Hi!
I have A5 F5 2018 and installed Matrix, previously it had LED lamps.
I can't parametrize 29 and 39 modules. I uploaded flashes a5_MXB_4m0907397ac with VCP, but that didn't change the situation. D6 & D7 updated ok.
Even tried downgrading soft to 0023, but also nothing. Other parameter files for (A4, Q7) 4m0907397ac module from VCP server doesn't work either.
What else can I do? DRL and indicators are dead. High Beam works fine.
Should I change 29 and 39 modules to 4M0907397AD?
Thanks!
Wednesday,11,September,2019,18:17:23:43668
VCDS Version: 19.6.1.0 HEX-NET CB: 0.4508.4
Dealer/Shop Name: VagLab
Workshop Code: 444 12345 012345
VIN: WAUBNCF51JA132577 License Plate: A5 F5 USA
Mileage: 3507km-2179mi Repair Order:
Chassis Type: F5-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 52 5F 6C 6D
81 A5 A9 BB BC CA CF D6 D7
VIN: WAUBNCF51JA132577 Mileage: 3507km-2179miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC) Labels:. 06K-907-425-V2.clb
Part No SW: 8W0 906 259 J HW: 06L 907 425 C
Component: 2.0l R4 TFSI H15 0002
Revision: --H15---
Coding: 1A2500322326010E34280000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
ROD: EV_ECM20TFS020_AU49.rod
VCID: C8DC2BB57319EF0F91-809C
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 BA HW: 0CJ 927 156
Component: 0CL 20TFSINAR H05 0001
Revision: --H05--- Serial number: 0000000952
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU49.rod
VCID: 814AF69110A31E4716-80D4
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180178002621
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 Q HW: 8W0 907 379 J
Component: ESP9 Plus H10 0775
Coding: 18AA409A28A50A9811A3489800845292E5359A180214508812004A49A7AC59
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: D3E60CD9BA5F5CD7F4-8086
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0251
Coding: 140805095548000D10000100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: C4C43F854F31CB6F7D-8090
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002582387
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 3BA1593900PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07500363C1281CCD0515871418AC98B9110B3D08000000000000000020001A810A450222025705
Shop #: WSC 12345 444 12345
VCID: 8248F99D15A5055F0F-80D6
Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB
Component: 494 LL 200618 036 0471
Serial number: 00000001806140308086
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 21588387X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 26 07 2017 01051907
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z01FY02
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20180628094906 00403
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE130041823310593
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 CS HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00877312
Subsystem 8 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2818000072425005
66678 - Databus
[Left LCM: implausible data record]
Reset counter: 143
Mileage: 3507 km
Date: 2019.09.11
Time: 18:10:12
average_Voltage_terminals: 12.20 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 29.00 °C
interior_temperature: 26.50 °C
Vehicle speed: 0.00 km/h
66679 - Databus
[Right LCM: implausible data record]
Reset counter: 143
Mileage: 3507 km
Date: 2019.09.11
Time: 18:10:12
66963 - Databus
[Left LCM: turn signal faulty]
Reset counter: 143
Mileage: 3507 km
Date: 2019.09.11
Time: 18:10:12
66964 - Databus
[Right LCM: turn signal faulty]
Reset counter: 143
Mileage: 3507 km
Date: 2019.09.11
Time: 18:10:12
67735 - Databus
[MxB not available]
Reset counter: 143
Mileage: 3507 km
Date: 2019.09.11
Time: 18:10:12
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 G HW: 8W0 959 655 G
Component: Airbag10.44 H05 0107
Serial number: 003UQ003450S
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: CDD21AA19C7B0A27A2-8098
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705G0184S02185
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706J0184S01408
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J180009STR702
Subsystem 4 - Part No SW: ----------- HW: 442 060 607 18
Serial number: 3577Y00AF27DBDE4B24X
Subsystem 5 - Part No SW: ----------- HW: 442 060 707 18
Serial number: 3587Y00C326D2BB2520/
Subsystem 6 - Part No SW: ----------- HW: 442 0B3 006 18
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700AF2B0ECB1F06Y
Subsystem 7 - Part No: -----------
Serial number: 3527700B12B0ECB0A2DP
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 906 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B92A9BC72341K
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 906 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B92A9BC7543BY
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GK HW: 4M0 907 129 GK
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: FF4E7069665768B760-80AA
