MKV Unable to learn base steering angle limits
AndrewS.
C?ID=384326
HI all!
First post and over all new to VCDS. First off i love the software... but i'm worried i screwed something up. I've had no trouble with things like programming new key fobs, adapting new CECM and multi function steering wheel and a few other tweaks. At some point though the yellow steering and the traction control lights came on and both are functioning in an extremely limited mode if they are functioning at all. i tried the learning process with turning the wheel to certain positions for specified times and also driving for several hundred miles hoping it would self learn but have had no such luck.:banghead: Currently i'm at a bit of a loss and don't know where to "turn" next and would appreciate and suggestions.
Thanks in advance!
AutoScan-
Sunday,03,November,2019,18:42:50:38212
VIN: WVWCR71K16W170286   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWCR71K16W170286   Mileage: 491360km-305316miles
37-Navigation -- Status: Not registered 0011
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 AR    HW: Hardware No
   Component: 2.5l R5/4V      G   6747
   Revision: --------    Serial number: VWZ7Z0F3579635
   Shop #: WSC 01279 785 00200
   VCID: 79AFEAD365D0068F8E9-802C
000017 - Bank 1: Camshaft A (Intake)
               P0011 - 008 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
                    Mileage: 489428 km
                    Time: 22:17:54
                    RPM: 2153 /min
                    Load: 60.8 %
                    Speed: 88.0 km/h
                    Temperature: 78.0°C
                    Temperature: 14.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.970 V
000369 - Fuel Trim; Bank 1
               P0171 - 001 - System Too Lean - Intermittent
                    Fault Status: 00100001
                    Mileage: 489532 km
                    Time: 20:46:53
                    RPM: 1947 /min
                    Load: 70.6 %
                    Speed: 79.0 km/h
                    Temperature: 83.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.843 V
005170 - Secondary Air Injection Solenoid Valve (N112)
               P1432 - 004 - Open Circuit - Intermittent
                    Mileage: 490081 km
                    Time: 00:07:19
                    RPM: 1017 /min
                    Load: 36.8 %
                    Temperature: 61.0°C
                    Temperature: 36.0°C
                    Voltage: 8.001 V
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0021122
   VCID: 71BFD2F33DA04ECF369-8024
   Part No: 1K0 820 047 EC
   Component: Climatic PQ35   090 0505
   VCID: 698FBA931570B60F7E9-803C
   Revision: 00H46000    Serial number: 00000002330203
   Coding: 008D8F314004150000140000001400000028730B5C0000
   Shop #: WSC 01287 785 00200
   VCID: 372B2CEB1344D0FF38D-8062
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Shop #: WSC 01287
                    Reset counter: 81
                    Mileage: 491361 km
                    Voltage: 12.75 V
   Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
   Component: 5L AIRBAG VW8R  032 7900
   Revision: 03032000    Serial number: 0038FD05CLB2
   Coding: 0013644
   Shop #: WSC 01269 785 00200
   VCID: 392F2AD32550C68FCE9-806C
   Subsystem 1 - Part No: 1K0 959 339 D
   Component: BF-Gewichtsens. 006 0006
   Subsystem 2 - Serial number: 6332MSME107B3A1AE
   Subsystem 3 - Serial number: 6342MSME110B630F9
   Subsystem 4 - Serial number: 6352QSME0B3222478
   Subsystem 5 - Serial number: 6362QSME0A2C117BM
   Subsystem 6 - Serial number: 63727SME09650203S
   Subsystem 7 - Serial number: 63827SME086C05495
   Part No SW: 1K0 953 549 AJ    HW: 1K0 953 549 AJ
   Component: J0527           034 0070
   Coding: 0002022
   VCID: 7AADF5DF60D60D97873-802E
   Component: E0221           007 0050
