502C310EDE440135
   Subsystem 6 - Part No SW: -----------    HW: 480 402 408 13
   Serial number: 3526502C510EDE45736L
   Subsystem 7 - Part No SW: -----------    HW: 480 401 908 13
   Serial number: 3556502AD10EDE43E03T
   Part No SW: 5Q0 953 521 EQ    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0085
   Revision: FF026026    Serial number: 20130813400222
   Coding: 1604
   ASAM Dataset: EV_SMLSVALEOMQB 001011
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 0506352784EC9267A6-8050
   Part No SW: 5G0 920 851     HW: 5G0 920 851
   Component: KOMBI         152 2210
   Coding: 07A402002300000800080800040000
   VCID: 65C615A764AC726706-8030
   Part No SW: 5Q0 907 530 K    HW: 5Q0 907 530 K
   Component: GW MQB Low    210 2147
   Revision: --------    Serial number: 26081310800536
   Coding: 030000042B086400EF00024C080E00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 009011
   ROD: EV_GatewConti_009.rod
   VCID: 397E89D7B894268792-806C
   Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Serial number: 3131701103
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Component: TSG FS        007 0006
   Serial number: 0000071331467
   Coding: 003003208000028000001000
   VCID: 55A6256734CCE2E796-8000
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002475858
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 01
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D769DC7ACBC1AA7BE-8068
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Component: TSG BFS       007 0006
   Serial number: 0000070415970
   Coding: 003001208000028000801000
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002488383
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT1.clb
   Part No SW: 5G0 035 867     HW: 5G0 035 867
   Component: MU-E--ER      170 0146
   Revision: --------    Serial number: 000086237903000
   Coding: 02730200FF0000004011000100000000000000040000010000
   ASAM Dataset: EV_MUEnt4CCONT 004052
   ROD: EV_MUEnt4CCONT.rod
   VCID: 69DE199788B4560722-803C
   Part No SW: 5Q0 907 383     HW: 5Q0 907 383
   Component: Anhaenger     H11 0030
   Revision: 6A001003    Serial number: 00000194335544
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctDemouHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 74E078E3DF769BEF81-8020
matrixbike
C?ID=257276 (NRRT)
Here is the old car that was ok :
VIN: WVWZZZAUZFP632382   Mileage: 49580km-30807miles
Address 01: Engine (J623-CRKB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FD    HW: 04L 907 309 E
   Component: R4 1,6L EDC   H22 8122
   Revision: 86H22---
   Coding: 01190012032415096000
   Shop #: WSC 00028 028 00077
   ASAM Dataset: EV_ECM16TDI01104L906021FD 002008
   ROD: EV_ECM16TDI01104L906021FD.rod
   VCID: 6CD060838746432F59-8038
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 61175000009676
   Coding: 04FA62A11423096E077A060841C52520462890E06082A4F300400078C002
   VCID: 7EF45ACBE13AC1BFE7-802A
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 02020104202100011005000000101000
   Shop #: WSC 00028 028 00067
   VCID: 6ADC669B8DB25D1F2B-803E
   Part No SW: 5Q0 937 086 AE    HW: 5Q0 937 086 AE
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86583004151316
   Coding: 00020846C24100DB4BE44000001C07081000000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DF65DC7EC3CDAA7FE-8028
   Component: WWS    150420  043 0551
   Serial number:         150424174123
   Serial number: 21072667
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
   Revision: --------    Serial number: 39391603503911
   Coding: 0031051141
   Shop #: WSC 00028 028 00066
   Component: AirbagVW20    014 0385
   Serial number: 003F6R0JS32H
   Shop #: WSC 00028 028 00301
   VCID: 418EE137D0447E47DA-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 904 15
   Serial number: 35767000000916DC441Z
   Subsystem 2 - Part No SW: -----------    HW: 480 002 904 15
   Serial number: 35867000000EDBFC441H
   Subsystem 3 - Part No SW: -----------    HW: 480 402 204 15
   Serial number: 3516502B11A91E7550DD
   Subsystem 4 - Part No SW: -----------    HW: 480 402 204 15
   Serial number: 3526502BF1A87861E10J
   Subsystem 5 - Part No SW: -----------    HW: 480 402 204 15
   Serial number: 3556502BF1A91E7380AT
   Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150503400110
