2006 Audi S4 Avant Manual missfire issues
cdsjklee
C?ID=379696
Hello.First time Audi owner and Just purchased Ross Tech scannder per Forum members suggestion.
I have 2006 S4 Manual. 87000 miles
car seem fine at idle but when I drive it hesitates and drives very sluggish.
when RPM is raised to 2500 or over CEL flashes and sometimes CEL goes away soon as I slow down.
But sometimes it stays on solid.
CEL Code
P0300, P0301, P0302,P0305,P0307,P0308
P0174,P0172
so far repair shop replaced all the spark plugs, Coils packs, Injectors, fuel filters, Vapor Canister Purge Solenoid.
Car ran fine for for about 4000 miles then another CEL
P0300,P0301,P0302, P0303, and same condition as before..
errors appear under load not at idle.
At idle engine does not shake it is very smooth. It is very quite even at cold start.
Also Passenger side exhaust out put is very weak compare to the Drivers side.
Please Help.
Friday,18,October,2019,12:36:53:62900
VIN: WAUUL78E26A135028   License Plate:
Mileage: 140840km-87513mi   Repair Order:
          67 69 75 76 77
VIN: WAUUL78E26A135028   Mileage: 140840km-87513miles
Address 01: Engine        Labels: 079-910-560-BBK.lbl
   Part No SW: 8E2 910 560     HW: 8E2 907 560
   Component: 4.2L V8/5V      G   0030
   Revision: --H01---    Serial number:
   Coding: 0007711
   Shop #: WSC 26147 444 51445
   VCID: 6491AC2C0254E4674DF-8030
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
   Component: ESP8 quattro    H05 0120
   Coding: 0004901
   Shop #: WSC 06325 000 00000
   VCID: 290FFD1825F6790FBE9-807C
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Reset counter: 38
                    Hex Value: 0x0000
                    Hex Value: 0x6222
                    Hex Value: 0x0028
                    Hex Value: 0x018C
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2832
   Coding: 00000
   VCID: 6D87C908D48EA52F121-50D0
            80-00 - Single-Wire Operation
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  USA 0504
   Coding: 11023
   Shop #: WSC 65536
   VCID: 3B233750DA7AFB9FDC5-4AA4
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW:
   Component: SDAR XM
   Revision:             Serial number: AUZ4Z7E8036892
   VCID: 2B0307102F2A6B1F4C5-513C
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H11 3540
   Revision: 91H1135    Serial number: 0036N0011GCJ
   Coding: 0032607
   VCID: 3C21344CDA64FCA7D5F-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 35NRL
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB4022A932EPÿ†63
   Subsystem 5 - Serial number: A932EPÿ†6342DRB4025189A4Nÿ†63
   Subsystem 6 - Serial number: 189A4Nÿ†6352ARB400B524DCTÿ†63
   Subsystem 7 - Serial number: 524DCTÿ†6362ARB400B3CE80Vÿ†63
   Subsystem 8 - Serial number: 3CE80Vÿ†63729RB400C58452Jÿ†63
   Subsystem 9 - Serial number: 58452Jÿ†63829RB400C58462Lÿ
   Subsystem 10 - Serial number: 58462Lÿ
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 04042
   Shop #: WSC 06325
   VCID: 41DF45B8B896914F869-4AA4
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 982 C    HW: 8E0 920 982 C
   Component: KOMBI+WFS 4     H12 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0023261
   Shop #: WSC 26147 444 58994
   VCID: 2E050E041C081E376BB-50F4
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0023261
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71BFD578C88641CF369-4B1E
   Part No: 8E0 959 433 BT
   Component: Komfortgerát T7B    3332
   Coding: 12092
   Shop #: WSC 06325
   VCID: 04518CACE7044467EDF-4AA4
   Component: Tõrsteuer.FS BRM 0506
   Component: Tõrsteuer.BF BRM 0205
   Component: Tõrsteuer.HL BRM 0606
   Component: Tõrsteuer.HR BRM 0606
9 Faults Found:
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Component: AFS 1           H01 0010
   Coding: 0000019
   VCID: 2809F81C3EFC4007A17-807C
   Subsystem 1 - Part No: 8E0 941 329
   Component: AFS-Modul links H03 0020
   Subsystem 2 - Part No: 8E0 941 329
   Component: AFS-Modul rechtsH03 0020
02769 - Headlight Swivel Module; Left
                    Fault Status: 00100011
                    Reset counter: 15
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8E0 035 192 F    HW: 8E0 035 192 F
   Component: RNS-E US3       H70 0110
   Revision:      01S    Serial number: AUZBZ7E2002903
   Coding: 0309637
   Shop #: WSC 06431 176 52258
   VCID: 270BFB2033C24F7FA8D-513C
7 Faults Found:
00532 - Supply Voltage B+
                    Fault Frequency: 10
                    Reset counter: 79
                    Date: 2006.01.21
                    Time: 04:40:38
