2014 Audi A3 bulb warning
Radiosolutions
C?ID=178437
63 reg, can someone help me disable bulb warning system on this audi a3 please. thankyou
Friday,15,November,2019,12:57:06:42542
VCDS Version: 19.6.2.0
VIN: WAUZZZ8VXEA065325   License Plate: AO63DCX
Mileage: 112735km-70050mi   Repair Order: JUSTIN
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F BB BC
VIN: WAUZZZ8VXEA065325   Mileage: 112735km-70050miles
   Part No SW: 04L 906 021 AL    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5516
   Revision: 84H22---
   Coding: 02190012030501092000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM16TDI01104L906021AL 002009
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 6FED0219B63B22374E-803A
   Revision: 00000000    Serial number: 6249300000050E
   Coding: 12F18AA224260A71017A060241C82548512450806082A4F2004100748508
   VCID: 7BF52649F2434E97F2-802E
   Part No SW: 8V0 820 043     HW: 8V0 820 043
   Component: AC Automat    H13 0032
   Revision: 20024000    Serial number: 00000000151273
   Coding: 03100104002000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   Serial number: EAB8C6C6000000000001
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 250
                    Mileage: 112724 km
                    Date: 2019.11.07
                    Time: 15:43:36
                    Outside air temperature: 8.5 °C
                    Temperature after evaporator: 13.7 °C
                    Refrigerant pressure: 0.8 bar
                    System run time-Terminal 15 on: 90 s
   Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
   Component: BCM MQBAB M   H14 0112
   Serial number: 00011325001289
   Coding: 07000842C24100DD03844004B31407A80000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 489F8985F315D50F2F-801C
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130825  041 0580
   Serial number:         130904031834
   Coding: 0A47F7
   Light switch:
   Subsystem 2 - Part No SW: 8V0 941 531 N    HW: 8V0 941 531 N
   Serial number: 08 07 2013  00000112
   Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY132111WLJ
   Serial number: 00000000000027721791
   Subsystem 5 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Serial number: 20482391
   Serial number: 003M2R033G6$
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4B95B689E2633E1702-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 608 13
   Serial number: 357670000006CA9DDD0I
   Subsystem 2 - Part No SW: -----------    HW: 480 002 608 13
   Serial number: 3586700000063C9DDD0C
   Subsystem 3 - Part No SW: -----------    HW: 480 400 609 13
   Serial number: 3516502991118712D3A1
   Subsystem 4 - Part No SW: -----------    HW: 480 400 609 13
   Serial number: 35265029B1118715722Z
   Subsystem 5 - Part No SW: -----------    HW: 480 401 908 13
   Serial number: 3556502B310EDE42E3FY
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 608 13
   Serial number: 2286502B91088B11514%
   Subsystem 7 - Part No SW: -----------    HW: 480 402 608 13
   Serial number: 2296502AF1088B14633A
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 608 13
   Serial number: 2306502B71088B15E198
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
   Revision: --------    Serial number: 09091304401234
   Coding: 8418
   ROD: EV_SMLSKLOMQB_009_VW37.rod
   VCID: 77FD3A79CE6B6AF796-8022
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
   Part No SW: 8V0 920 970 N    HW: 8V0 920 970 N
   Component: KOMBI         H03 2212
   Coding: 27840A00238046000100E800000000
   VCID: 479D8AB9FE0BDA7726-8012
   Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1144
   Revision: --------    Serial number: 0000970813
   Coding: 030100040B0876005B000248080B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 009013
   ROD: EV_GatewLear_009.rod
   VCID: 3A7BE34DBDF9B79FA9-806E
   Serial number: 19 08 2013  C0323901
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051942278
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 19081304080056
   Coding: 00108E205C01040000001002
   VCID: 3F8D9259A6DB92B79E-806A
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D71E851ACD780A78C-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 02091301100015
   Coding: 001086205E01040000001002
   VCID: 3E73EF5DA1D19BBF95-806A
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    040 0420
   Serial number: A7F00909131043
   Coding: 01730301FF00000021111101000A00002F0004460100010006
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 3B75E649B2C38E97B2-806E
   Subsystem 1 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H48 0013
   Serial number: AUZ8Z9DG602M5Z
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000011071300021180
   Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
   Component: TSG HFS       010 0006
   Serial number: 25081306070403
   Coding: 000086204001040000001002
   VCID: 418994A1D02FE447E8-8014
   Component: TSG HBFS      010 0006
   Serial number: 25081301100406
End-------------------------(Elapsed Time: 03:55)--------------------------
There are no fault codes for bulbs in this scan. I do not think it's possible to "disable bulb warning system" in its entirety. Please explain exactly what you wish to do and why.
Radiosolutions
C?ID=178437
It's showing a fault on dash for light system malfunction
There is also a bulb with a cross through it. All bulbs tested fine.
Uwe if I disconnect a bulb it sees the fault, but no faults are stored in central electrics
DV52
C?ID=194404
radiosolutions: Uwe's observation is telling (it normally is ;))
I note that the lower nibble of Byte 2 is hex0 on the BCM in your auto-scan - which means that this car believes that it is equipped with incandescent lamps. I also note that the car has a medium level BCM.
I've just been correctly reminded on another thread (thanks m78a) that making changes to adaptation channels in the BCM (for example - like telling the BCM to operate HID's) MAY result in the exact same (tautology intended) symptoms that you describe - being no DTC in the BCM but warning lights on the dash.
Is there a chance that this car has had a light-fitting retro-fit, or perhaps an adaptation channel setting has been inappropriately set? The former possibility should be obvious and an examination of the BCM admap might be prudent to address the latter possibility - perhaps?
Radiosolutions
C?ID=178437
here is a scan of adaption files,if someone could check them please.
;SW:5Q0-937-084-S   HW:5Q0-937-084-S ---  Cent. Elect.
