A5 F5 Matrix headlights retrofit problem
cinek2004
Poland
C?ID=326815
Hi!
I have A5 F5 2018 and installed Matrix, previously it had LED lamps.
I can't parametrize 29 and 39 modules. I uploaded flashes a5_MXB_4m0907397ac with VCP, but that didn't change the situation. D6 & D7 updated ok.
Even tried downgrading soft to 0023, but also nothing. Other parameter files for (A4, Q7) 4m0907397ac module from VCP server doesn't work either.
What else can I do? DRL and indicators are dead. High Beam works fine.
Should I change 29 and 39 modules to 4M0907397AD?
Wednesday,11,September,2019,18:17:23:43668
VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
Dealer/Shop Name: VagLab
Workshop Code: 444 12345 012345
VIN: WAUBNCF51JA132577   License Plate: A5 F5 USA
Mileage: 3507km-2179mi   Repair Order:
Chassis Type: F5-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 52 5F 6C 6D
          81 A5 A9 BB BC CA CF D6 D7
VIN: WAUBNCF51JA132577   Mileage: 3507km-2179miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC)       Labels:. 06K-907-425-V2.clb
   Part No SW: 8W0 906 259 J    HW: 06L 907 425 C
   Component: 2.0l R4 TFSI  H15 0002
   Revision: --H15---
   Coding: 1A2500322326010E34280000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
   ROD: EV_ECM20TFS020_AU49.rod
   VCID: C8DC2BB57319EF0F91-809C
Readiness: 1110 0101
   Part No SW: 8W2 927 155 BA    HW: 0CJ 927 156
   Component: 0CL 20TFSINAR H05 0001
   Revision: --H05---    Serial number: 0000000952
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 814AF69110A31E4716-80D4
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180178002621
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 Q    HW: 8W0 907 379 J
   Component: ESP9 Plus     H10 0775
   Coding: 18AA409A28A50A9811A3489800845292E5359A180214508812004A49A7AC59
   Shop #: WSC 06334 790 00001
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: D3E60CD9BA5F5CD7F4-8086
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0251
   Coding: 140805095548000D10000100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: C4C43F854F31CB6F7D-8090
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002582387
   Serial number: 3BA1593900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07500363C1281CCD0515871418AC98B9110B3D08000000000000000020001A810A450222025705
   Shop #: WSC 12345 444 12345
   VCID: 8248F99D15A5055F0F-80D6
   Subsystem 1 - Part No SW: 8W6 955 119     HW: 8W6 955 119   Labels: 1KX-955-119.CLB
   Component: 494 LL 200618  036 0471
   Serial number: 00000001806140308086
   Coding: 5FC7F7
   Serial number: 21588387X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 26 07 2017  01051907
   Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600350Z01FY02
   Coding: 350000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20180628094906 00403
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE130041823310593
   Interior Light Module:
   Subsystem 7 - Part No SW: 8W0 947 135 CS    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00877312
   Subsystem 8 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000072425005
66678 - Databus
          [Left LCM: implausible data record]
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.11
                    Time: 18:10:12
                    average_Voltage_terminals: 12.20 V
                    Outside air temperature sensor-Outside air temperature on CAN: 29.00 °C
                    interior_temperature: 26.50 °C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
66679 - Databus
          [Right LCM: implausible data record]
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.11
                    Time: 18:10:12
66963 - Databus
          [Left LCM: turn signal faulty]
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.11
                    Time: 18:10:12
66964 - Databus
          [Right LCM: turn signal faulty]
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.11
                    Time: 18:10:12
67735 - Databus
          [MxB not available]
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.11
                    Time: 18:10:12
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 G    HW: 8W0 959 655 G
   Component: Airbag10.44   H05 0107
   Serial number: 003UQ003450S
   Coding: BFCCF0C000800000A0000033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: CDD21AA19C7B0A27A2-8098
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 8W0857705G0184S02185
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 8W0857706J0184S01408
   Coding: 80000D
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J180009STR702
   Subsystem 4 - Part No SW: -----------    HW: 442 060 607 18
   Serial number: 3577Y00AF27DBDE4B24X
   Subsystem 5 - Part No SW: -----------    HW: 442 060 707 18
   Serial number: 3587Y00C326D2BB2520/
   Subsystem 6 - Part No SW: -----------    HW: 442 0B3 006 18
   Serial number: 3517700AF2B0ECB1F06Y
   Subsystem 7 - Part No: -----------
   Serial number: 3527700B12B0ECB0A2DP
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 906 18
   Serial number: 3557500B92A9BC72341K
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 906 18
   Serial number: 3567500B92A9BC7543BY
   Part No SW: 4M0 907 129 GK    HW: 4M0 907 129 GK
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: FF4E7069665768B760-80AA
   Part No SW: 8W5 920 890 G    HW: 8W5 920 890 G
   Component: FBenUSA       H19 0377
   Coding: 09E741C72888080907036D601800000008000000
   VCID: C7DE28897E07E07798-8092
   Part No SW: 8W6 907 468 F    HW: 8W6 907 468 E
   Component: Gateway       H43 0123
   Revision: 7B000002    Serial number: 0287B024018707
   Coding: 030100010000064029070000005900126C180007100000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   Subsystem 1 - Part No SW: 8W0 951 523 H    HW: 8W0 951 523 H
   Component: J453 MFL  H04 0004
   Serial number: 20180703111409 21323
   Serial number: 0913428504
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   VCID: F8BC9B7543795F8F21-80AC
0018 - Data Set Implausible
          B2012 00 [009] - -
          [Implausible dataset]
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.11
                    Time: 18:10:38
   Component: MEM-FS        009 0042
   Serial number: 00000332423388
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   VCID: F9BA9E71787346875E-80AC
