- Joined
- Apr 28, 2014
- Messages
- 52
- Reaction score
- 31
- Location
- New Zealand
- VCDS Serial number
- C?ID=213797
Hi all,
Panel beater replaced the rear camera with new part, obviously needs coding. The old camera has no communication so can't pull the code off that. Can anyone work out the coding for me please!!
Tuesday,03,September,2019,15:23:41:55685
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZ3CZGE126004 License Plate: JUZ154
Mileage: 63189km-39263mi Repair Order:
Chassis Type 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 52 5F 6C
A5 CF
VIN: WVWZZZ3CZGE126004 Mileage: 63189km-39263miles
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 GA HW: 04L 907 309 M
Component: R4 2,0L EDC H23 1621
Revision: B4H23---
Coding: 011D0012046705083000
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_ECM20TDI01104L906026GA 002002
ROD: EV_ECM20TDI01104L906026GA_002.rod
VCID: 6FEDC1C7B644893770-803A
Part No SW: 0D9 300 012 A HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4902
Revision: 06253104 Serial number: TFK01510083247
Shop #: WSC 05311 115 00063
ROD: EV_TCMDQ250021.rod
VCID: 1427AE2BFFA20AEF2D-8040
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 63085000000560
Coding: 40EC928F34224B720777070041C74902492CD2E0E08292F918625038E2A9
VCID: 7AFBE093FD06DC9FD7-802E
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0384828524
Coding: 000F0F0F03
Shop #: WSC 05311 000 00151
ASAM Dataset: EV_KessyHellaMQBAB 004032
VCID: 39793F9FB88017879E-806C
Part No SW: 5G0 907 044 BG HW: 5G0 907 044 BG
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 1212010420210001111550000010180A
ASAM Dataset: EV_ACClimaBHBVW37X 005137
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID: 6DD1DBCFBC487B2742-8038
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 AJ HW: 5Q0 937 086 AJ
Revision: -------- Serial number: 86581810151763
Coding: 03011846C2C102FF0FA44094B11407281880000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 020B987395D6945F8F-8056
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 151015 043 0607
Serial number: 151031062618
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M11D09H04M44S09
Coding: 90A8DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 HW: 3G0 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 26 06 2015 10000872
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY152660R3D
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0312
Serial number: 00000000000033704041
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391529608929
Coding: 0071155811
VCID: 44875E6BCF425A6FFD-8010
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 320467D251FFC428949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 34670EAB9FE2EAEF4D-8060
Part No SW: 3Q0 959 655 BA HW: 3Q0 959 655 BA
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003SSPN6CX7-
Coding: 88CCC000000000005C5400CC008800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7EF3EC83E12EF0BFEB-802A
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 3G2857705E0302P01673
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G2857706E0302P01800
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 002 010 15
Serial number: 3576U000000C0254371%
Subsystem 4 - Part No SW: ----------- HW: 454 002 010 15
Serial number: 3586U00000030254371Y
Subsystem 5 - Part No SW: ----------- HW: 454 801 810 15
Component: SideSensor_Dr 301 0148
Serial number: 3516RBEE2BF08000000V
Subsystem 6 - Part No SW: ----------- HW: 454 801 610 15
Component: SideSensor_Pr 301 0148
Serial number: 3526R3584B5080000001
Subsystem 7 - Part No SW: ----------- HW: 454 802 610 15
Component: FrontSensor_D 304 0149
Serial number: 3556VC4CDF608000000Y
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151024401052
Coding: 0C10
Shop #: WSC 00015 115 00001
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F8D5187A6A439B7A0-806A
Part No SW: 3G0 920 751 A HW: 3G0 920 751 A
Component: KOMBI 301 6421
Coding: 27A4081BE788000801886B0B1000000000000000
VCID: 2345FDF72A0C7D57A4-8076
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 30101510803136
Coding: 030300345F087300FB00225C1E0F00010001070000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 79F9FF9FF800D787DE-802C
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29150002138440045437
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 2874368303
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00014.09.15
Coding: 0301
VCID: 4A9B7053ED668C1F07-801E
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 15000143570004
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E9C7BFA0709FC766-8024
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 B HW: 3Q0 907 566
Component: MRR1Rear H16 0230
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
VCID: 377D39A78E9401F768-8062
Component: TSG FS 020 0041
Serial number: 280715BGP21041
Coding: 00350A208001028000001000
VCID: 43855D77CA4C5D57C4-8016
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002477969
Coding: 0D0000
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 9103
Shop #: WSC 00015 115 00305
Component: TSG BFS 020 0041
Serial number: 160715BGF15874
Coding: 003500208001028000001000
VCID: 428B5873D556545FCF-8016
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002485315
Coding: 050000
Part No SW: 3Q0 035 846 HW: 3Q0 035 846
Component: MU-S-N-ER 820 0624
Coding: 02840208FF00000051510001001828001F0108C601200100C7
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 6ED3DCC3B14E803F7B-803A
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H52 1028
Serial number: VWZ8Z9REN011VU
Subsystem 2 - Part No SW: 3G0 919 866 P HW: -----------
Component: MRM2 2016 --- 0521
7179 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 112
Mileage: 63189 km
Date: 2019.09.03
Time: 14:37:23
Voltage terminal 30: 14.1 V
BAP-BAP_Function_ID: 02
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H17 0170
Coding: 0000000000000000000000
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
VCID: 77FDF9A7CE14C1F7A8-8022
10490624 - No End-of-Line Programming
B2013 00 [009] - -
Reset counter: 112
Mileage: 63189 km
Date: 2019.09.03
Time: 14:38:13
13636352 - Control module not coded
U1013 00 [009] - -
Reset counter: 112
Mileage: 63189 km
Date: 2019.09.03
Time: 14:38:13
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 112
Mileage: 63189 km
Date: 2019.09.03
Time: 14:38:13
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 C HW: 3Q0 980 654
Component: MQB_B_MFK H04 0023
Serial number: 30101511P10271
Coding: 0004080204000101000213468050410084000E000000
Address CF: Lane Chge Asst 2
Interface not compatible.
End-------------------------(Elapsed Time: 05:42)--------------------------
