2018 Sportwagen BCM access
gadgetguy
SK, Canada
C?ID=311202
I can’t imagine I’m the only one who’s run into this, but I’ve failed to find any answer save for one post on here with a screenshot that looks exactly like mine, and the answer was “BCM coding needs to be done through adaptations now”. I’m trying to add footwell lighting and I cannot access the BCM to long code it - see attached image. Any thoughts? Is it perhaps because my Sportwagen is a Trendline/S model and the BCM is a lower line one? I did look at it appears to have pin 72 (IIRC) that the lighting pins into.
https://www.dropbox.com/s/exediimrrwe7qud/Photo 2019-10-11, 19 38 43.jpg?dl=0
Mk 7.5 BCMs do not support coding. Everything that used to be tweakable via coding still is, but it's now all done in the Adaptation channels (and there's a couple of thousand of them!).
Please post an Auto-Scan and an Adaptation Channel Map.
The latter is done as follows:
[Applications]
[Controller Channel Map]
Set Controller address to 09.
Leave Login or security code blank.
Select the Adaptations function.
Select CSV file as Output.
[Go]
See also:
https://www.ross-tech.com/vcds/tour/controller-channels-map.php
DV52
C?ID=194404
^^^ the software switch that was previously on Byte 17. Bit 3 ("Ambiente fussram, installed" on yellow LCH screen/"Ambient footwell light(s) installed" on normal LCH screen) is on your BCM as: IDE09732-ENG114629-Interior light: light configuration-Foot well lighting - but its currently set as installed.
I can also see from your admap that the Leuchte-set for the foot-well light (which is Leuchte30FR LC72) is activated and it is set-up for incandescent lamp(s). I assume that you have run a wire to pin#72, socket C to power the lamp.
In the dim recesses of my feeble mind I can vaguely recall discovering that footwell lights was SWAP - but I'm really not sure if my memory is correct. Perhaps some else here can confirm/correct my suspicion?
PS: there was also another software switch on Byte 5, Bit 6 - labelled "Footwell lights installed" on both yellow/normal LCH screens!
PPS: interesting DTCs - are they persistent if cleared?
Thanks, Uwe!
What's the preferential way to attach Auto-Scans? For now, here are links to the files.
Just paste the text in-line here, like this:
Saturday,12,October,2019,16:46:15:05227
VIN: 3VW217AU6JM766374   License Plate:
Mileage: 15549km-9661mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 15 16 17 19 22 42 44 52 5F
VIN: 3VW217AU6JM766374   Mileage: 15549km-9661miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091900122426002F0000
   Shop #: WSC 00066 790 00392
   ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
   ROD: EV_ECM18TFS0208V0906264M.rod
   VCID: 46D557453826AB87B3B-8012
Readiness: 1110 1101
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 CS    HW: 5Q0 614 517 AF
   Component: ESC           H62 0973
   Revision: 00000000    Serial number: 51408000000643
   Coding: 04FA6AA124260972407A0307A0C7292056249002C005943400435050C009430B00000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037_VW37.rod
   VCID: 04518D4D4E9A5997EDF-8050
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 02020004200110000000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004134
   ROD: EV_ACManueBHBVW37X_004.rod
   VCID: 4CC1656D264A51D765F-8018
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0246
   Revision: --------    Serial number: C86424061800DI
   Shop #: WSC 00066 790 00245
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0B43A67163C416EFAC5-805E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    180423  043 0551
   Serial number: 97022066180507035853
   Coding: 0E4DFD
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S3Y18M05D24H06M53S03
   Coding: 00A8DD
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Component: AirbagVW20    011 0830
   Serial number: 003MHM04F6MP
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 51FF7419C1687C3F169-8004
   Occupant Detection:
   Serial number: 694000000000001GP5VB
   Coding: 303337
   Subsystem 2 - Part No SW: -----------    HW: 480 000 106 18
   Serial number: 357000000001892D4D2O
   Subsystem 3 - Part No SW: -----------    HW: 480 001 006 18
   Serial number: 35800000000AD2859E2-
   Subsystem 4 - Part No SW: -----------    HW: 480 402 805 18
   Component: SideSensor_Dr  004 6149
   Serial number: 35100011C2AF26F363DC
   Subsystem 5 - Part No SW: -----------    HW: 480 401 105 18
   Serial number: 35200019929E7324A330
   Subsystem 6 - Part No SW: -----------    HW: 480 400 406 18
   Component: FrontSensor_D  004 6149
   Serial number: 35500010E2AEB0E34336
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 406 18
   Component: FrontSensor_P  004 6149
   Serial number: 35600010E2AEB0E343FJ
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 31051820240188
   Coding: 0400
   VCID: 0D47A8691DD018DFB21-8058
   Part No SW: 5G1 920 740 C    HW: 5G1 920 740 C
   Component: KOMBI         242 0310
   Coding: 03B51002A180080402082E001000000000000000
   VCID: 2615F7C598664B8793B-8072
   Part No SW: 3Q0 907 530 K    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5323
   Serial number: 22051800840422
   Coding: 0901000830085900FA000008080F00000001070000000000000000000000
   Shop #: WSC 00066 790 07027
   ROD: EV_GatewNF.rod
   VCID: 372B2A814FCCC20F38D-8062
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001869260016382
   Coding: 29FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H55 0041
   Serial number: 0345221
8782084 - Tiptronic Downshift Switch/Paddle in Steering Wheel
          B114E 96 [009] - Component internal failure
                    Reset counter: 117
                    Mileage: 15549 km
                    Date: 2019.10.12
                    Time: 16:26:27
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: On
8782085 - Tiptronic Upshift Switch/Paddle in Steering Wheel
          B114F 96 [009] - Component internal failure
                    Reset counter: 117
                    Mileage: 15549 km
                    Date: 2019.10.12
                    Time: 16:26:27
                    Terminal 15: On
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00022.03.18
   Coding: 0001
   Serial number: 9601153042745
   Coding: 003103201000020000000000
   VCID: 47CB5A413F2CB28F48D-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000509807
   Coding: 011000
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  172 1081
   Coding: 010A0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F9711DCA627537197-8004
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0500140020162
   Coding: 003103201C00020000000000
   VCID: 015F845951884CBFC69-8054
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000505712
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0753
   Coding: 02731200BE00000051220001001828001F0500D40120010002
   Shop #: WSC 00066 790 00405
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D0708E9BD9078DF521-8078
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  H50 8120
   Serial number: VWZ6ZHT1340048
6 Faults Found:
          B11CF 53 [009] - Deactivated
                    Reset counter: 117
                    Mileage: 15549 km
                    Date: 2019.10.12
                    Time: 16:27:02
                    Voltage terminal 30: 12.2 V
                    SDARS_tuner_status_2-Antenna current: 0 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 02
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 02
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [009] - Open Circuit
                    Reset counter: 117