   Coding: 0400
   VCID: 3A7C96DBBD922D9F9B-806E
   Part No SW: 5G1 920 741     HW: 5G1 920 741
   Component: KOMBI         204 4270
   Coding: 07A412002380000800082A001400000000000000
   VCID: 64C008A36F960B6F11-8030
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 02051510802234
   Coding: 030100040F087300EF000248080F00010001050000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 71EE71F7A064AEC76A-8024
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29180000382040088075
   Coding: 280000
   Serial number: 0746876403
   Part No SW: 5Q4 959 393 C    HW: 5Q4 959 393 B
   Component: TSG FS        009 0015
   Serial number: 0000148224764
   Coding: 003003208000020000001000
   Serial number: 00000000000008842867
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   Part No SW: 5Q4 959 392 C    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0015
   Serial number: 0000148147446
   Coding: 003001208000020000801000
   VCID: 428CEE3BD542655FC3-8016
   Serial number: 00000000000008792661
   Coding: 090000
   Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
   Component: MU-S--ER      041 0421
   Serial number: V1C00505152925
   Coding: 02730200FF00000011110001000800031F0100840100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H60 0030
   Serial number: VWZ8Z9RS208VW0
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: ConWysTrailer H14 0137
   Serial number: 00000181563668
Have you had a look at the several Adaptation channels that relate to Auto-Hold?
matrixbike
C?ID=257276 (NRRT)
the problem is that i have no idea where to look more , and what I wonder is why is this thing not a default thing ?
PetrolDave
Westbury, UK
C?ID=1423
For reasons known only to themselves VAG decided to change it.
As one well known engineers proverb says " Ours is not to reason why, ours is just to sit and cry" :cool:
matrixbike
C?ID=257276 (NRRT)
for example : if I cheat couple the buckle an hop in the car and drive normally, it behaves 100% as it should , I wonder if is not possible to disable the buckle check? So once I put the key in the ignition the auto hold stay active ??? Like it is now with the couple in the buckle ....
DV52
C?ID=194404
^^^matrixbike: Hi - I don't know the answer to your question, but here's a few observations from a cursory look at the stuff that I have recorded.
In early RoW mk7s, the hex03 module had an adaptation channel MAS02666-Seat belt buckle scan which always appeared to be factory set to activated.
I've had a look at a 5Q0-907-379-F module and a 3Q0-907-379-C module which are the only early mk7 NAR models in my database and they are both missing this channel. I suspect if you make an admap of the hex03 module in your car, you will like wise observe that the channel is also missing.
So, I'm guessing of course but if these early NAR ABC modules did allow the buckle scan function to be turned OFF/ON, the software switch might be in long-code, somewhere. But (and assuming my hypothesis is correct) as to which Byte/Bit is responsible for this switch- I have no idea!!
However, in the alternative that NAR modules do indeed still have this channel (and as some here have discovered) - first entering an appropriate SA from the many codes that are available to the hex03 module might expose the missing adaptation channel in your NAR module. Perhaps (and again I'm guessing), the appropriate channel in NAR cars is hidden by the correct SA - perhaps it's a long, slow process of trying the SA s one-by-one and then looking in adaptations - maybe?
matrixbike
C?ID=257276 (NRRT)
Make total sense what you are saying there because when I try to set it from active to not active is says that is missing some parameters, I wonder what else could I possibly do instead of cheating phisically the buckle ?
darkchina811
ITALY
C?ID=333184
I know I have a situation similar to this one, my EPB started acting differently after I coded one of the various retrofits I did. probably when I upgraded PLA from 2.0 to 3.0
I'll subscribe to the thread and share my insight when I get back to my car.
matrixbike
C?ID=257276 (NRRT)
I have talked with VW and they would like to help if possible so Friday I am down to them to se what we can do.....this should be fun....