;Component:BCM MQBAB M   H14 0112, Coding:07000842C24100DD03844004B31407A80000000000000000000000000000
;EV_BCMCONTI,011001,EV_BCMBOSCH_011.rod
;Saturday,16,November,2019,09:10:27:42542
;VCDS Version: Release 19.6.2  Data version: 20190930 DS308.0
;VCID: 489F8985F315D50F2F-801C
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8 ,9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,not active ,9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,active ,9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,1000 ms,9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,1000 ms,9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,1000 ms,9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,1000 ms,9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1000 ms,9
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,active ,9
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,9
IDE01550-Service position,133.197670 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,No ,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,No ,2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,2
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,not active ,3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.25 °,13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,13
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °,13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °,13
IDE03638-ENG116676-static AFS light-Upper speed threshold,32.0 km/h,13
IDE03638-ENG116674-static AFS light-Vorschrift,OFF ,13
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separate ,3
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,3
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,SMLS ,3
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,3
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,3
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,3
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.248 %,3
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,1.0 %,3
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,separate ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,60 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG148888-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,not active ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Fog light ,5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,Not Present ,5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,16 ,5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,2 ,5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,not enabled ,5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,20 seconds ,5
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,1 Minute ,5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,not active ,5
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,not active ,5
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,Default ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,1
IDE04928-ENG148904-Anti-theft device-Überwachung Innenentriegelungshebel,active ,1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,4
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,4
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
IDE05142-ENG115722-Access control-Electrical rear lid,not active ,4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active ,4
IDE05142-ENG115755-Access control-Notschließfunktion,not active ,4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,4
IDE05142-ENG115758-Access control-Valet Parking,not active ,4
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,4
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,active ,4
IDE05144-Read parameter address,00 00 00 ,3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,35 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,11 ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,21 ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,3F ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44 ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41 ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,minimize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,minimize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,100 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,27 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,27 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,100 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,100 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,100 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,100 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,100 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,100 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,100 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,100 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,100 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,100 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,100 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,100 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,100 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,25 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,25 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,25 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,25 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,13 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,13 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,03 ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,04 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,26 ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,2F ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,27 ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,02 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,03 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,04 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,05 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,06 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,20 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,21 ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,23 - allgemeine Scheinwerfer ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,23 - allgemeine Scheinwerfer ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,46 - LED Kleinleistung ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,46 - LED Kleinleistung ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,12 - Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,12 - Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,8 - allgemeine Glühlampe 12W ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,13 - Bremsleuchten ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,13 - Bremsleuchten ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,8 - allgemeine Glühlampe 12W ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,8 - allgemeine Glühlampe 12W ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,8 - allgemeine Glühlampe 12W ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,46 - LED Kleinleistung ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,11 - Abblendlicht ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,11 - Abblendlicht ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,23 - allgemeine Scheinwerfer ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,23 - allgemeine Scheinwerfer ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,only_if_closed ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,30 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,45 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,46 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,8 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,26 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,26 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,8 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,45 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,46 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,47 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,48 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,9 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,30 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,30 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,30 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,10 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,0 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,0 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,3 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,5 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,30 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,3 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,5 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,8 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,8 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,0 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,0 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,0 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,0 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,30 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,30 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,8 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,8 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,15 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,15 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,30 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,30 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 09 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 FF F6 06 00 0F 1E 00 85 0F 32 F7 64 23 45 21 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 FF F6 56 00 0F 1E 00 86 28 32 F7 65 0F 43 21 57 1B 03 32 3F 3A 69 58 93 0D 09 A3 03 F5 F6 26 00 0F 19 00 88 0F 2D F7 68 1E 45 21 57 1B 03 22 3F 3A 69 58 93 0C 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 66 23 45 21 57 9B 23 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 20 24 2B 3F ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,14
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,14
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,20.00 °C,14
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,19.00 °C,14
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,28.00 °C,14
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,27.50 °C,14
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,14
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,14
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,41.00 °C,14
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,40.50 °C,14
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,50.00 °C,14
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,49.00 °C,14
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,63.00 °C,14
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,62.50 °C,14
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,not active ,6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,active ,6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active ,6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,50 %,6
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active ,2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
IDE07007-ENG148891-A/C heater function via remote control-Anzahl zulaessiger Remotestarts,2 ,2
IDE07007-ENG148876-A/C heater function via remote control-RemoteStart Betrieb Dauer,10 min,2
IDE07356-Position during interval mode,21.197781 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,5
IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
IDE08542-IDE02022-Access control 2-Comfort opening,not active ,6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,not active ,6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,not active ,6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,Yes ,6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,Yes ,6
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,Yes ,6
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,6
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,6
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,not active ,6
IDE08542-ENG115671-Access control 2-Regenschließen,not active ,6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active ,6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active ,6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,6
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,6
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,not active ,6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,500 ms,4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,800 ms,4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,Not Present ,4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,1
IDE08787-ENG148893-Auxiliary functions-Menuesteuerung Garagentoroeffner,active ,1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,1
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,1
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE10298-Alternating park position 1,18.197784 °,2
IDE10299-Alternating park position 2,21.197781 °,2
MAS01490-Energy management,active ,1
MAS05055-lower turn position,26.197776 °,2
MAS05056-upper turn position,166.197637 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,3
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,3
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,3
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,3
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,3
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,3
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,3
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,3
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,3
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,3
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,3
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,3
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,3
ENG99457-ENG98971-Head area heater-Temperature,-3 ,2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,100.0 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,95.0 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,80.0 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,40.0 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,20.0 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,10.0 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,5.0 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,3.0 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,1.0 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 lx,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 %,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 %,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 %,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 %,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 %,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 %,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 %,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 %,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 %,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 %,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,100 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,150 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,6.0 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,6.0 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,16.0 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,30.0 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,60.0 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 %,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 %,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 %,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 %,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 %,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 %,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 %,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 %,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 %,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 %,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 %,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 %,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.0 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.0 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.0 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.0 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.0 ,10
ENG148505-ENG115658-InnenbeleuchtungKL 58xs min-x0,0 lx,8
ENG148505-ENG101574-InnenbeleuchtungKL 58xs min-X1,8 lx,8
ENG148505-ENG99557-InnenbeleuchtungKL 58xs min-X2,50 lx,8
ENG148505-ENG102140-InnenbeleuchtungKL 58xs min-X3,500 lx,8
ENG148505-ENG115659-InnenbeleuchtungKL 58xs min-y0,6.0 %,8
ENG148505-ENG99777-InnenbeleuchtungKL 58xs min-Y1,6.0 %,8
ENG148505-ENG100480-InnenbeleuchtungKL 58xs min-Y2,100.0 %,8
ENG148505-ENG100773-InnenbeleuchtungKL 58xs min-Y3,100.0 %,8
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links Dunkelphase ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,100 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,23 - allgemeine Scheinwerfer ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,Coming Home oder Leaving Home aktiv ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,100 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,23 - allgemeine Scheinwerfer ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,Coming Home oder Leaving Home aktiv ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,03 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,46 - LED Kleinleistung ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Ambientelicht 1 ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,04 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,46 - LED Kleinleistung ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Ambientelicht 2 ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links Dunkelphase ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts Dunkelphase ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts Dunkelphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,25 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,25 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,13 - Bremsleuchten ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Coming Home oder Leaving Home aktiv ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,25 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,25 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,13 - Bremsleuchten ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Coming Home oder Leaving Home aktiv ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,27 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,27 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100 ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,Coming Home oder Leaving Home aktiv ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,13 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,11 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,Coming Home oder Leaving Home aktiv ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,13 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,21 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,Coming Home oder Leaving Home aktiv ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,8 - allgemeine Glühlampe 12W ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,8 - allgemeine Glühlampe 12W ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,26 ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,35 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,8 - allgemeine Glühlampe 12W ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,03 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,Ambientelicht 1 ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,04 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,05 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,06 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,27 ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,3F ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,8 - allgemeine Glühlampe 12W ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,minimize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,100 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,20 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Lichthupe generell ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,minimize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,100 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,21 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Lichthupe generell ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,23 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,23 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
Elapsed Time: 01:28
DV52
C?ID=194404
RadioSolution: Thanks for the BCM admap.