                    Mileage: 15549 km
                    Date: 2019.10.12
                    Time: 16:26:26
                    Voltage terminal 30: 12.0 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 51 dBµV
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [009] - Open Circuit
                    Reset counter: 117
                    Mileage: 15549 km
                    Date: 2019.10.12
                    Time: 16:26:26
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 214 dBµV
0009 - Antenna for Satellite Radio
          B10F4 13 [009] - Open Circuit
                    Reset counter: 117
                    Mileage: 15549 km
                    Date: 2019.10.12
                    Time: 16:26:27
2565 - GPS Antenna
          B1054 13 [009] - Open Circuit
          [GPS aerial - open circuit]
                    Reset counter: 117
                    Mileage: 15549 km
                    Date: 2019.10.12
                    Time: 16:26:27
                    Voltage terminal 30: 12.1 V
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 117
                    Mileage: 15549 km
                    Date: 2019.10.12
                    Time: 16:26:29
                    BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:13, VBatt start/end: 12.3V/12.3V)-----------
;SW:5Q0-937-087-AR   HW:5Q0-937-087-AN ---  Cent. Elect.
;Component:BCM PQ37BOSCH 034 0246, Coding:
;EV_BodyContrModul1UDSBosc,018001,EV_BCMBOSCH_018.rod
;Saturday,12,October,2019,16:47:29:05227
;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
;VCID: 0B43A67163C416EFAC5-805E
IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3
IDE01550-Service position,170.494336 °,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms,10
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,240 s,11
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Horn_verbaut ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),Yes ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 06 12 9C 08 09 1C 00 00 00 04 4C 00 4C 14 00 64 07 13 9C 08 0A 1C 00 00 00 01 3A 00 49 14 00 7F 06 00 80 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 07 00 80 08 0A 7F 00 00 00 0B 36 00 1A 0B 00 64 1E 00 80 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 1E 00 80 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 1E 00 80 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 1E 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,16.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,16.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,26.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,24.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,26.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,24.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,49.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,48.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,49.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,48.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13125-Button in center console-Function of button 1,not coded/not installed ,8
IDE06507-MAS13132-Button in center console-Function of button 3,NOT-DEFINED ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,31.494474 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,not active ,6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,255 min,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG141956-Assistance light functions-Humidity sensor,not installed ,9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,7.494498 °,2
IDE10299-Alternating park position 2,29.494476 °,2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,0 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,0 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
MAS01490-ENG141978-Energy management-Recuperation,not active ,5
MAS05055-lower turn position,31.494474 °,2
MAS05056-upper turn position,170.494336 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,0 ,60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,0 ,60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,0 ,60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,0 ,60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,0 ,60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,0 ,60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,0 ,60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,0 ,60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,0 ,60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,0 ,60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,0 ,60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,0 ,60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,0 ,60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,0 ,60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,0 ,60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,0 ,60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,0 ,60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,0 ,60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,0 ,60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,0 ,60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,0 ,60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,0 ,60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,0 ,60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,0 ,60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,0 ,60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,0 ,60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,limitieren ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,Yes ,5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,true ,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,No ,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,No ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,not active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,6 s,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,Basis ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
ENG141645-MAS00214-HW_Verbau-Brake pad wear,not installed ,8
ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,58.5 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,58.5 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,58.5 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,58.5 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,54.5 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,49.5 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,46.5 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,35.5 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,31.5 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,36 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,35 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,0 ,16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00 ,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,not active ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,0 ,16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00 ,16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,not active ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,43 - allgemeine LED ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,43 - allgemeine LED ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,38 - LED Blinkleuchten ,16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Blinken links Hellphase ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,38 - LED Blinkleuchten ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Blinken rechts Hellphase ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,54 ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,53 