Hello. looking for information which bits should be changed in BCM module to recode US lamps to EU. Thank you in advance for your help.
Car Audi A3 2016
The lamp has been soldered diodes, coding remained.
Car Audi A3 2016
Monday,02,September,2019,20:35:47:07292
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4441.4
VIN: WAUK8GFF8G1071552 License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 47 52 55
5F 6C A5 BB BC
VIN: WAUK8GFF8G1071552 Mileage: 69825km-43387miles
Address 01: Engine (J623-CNTC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00122466000F3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
ROD: EV_ECM20TFS0205G0906259D_AU37.rod
VCID: AF2E4CEEF601B032F4-80FA
22008 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [039] - -
Mileage: 69825 km
Date: 2019.05.10
Time: 20:10:26
Coolant temperature: 92 °C
Intake air temperature: 59 °C
Voltage terminal 30: 12.187 V
Engine: operating status: ES
ECU_STATE: ENG_STOP
Engine oil temperature: 106.0 °C
Time since engine start: 0.0 s
T_ES: 17 min
Cruise control switch actuation-Main switch hardware: operated
Cruise control switch actuation-Main switch CAN: operated
STATE_ERR_ABC_PRED: 18
Readiness: 1110 1101
Part No SW: 0D9 300 013 B HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4902
Revision: 06253104 Serial number: TFK01509250171
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 9660990A699B61FA97-80C2
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 63185000001468
Coding: 13FF6A9234270A6D017C030581C529C8562C5080C08194B6184150040208
ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
VCID: FAB8ADBA7DC3A59A13-80AE
8192 - Databus
[FCAN: ACC_07 message is not received]
Reset counter: 0
Date: 2019.05.10
Time: 20:10:26
8196 - Databus
[FCAN : ACC_10 message is not received]
Reset counter: 0
Date: 2019.05.10
Time: 20:10:26
Revision: 00021000 Serial number: 0387605410
Coding: 030C0C
VCID: BA386DBA3D43659A53-80EE
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000812260
Coding: 03000014010000000000000000001400
VCID: B326409E1A2994D290-80E6
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 930801E7000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AH HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0175
Serial number: 01061534100462
Coding: 04151C46C04106FD41C04004511007A00800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: FF4E5CAE66E180B224-80AA
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 151116 043 0585
Serial number: 151126055747
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 61022406
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 19 09 2015 00000204
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0312
Serial number: 00000000000064297708
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000P5CW200000
Coding: 101F00
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391533606150
Coding: 0070150011
VCID: C3C6105E4A89245200-8096
Address 13: Auto Dist. Reg
Component: AirbagVW20 010 0830
Serial number: 003GCR045HEC
Coding: 9DCCFCC0000000005000001AC24800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: C7DE044E7EB10872DC-8092
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34230167A09121551442
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34230168A10121540217
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001F4WTE
Coding: 303334
Subsystem 4 - Part No SW: ----------- HW: 480 002 011 15
Serial number: 3570000000038A88D71U
Subsystem 5 - Part No SW: ----------- HW: 480 002 011 15
Serial number: 358000000001EA88D71Z
Subsystem 6 - Part No SW: ----------- HW: 480 402 711 15
Serial number: 3510002C11E24313E04R
Subsystem 7 - Part No SW: ----------- HW: 480 401 711 15
Serial number: 3520002A51E3443510BU
Subsystem 8 - Part No SW: ----------- HW: 480 401 609 15
Serial number: 3550002C51D1B5D37224
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 401 609 15
Serial number: 3560002B91D1B5D12153
Part No SW: 8V0 953 521 GR HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 22111504220604
Coding: E818
ASAM Dataset: EV_SMLSKLOMQB 020001
VCID: 906CEF124B7F8FCACD-80C4
