New A6 C7 owner with an un-clearable set of errors
Evanescent66
Northern Ireland
C?ID=368112
I recently acquired an A6 C7 s-line with a number of faults. I reseated the ABS connector and replaced the battery and thought I may have solved it only for it to return after two days...
Assuming this is some kind of connection, or ground problem but am a bit at a loss...
Any sensible suggestions welcome
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 19.6.2(x64) Data version: 20190930 DS308.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Friday,11,October,2019,11:55:21:05709
VIN: WAUZZZ4G7EN047221 License Plate: WG63ZNP
Mileage: 155701km-96748mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F 62
72
VIN: WAUZZZ4G7EN047221 Mileage: 155701km-96748miles
3B-Sensor Elect. -- Status: Cannot be reached 0100
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 LA HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2023
Revision: 45H25---
Coding: 0A194012242401080000
ASAM Dataset: EV_ECM20TDI01103L906018LA 003009
ROD: EV_ECM20TDI01103L906018GT.rod
VCID: 74B1DD4DBE3A4B77DDF-8020
U1113 00 [039] - -
Mileage: 155701 km
Date: 2019.10.06
Time: 03:04:23
Engine speed: 830.50 /min
Normed load value: 31.4 %
Coolant temperature: 60 °C
Intake air temperature: 16 °C
Voltage terminal 30: 14.520 V
Cruise Control System (CCS): switch position-Bits 0-7: 129
Cruise Control System (CCS): status-Bits 0-7: 40
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
U1113 00 [039] - -
Mileage: 155701 km
Date: 2019.10.06
Time: 03:04:23
Self-Diagnosis Log
Page 3
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 155701 km
Date: 2019.10.06
Time: 03:04:23
Engine speed: 829.50 /min
Normed load value: 31.8 %
Voltage terminal 30: 14.460 V
Longitudinal acceleration: raw value: 32.767 m/s²
Vehicle inclination acceleration angle: raw value: 32.767 m/s²
Status: incline angle-Bits 0-7: 1
Longitudinal acceleration sensor: status-Bits 0-7: 1
Vehicle lateral acceleration: raw value: 327.67 g
Self-Diagnosis Log
Page 4
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 06A09F016005F9809B00
VCID: 3A2D3375DCDEFD07C73-806E
0518 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
[ComScl_PDU_SARA_06_Timeout]
Reset counter: 24
Mileage: 155701 km
Date: 2019.10.06
Time: 03:04:21
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 01
F-Type: 0D
Uz: B9
0486 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Ldm_ApbFailureState]
Reset counter: 24
Mileage: 155701 km
Date: 2019.10.06
Time: 03:04:21
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 02
Self-Diagnosis Log
Page 5
F-Type: 08
Uz: B9
0803 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
[SCL_SARA_Accel_X_010_Invalid]
0804 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
[SCL_SARA_Accel_Y_010_Invalid]
0805 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
[SCL_SARA_Omega_Z_010_Invalid]
Part No SW: 4H0 907 064 DN HW: 4H0 907 064 DN
Component: BCM2 2.0 H35 0510
Coding: 03B83046000000000000
VCID: 78A9E97DA2D22F17F17-802C
Serial number: 0213000277728007
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AC HW: 4G0 820 043 AC
Component: KLIMA 2 ZONEN H11 0087
Serial number: 06081300111349
Coding: 34210008A1
ASAM Dataset: EV_AirCondiBasisUDS 002045
VCID: 6099A11D1AC2C7D7A97-8034
Self-Diagnosis Log
Friday,11,October,2019,11:55:22:05709
Page 6
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001473595
Coding: 2600201040349F600481008300001D0C0F9D830827090201000004606100
VCID: 6E85CF25D09661A72BB-803A
Component: WWS57X 130724 H36 0080
Serial number: 130730230906
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21655456
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - LDS H07 0044
Serial number: 13 08 2013 00000238
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: CDD804C6000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Revision: 11001001 Serial number: 61031323802800
Coding: 08C206
VCID: 71BFD459C1287E5F369-8024
Self-Diagnosis Log
Page 7
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00EFNUY