   Part No: 1K0 920 953 C
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0007203
   Shop #: WSC 07434 444 92463
   VCID: 2B03009BDF0C641F4C5-807E
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800106318118A
   Coding: 3D3F0340070002
   VCID: 2A0D059FD0F67D17B73-807E
                    Reset counter: 81
                    Mileage: 491361 km
                    Time: 07:40:39
01304 - Radio
                    Reset counter: 81
                    Mileage: 491361 km
                    Time: 07:40:43
                    Reset counter: 81
                    Mileage: 491361 km
                    Time: 07:40:43
   Component: IMMO            VDD 4312
   Shop #: WSC 07320 444 12178
Address 37: Navigation
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2373
   Coding: 0001205
   VCID: 363521EF144E29F723B-8062
   Part No: 1K1 909 144 K
   VCID: 333318FB073C3CDF045-8066
02546 - Steering Limit Stop
                    Mileage: 1360 km
                    Temperature: 18.0°C
                    Voltage: 11.70 V
                    Voltage: 11.50 V
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AF
   Coding: 13C803083F09058F880F048050CC
   Shop #: WSC 07437 444 12591
   VCID: 74B1DBE742B27BE7DDF-8020
   Part No: 1K0 959 702 K
   Coding: 0001205
Address 56: Radio
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2438
   Coding: 0000144
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 34311BE702323BE71DF-8060
End----(Elapsed Time: 01:00, VBatt start/end: 12.7V/11.9V. VIgn 11.9V)-----
AndrewS.
C?ID=384326
thanks for the tip!
i did some more digging and found that under the measuring blocks for 03-ABS, under group 4 the angle sensor is reading 0.00 degrees all the time. (not sure if that's just because its not properly calibrated or not.) To eliminate any physical damage as a potential problem i just replaced both the steering angle sensor and clock spring that has the flags on the back. the reading is still the same.
its probably relevant to note that the steering column computer, MFSW, CECM, clock spring, and angle sensor are now all out of a GTI and on my Rabbit.
So you're saying you've got parts on this car that may not be the correct parts?
Jack will be along with "FOD" in 3... 2.. 1. :)
JPPSG
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
AndrewS.
C?ID=384326
Looks like I need to move this to retrofits if I can figure out how:p
AndrewS.
C?ID=384326
OK, status update. after letting the car sit over night i came back and read measuring block 4 again. IT WORKED!! super excited that it wasn't a physical issue and that everything worked with the current combination of parts i decided it would be a good idea to re perform the sensor calibration. after carefully performing all the steps and everything was accepted, i went back to read the sensor output. its back to 0.00..........:banghead:
what the heck did i do wrong?
MartinsX
Riga, Latvia
C?ID=268515
Sometimes some ESP and/or Steering Assist systems "don't like" basic settings procedure by some reason. But it's enough to turn steering wheel from one end stop to another and return it to center position and calibration is done without any diagnostic equipment. Engine must be running.
For example some days ago I had Skoda Superb in my workshop for some electric repairs. After finishing work I reconnected battery and yellow steering warning light was on along with the same fault codes:
                    Mileage: 1360 km
                    Temperature: 18.0°C
                    Voltage: 11.70 V
                    Voltage: 11.50 V
P.S. Fault codes are copied from OP's scan, in my case FF data was different, of course.
Tried calibration several times - unsuccessful.
Started engine, turned wheel from end to end and warning light went off, fault codes disappeared.