Part No SW: 8V0 920 871 T HW: 8V0 920 871 T
Component: KOMBI H03 6423
Coding: 0B8418196E8800080280E8001800000000000000
VCID: CDD236669CCDE222E6-8098
16776960 - Databus
[ACC_02 keine Kommunikation]
Reset counter: 0
Mileage: 69825 km
Date: 2019.05.10
Time: 20:10:24
16776961 - Databus
[ACC_04 keine Kommunikation]
Reset counter: 0
Mileage: 69825 km
Date: 2019.05.10
Time: 20:10:24
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 05121510803482
Coding: 0101000830085A005B00021C180B00000001010000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: F9BAB2B678C5AE821A-80AC
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 20 11 2015 A0064216
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
[Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
Reset counter: 0
Mileage: 69825 km
Date: 2019.05.10
Time: 20:10:25
Terminal 15: On
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00011.11.15
Coding: 0001
VCID: CAD83D7A6DA3F51AC3-809E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000256360003
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: B42443821F2793EA89-80E0
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H06 0080
Serial number: 0385146096
Coding: 030211
ROD: EV_LaneChangAssis_VW51.rod
VCID: B83C77B2034F778AA5-80EC
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H06 0080
Serial number: 0386905912
Coding: 030211
Component: TSG FS 020 0041
Serial number: 131015BJB05353
Coding: 005D1B204000048000000003
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 9102
VCID: C4C413424F87236A39-8090
Address 47: Sound System (J525) Labels:* None
Part No SW: 8V0 035 465 D HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0420
Serial number: AUZ8ZAFN901TXM2
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
VCID: B93A72B638456E825A-80EC
Component: TSG BFS 020 0041
Serial number: 161015BJF13613
Coding: 005D13204000048000000003
VCID: C2C8155A55932D5A0B-8096
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 012A000123200400
ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
VCID: BFCE1CAE266140B264-80EA
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: 1F1F00
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
5544944 - Output Stage for LED Headlamp; Right
B149B F0 [137] - Not Coded
Reset counter: 0
Mileage: 69825 km
Date: 2019.05.10
Time: 20:10:24
5335297 - Fan 2 for Right Headlamp
C1169 01 [137] - Electrical Failure
Reset counter: 0
Mileage: 69825 km
Date: 2019.05.10
Time: 20:10:24
5276164 - Power Output Module for Right Headlamp
C1082 04 [137] - Internal System Fault
Reset counter: 0
Mileage: 69825 km
Date: 2019.05.10
Time: 20:10:29
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 047 C HW: 8V0 035 047 B
Component: MU-H-NS-US H44 0403
Serial number: A052K0F7510236
Coding: 017301020000000021220002041A00002F000124010001047E
ROD: EV_MUHig6C3HBAS_AU37.rod
Subsystem 1 - Part No SW: V03 959 800 T HW: -----------
Component: NAR 2016 --- 0048
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY204HTX
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000014101500020020
Component: Gracenote --- 3006
U1111 00 [009] - -
[ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 0
Mileage: 69825 km
Date: 2019.05.10
Time: 20:10:30
Voltage terminal 30: 12.3 V
BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 0
Mileage: 69825 km
Date: 2019.05.10
Time: 20:10:30
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE_AU37.rod
VCID: B02C4F92EB3FAFCAED-80E4
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000468391
Coding: 0100000000010303000500010100000100
ROD: EV_MFKBoschAU370.rod
VCID: BC346BA237775BAA41-80E8
393216 - Databus
[ACC_10_TO_FAILURE]
Reset counter: 0
Mileage: 69825 km
Date: 2019.05.10
Time: 20:10:25
Control Module temperature: 49 °C
Outside air temperature: 22.5 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 12.1 V
Terminal 15 on: 881.0 s
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 191115BKI03982
Coding: 004D13204000048000000002
Component: TSG HBFS 020 0041
Serial number: 191115BKI03985
End----------(Elapsed Time: 01:53, VBatt start/end: 12.1V/12.1V)-----------