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,43 - allgemeine LED ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,minimize ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,28 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,28 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Blinken links aktiv (beide Phasen) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Nebellicht links ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,18 - 2* 5W ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,minimize ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,28 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,28 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Nebellicht rechts ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen) ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,minimize ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Coming Home oder Leaving Home aktiv ,16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,minimize ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Coming Home oder Leaving Home aktiv ,16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,minimize ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Coming Home oder Leaving Home aktiv ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,minimize ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Coming Home oder Leaving Home aktiv ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 13 00 3D 18 00 7F 00 00 00 00 00 00 00 00 00 2B 23 00 3E 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 26 0A 00 29 02 00 7F 00 00 00 00 00 00 00 00 00 26 1A 00 2A 04 00 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 53 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,2B 00 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 00 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 12 00 00 00 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-101.5 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,1.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,10.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,1.00 s,62
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141954-Networking-A/C electronics,installed ,8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
ENG122979-ENG141953-Networking-Getriebesteuergeraet,not installed ,8
ENG122979-ENG99457-Networking-Head area heater,not installed ,8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
ENG122979-ENG141969-Networking-UGDO,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,not active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,not active ,8
ENG124714-OCU-,not installed ,8
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,not_active ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,not active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,0 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,0 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,0 ms,10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271875-Slave_systems_identification-Light switch,Not available ,6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,5.0 min,10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,Potentiometer ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,not active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,not active ,9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,not active ,9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,not active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,Always ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,not installed ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,not active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,not active ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,not active ,9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,not active ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,not active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,not installed ,9
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,not active ,7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein,active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active ,4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,not active ,7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,active ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,not active ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Contact control ,7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,active ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5
Elapsed Time: 02:02
Now adding footwell lights on one of these cars is not something I'm familiar with, but I expect others are, so please stand by.
gadgetguy
SK, Canada
C?ID=311202
@DV52 my goodness, I have all the big hitters come out for this post!
I had already monkeyed around with some adaptations as I'd found a forum post on Briskoda but became stumped when I got to the BCM coding modifications - hence footwell lights being enabled. In the end, I stumbled across a Kufatec coding table for 7.5 from ZERO815 on Golfmk7 and everything was solved.
I'm understanding now what everybody is getting at about BCM long coding being done through adaptations on 7.5. Is this a limitation put in by VAG? It seems wildly more complicated now that just ticking some boxes. Furthermore, is there any way to translate DIY's for mk7 involving BCM coding to the new method in adaptations - or is it just a matter of waiting until the brilliant minds of the community have it sorted?
Regarding the DTCs - I've swapped in a european R-Line steering wheel and buttons and I'm assuming that's what's throwing the tiptronic codes. For the 5F codes, I've gone from the 6.5" base display and retrofitted a glovebox mounted 5F as well as an 8" display, but I don't care much for terrestrial radio or satellite radio as I utilize CarPlay and streaming services primarily, so my laziness got the best of me and I didn't purchase/fit a sat radio antenna or the relocation harness for the terrestrial.
DV52
C?ID=194404
^^^ thanks for the kind words - but I would be more than fraudulent if I didn't correct your misapprehension: ain't notin' "big hitter" about this particular canard-noir! I'm just a rank-amateur who is often awestruck by (and who learns much more from) the expertise of the real professionals on this forum !!
My personal credo has always been "never wait for anyone" (i.e. when an opportunity arises -ALWAYS get in before the hoarders)!!!
If you are making changes from long-coding instruction on older style BCM s - simply use the descriptor for the Byte/Bit and search through the adaptation channels for same/similar wording. Of course, this process is helped enormously if you have previously made an admap of the BCM on your car - because you can do the searching on a laptop/PC using the software function on your computer application (like MS Excel, or MS Access, or Notepad). It really isn't difficult and you will be surprised how effective even the simplest of search terms can be.
As for your question about " Is this a limitation put in by VAG"- yes, the BCM changes were made by the boffins @ VAG (VCDS simply reports what the module spews-out when listing adaptation channel names and settings. And, I'm not sure if "limitation" is correct - notwithstanding the brilliant LCH screens, there are advantages in using channels IMO (i.e. channel names are easier to search- for starters). Plus, with the newer style BCMs, all the allowable modifications are now in the one spot:adaptation channels!!
Try clearing the DTCs!