In an attempt to compare apples and apples and given that we down here in the Antipodes have similar road rules - I've tried to find a BCM in my database with close charcteristics to your A3. The best that I could do was an Aussie BCM 5Q0-937-084-N from a mk7 Golf which was factory equiped with incandescent headlight and taillight fittings (this compares with your 5Q0-937-084-S with factory incandescent fittings, I assume). In a further attempt to minimize differences across VW/Audi models, I also refer to the BCM in my Audi A3 8V - which is MY17 (and which has incandescent tails and HID headlights).
So- let's start with the way that the 35 x exterior lights on your A3 are programmed - below I've listed the Leuchte-channels from your admap and I compare the settings across the 3 x BCM s. The first row is the column headings for the subsequent records and in the last entry for each record, I answer the question - are the settings the same in your car for EITHER the Golf BCM, OR the BCM in my later model A3?
Anyhow, the general thrust of the tail light Leuchte-sets in the table below suggest that the car has incandescent fittings. However, Leuchte16BLK and Leuchte17TFL appear to be programmed for LED fittings. Normally, these 2 xLeuchte-sets are assigned to the inner turn-signal lamps which only exist on LED tails and on incandescent tails they are inactive. Curiosly, in your BCM, they appear to be programmed for cabin ambient lighting. I'm not sure why unless the owner has rewired the loom somehow - perhaps?
Adaptation Channel		>RadioSolution BCM Setting		>5Q0-937-084-N setting		>A3 settings		>Same?
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	>	100	>	100	>	100	>	TRUE
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	>	0	>	0	>	0	>	TRUE
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	>	0	>	0	>	0	>	TRUE
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	>	0	>	0	>	0	>	TRUE
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	>	14	>	14	>	14	>	TRUE
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	>	34	>	34	>	34	>	TRUE
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	>	12 - Blinkleuchten	>	12 - Blinkleuchten	>	12 - Blinkleuchten	>	TRUE
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	>	Always	>	Always	>	Always	>	TRUE
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	>	Blinken links Hellphase	>	Blinken links Hellphase	>	Blinken links Hellphase	>	TRUE
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	>	not active	>	not active	>	not active	>	TRUE
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	>	Blinken links Dunkelphase	>	not active	>	Blinken links Dunkelphase	>	TRUE
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	>	not active	>	not active	>	not active	>	TRUE
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	>	not active	>	not active	>	not active	>	TRUE
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	>	not active	>	not active	>	not active	>	TRUE
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	>	not active	>	not active	>	not active	>	TRUE
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	>	not active	>	not active	>	not active	>	TRUE
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	>	0	>	0	>	127	>	TRUE
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	>	0	>	0	>	0	>	TRUE
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	>	0	>	0	>	0	>	TRUE
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	>	0	>	0	>	0	>	TRUE
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	>	0	>	0	>	1E	>	TRUE
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	>	0	>	0	>	37	>	TRUE
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	>	not active	>	not active	>	2 - Shutter: Diagnosesensierung für 'LED low'	>	TRUE
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	>	Always	>	Always	>	Always	>	TRUE
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	>	not active	>	not active	>	Left high beam	>	TRUE
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	>	not active	>	not active	>	Lichthupe generell	>	TRUE
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	>	not active	>	not active	>	not active	>	TRUE
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	>	not active	>	not active	>	not active	>	TRUE
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	>	not active	>	not active	>	not active	>	TRUE
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	>	not active	>	not active	>	not active	>	TRUE
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	>	not active	>	not active	>	not active	>	TRUE
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	>	not active	>	not active	>	not active	>	TRUE
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	>	0	>	0	>	127	>	TRUE
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	>	0	>	0	>	0	>	TRUE
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	>	0	>	0	>	0	>	TRUE
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	>	0	>	0	>	0	>	TRUE
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	>	0	>	0	>	1F	>	TRUE
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	>	0	>	0	>	41	>	TRUE
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	>	not active	>	not active	>	2 - Shutter: Diagnosesensierung für 'LED low'	>	TRUE
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	>	Always	>	Always	>	Always	>	TRUE
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	>	not active	>	not active	>	Right high beam	>	TRUE
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	>	not active	>	not active	>	Lichthupe generell	>	TRUE
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	>	not active	>	not active	>	not active	>	TRUE
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	>	not active	>	not active	>	not active	>	TRUE
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	>	not active	>	not active	>	not active	>	TRUE
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	>	not active	>	not active	>	not active	>	TRUE
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	>	not active	>	not active	>	not active	>	TRUE
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	>	not active	>	not active	>	not active	>	TRUE
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	>	maximize	>	maximize	>	minimize	>	TRUE
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	>	100	>	100	>	100	>	TRUE
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	>	100	>	100	>	0	>	TRUE
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	>	0	>	0	>	0	>	TRUE
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	>	0	>	0	>	0	>	TRUE
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	>	22	>	22	>	5F	>	TRUE
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	>	38	>	38	>	38	>	TRUE
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	>	23 - allgemeine Scheinwerfer	>	10 - allgemeine Scheinwerfer	>	23 - allgemeine Scheinwerfer	>	TRUE
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	>	Always	>	Always	>	Always	>	TRUE
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	>	Nebellicht links	>	Nebellicht links	>	Nebellicht links	>	TRUE
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	>	not active	>	Abbiegelicht links	>	not active	>	TRUE
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	>	Coming Home oder Leaving Home aktiv	>	Left high beam	>	not active	>	FALSE
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	>	not active	>	Lichthupe generell	>	not active	>	TRUE
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	>	not active	>	not active	>	not active	>	TRUE
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	>	not active	>	not active	>	not active	>	TRUE
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	>	not active	>	not active	>	Blinken links aktiv (beide Phasen)	>	TRUE
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	>	not active	>	not active	>	not active	>	TRUE
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	>	maximize	>	maximize	>	minimize	>	TRUE
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	>	100	>	100	>	100	>	TRUE
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	>	100	>	100	>	0	>	TRUE
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	>	0	>	0	>	0	>	TRUE
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	>	0	>	0	>	0	>	TRUE
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	>	23	>	23	>	60	>	TRUE
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	>	42	>	42	>	42	>	TRUE
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	>	23 - allgemeine Scheinwerfer	>	10 - allgemeine Scheinwerfer	>	23 - allgemeine Scheinwerfer	>	TRUE
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	>	Always	>	Always	>	Always	>	TRUE
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	>	Nebellicht rechts	>	Nebellicht rechts	>	Nebellicht rechts	>	TRUE
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	>	not active	>	Abbiegelicht rechts	>	not active	>	TRUE
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	>	Coming Home oder Leaving Home aktiv	>	Right high beam	>	not active	>	FALSE
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	>	not active	>	Lichthupe generell	>	not active	>	TRUE
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	>	not active	>	not active	>	not active	>	TRUE
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	>	not active	>	not active	>	not active	>	TRUE
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	>	not active	>	not active	>	Blinken rechts aktiv (beide Phasen)	>	TRUE
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	>	not active	>	not active	>	not active	>	TRUE
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15	>	maximize	>	maximize	>		>	TRUE
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15	>	maximize	>	maximize	>		>	TRUE
