C7.5 A6 Auto SS Functionality
AudiSportB5S4
CT, USA
C?ID=58275
Hi all,
Doing some poking around and reading a recent thread on here about disabling the auto start/stop on the A1 thread, trying to figure out of it's been addressed on the C7.5s (2016) yet which I would imagine it has been. I have come across this post and wanted some help interpreting it.. I follow through most of this guessing that "worth" means value? I went into central electric 09, went to bit 34 and found that the value was 20. If I add 32 to that, so 52, that would achieve per what he says is essentially the SSA remembering how I set it between key cycles? I wanted to confirm this just because changing these values more so than the other ones in the long-coding helpers are a little scarier to me unless it's confirmed.
Appreciate any help as always!
Stg 09
Login 20113
Adaption channel 34 reading
a) worth of adaption channel 34 reduce by 4 (effected Bit 2 to 0) = SSA per default after each ignition on to off
or
b) add to worth of adaption channel 34 the worth 32 (effected Bit 5 to 1) = SSA with memory-function
and/or
c) add to worth of adaption channel 34 the worth 64 (effected Bit 6 to 1) = SSA with inverted display
Have we got an Auto-Scan from this car somewhere?
AudiSportB5S4
CT, USA
C?ID=58275
Ah right - apologies. I will post one the next time I get the chance to be in front of the car and run it.
AudiSportB5S4
CT, USA
C?ID=58275
I'll post one up (auto-scan) for the heck of it, but just wanted to post that what I originally put up worked for me.
Central Electric, Login with Security code, Adaptation channel 34, change value from 20 to 52
AudiSportB5S4
CT, USA
C?ID=58275
Posting up the auto-scan from this car.. And I know about the PCV fault :)
Monday,18,November,2019,13:12:17:61036
VCDS Version: 19.6.2.0
VIN: WAUFGAFC2GN086144   License Plate:
Mileage: 139193km-86490mi   Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3B 3C 42 44 46 52 53 55 5F
          62 6C 72 8F 90
VIN: WAUFGAFC2GN086144   Mileage: 139193km-86490miles
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G2 907 551 A    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0004
   Revision: --H10---
   Coding: 0A2A00320526010D3000
   ASAM Dataset: EV_ECM30TFS0214G2907551A 002001
   ROD: EV_ECM30TFS0214G2907551A_002.rod
   VCID: 2959C69548174E07D0-807C
24194 - PCV Valve Malfunction
          P052E 00 [109] - -
                    Mileage: 138465 km
                    Date: 2019.09.25
                    Time: 16:13:48
                    Engine speed: 705.75 /min
                    Normed load value: 23.9 %
                    Coolant temperature: 88 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 14.375 V
                    Air mass: actual value (mg/stroke): 151.40 mg/stroke
                    Throttle valve angle: 3.188 °
                    Oxygen ctrl factor with precontrol correction: -2.48 %
                    Oxygen control factor with precontrol correction: bank 2: -2.67 %
                    Engine status: Idling
                    Charge air pressure: actual value: 0.438 bar
                    Ambient air pressure: 0.998 bar
   Part No SW: 4G0 927 158 AM    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H19 1004
   Revision: --H19---
   Coding: 000001
   VCID: 79F9D6D5F8373E87E0-802C
   Coding: 44A7964122E569821B00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 41897E35D067A647E8-8014
   Part No SW: 4H0 907 064 GR    HW: 4H0 907 064 GR
   Component: BCM2 2.0      H37 0572
   Coding: 0DA86F4E000000000000
   VCID: 7F0D38CDEE1310B7DE-802A
   Serial number: 2315000204935016
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 4G0 820 043 CG    HW: 4G0 820 043 CG
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 11091500111261
   Coding: 66013118490000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 66C38DA99989A17F3D-8032
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Revision: 21020001    Serial number: 00001168863001
   Coding: 01050011003C9FE081004087C0003800CF9CD208A608022180000414F110150200600034030000
   VCID: 76E3DDE9C12951FF8D-8022
   Component: WWS57X 150808  H38 0080
   Serial number:         150820093130
   Coding: 0045F7
   Serial number: 20673541
   Coding: 02006D
   Component: E1 - LDS  H07 0044
   Serial number: 23 09 2015  00001126
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z020D7A31
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA121750000015669172
   Coding: 020300
   Subsystem 6 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Serial number: 16188AC7000000000001
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0002HTBZ
   Coding: 303331343135303334394A55304C34473053
   VCID: 346727E19FD503EF73-8060
   Component: BF-Gewichtss.  H11 0046
   Serial number: 6940000Y150001E2V70S
   Serial number: 3575HRB405N3JUCUD1OO
   Serial number: 3585HRB405T3JUCU5G4I
   Serial number: 3515JRB405P3I87IFHCV
   Serial number: 3525JRB405L3IT4AD85K
   Serial number: 3554VRB401A535LQ896C
   Serial number: 3564VRB401A535LQN1KY
   Revision: C0068538    Serial number: 90862OIJ00191
   Coding: 000034
   VCID: 3B750CDDBA8BCC97B2-806E
   Serial number: 14 08 2015  G0042630
   Part No SW: 4G8 920 986 P    HW: 4G8 920 986 P
   Component: TBenUsa       H11 0106
   Revision: 07001088    Serial number: 658190915592013
   Coding: 0BE609040B41D705020000
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 45816A25C44F8A67D4-8010
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001986435
   Coding: C0CD073010
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 3B750CDDB28BCC97B2-806E
   Serial number: 9120167903
   Voltage stabilizer:
   Serial number: 15071700000000000279
   Revision: AA000000    Serial number: 00000166691003
   VCID: 77FDD0EDC62328F796-8022
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720KM1FI
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 336524FD9ADB04D76A-8066
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H06 0060
   Serial number: 0381171629
   Coding: 040211
   VCID: 397916D5B8B7FE87A0-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0060
   Serial number: 0381799031
   Coding: 040211
   Coding: 011F17015E00628002000012
   VCID: 479D602DF643987726-8012
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000242066
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A7B09D9BDB1F59FA9-806E
   Revision: 00002001    Serial number: 0374675264
   Coding: 0106063A00FA408580B0080402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000312181
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST000JEXF900000
   Coding: 101F02
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93614170
   Coding: 011F17015E00628002000002
   VCID: 46836D29F149817FDD-8012
   Revision: --------    Serial number: 00000001603776
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D5132857CFF52273C-8078
   Coding: 04FA021122200400
   Coding: E01E00
   Coding: E01E00
13705487 - Databus
                    Reset counter: 213
                    Mileage: 138515 km
                    Date: 2019.11.09
                    Time: 16:20:35
   Part No SW: 4G1 035 027 M    HW: 4G1 035 027
   Component: MU-H-LNS-US   042 1062
   Serial number: A279I0F7500082
   Coding: 017501020000000013220002041A00102F0006E5F17001047E
   Shop #: WSC 00612 002 1048576
   VCID: 2A5B39994D11451FD9-807E
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Serial number: AUZ8Z9FY802FML
   Multimedia Operating Unit:
   Serial number: 90349PJB000TV
   Component: Gracenote2  --- 3006
   VCID: 49996615E0576E0730-801C
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 0275000102002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
   VCID: 78FFD3D1C33D278F9F-802C
   Component: RGS-VL        H14 0080
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31692EF560C736C718-8064
   Component: RGS-VR        H14 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 326B21F965C10DDF61-8066
End-------------------------(Elapsed Time: 05:59)--------------------------
hadez16
C?ID=289891
Yes, do it.