          B2012 00 [009] - -
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.11
                    Time: 18:10:46
   Part No SW: 4M0 907 566 E    HW: 4M0 907 566
   Component: MRR1Rear      H20 0430
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: B73E58490EE790F7E8-80E2
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0130
   Serial number: 0000331072186
   Coding: 001F4B625E00108000010432
   VCID: C3C63C994A3FCC5744-8096
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: C2C8399D5525C55F4F-8096
   Part No SW: 8W0 907 064 EC    HW: 8W0 907 064 DC
   Component: BCM2 MLBevo   025 0387
   Coding: 013400004F9100C0650BA0006E01080233024000810026502F0400000F04803F001E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   Ignition key:
   Subsystem 1 - Part No SW: 4M0 959 754 AK    HW: 4M0 959 754 AK
   Component: ID-Geber  H40 0105
   Serial number: 3618000111203002
   Serial number: 000000000ZY1815416W7
   Serial number: 00000000000099348290
   Subsystem 4 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0905
   Serial number: 12055137
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0130
   Serial number: 0000331122528
   Coding: 001F4B225E00108000010430
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880 C    HW: 8W5 035 880
   Component: MU-P-LN-EU    034 1329
   Serial number: A798G0JB113973
   Coding: 01940301FF0A000053110001041800102F000EE401700900FE
   VCID: BFCE306926D7A8B720-80EA
   Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H32 0170
   Serial number: TPO00121041800820042
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK126061800020450
   Compact Disc Database:
   Component: Gracenote2  --- 3012
   Component: RVC Compact   H12 0250
   Coding: 0294030102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: B3266C591A9F7CD7D4-80E6
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0166
   Revision: --------    Serial number: 32012952600000
   Coding: 0630
   Part No SW: 8W1 713 041 N    HW: 8W1 713 041 K
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 18071048197469
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: BE304D6D21DDA1BF2B-80EA
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W6 907 217 A    HW: 8W6 907 217 A
   Component: BVS           H17 0050
   Coding: 0404090300000401022023A2A40000FC00F0C023E280
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: C0CC33955B29D74F59-8094
1123669 - Left Matrix High Beam
          C1175 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.11
                    Time: 16:53:22
                    Control Module temperature: 41 °C
                    Voltage terminal 15: 14.40 V
1123670 - Right Matrix High Beam
          C1176 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.11
                    Time: 16:53:22
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 8W0 907 159 H    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0008
   Serial number: 180618201516
   VCID: C6C0258D790DF97F63-8092
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HFS       005 0130
   Serial number: 0000331274448
   Coding: 000F4B220000108040000020
   VCID: C5C22281440BF2676A-8090
   Component: TSG HBFS      005 0130
   Serial number: 0000331278451
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 228000049301
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: BD324A612CDBBAA732-80E8
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 E    HW: 4M0 907 590
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   VCID: B4246F451F917BEFCD-80E0
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
   Component: LED1L         H10 2003
   VCID: 9A78A1FD9D35AD9FF7-80CE
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H10 2003
End----------(Elapsed Time: 02:10, VBatt start/end: 12.2V/12.2V)-----------
Thanks!
cinek2004
Poland
C?ID=326815
The story goes...
So... I changed 29 and 39 modules to AD, DRL and blinkers work, but both front indicators are not dynamic. Whole led strip is lightened.
I did parametrisation to MXB of light modules. Lamps are not calibrated yet (67735, 67737 errors).
What else can I do?
Thursday,19,September,2019,22:12:03:43668
VIN: WAUBNCF51JA132577   License Plate: A5 F5 USA MATRIX
   Revision: --H15---
   Coding: 07500363C1291CCD0515871418AC98B9110B3D08000000000000000020001A810A450222025705
   Coding: 5FC7F7
   Coding: 02005D
   Coding: 350000
66963 - Databus
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.19
                    Time: 02:26:27
                    average_Voltage_terminals: 11.40 V
                    Outside air temperature sensor-Outside air temperature on CAN: 15.50 °C
                    interior_temperature: 17.00 °C
66964 - Databus
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.19
                    Time: 02:26:50
                    average_Voltage_terminals: 11.50 V
67735 - Databus
          [MxB not available]
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.19
                    Time: 02:25:33
67737 - Databus
          [MXB_error-lamp_requested]
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.19
                    Time: 02:26:40
   Coding: 80000D
   Coding: 80000D
   Occupant Detection:
   Subsystem 7 - Part No SW: -----------    HW: 442 0B3 006 18
   Part No SW: 4M0 907 397 AD    HW: 4M0 907 397 D
0773 - Dynamic Turn Signal Activation
          C1237 01 [009] - Electrical Failure
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.19
                    Time: 02:26:24
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.19
                    Time: 02:26:48
   Revision: --------
   Coding: 0E8002
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Coding: 0630
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.19
                    Time: 02:25:31
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 11.60 V
                    Reset counter: 143
                    Mileage: 3507 km
                    Date: 2019.09.19
                    Time: 02:25:31
   Revision: --------
   Coding: 0E8002
End----(Elapsed Time: 02:07, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
cinek2004
Poland
C?ID=326815
Turns out seller installed 8w6998473(4)A Led modules onto headlights instead of 8w6998473(4)C.
After changing these modules I finally have dynamic turn signals and retrofit is finished!
