Audi A3 2016r. exchange of US lamps for EU
daniel.b
Europe
C?ID=318819
Hello. looking for information which bits should be changed in BCM module to recode US lamps to EU. Thank you in advance for your help.
Car Audi A3 2016
The lamp has been soldered diodes, coding remained.
Monday,02,September,2019,20:35:47:07292
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4441.4
VIN: WAUK8GFF8G1071552   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 47 52 55
          5F 6C A5 BB BC
VIN: WAUK8GFF8G1071552   Mileage: 69825km-43387miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0A1D00122466000F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D_AU37.rod
   VCID: AF2E4CEEF601B032F4-80FA
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
                    Mileage: 69825 km
                    Date: 2019.05.10
                    Time: 20:10:26
                    Engine speed: 0.00 /min
                    Coolant temperature: 92 °C
                    Intake air temperature: 59 °C
                    Voltage terminal 30: 12.187 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 106.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 17 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: operated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: operated
                    Cruise control switch actuation-Large increment: not activated
                    STATE_ERR_ABC_PRED: 18
Readiness: 1110 1101
   Part No SW: 0D9 300 013 B    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4902
   Revision: 06253104    Serial number: TFK01509250171
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 9660990A699B61FA97-80C2
   Revision: 00000000    Serial number: 63185000001468
   Coding: 13FF6A9234270A6D017C030581C529C8562C5080C08194B6184150040208
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: FAB8ADBA7DC3A59A13-80AE
8192 - Databus
          [FCAN: ACC_07 message is not received]
                    Reset counter: 0
                    Date: 2019.05.10
                    Time: 20:10:26
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Reset counter: 0
                    Date: 2019.05.10
                    Time: 20:10:26
   Revision: 00021000    Serial number: 0387605410
   Coding: 030C0C
   VCID: BA386DBA3D43659A53-80EE
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000812260
   Coding: 03000014010000000000000000001400
   VCID: B326409E1A2994D290-80E6
   Serial number: 930801E7000000000001
   Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061534100462
   Coding: 04151C46C04106FD41C04004511007A00800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: FF4E5CAE66E180B224-80AA
   Component: WWS371 151116  043 0585
   Serial number:         151126055747
   Coding: 0A47F7
   Serial number: 61022406
   Coding: 00006C
   Serial number: 19 09 2015  00000204
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000064297708
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000P5CW200000
   Coding: 101F00
   Revision: --------    Serial number: 39391533606150
   Coding: 0070150011
   VCID: C3C6105E4A89245200-8096
Address 13: Auto Dist. Reg
   Serial number: 003GCR045HEC
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: C7DE044E7EB10872DC-8092
   Belt Pretensioner left:
   Serial number: 34230167A09121551442
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A10121540217
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001F4WTE
   Coding: 303334
   Subsystem 4 - Part No SW: -----------    HW: 480 002 011 15
   Serial number: 3570000000038A88D71U
   Subsystem 5 - Part No SW: -----------    HW: 480 002 011 15
   Serial number: 358000000001EA88D71Z
   Subsystem 6 - Part No SW: -----------    HW: 480 402 711 15
   Serial number: 3510002C11E24313E04R
   Subsystem 7 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3520002A51E3443510BU
   Subsystem 8 - Part No SW: -----------    HW: 480 401 609 15
   Serial number: 3550002C51D1B5D37224
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 401 609 15
   Serial number: 3560002B91D1B5D12153
   Part No SW: 8V0 953 521 GR    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 22111504220604
   Coding: E818
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 906CEF124B7F8FCACD-80C4
   Part No SW: 8V0 920 871 T    HW: 8V0 920 871 T
   Component: KOMBI         H03 6423
   Coding: 0B8418196E8800080280E8001800000000000000
   VCID: CDD236669CCDE222E6-8098
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 0
                    Mileage: 69825 km
                    Date: 2019.05.10
                    Time: 20:10:24
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 0
                    Mileage: 69825 km
                    Date: 2019.05.10
                    Time: 20:10:24
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 05121510803482
   Coding: 0101000830085A005B00021C180B00000001010000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: F9BAB2B678C5AE821A-80AC
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 20 11 2015  A0064216
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 0
                    Mileage: 69825 km
                    Date: 2019.05.10
                    Time: 20:10:25
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
   Serial number: HA1-00011.11.15
   Coding: 0001
   VCID: CAD83D7A6DA3F51AC3-809E
   Revision: 00000000    Serial number: 15000256360003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: B42443821F2793EA89-80E0
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Component: SWA Master    H06 0080
   Serial number: 0385146096
   Coding: 030211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: B83C77B2034F778AA5-80EC
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H06 0080
   Serial number: 0386905912
   Coding: 030211
   Serial number: 131015BJB05353
   Coding: 005D1B204000048000000003
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 9102
   VCID: C4C413424F87236A39-8090
   Part No SW: 8V0 035 465 D    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0420
   Serial number: AUZ8ZAFN901TXM2
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: B93A72B638456E825A-80EC
   Serial number: 161015BJF13613
   Coding: 005D13204000048000000003
   VCID: C2C8155A55932D5A0B-8096
   Component: AFS-ECU       H01 0110
   Coding: 012A000123200400
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: BFCE1CAE266140B264-80EA
   Coding: E00100
   Coding: 1F1F00
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
5544944 - Output Stage for LED Headlamp; Right
          B149B F0 [137] - Not Coded
                    Reset counter: 0
                    Mileage: 69825 km
                    Date: 2019.05.10
                    Time: 20:10:24
5335297 - Fan 2 for Right Headlamp
          C1169 01 [137] - Electrical Failure
                    Reset counter: 0
                    Mileage: 69825 km
                    Date: 2019.05.10
                    Time: 20:10:24
5276164 - Power Output Module for Right Headlamp
          C1082 04 [137] - Internal System Fault
                    Reset counter: 0
                    Mileage: 69825 km
                    Date: 2019.05.10
                    Time: 20:10:29
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 047 C    HW: 8V0 035 047 B
   Component: MU-H-NS-US    H44 0403
   Serial number: A052K0F7510236
   Coding: 017301020000000021220002041A00002F000124010001047E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Subsystem 1 - Part No SW: V03 959 800 T    HW: -----------
   Component: NAR 2016  --- 0048
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY204HTX
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000014101500020020
   Compact Disc Database:
   Component: Gracenote  --- 3006
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 0
                    Mileage: 69825 km
                    Date: 2019.05.10
                    Time: 20:10:30
                    Voltage terminal 30: 12.3 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 0
                    Mileage: 69825 km
                    Date: 2019.05.10
                    Time: 20:10:30
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE_AU37.rod
   VCID: B02C4F92EB3FAFCAED-80E4
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000468391
   Coding: 0100000000010303000500010100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: BC346BA237775BAA41-80E8
393216 - Databus
          [ACC_10_TO_FAILURE]
                    Reset counter: 0
                    Mileage: 69825 km
                    Date: 2019.05.10
                    Time: 20:10:25
                    Control Module temperature: 49 °C
                    Outside air temperature: 22.5 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 12.1 V
                    Terminal 15 on: 881.0 s
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 191115BKI03982
   Coding: 004D13204000048000000002
   Serial number: 191115BKI03985
End----------(Elapsed Time: 01:53, VBatt start/end: 12.1V/12.1V)-----------