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15	>	maximize	>	maximize	>		>	TRUE
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15	>	0	>	0	>		>	TRUE
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15	>	0	>	0	>		>	TRUE
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15	>	0	>	0	>		>	TRUE
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15	>	0	>	0	>		>	TRUE
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	>	0	>	0	>		>	TRUE
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15	>	0	>	0	>		>	TRUE
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15	>	not active	>	not active	>		>	TRUE
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15	>	Always	>	Always	>		>	TRUE
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15	>	not active	>	not active	>		>	TRUE
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15	>	not active	>	not active	>		>	TRUE
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15	>	not active	>	not active	>		>	TRUE
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15	>	not active	>	not active	>		>	TRUE
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15	>	not active	>	not active	>		>	TRUE
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15	>	not active	>	not active	>		>	TRUE
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15	>	not active	>	not active	>		>	TRUE
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15	>	not active	>	not active	>		>	TRUE
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	>	100	>	0	>	0	>	FALSE
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	>	0	>	0	>	0	>	TRUE
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	>	0	>	0	>	0	>	TRUE
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	>	0	>	0	>	0	>	TRUE
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	>	3	>	0	>	0	>	FALSE
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	>	0	>	0	>	0	>	TRUE
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	>	46 - LED Kleinleistung	>	not active	>	not active	>	FALSE
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	>	Always	>	Always	>	Always	>	TRUE
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	>	Ambientelicht 1	>	not active	>	not active	>	FALSE
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	>	not active	>	not active	>	not active	>	TRUE
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	>	not active	>	not active	>	not active	>	TRUE
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	>	not active	>	not active	>	not active	>	TRUE
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	>	not active	>	not active	>	not active	>	TRUE
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	>	not active	>	not active	>	not active	>	TRUE
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	>	not active	>	not active	>	not active	>	TRUE
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	>	not active	>	not active	>	not active	>	TRUE
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	>	100	>	0	>	0	>	FALSE
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	>	0	>	0	>	0	>	TRUE
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	>	0	>	0	>	0	>	TRUE
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	>	0	>	0	>	0	>	TRUE
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	>	4	>	0	>	0	>	FALSE
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	>	0	>	0	>	0	>	TRUE
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	>	46 - LED Kleinleistung	>	not active	>	not active	>	FALSE
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	>	Always	>	Always	>	Always	>	TRUE
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	>	Ambientelicht 2	>	not active	>	not active	>	FALSE
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	>	not active	>	not active	>	not active	>	TRUE
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	>	not active	>	not active	>	not active	>	TRUE
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	>	not active	>	not active	>	not active	>	TRUE
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	>	not active	>	not active	>	not active	>	TRUE
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	>	not active	>	not active	>	not active	>	TRUE
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	>	not active	>	not active	>	not active	>	TRUE
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	>	not active	>	not active	>	not active	>	TRUE
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	>	100	>	100	>	105	>	TRUE
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	>	0	>	0	>	0	>	TRUE
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	>	0	>	0	>	0	>	TRUE
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	>	0	>	0	>	0	>	TRUE
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	>	16	>	16	>	16	>	TRUE
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	>	8	>	8	>	8	>	TRUE
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	>	12 - Blinkleuchten	>	12 - Blinkleuchten	>	12 - Blinkleuchten	>	TRUE
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	>	Always	>	Always	>	Always	>	TRUE
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	>	Blinken links Hellphase	>	Blinken links Hellphase	>	Blinken links Hellphase	>	TRUE
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	>	not active	>	not active	>	not active	>	TRUE
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	>	Blinken links Dunkelphase	>	not active	>	Blinken links Dunkelphase	>	TRUE
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	>	not active	>	not active	>	not active	>	TRUE
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	>	not active	>	not active	>	not active	>	TRUE
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	>	not active	>	not active	>	not active	>	TRUE
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	>	not active	>	not active	>	not active	>	TRUE
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	>	not active	>	not active	>	not active	>	TRUE
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	>	100	>	100	>	105	>	TRUE
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	>	0	>	0	>	0	>	TRUE
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	>	0	>	0	>	0	>	TRUE
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	>	0	>	0	>	0	>	TRUE
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	>	18	>	18	>	18	>	TRUE
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	>	18	>	18	>	18	>	TRUE
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	>	12 - Blinkleuchten	>	12 - Blinkleuchten	>	12 - Blinkleuchten	>	TRUE
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	>	Always	>	Always	>	Always	>	TRUE
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	>	Blinken rechts Hellphase	>	Blinken rechts Hellphase	>	Blinken rechts Hellphase	>	TRUE
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	>	not active	>	not active	>	not active	>	TRUE
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	>	Blinken rechts Dunkelphase	>	not active	>	Blinken rechts Dunkelphase	>	TRUE
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	>	not active	>	not active	>	not active	>	TRUE
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	>	not active	>	not active	>	not active	>	TRUE
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	>	not active	>	not active	>	not active	>	TRUE
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	>	not active	>	not active	>	not active	>	TRUE
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	>	not active	>	not active	>	not active	>	TRUE
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	>	100	>	100	>	100	>	TRUE
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	>	0	>	0	>	0	>	TRUE
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	>	0	>	0	>	0	>	TRUE
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	>	0	>	0	>	0	>	TRUE
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	>	15	>	15	>	15	>	TRUE
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	>	3E	>	3E	>	3E	>	TRUE
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	>	12 - Blinkleuchten	>	12 - Blinkleuchten	>	12 - Blinkleuchten	>	TRUE
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	>	Always	>	Always	>	Always	>	TRUE
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	>	Blinken rechts Hellphase	>	Blinken rechts Hellphase	>	Blinken rechts Hellphase	>	TRUE
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	>	not active	>	not active	>	not active	>	TRUE
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	>	Blinken rechts Dunkelphase	>	not active	>	Blinken rechts Dunkelphase	>	TRUE
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	>	not active	>	not active	>	not active	>	TRUE
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	>	not active	>	not active	>	not active	>	TRUE
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	>	not active	>	not active	>	not active	>	TRUE
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	>	not active	>	not active	>	not active	>	TRUE
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	>	not active	>	not active	>	not active	>	TRUE
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	>	maximize	>	minimize	>	maximize	>	TRUE
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	>	100	>	100	>	27	>	TRUE
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	>	25	>	28	>	22	>	FALSE
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	>	25	>	0	>	105	>	FALSE
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	>	0	>	100	>	0	>	TRUE
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	>	39	>	39	>	39	>	TRUE
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	>	10	>	10	>	10	>	TRUE