                    Voltage: 11.80 V
                    Fault Frequency: 13
                    Reset counter: 79
                    Date: 2006.01.21
                    Time: 04:39:45
                    Voltage: 11.80 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
02261 - Data Medium
                    Fault Status: 00101110
                    Reset counter: 60
                    Date: 2005.03.13
                    Time: 21:37:25
                    Mileage: 655350 km
                    Count: 604
                    Clock: 15:37
00856 - Radio Antenna
                    Fault Status: 00101011
                    Reset counter: 60
                    Date: 2005.02.10
                    Time: 00:00:57
                    Mileage: 655350 km
                    Count: 1002
                    Clock: 02:53
                    Reset counter: 79
                    Date: 2005.02.10
                    Time: 00:02:43
                    Mileage: 655350 km
                    Count: 2607
                    Clock: 22:55
00857 - CD Changer Unit (R41)
                    Fault Frequency: 22
                    Reset counter: 64
                    Date: 2007.04.09
                    Time: 17:46:05
                    Fault Frequency: 34
                    Reset counter: 79
                    Date: 2006.04.30
                    Time: 08:29:48
                    Bin. Bits:     0000
                    Mileage: 655350 km
                    Count: 610
                    Clock: 11:55
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273     HW: 8E0 907 273
   Component: Reifendruck 3   H03 0110
   Coding: 0063022
   Shop #: WSC 06435 000 00000
   VCID: 698FBD18E556B90F7E9-513C
   Part No SW: 8P0 862 335 G    HW: 8P0 862 335 G
   Component: FSE_255x BT     H21 0190
   Revision: 00000001    Serial number: 00000000331627
   Coding: 0011877
   VCID: 3A2D3254D040C297C73-50D0
End----(Elapsed Time: 04:55, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
                Address 01: Engine  (8E2 910 560 )
12:53:37 Group 001: General
  760 /min  Engine Speed (G28)
  41.0°C  Coolant Temperature (G62)
  5.5 %  Lambda Control Bank 1
  6.3 %  Lambda Control Bank 2
  1.6 %  Lambda Control Bank 1
  10.2 %  Lambda Control Bank 2
12:53:37 Group 002: General
  18.0 %  Engine Load
  3.28 ms  Injection Timing
  6.39 g/s  Mass Air Flow Sensor (G70)
12:53:39 Group 001: General
  2.3 %  Lambda Control Bank 1
  10.9 %  Lambda Control Bank 2
12:53:39 Group 002: General
  18.0 %  Engine Load
  6.28 g/s  Mass Air Flow Sensor (G70)
Readiness Status: 0110 0101
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Failed or Incomplete
Oxygen Sensor(s): Failed or Incomplete
Air Conditioning: Passed
Secondary Air Injection: Passed
Evaporative Emissions: Failed or Incomplete
Catalyst Heating: Passed
Catalytic Converter(s): Failed or Incomplete
What do the fuel trims look like? Any significant difference between the banks?
cdsjklee
C?ID=379696
They are different.
I do not know how to post pictures so this is best I can do
Adaptation(Idle) Adaptation(Partial)
Bank 1 Sensor 1 Bank 1 Sensor 1 Bank 1 Sensor 1 Bank 2 sensor 2
Group 032 0.4% 0.0% 1.5% 0.0% Value stays same
Group 033 -1.6% to 2.3% 1.520v to1.540v 0.8% to -2.3%, -3.1% 1520v to 1.540V Value changes
cdsjklee
C?ID=379696
I removed passenger side oxygen sensor before pre cat and sensor is tan color not black as I see the pictures of used oxygen sensor.
Is it normal ?
They are different.
I would not call that difference significant. Moreover, those long-term numbers are all at idle, and IIRC, your problems come under load. Since you cleared fault codes recently, you're going to have to drive the car some before the "Partial Load" values will budge from zero.
cdsjklee
C?ID=379696
Are these failed or incomplete meaning these failed or Incomplete parts need to be replaced?
No, it means the routines that monitor/test those systems have not had a chance to run (have not seen the correct conditions) since the last time you cleared fault codes.
cdsjklee
C?ID=379696
Just drove the S4 for about 14 miles it started ok for few miles then on the freeway RPM does not go over 3000 very sluggish.
then CEL flashes as I was try to go little faster but soon as I let go the gas CEL goes away...
At lower speed when I raise the RPM pass 3000 I hear some kind of knocking sound.
Temp guage is set at about middle but engine bay seems very hot.
and Yellow Flat tire looking symbol has appeared on center screen.
These are the result of Log.