Scan after repairs done, just for reference:
Monday,28,October,2019,23:48:54:32442
VCDS Version: 19.6.1.0
VIN: TMBJB93T0C9069635   License Plate:
Chassis Type: 3T-SK46 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 42 44 46 52 55 56 62
          6D 72 77
VIN: TMBJB93T0C9069635   Mileage: 110910km-68916miles
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 3T0 907 115 G    HW: 1Z0 907 115 F
   Component: 1.8l R4/4V TFSI     0030
   Revision: AAH18---    Serial number:
   Coding: 0203000C24070160
   Shop #: WSC 33361 790 00999
   VCID: 35614BEB5C3FCCE77A-8060
Readiness: 1110 0101
   Part No SW: 0AM 300 053 A    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 3070
   Revision: 00043014    Serial number: CU501203315185
   Shop #: WSC 33361 790 00098
   VCID: 2A5B68978581931FE7-807E
   Revision: 00H31001
   Coding: 843D601609280003211106E7901E0041350000
   VCID: 7BF59DD3FA9BDA97CC-802E
   Revision: 00085000    Serial number: 0172806223
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_SK46.rod
   VCID: 346776EF9F45D5EF4D-8060
   Part No SW: 3T0 907 044 BL    HW: 3T0 907 044 BL
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK46.rod
   VCID: 7DF193CBEC8FD4A7F2-8028
   Part No SW: 1K0 937 087 AB    HW: 1K0 937 087 AB
   Component: BCM PQ35  H+  110 0651
   Revision: 00110 AC
   Coding: 40190AB8E05BF1C040080080710089E4437100AE776D8DF05C814000A040
   VCID: 71E9BFFBA8D7A0C766-8024
   Subsystem 1 - Part No: 3T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 16041  26  0602
   Coding: 00D7B7
   Component: RLS 170412 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32961210801708
   Coding: 108115
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_001.rod
   VCID: 336575F39A4BD2D754-8066
   Part No SW: 3T0 959 655 D    HW: 3T0 959 655 D
   Component: J234__LBH VW10 HI   2118
   Revision: 22017000    Serial number: 003LEP7QKUV5
   Coding: 0016968
   VCID: 428B20371DF16B5FCF-8016
   Subsystem 1 - Serial number: 6332MTS644832838
   Subsystem 2 - Serial number: 6342MTS665880872
   Subsystem 3 - Serial number: 6351HTS6VH5E1BKR
   Subsystem 4 - Serial number: 6361HTS660CL1BKJ
   Subsystem 5 - Serial number: 63727TS6EDD8MAKJ
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20120413200829
   Coding: 100A140000
   ROD: EV_SMLSNGVOLWS.rod
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
   Part No SW: 3T1 920 841 J    HW: 3T1 920 841 J
   Component: KOMBI         H05 0607
   Coding: 111F01
   VCID: 3A7B58D7BD21239F97-806E
   Revision:   H42       Serial number: 210412F2000232
   Coding: 359302
   VCID: 3A7B58D7B521239F97-806E
   Component: IMMO          H05 0607
   Coding: 000007
   VCID: 6ADBA8978D01531F27-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 12000070332005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E5364877169FF3F3B-807A
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
   Component: TSG FA        H09 0410
   Coding: 011D0220D000001000
   VCID: 4FAD19031EA3963750-801A
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 194    3305
   Revision: 00H22000
   VCID: 377D41E346333EF768-8062
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
   Component: TSG BF        H09 0410
   VCID: 4E93040719A99F3F5B-801A
   Coding: 1376839
   VCID: 346776EF5745D5EF4D-8060
   Coding: 00000021
   Component: AFS-Lst.-Modul r    S002
   Coding: 00000021
   Part No SW: 3T0 035 156 F    HW: 3T0 035 156 F
   Component: BOLERO        001 0008
   Revision: -----08S    Serial number: SKZ4Z3M1133283
   Coding: 0D0004000004
   VCID: 31697FFB6857E0C726-8064
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010C00200000001000
   Part No SW: 7N0 959 107 C    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0804
   Revision: 41011001    Serial number: 089200437
   Coding: 082301C002
   ASAM Dataset: EV_HDSGSk462 301133
   ROD: EV_HDSGSk462_SK46.rod
   VCID: 377D41E38E333EF768-8062
   Component: TSG HR        H06 0409
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007662363133
   Coding: 0B00000000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 275D91A35E93AE77F8-8072
End-------------------------(Elapsed Time: 03:30)--------------------------
Figure eight's and in reverse too might help, right Mr. X?
Sometimes carrying out in same session doing basic settings for G85 in 0x03 and 0x44 might do the trick?
MartinsX
Riga, Latvia
C?ID=268515
Of course, Jack. But this time it was not necessary in my case ;)