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	>	13 - Bremsleuchten	>	14 - kombinierte Blink- Bremsleuchten	>	13 - Bremsleuchten	>	TRUE
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	>	Always	>	Always	>	Always	>	TRUE
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	>	Brake light	>	Brake light	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	TRUE
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	>	not active	>	Blinken links Dunkelphase	>	Coming Home oder Leaving Home aktiv	>	FALSE
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	Parklicht links (beidseitiges Parklicht aktiviert li & re)	>	TRUE
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	>	Parklicht links (beidseitiges Parklicht aktiviert li & re)	>	Parklicht links (beidseitiges Parklicht aktiviert li & re)	>	not active	>	TRUE
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	>	Coming Home oder Leaving Home aktiv	>	Blinken links Hellphase	>	Brake light	>	FALSE
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	>	not active	>	not active	>	not active	>	TRUE
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	>	not active	>	Rear lid open	>	not active	>	TRUE
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	>	not active	>	not active	>	not active	>	TRUE
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	>	maximize	>	minimize	>	maximize	>	TRUE
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	>	100	>	100	>	27	>	TRUE
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	>	25	>	28	>	22	>	FALSE
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	>	25	>	0	>	105	>	FALSE
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	>	0	>	100	>	0	>	TRUE
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	>	3A	>	3A	>	3A	>	TRUE
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	>	20	>	20	>	20	>	TRUE
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	>	13 - Bremsleuchten	>	14 - kombinierte Blink- Bremsleuchten	>	13 - Bremsleuchten	>	TRUE
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	>	Always	>	Always	>	Always	>	TRUE
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	>	Brake light	>	Brake light	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	TRUE
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	>	not active	>	Blinken rechts Dunkelphase	>	Coming Home oder Leaving Home aktiv	>	FALSE
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	Parking light right	>	TRUE
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	>	Parking light right	>	Parking light right	>	not active	>	TRUE
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	>	Coming Home oder Leaving Home aktiv	>	Blinken rechts Hellphase	>	Brake light	>	FALSE
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	>	not active	>	not active	>	not active	>	TRUE
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	>	not active	>	Rear lid open	>	not active	>	TRUE
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	>	not active	>	not active	>	not active	>	TRUE
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	>	maximize	>	minimize	>	maximize	>	TRUE
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	>	100	>	127	>	127	>	FALSE
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	>	0	>	127	>	0	>	TRUE
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	>	0	>	100	>	0	>	TRUE
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	>	0	>	0	>	0	>	TRUE
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	>	2C	>	2C	>	2C	>	TRUE
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	>	29	>	29	>	29	>	TRUE
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	>	42 - LED dritte Bremsleuchte	>	42 - LED dritte Bremsleuchte	>	42 - LED dritte Bremsleuchte	>	TRUE
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	>	Always	>	Always	>	Always	>	TRUE
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	>	Brake light	>	Brake light	>	Brake light	>	TRUE
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	>	not active	>	Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken	>	not active	>	TRUE
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	>	not active	>	Blinken links Dunkelphase	>	not active	>	TRUE
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	>	not active	>	Blinken rechts Dunkelphase	>	not active	>	TRUE
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	>	not active	>	Brake light	>	not active	>	TRUE
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	>	not active	>	Rueckfahrlicht	>	not active	>	TRUE
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	>	not active	>	not active	>	not active	>	TRUE
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	>	not active	>	not active	>	not active	>	TRUE
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	>	27	>	28	>	29	>	FALSE
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	>	0	>	100	>	0	>	TRUE
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	>	0	>	0	>	0	>	TRUE
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	>	0	>	0	>	0	>	TRUE
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	>	29	>	29	>	29	>	TRUE
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	>	0A	>	0A	>	0A	>	TRUE
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	>	9 - allgemeine Glühlampe 27W: auch H15	>	9 - allgemeine Glühlampe 27W: auch H15	>	9 - allgemeine Glühlampe 27W: auch H15	>	TRUE
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	>	Always	>	only_if_closed	>	Always	>	TRUE
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	TRUE
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	>	Coming Home oder Leaving Home aktiv	>	not active	>	Coming Home oder Leaving Home aktiv	>	TRUE
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	>	not active	>	Brake light	>	not active	>	TRUE
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	>	not active	>	not active	>	not active	>	TRUE
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	>	not active	>	not active	>	not active	>	TRUE
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	>	not active	>	not active	>	not active	>	TRUE
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	>	not active	>	not active	>	not active	>	TRUE
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	>	not active	>	not active	>	not active	>	TRUE
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	>	27	>	28	>	29	>	FALSE
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	>	0	>	100	>	0	>	TRUE
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	>	0	>	0	>	0	>	TRUE
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	>	0	>	0	>	0	>	TRUE
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	>	2A	>	2A	>	2A	>	TRUE
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	>	1A	>	1A	>	1A	>	TRUE
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	>	9 - allgemeine Glühlampe 27W: auch H15	>	9 - allgemeine Glühlampe 27W: auch H15	>	9 - allgemeine Glühlampe 27W: auch H15	>	TRUE
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	>	Always	>	only_if_closed	>	Always	>	TRUE
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	TRUE
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	>	Coming Home oder Leaving Home aktiv	>	not active	>	Coming Home oder Leaving Home aktiv	>	TRUE
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	>	not active	>	Brake light	>	not active	>	TRUE
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	>	not active	>	not active	>	not active	>	TRUE
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	>	not active	>	not active	>	not active	>	TRUE
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	>	not active	>	not active	>	not active	>	TRUE
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	>	not active	>	not active	>	not active	>	TRUE
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	>	not active	>	not active	>	not active	>	TRUE
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	>	100	>	100	>	127	>	TRUE
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	>	0	>	0	>	0	>	TRUE
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	>	0	>	0	>	0	>	TRUE
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	>	0	>	0	>	0	>	TRUE
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	>	30	>	30	>	30	>	TRUE
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	>	28	>	28	>	28	>	TRUE
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	>	43 - allgemeine LED	>	18 - 2* 5W	>	43 - allgemeine LED	>	TRUE
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	>	Always	>	Always	>	Always	>	TRUE
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	TRUE
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	>	Coming Home oder Leaving Home aktiv	>	not active	>	Coming Home oder Leaving Home aktiv	>	TRUE
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	>	not active	>	not active	>	not active	>	TRUE
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	>	not active	>	not active	>	not active	>	TRUE
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	>	not active	>	not active	>	not active	>	TRUE
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	>	not active	>	not active	>	not active	>	TRUE
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	>	not active	>	not active	>	not active	>	TRUE
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	>	not active	>	not active	>	not active	>	TRUE
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	>	100	>	100	>	105	>	TRUE
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	>	0	>	0	>	0	>	TRUE
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	>	13	>	0	>	0	>	FALSE
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	>	0	>	0	>	0	>	TRUE
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	>	2E	>	2F	>	2E	>	TRUE
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	>	11	>	1C	>	0C	>	FALSE