Sunday,20,October,2019,09:05:52:62900
09:05:30 Group 031: Lambda Control (Lambda Sensor Voltages)
  1.991  Lambda Control Bank 1 (actual)
  1.000  Lambda Control Bank 1 (specified)
  1.991  Lambda Control Bank 2 (actual)
  1.000  Lambda Control Bank 2 (specified)
09:05:30 Group 032: Lambda Control (Mixture Adaptation)
  0.4 %  Adaptation (Idle) Bank 1 Sensor 1
  -9.4 %  Adaptation (Partial) Bank 1 Sensor 1
  -2.4 %  Adaptation (Idle) Bank 2 Sensor 1
  11.7 %  Adaptation (Partial) Bank 2 Sensor 1
09:05:30 Group 033: Lambda Control
  0.0 %  Lambda Control Bank 1 Sensor 1
  3.780 V  Sensor Voltage Bank 1 Sensor 1
  0.0 %  Lambda Control Bank 2 Sensor 1
  3.960 V  Sensor Voltage Bank 2 Sensor 1
09:20:58 Group 031: Lambda Control (Lambda Sensor Voltages)
  1.000  Lambda Control Bank 1 (actual)
  1.000  Lambda Control Bank 2 (actual)
09:20:58 Group 032: Lambda Control (Mixture Adaptation)
  0.8 %  Adaptation (Idle) Bank 1 Sensor 1
  -13.3 %  Adaptation (Partial) Bank 1 Sensor 1
  -3.4 %  Adaptation (Idle) Bank 2 Sensor 1
  20.3 %  Adaptation (Partial) Bank 2 Sensor 1
09:20:58 Group 033: Lambda Control
  2.3 %  Lambda Control Bank 1 Sensor 1
  1.540 V  Sensor Voltage Bank 1 Sensor 1
  2.3 %  Lambda Control Bank 2 Sensor 1
  1.520 V  Sensor Voltage Bank 2 Sensor 1
09:21:09 Group 031: Lambda Control (Lambda Sensor Voltages)
09:21:09 Group 032: Lambda Control (Mixture Adaptation)
09:21:09 Group 033: Lambda Control
  3.9 %  Lambda Control Bank 1 Sensor 1
  1.520 V  Sensor Voltage Bank 1 Sensor 1
  -2.3 %  Lambda Control Bank 2 Sensor 1
                Address 01: Engine       Labels: 079-910-560-BBK.LBL
Control Module Part Number: 8E2 910 560     HW: 8E2 907 560
  Component and/or Version: 4.2L V8/5V      G   0030
           Software Coding: 0007711
            Work Shop Code: WSC 26147 444 51445
17538 - Fuel Trim; Bank 2 (Mult)
            P1130 - 001 - System too Lean
                    Fault Status: 01100001
                    Mileage: 140864 km
                    RPM: 2931 /min
                    Load: 40.4 %
                    Speed: 111.0 km/h
                    Temperature: 90.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.843 V
            P0300 - 001 -
                    Mileage: 140868 km
                    RPM: 3286 /min
                    Load: 71.7 %
                    Speed: 47.0 km/h
                    Temperature: 96.0°C
                    Temperature: 37.0°C
                    Voltage: 13.716 V
16686 - Cylinder 2
            P0302 - 001 - Misfire Detected
                    Mileage: 140868 km
                    RPM: 3286 /min
                    Load: 71.7 %
                    Speed: 47.0 km/h
                    Temperature: 96.0°C
                    Temperature: 37.0°C
                    Voltage: 13.716 V
16685 - Cylinder 1
            P0301 - 001 - Misfire Detected
                    Mileage: 140869 km
                    RPM: 3424 /min
                    Load: 71.7 %
                    Speed: 68.0 km/h
                    Temperature: 99.0°C
                    Temperature: 35.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.843 V
16687 - Cylinder 3
            P0303 - 001 - Misfire Detected
                    Mileage: 140869 km
                    RPM: 2855 /min
                    Load: 74.9 %
                    Speed: 40.0 km/h
                    Temperature: 102.0°C
                    Temperature: 40.0°C
                    Voltage: 13.716 V
Readiness: 0000 0101
Readiness Status: 0000 0101
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Passed
Wow, there's quite a difference now in fuel trims. Bank one went rich while bank 2 went lean.
I am not sure what would cause this, but hopeflly someone will have some ideas.
cdsjklee
C?ID=379696
someone told me my S4 may have clogged cat. but I do not have any CEL for Clogged cat or oxygen sensor. what do you guys think?
it gets worse as temp goes up.
Remove before-CAT oxygen sensor and use a bore-scope "snake" camera to do a visual inspection? Those things are pretty cheap now; many will work with a smart-phone:
https://www.amazon.com/s?k=endoscope
cdsjklee
C?ID=379696
Removed Bank 1 cat (passenger side), It looks OK.
Do not see any broken pieces and I did shake the cat no rattling sound.
but as I mention before Bank 1 side exhaust is very weak compare to Driver side. Exhaust out put should be same on both side or is it normal to have ones side a lot more stronger than other side ?