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W5 920 890 G HW: 8W5 920 890 G
Component: FBenUSA H19 0377
Coding: 09E741C72888080907036D601800000008000000
ASAM Dataset: EV_DashBoardAU736 001027
VCID: C7DE28897E07E07798-8092
Part No SW: 8W6 907 468 F HW: 8W6 907 468 E
Component: Gateway H43 0123
Revision: 7B000002 Serial number: 0287B024018707
Coding: 030100010000064029070000005900126C180007100000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
Subsystem 1 - Part No SW: 8W0 951 523 H HW: 8W0 951 523 H
Component: J453 MFL H04 0004
Serial number: 20180703111409 21323
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0913428504
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
VCID: F8BC9B7543795F8F21-80AC
0018 - Data Set Implausible
B2012 00 [009] - -
[Implausible dataset]
Reset counter: 143
Mileage: 3507 km
Date: 2019.09.11
Time: 18:10:38
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0042
Serial number: 00000332423388
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
VCID: F9BA9E71787346875E-80AC
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
B2012 00 [009] - -
Reset counter: 143
Mileage: 3507 km
Date: 2019.09.11
Time: 18:10:46
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 E HW: 4M0 907 566
Component: MRR1Rear H20 0430
Revision: --------
Coding: 0E8002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: B73E58490EE790F7E8-80E2
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0130
Serial number: 0000331072186
Coding: 001F4B625E00108000010432
VCID: C3C63C994A3FCC5744-8096
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: C2C8399D5525C55F4F-8096
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 EC HW: 8W0 907 064 DC
Component: BCM2 MLBevo 025 0387
Coding: 013400004F9100C0650BA0006E01080233024000810026502F0400000F04803F001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
Ignition key:
Subsystem 1 - Part No SW: 4M0 959 754 AK HW: 4M0 959 754 AK
Component: ID-Geber H40 0105
Serial number: 3618000111203002
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1815416W7
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099348290
Subsystem 4 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: 12055137
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0130
Serial number: 0000331122528
Coding: 001F4B225E00108000010430
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 880 C HW: 8W5 035 880
Component: MU-P-LN-EU 034 1329
Serial number: A798G0JB113973
Coding: 01940301FF0A000053110001041800102F000EE401700900FE
VCID: BFCE306926D7A8B720-80EA
Subsystem 1 - Part No SW: V03 959 802 DF HW: -----------
Component: ECE 2019/2020 --- 0177
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0170
Serial number: TPO00121041800820042
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK126061800020450
Component: Gracenote2 --- 3012
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0250
Coding: 0294030102002001400040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: B3266C591A9F7CD7D4-80E6
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0166
Revision: -------- Serial number: 32012952600000
Coding: 0630
ASAM Dataset: EV_DeckLidCONTIAU736 001016
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 N HW: 8W1 713 041 K
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 18071048197469
ROD: EV_GSMWaehlZFAU736.rod
VCID: BE304D6D21DDA1BF2B-80EA
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 A HW: 8W6 907 217 A
Component: BVS H17 0050
Coding: 0404090300000401022023A2A40000FC00F0C023E280
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: C0CC33955B29D74F59-8094
1123669 - Left Matrix High Beam
C1175 54 [009] - Missing Calibration / Basic Setting
Reset counter: 143
Mileage: 3507 km
Date: 2019.09.11
Time: 16:53:22
Control Module temperature: 41 °C
Voltage terminal 15: 14.40 V
1123670 - Right Matrix High Beam
C1176 54 [009] - Missing Calibration / Basic Setting
Reset counter: 143
Mileage: 3507 km
Date: 2019.09.11
Time: 16:53:22
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8W0 907 159 H HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0008
Serial number: 180618201516
VCID: C6C0258D790DF97F63-8092
Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
Component: TSG HFS 005 0130
Serial number: 0000331274448
Coding: 000F4B220000108040000020
VCID: C5C22281440BF2676A-8090
Component: TSG HBFS 005 0130
Serial number: 0000331278451
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 228000049301
VCID: BD324A612CDBBAA732-80E8
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 E HW: 4M0 907 590
Revision: --------
Coding: 0E8002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: B4246F451F917BEFCD-80E0
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 CB HW: 7PP 941 592 C
Component: LED1L H10 2003
VCID: 9A78A1FD9D35AD9FF7-80CE
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H10 2003
End----------(Elapsed Time: 02:10, VBatt start/end: 12.2V/12.2V)-----------
Thanks!