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	>	9 - allgemeine Glühlampe 27W: auch H15	>	9 - allgemeine Glühlampe 27W: auch H15	>	9 - allgemeine Glühlampe 27W: auch H15	>	TRUE
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	>	only_if_closed	>	only_if_closed	>	only_if_closed	>	TRUE
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	>	Nebelschlusslicht wenn kein Anhaenger gesteckt	>	Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr	>	Nebelschlusslicht wenn kein Anhaenger gesteckt	>	TRUE
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	>	not active	>	not active	>	not active	>	TRUE
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	>	not active	>	not active	>	not active	>	TRUE
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	>	not active	>	not active	>	not active	>	TRUE
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	not active	>	not active	>	FALSE
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	>	Coming Home oder Leaving Home aktiv	>	not active	>	not active	>	FALSE
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	>	not active	>	not active	>	not active	>	TRUE
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	>	not active	>	not active	>	not active	>	TRUE
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	>	100	>	0	>	105	>	FALSE
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	>	0	>	0	>	0	>	TRUE
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	>	13	>	0	>	0	>	FALSE
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	>	0	>	0	>	0	>	TRUE
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	>	2F	>	0	>	2F	>	TRUE
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	>	21	>	0	>	1C	>	FALSE
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	>	9 - allgemeine Glühlampe 27W: auch H15	>	not active	>	9 - allgemeine Glühlampe 27W: auch H15	>	TRUE
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	>	only_if_closed	>	Always	>	only_if_closed	>	TRUE
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	>	Nebelschlusslicht wenn kein Anhaenger gesteckt	>	not active	>	Nebelschlusslicht wenn kein Anhaenger gesteckt	>	TRUE
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	>	not active	>	not active	>	not active	>	TRUE
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	>	not active	>	not active	>	not active	>	TRUE
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	>	not active	>	not active	>	not active	>	TRUE
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	not active	>	not active	>	FALSE
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	>	Coming Home oder Leaving Home aktiv	>	not active	>	not active	>	FALSE
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	>	not active	>	not active	>	not active	>	TRUE
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	>	not active	>	not active	>	not active	>	TRUE
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	>	maximize	>	maximize	>	minimize	>	TRUE
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	>	100	>	100	>	105	>	TRUE
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	>	0	>	0	>	0	>	TRUE
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	>	0	>	0	>	0	>	TRUE
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	>	0	>	0	>	0	>	TRUE
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	>	31	>	31	>	31	>	TRUE
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	>	0B	>	0B	>	0B	>	TRUE
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	>	8 - allgemeine Glühlampe 12W	>	9 - allgemeine Glühlampe 27W: auch H15	>	8 - allgemeine Glühlampe 12W	>	TRUE
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	>	Always	>	only_if_closed	>	only_if_closed	>	FALSE
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	>	Rueckfahrlicht	>	Rueckfahrlicht	>	Rueckfahrlicht	>	TRUE
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	>	not active	>	not active	>	not active	>	TRUE
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	>	not active	>	not active	>	Fahrzeug ist nicht fahrbereit (Motor läuft nicht: Elektroantrieb nicht aktiv o.ä.)	>	TRUE
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	>	not active	>	not active	>	not active	>	TRUE
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	>	not active	>	not active	>	not active	>	TRUE
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	>	not active	>	not active	>	not active	>	TRUE
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	>	not active	>	not active	>	not active	>	TRUE
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	>	not active	>	not active	>	not active	>	TRUE
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	>	maximize	>	maximize	>	minimize	>	TRUE
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	>	100	>	100	>	105	>	TRUE
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	>	0	>	0	>	0	>	TRUE
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	>	0	>	0	>	0	>	TRUE
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	>	0	>	0	>	0	>	TRUE
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	>	32	>	32	>	32	>	TRUE
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	>	1B	>	1B	>	1B	>	TRUE
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	>	8 - allgemeine Glühlampe 12W	>	9 - allgemeine Glühlampe 27W: auch H15	>	8 - allgemeine Glühlampe 12W	>	TRUE
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	>	Always	>	only_if_closed	>	only_if_closed	>	FALSE
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	>	Rueckfahrlicht	>	Rueckfahrlicht	>	Rueckfahrlicht	>	TRUE
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	>	not active	>	not active	>	not active	>	TRUE
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	>	not active	>	not active	>	Fahrzeug ist nicht fahrbereit (Motor läuft nicht: Elektroantrieb nicht aktiv o.ä.)	>	TRUE
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	>	not active	>	not active	>	not active	>	TRUE
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	>	not active	>	not active	>	not active	>	TRUE
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	>	not active	>	not active	>	not active	>	TRUE
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	>	not active	>	not active	>	not active	>	TRUE
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	>	not active	>	not active	>	not active	>	TRUE
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	>	maximize	>	maximize	>	minimize	>	TRUE
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	>	100	>	0	>	26	>	FALSE
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	>	0	>	0	>	26	>	TRUE
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	>	0	>	0	>	127	>	TRUE
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	>	0	>	0	>	26	>	TRUE
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	>	26	>	0	>	4A	>	FALSE
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	>	35	>	0	>	48	>	FALSE
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	>	8 - allgemeine Glühlampe 12W	>	not active	>	4 - LED Tagfahrlichtmodul Signal	>	FALSE
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	>	Always	>	Always	>	Always	>	TRUE
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	not active	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	TRUE
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	>	Parklicht links (beidseitiges Parklicht aktiviert li & re)	>	not active	>	Parklicht links (beidseitiges Parklicht aktiviert li & re)	>	TRUE
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	>	not active	>	not active	>	Coming Home oder Leaving Home aktiv	>	TRUE
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	>	not active	>	not active	>	not active	>	TRUE
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	>	not active	>	not active	>	Daytime running lights	>	TRUE
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	>	not active	>	not active	>	not active	>	TRUE
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	>	not active	>	not active	>	Blinken links aktiv (beide Phasen)	>	TRUE
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	>	not active	>	not active	>	not active	>	TRUE
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	>	100	>	100	>	100	>	TRUE
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	>	0	>	0	>	0	>	TRUE
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	>	0	>	0	>	0	>	TRUE
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	>	0	>	0	>	0	>	TRUE
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	>	2	>	2	>	2	>	TRUE
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	>	0	>	0	>	0	>	TRUE
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	>	46 - LED Kleinleistung	>	36 - LED Kleinleistung	>	46 - LED Kleinleistung	>	TRUE
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	>	Always	>	Always	>	Always	>	TRUE
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	>	Footwell light	>	Footwell light	>	Footwell light	>	TRUE
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	>	not active	>	not active	>	not active	>	TRUE
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	>	not active	>	not active	>	not active	>	TRUE
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	>	not active	>	not active	>	not active	>	TRUE
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	>	not active	>	not active	>	not active	>	TRUE
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	>	not active	>	not active	>	not active	>	TRUE
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	>	not active	>	not active	>	not active	>	TRUE
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	>	not active	>	not active	>	not active	>	TRUE
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	>	100	>	0	>	100	>	TRUE
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	>	0	>	0	>	0	>	TRUE