I connected vacuum to Pre cat side of pipe and checked to see any air movements through the pipe.
it does move air but very of weak I am not sure how strong it should move air . Is there a better way to check if cat is clogged ?
I would also expect it to be close to equal, but I do not have a good mental (or any other kind of) picture of this exhaust system. Is it fully separate or are there one or more cross-overs or common paths?
grant@gendan
Have the front pre-CAT Lambda sensors been changed? Most pre-CAT Lambda sensors are only good for about 50K-60K miles then they get sluggish.
You mention you have changed many parts on this engine but do not mention replacing these sensors.
Maybe one has been replaced previously and is working OK while the other is sluggish.
The car ignores these sensors until the engines has warmed-up so if it runs OK cold, this could be another pointer towards the Lambda sensors.
I also recommend performing a compression test on each cylinder. I have seen hairline cracks in the head cause similar issues once the engine gets hot.
cdsjklee
C?ID=379696
Hello.
I managed to resolve the missfire issues.
car runs well now drive about 80 miles with no issues but now I have one fault code P0421 (expected since I have gutted pre cat bank1) It looked fine but it was at lest 90% clogged.
After gutted pre cat exhaust output was a lot more stronger. Now need install a new cat on bank1 now.
need to get a smog check but readiness is not ready after 80 miles of driving.
Friday,22,November,2019,12:22:12:62900
VIN: WAUUL78E26A135028   License Plate: 111
Mode 9 : Calibration Identification
Type 02 - VIN : WAUUL78E26A135028 (Address E8)
Type 04 - Calibration ID : 8E2910560   0030 (Address E8)
Type 06 - Calibration Verification Number : 8D4973D0 (Address E8)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 2501
    Ignition cycle count : 12098
    Conditions completion count / Specified conditions encountered count
         Catalyst monitor bank 1 : 3641 / 2496
         Catalyst monitor bank 2 : 3629 / 2496
         O2 Sensor monitor bank 1 : 1882 / 2501
         O2 Sensor monitor bank 2 : 1839 / 2501
         EGR-VVT monitor : 0 / 0
         AIR monitor : 0 / 0
         EVAP monitor : 452 / 849
Saturday,23,November,2019,14:52:14:62900
Mode 03: Emission related fault codes
Address 7E8: 1 Fault Found:
P0421 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 1  --  MIL Status: MIL ON
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Passed
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Passed
Secondary air system monitoring:  Passed
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Passed
Oxygen sensor heater monitoring:  Passed
Exhaust Gas Recirculation: Not installed.
Fuel System:  Passed
Fuel System:  Passed
          67 69 75 76 77
VIN: WAUUL78E26A135028   Mileage: 141020km-87625miles
   Coding: 0007711
16805 - Warm Up Catalyst; Bank 1
            P0421 - 001 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11100001
                    Mileage: 140981 km
                    RPM: 2638 /min
                    Load: 22.7 %
                    Speed: 53.0 km/h
                    Temperature: 93.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.716 V
   Coding: 0004901
   Coding: 00000
   Coding: 11023
   Shop #: WSC 65536
   Component: SDAR XM
   Coding: 0032607
   Coding: 04042
   Shop #: WSC 06325
   Coding: 0023261
   VCID: 2E050E041C081E376BB-5118
   Coding: 0023261
   Coding: 00002
            37-10 - Faulty - Intermittent
            80-10 - Single-Wire Operation - Intermittent
   Coding: 12092
   Shop #: WSC 06325
   Coding: 0000019
   Coding: 0309637
   Coding: 0063022
   Coding: 0011877
End----------(Elapsed Time: 05:14, VBatt start/end: 12.4V/12.3V)-----------
Saturday,23,November,2019,15:03:35:62900
Freeze Frame Data for address 7E8
    PID02 DTC that caused freeze frame data storage: P0421
    PID03 Fuel system 1/2 status: Closed loop, using O2 sensors
              ... Closed loop, using O2 sensors
    PID04 Calculated load value: 22.7 %
    PID05 Engine coolant temperature: 93 °C
    PID06 Short Term Trim - Bank 1: 0.0 %
    PID07 Long Term Trim - Bank 1: 0.8 %
    PID08 Short Term Trim - Bank 2: 1.6 %
    PID09 Long Term Trim - Bank 2: -3.1 %
    PID0C Engine RPM: 2638 /min
    PID0D Vehicle speed: 53 km/h
    PID0E Ignition timing advance for cyl #1: 38.0 Degrees
    PID0F Intake air temperature: 21 °C
    PID10 Mass Air Flow: 21.08 g/s
    PID11 Throttle position sensor: 15.7 %
    PID12 Secondary Air Status: Atmosphere/off
    PID1F Time since engine start: 851 s
