2009 Jetta 2.5 Abs Coding [MK60EC1]
Jessenelms13
College Grove TN, USA
C?ID=383660
Hey guys i got back and the new interface arrived today.
Still needing the coding if you can help. Please let me know what else i need. Thanks
Tuesday,15,October,2019,15:34:46:26550
VIN: 3VWTM71K89M310236   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 65
          72
VIN: 3VWTM71K89M310236   Mileage: 260050km-161587miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 P    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9205
   Revision: G6H02---    Serial number: VWX7Z0HD24201Z
   Coding: 0000075
   VCID: 3B2330C74F63DBBFDC5-806E
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Mileage: 259893 km
                    Time: 11:20:05
                    Temperature: 55.0°C
                    Temperature: 44.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 12.065 V
000819 - Knock Sensor 2 (G66)
               P0333 - 000 - Signal too High - Intermittent
                    Mileage: 259928 km
                    Time: 17:01:02
                    RPM: 1961 /min
                    Load: 67.0 %
                    Speed: 93.0 km/h
                    Temperature: 85.0°C
                    Temperature: 45.0°C
                    Voltage: 13.843 V
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000840
   VCID: 7DA7FEDF11F7158FA21-8028
   Part No SW: 1K0 907 379 AM    HW: 1K0 907 379 AM
   Component: ESP MK60EC1   H45 0108
   Revision: 00H45001
   VCID: 7DA7FEDF1DF7158FA21-8028
                    Fault Status: 01100101
                    Reset counter: 68
                    Mileage: 260030 km
                    Count: 3
                    Count: 28672
                    Count: 279
                    Count: 41216
                    Count: 768
                    Reset counter: 68
                    Mileage: 260030 km
                    Count: 3
                    Count: 28672
                    Count: 295
                    Count: 41216
                    Count: 768
                    Reset counter: 68
                    Mileage: 260030 km
                    Count: 3
                    Count: 28672
                    Count: 270
                    Count: 41216
                    Count: 768
                    Reset counter: 68
                    Count: 7
                    Count: 28672
                    Count: 195
                    Count: 41216
                    Count: 50432
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A9EFCB3ED530A7F17-802C
   Revision: 00H54000    Serial number: 00000001152291
   Coding: 148D8F2340041500070000001C000000000873075C000120000000000000
   VCID: 323D1DE398291AF70F3-8066
   Component: Wischer 081208 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 1K0 909 605 AC    HW: 1K0 909 605 AC
   Component: 0K AIRBAG VW8R  038 8600
   Revision: 07038600    Serial number: 003E7M0851M$
   Coding: 0012363
   VCID: 6D87CE9F4197850F121-8038
   Subsystem 2 - Serial number: 6332MSME42126B3AA
   Subsystem 3 - Serial number: 6342MSME423427723
   Subsystem 4 - Serial number: 6351HSME19284F2EM
   Subsystem 5 - Serial number: 6361HSME19490F6FR
   Subsystem 6 - Serial number: 63727SME1A021B6F6
   Subsystem 7 - Serial number: 63827SME1A046466+
00532 - Supply Voltage B+
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           052 0111
   Coding: 0001034
   VCID: 025D8D2368096A77DF3-8056
   Part No SW: 1K0 920 974 Q    HW: 1K0 920 974 Q
   Component: KOMBIINSTRUMENT 3HL 2416
   Revision: V0003000    Serial number: VWX7Z0HD24201Z
   Coding: 0007203
   VCID: 3C2133DB4A6DDC87D5F-8068
                    Reset counter: 104
                    Mileage: 259893 km
                    Time: 11:20:06
   Part No SW: 1K0 907 530 T    HW: 1K0 907 951
   Component: J533  Gateway   H06 0071
   Revision:   H06 01    Serial number: 261008F1000692
   Coding: ED807F07400213002002
   VCID: 38292FCB7E55F0A7317-806C
                    Fault Status: 00110100
                    Reset counter: 104
                    Mileage: 259893 km
                    Time: 11:20:06
   Component: IMMO            3HL 2416
   Part No SW: 5N0 035 342 A    HW: 5N0 035 342 A
   Component: SG EXT.PLAYER H13 0062
   Revision: A1001003    Serial number: 7667278125
   VCID: 2517F6BFD5E77D4F9A1-8070
   Part No SW: 3C0 035 684 A    HW: 3C0 035 684
   Component: RNS-MID       H17 0380
   Revision: AB001001    Serial number: VWZ6Z7H5293102
   Coding: 040004000400000600
   VCID: 211FE2AFC1CF916FE69-8074
03181 - Internal Error SDARS Module
                    Reset counter: 108
                    Mileage: 185920 km
00856 - Radio Antenna
                    Reset counter: 69
                    Mileage: 243936 km
   Revision: 72009005    Serial number: 00000665589106
   Coding: 0001205
   VCID: 6FBBD4974B9B771F20D-803A
   Part No: 1K0 909 144 C
   Revision: 00H15000
   VCID: 2A0D0583B0F95237B73-807E
                    Reset counter: 114
                    Mileage: 259893 km
                    Time: 11:20:06
                    Voltage: 12.13 V
                        DD
                    Temperature: 38.0°C
   Coding: 139007885283281B0904058FB0880F0488DC00
   VCID: 04518B3B721D6447EDF-8050
                    Fault Status: 00100111
                    Fault Frequency: 10
                    Reset counter: 105
                    Mileage: 257541 km
                    Time: 08:16:42
Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 6695B1B36861B65753B-8032
   Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB10  H01 0180
   Revision: 72009005    Serial number: 08110205233901
   Coding: 0001204
   VCID: 70B9D7EB56A568E7397-8024
                    Reset counter: 69
                    Mileage: 185920 km
                    Reset counter: 69
                    Mileage: 243936 km
   Revision: 12006001    Serial number: 00000003670357
   Coding: 0001168
   VCID: 76B5E1F334C146D7E3B-8022
                    Fault Status: 00111000
                    Reset counter: 106
                    Mileage: 237284 km
                    Fault Status: 00111100
                    Fault Frequency: 209
                    Reset counter: 107
                    Mileage: 237284 km
   Coding: 0100101
00625 - Vehicle Speed Signal
                    Reset counter: 104
                    Mileage: 259893 km
                    Time: 11:20:07
   Revision: 12006001    Serial number: 00000003656310
   Coding: 0001168
   VCID: 77ABECF733CB3FDFF8D-8022
End----(Elapsed Time: 01:41, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Got you Verified. Moving this to Car Repair Support.
Unless you have some record of the original coding for this car, nothing I can think of. Please be a bit patient. I've never mastered the black art of MK60EC1 codings but other people here have.
Jessenelms13
C?ID=383660
I do have the original coding
11 3B 40 0D 49 23 00 FA 88 0D 02 E7 92 1F 00 41 30 00
What happens if you put in that coding? It needs to go in without spaces, like this:
113B400D492300FA880D02E7921F00413000
Jessenelms13
C?ID=383660
Well I’ll be honest, I hadn’t tried it with the Ross-tech cable and it accepted the code. So I need to go through basic settings now, correct?
Jessenelms13
C?ID=383660
So it said code accepted but gives me a Re-code Invalid appears to be uninitiated control module. Then gives me 3 options
Jessenelms13
C?ID=383660
Jessenelms13
C?ID=383660
Jessenelms13
C?ID=383660