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	>	0	>	0	>	0	>	TRUE
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	>	0	>	0	>	0	>	TRUE
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	>	3	>	0	>	3	>	TRUE
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	>	0	>	0	>	0	>	TRUE
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	>	not active	>	not active	>	not active	>	TRUE
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	>	Always	>	Always	>	Always	>	TRUE
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	>	Ambientelicht 1	>	not active	>	Ambientelicht 1	>	TRUE
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	>	not active	>	not active	>	not active	>	TRUE
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	>	not active	>	not active	>	not active	>	TRUE
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	>	not active	>	not active	>	not active	>	TRUE
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	>	not active	>	not active	>	not active	>	TRUE
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	>	not active	>	not active	>	not active	>	TRUE
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	>	not active	>	not active	>	not active	>	TRUE
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	>	not active	>	not active	>	not active	>	TRUE
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	>	100	>	0	>	100	>	TRUE
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	>	0	>	0	>	0	>	TRUE
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	>	0	>	0	>	0	>	TRUE
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	>	0	>	0	>	0	>	TRUE
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	>	4	>	0	>	4	>	TRUE
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	>	0	>	0	>	0	>	TRUE
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	>	not active	>	not active	>	not active	>	TRUE
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	>	Always	>	Always	>	Always	>	TRUE
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	>	Ambientelicht 2	>	not active	>	Ambientelicht 2	>	TRUE
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	>	not active	>	not active	>	not active	>	TRUE
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	>	not active	>	not active	>	not active	>	TRUE
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	>	not active	>	not active	>	not active	>	TRUE
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	>	not active	>	not active	>	not active	>	TRUE
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	>	not active	>	not active	>	not active	>	TRUE
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	>	not active	>	not active	>	not active	>	TRUE
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	>	not active	>	not active	>	not active	>	TRUE
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	>	100	>	0	>	100	>	TRUE
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	>	0	>	0	>	0	>	TRUE
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	>	0	>	0	>	0	>	TRUE
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	>	0	>	0	>	0	>	TRUE
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	>	5	>	0	>	5	>	TRUE
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	>	0	>	0	>	0	>	TRUE
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	>	not active	>	not active	>	not active	>	TRUE
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	>	Always	>	Always	>	Always	>	TRUE
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	>	Ambientelicht 3	>	not active	>	Ambientelicht 3	>	TRUE
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	>	not active	>	not active	>	not active	>	TRUE
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	>	not active	>	not active	>	not active	>	TRUE
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	>	not active	>	not active	>	not active	>	TRUE
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	>	not active	>	not active	>	not active	>	TRUE
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	>	not active	>	not active	>	not active	>	TRUE
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	>	not active	>	not active	>	not active	>	TRUE
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	>	not active	>	not active	>	not active	>	TRUE
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	>	100	>	0	>	100	>	TRUE
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	>	0	>	0	>	0	>	TRUE
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	>	0	>	0	>	0	>	TRUE
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	>	0	>	0	>	0	>	TRUE
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	>	6	>	0	>	6	>	TRUE
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	>	0	>	0	>	0	>	TRUE
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	>	not active	>	not active	>	not active	>	TRUE
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	>	Always	>	Always	>	Always	>	TRUE
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	>	Ambientelicht 4	>	not active	>	Ambientelicht 4	>	TRUE
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	>	not active	>	not active	>	not active	>	TRUE
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	>	not active	>	not active	>	not active	>	TRUE
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	>	not active	>	not active	>	not active	>	TRUE
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	>	not active	>	not active	>	not active	>	TRUE
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	>	not active	>	not active	>	not active	>	TRUE
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	>	not active	>	not active	>	not active	>	TRUE
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	>	not active	>	not active	>	not active	>	TRUE
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	>	maximize	>	maximize	>	minimize	>	TRUE
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	>	100	>	0	>	26	>	FALSE
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	>	0	>	0	>	26	>	TRUE
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	>	0	>	0	>	127	>	TRUE
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	>	0	>	0	>	26	>	TRUE
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	>	27	>	0	>	4C	>	FALSE
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	>	3F	>	0	>	4C	>	FALSE
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	>	8 - allgemeine Glühlampe 12W	>	not active	>	4 - LED Tagfahrlichtmodul Signal	>	FALSE
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	>	Always	>	Always	>	Always	>	TRUE
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	not active	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	TRUE
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	>	Parking light right	>	not active	>	Parking light right	>	TRUE
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	>	not active	>	not active	>	Coming Home oder Leaving Home aktiv	>	TRUE
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	>	not active	>	not active	>	not active	>	TRUE
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	>	not active	>	not active	>	Daytime running lights	>	TRUE
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	>	not active	>	not active	>	not active	>	TRUE
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	>	not active	>	not active	>	Blinken rechts aktiv (beide Phasen)	>	TRUE
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	>	not active	>	not active	>	not active	>	TRUE
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	>	maximize	>	minimize	>	maximize	>	TRUE
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	>	minimize	>	maximize	>	maximize	>	FALSE
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	>	100	>	100	>	127	>	TRUE
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	>	0	>	0	>	127	>	TRUE
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	>	0	>	31	>	0	>	TRUE
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	>	0	>	100	>	0	>	TRUE
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	>	20	>	43	>	49	>	FALSE
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	>	3A	>	48	>	48	>	FALSE
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	>	9 - allgemeine Glühlampe 27W: auch H15	>	9 - allgemeine Glühlampe 27W: auch H15	>	1 - LED Tagfahrlichtmodul Versorgung	>	TRUE
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	>	Always	>	Always	>	Always	>	TRUE
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	>	Daytime running lights	>	Daytime running lights	>	Daytime running lights	>	TRUE
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	>	not active	>	not active	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	TRUE
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	>	not active	>	Blinken links aktiv (beide Phasen)	>	Coming Home oder Leaving Home aktiv	>	FALSE
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	>	not active	>	not active	>	Parklicht links (beidseitiges Parklicht aktiviert li & re)	>	TRUE
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	>	Lichthupe generell	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	not active	>	FALSE
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	>	not active	>	Parklicht links (beidseitiges Parklicht aktiviert li & re)	>	not active	>	TRUE
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	>	not active	>	Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken	>	not active	>	TRUE
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	>	not active	>	not active	>	not active	>	TRUE
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	>	maximize	>	minimize	>	maximize	>	TRUE
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	>	minimize	>	maximize	>	maximize	>	FALSE
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	>	100	>	100	>	127	>	TRUE
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	>	0	>	0	>	127	>	TRUE