Coding: 3032343631324E303235554A305234473053
VCID: 36352745E8C6196723B-8062
Serial number: 3575HRB400450J5S495T
Serial number: 3585HRB401050JEAE29P
Serial number: 3515JRB401250KB2912%
Serial number: 3525JRB400A50L36J0R
Serial number: 3554VRB405B1ROCCG9TL
Serial number: 3564VRB405F1ROCC516R
1049093 - Databus
[CAN: 0x101 ESP_02 error value ESP_Querbeschleunigung]
Reset counter: 24
Mileage: 155701 km
Date: 2019.10.06
Time: 03:04:22
1049094 - Databus
[CAN: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
Reset counter: 24
Mileage: 155701 km
Self-Diagnosis Log
Page 8
Date: 2019.10.06
Time: 03:04:22
1049095 - Databus
[CAN: 0x101 ESP_02 error value ESP_Gierrate]
Reset counter: 24
Mileage: 155701 km
Date: 2019.10.06
Time: 03:04:22
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20130830000008
Coding: 000014
VCID: 3039115D0A223757797-8064
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 950 S HW: 4G8 920 950 S
Component: MDieGb H43 0410
Revision: 27450257 Serial number: 658140813592024
Coding: 33A408000B412600010000
ASAM Dataset: EV_RBC7KMID 004048
ROD: EV_RBC7KMID.rod
VCID: 3FDB4261C7FCD82FF0D-806A
Self-Diagnosis Log
Page 9
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000001066582
Coding: 00CD074400
ASAM Dataset: EV_GatewPkoUDS 001018
Serial number: 4266551203
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 13061000000000000349
6655 - Sensor electronics control module
U1077 00 [009] - No communication
Reset counter: 24
Mileage: 155701 km
Date: 2019.10.06
Time: 03:04:21
Voltage terminal 30: 14.2 V
Voltage terminal 15: 14.3 V
Control Module temperature: 26 °C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Address 3B: Sensor Elect.
Self-Diagnosis Log
Page 10
Component: TSG FA H03 0507
Coding: 011C16004001620002080002
VCID: 47CB5A819FAC90EF48D-8012
Component: RCEPS H38 0010
Revision: 00001000 Serial number: 0026797143
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D1B5504AE05470F3-8066
Revision: 00002001 Serial number: 0313099519
Coding: 011B062280B900408320080400010E470000000000000000000000000000
Component: DWA-Sensor H01 0010
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000026821
VCID: 1D67D8E96DB0AA3FC21-8048
Self-Diagnosis Log
Page 11
Component: TSG BF H03 0507
VCID: 46D5578598A689E7B3B-8012
Self-Diagnosis Log
Page 12
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000789673
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C01052D268A53B745F-8078
459264 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[FC_SIGNAL_ESP_LAENGSBESCHL_ERROR_VALUE]
Reset counter: 24
Mileage: 155701 km
Date: 2019.10.06
Time: 03:04:21
Voltage terminal 30: 14.5 V
Internal Fault ID: 138
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Auto Adjust: not active
Status ParkingBrake left: Set
Status ParkingBrake right: Set
463616 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
Self-Diagnosis Log
Page 13
Reset counter: 24
Mileage: 155701 km
Date: 2019.10.06
Time: 03:04:21
Internal Fault ID: 185
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 130821-0002-073
Coding: 112196101000A300
ROD: EV_HeadlRegulBasic.rod
VCID: 2D0708291D905ABF521-8078
Self-Diagnosis Log
Page 14
Part No SW: 4G0 035 192 H HW: 4G0 035 192 F
Component: RMC Nav Plus H54 0801
Coding: 0101000101415B47082B060301020100000000
VCID: 270BFA013FEC70EFA8D-8072
Subsystem 1 - Part No SW: 4G0 919 603 A HW: 4G0 919 603 A
Component: DU6 Basic H43 0084
Serial number: 9464GY0D2616712
Subsystem 2 - Part No SW: 4G2 919 710 B HW: 4G2 919 710 B
Component: E380 BDT C7 H11 0204
Serial number: 90349MHQ000ML
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0507
VCID: 49CF5CB989B8669F5E9-801C
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
End----------(Elapsed Time: 01:37, VBatt start/end: 12.2V/12.1V)-----------
Ian
Admin request: Please don't use the [Print] function in VCDS to post data here. The formatting it produces is optimized for a sheet-fed printer, but is less than perfectly readable here. Please use [Copy], or [Save] and then open the plain-text file and copy the contents here.
