Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: DPF soot
    Sep 2018
    DPF soot
    Whatís the difference between soot measured and calculated
    I have been having my car doing regen it went away and stopped reving a little while ago then come back I drove at 40/50mph air con on 2500 rpm for 15/20 mins a couple of trips before when I scanned it was at 18.00g now itís down to 8.01g on the calculated and -2.26 on the measured
    What is the good soot levels is it as low as possible
    Cheers Matt
    I believe that Measured is based on the differential pressure sensor, while calculated is the ECU's best guess as to how much soot "should" have accumulated.
    Check differential pressure readings with key on, engine off, and again with the engine at idle.
    Sep 2018
    Ok cheers for that I did have that up but couldnít remember what I was I will give it a go see the difference
    Iím just glad the soot is down from before now the car shouldnít hand on the revs where is wants to do a regen
    Sep 2018
    I have just looks at some pics of my results even when the soot was up at 18g the messured was still -2.26
    Sep 2018
    Hi uwe
    Plugged in to my car this morning and the differential pressure readings was 2hPa with engine off and then idle it was at 8hPa reved to 2500 and was at 25hPa
    Iím not 100% what these readings are though is that what I should be expecting ?
    Cheers Matt
    Sep 2018
    Also a thought I donít seem to be able to have measuring blocks on my engine module itís greyed out for some reason how I see my reading are on advance measuring values
    Quote Originally Posted by Matt k View Post
    Also a thought I don’t seem to be able to have measuring blocks on my engine module it’s greyed out for some reason how I see my reading are on advance measuring values
    That's because your engine ECU uses UDS protocol.
  9. Likes Uwe liked this post
  10. #8
    Sep 2018
    Cheers after I wrote that I seen another post that explained it
  11. #9
    Sep 2018
    Do you now what the reading should be ball park figure ?
  12. #10
    Should be 0 with the engine not running, and a very low number at idle.
    But we're missing context here. Have you posted an Auto-Scan from your car someplace on this forum so we can see exactly what engine and ECU you've got?