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	>	0	>	31	>	0	>	TRUE
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	>	0	>	100	>	0	>	TRUE
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	>	21	>	44	>	4B	>	FALSE
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	>	44	>	4C	>	4C	>	FALSE
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	>	9 - allgemeine Glühlampe 27W: auch H15	>	9 - allgemeine Glühlampe 27W: auch H15	>	1 - LED Tagfahrlichtmodul Versorgung	>	TRUE
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	>	Always	>	Always	>	Always	>	TRUE
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	>	Daytime running lights	>	Daytime running lights	>	Daytime running lights	>	TRUE
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	>	not active	>	not active	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	TRUE
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	>	not active	>	Blinken rechts aktiv (beide Phasen)	>	Coming Home oder Leaving Home aktiv	>	FALSE
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	>	not active	>	not active	>	Parking light right	>	TRUE
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	>	Lichthupe generell	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	>	not active	>	FALSE
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	>	not active	>	Parking light right	>	not active	>	TRUE
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	>	not active	>	Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken	>	not active	>	TRUE
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	>	not active	>	not active	>	not active	>	TRUE
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	>	100	>	100	>	127	>	TRUE
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	>	0	>	0	>	127	>	TRUE
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	>	0	>	0	>	0	>	TRUE
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	>	0	>	0	>	0	>	TRUE
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	>	1A	>	1A	>	1A	>	TRUE
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	>	36	>	36	>	49	>	TRUE
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	>	11 - Abblendlicht	>	11 - Abblendlicht	>	3 - Xenon Abblendlicht	>	TRUE
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	>	Always	>	Always	>	Always	>	TRUE
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	>	Abblendlicht links	>	Abblendlicht links	>	Abblendlicht links	>	TRUE
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	>	not active	>	not active	>	Lichthupe generell	>	TRUE
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	>	not active	>	not active	>	Coming Home oder Leaving Home aktiv	>	TRUE
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	>	not active	>	not active	>	not active	>	TRUE
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	>	not active	>	not active	>	not active	>	TRUE
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	>	not active	>	not active	>	not active	>	TRUE
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	>	not active	>	not active	>	not active	>	TRUE
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	>	not active	>	not active	>	not active	>	TRUE
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	>	100	>	100	>	127	>	TRUE
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	>	0	>	0	>	127	>	TRUE
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	>	0	>	0	>	0	>	TRUE
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	>	0	>	0	>	0	>	TRUE
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	>	1B	>	1B	>	1B	>	TRUE
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	>	40	>	40	>	4D	>	TRUE
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	>	11 - Abblendlicht	>	11 - Abblendlicht	>	3 - Xenon Abblendlicht	>	TRUE
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	>	Always	>	Always	>	Always	>	TRUE
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	>	Abblendlicht rechts	>	Abblendlicht rechts	>	Abblendlicht rechts	>	TRUE
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	>	not active	>	not active	>	Lichthupe generell	>	TRUE
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	>	not active	>	not active	>	Coming Home oder Leaving Home aktiv	>	TRUE
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	>	not active	>	not active	>	not active	>	TRUE
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	>	not active	>	not active	>	not active	>	TRUE
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	>	not active	>	not active	>	not active	>	TRUE
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	>	not active	>	not active	>	not active	>	TRUE
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	>	not active	>	not active	>	not active	>	TRUE
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	>	100	>	100	>	0	>	TRUE
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	>	0	>	0	>	0	>	TRUE
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	>	0	>	0	>	0	>	TRUE
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	>	0	>	0	>	0	>	TRUE
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	>	1C	>	1C	>	0	>	TRUE
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	>	37	>	37	>	0	>	TRUE
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	>	23 - allgemeine Scheinwerfer	>	10 - allgemeine Scheinwerfer	>	not active	>	FALSE
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	>	Always	>	Always	>	Always	>	TRUE
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	>	Left high beam	>	Left high beam	>	not active	>	TRUE
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	>	Lichthupe generell	>	Lichthupe generell	>	not active	>	TRUE
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	>	not active	>	not active	>	not active	>	TRUE
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	>	not active	>	not active	>	not active	>	TRUE
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	>	not active	>	not active	>	not active	>	TRUE
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	>	not active	>	not active	>	not active	>	TRUE
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	>	not active	>	not active	>	not active	>	TRUE
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	>	not active	>	not active	>	not active	>	TRUE
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	>	maximize	>	maximize	>	maximize	>	TRUE
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	>	100	>	100	>	100	>	TRUE
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	>	0	>	0	>	0	>	TRUE
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	>	0	>	0	>	0	>	TRUE
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	>	0	>	0	>	0	>	TRUE
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	>	1D	>	1D	>	4	>	TRUE
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	>	41	>	41	>	0	>	TRUE
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	>	23 - allgemeine Scheinwerfer	>	10 - allgemeine Scheinwerfer	>	46 - LED Kleinleistung	>	FALSE
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	>	Always	>	Always	>	Always	>	TRUE
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	>	Right high beam	>	Right high beam	>	Ambientelicht 2	>	TRUE
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	>	Lichthupe generell	>	Lichthupe generell	>	not active	>	TRUE
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	>	not active	>	not active	>	not active	>	TRUE
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	>	not active	>	not active	>	not active	>	TRUE
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	>	not active	>	not active	>	not active	>	TRUE
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	>	not active	>	not active	>	not active	>	TRUE
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	>	not active	>	not active	>	not active	>	TRUE
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	>	not active	>	not active	>	not active	>	TRUE
Radiosolutions
C?ID=178437
What do I try. What do I have to change.thanks
I have noticed the car has led number plate lights. Is that correct.
DV52
C?ID=194404
Question 1
So - as I suggest above, the doubtful (I emphasis that I'm guessing) Leuchte-sets are Leuchte16BLK and Leuchte17TFL. Let's try and deactivate these Leuchte-sets and then see if the warning lights on the dash re-appear. To do this, try the following changes -please:
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 > not active (46 - LED Kleinleistung)
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 > not active (Ambientelicht 1)
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 > not active (46 - LED Kleinleistung)
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 > not active (Ambientelicht 2)
Note: I've shown the current settings in brackets, in case you need to revert the values back.
Question 2
The assigned Leuchte-set (normally) for the number plate is Leuchte25KZL HA59 and the setting in the Lasttyp channel tells the BCM what type of lamp is installed in the fitting.
As you can see from the setting below (which I thieved from your admap), the BCM has been instructed to operate the number-plate lamps as LED. In this mode, the PWM frequency that drives the lamps is double that of an incandescent setting and I suspect that other electrical characteristics also alter (because LEDs are current driven devices)- but I'm not sure about this latter bit!
Radiosolutions
C?ID=178437
Question 1
Question 2
I try these coding settings but still get vehicle lighting fault message. Strange one but cannot see why its happening.
Radiosolutions
C?ID=178437
just a update,just in case someone has same fault. there is a software update with odis online to cure the problem, all is fixed. thanks for all the help