Jef
HQ
Phew, that is a hard Auto-Scan to read, formatting was all wonky... but better than no Auto-Scan. :rolleyes:
Well that isn't good. The Sensor Electronics looks to be the J849 module, located on the center hump between the front seats. For any given control module to communicate, you must have ... (some of you know what is coming)....
Check your fuses as per the wiring diagram for your vehicle. If those check out good, then I'd access the J849 and at the terminal connection load test the powers/grounds.
DrPeter
16.4905° S, 151.7375° W
The Auto-Scan is a bit difficult to look at, next time please "copy & paste" the Auto-Scan from the text file rather than "copy & pasting" from the printed file. :)
I do see that [Address 3B: Sensor Elect.], the (J849-Sensor Electronics Control Module) is NOT online and therefor it is not communicating with all the other controllers on the vehicle, like the ABS and other controllers, who are are looking for information from the J849. As long as the J849 is off line, these controllers will continue to set fault codes, such as 'Function Restriction due to Faults in Other Modules'.
Like other controllers on this vehicle, in order to communicate on the network, the J849-Sensor Electronics Control Module needs the proper power, ground and connection to it's network, in this case the J849 is on the Flex-Ray data bus.
I would recommend to verify the power, ground and the connections to the Flex-Ray data bus for the J849 controller. For more information about the J849, its location and wiring diagrams, have a look at the following resource documents from Audi:
Official Factory Repair Information
Self-Study Program 990303 The 2012 Audi A7 Running Gear and Suspension Systems
Self-Study Program 990613 The 2012 Audi A6 Vehicle Introduction
Hope this helps,
drpeter
Evanescent66
Northern Ireland
C?ID=368112
Apologies all...a newbie error....have a habit of printing the log files to .pdf because it is easy to use beyond compare to spot the differences. Will use the copy function in future.
Thanks for the suggestions of Jef and Dr Peter particularily for the location of J849 module...maybe I will be lucky and the issue will be in the connector or closest ground point...
I will report back when I take a look tomorrow
Ian
Evanescent66
Northern Ireland
C?ID=368112
SUCCESS!...I hope
Since this fault had already shown itself to be intermittent I decided to go straight to the ground points (had checked the fuses 2 weeks previous).
Gave the ground under back seat a tweak and turning on ignition there where no errors.... I purchase a copy of a workshop manual on ebay and am kind of bumbling around a bit with the wiring and just guesstimated that the nearest ground point is the one under the seats. I am pretty sure that Uwe, Jef or Dr Peter will know if this is correct or if it is just coincidence that the fault has cleared.
Once again thanks to all for pointing me to the module under the centre console as the starting point.
Below is the scan after clearing the residual latched fault codes....
Ian:)
Saturday,12,October,2019,10:34:49:05709
          72
   Revision: 45H25---
   Coding: 34210008A1
   Coding: 0045F7
   Coding: 02006D
   Coding: 08C206
   Coding: 000014
   Coding: 00CD074400
   Voltage stabilizer:
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA72064KTJ
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33331E51FBB40C4F045-8066
End----(Elapsed Time: 01:39, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
