2013 Passat TDI SE EGT #1 Advanced Measuring Blocks
mothmonsterman
C?ID=370154
Sunday,28,July,2019,18:47:04:01373
VIN: 1VWBN7A39DC102815   License Plate: WI80S
Mileage: 182520km-113412mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 1VWBN7A39DC102815   Mileage: 182520km-113412miles
01-Engine -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CKRA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 997 009 J    HW: 03L 907 309 S
   Component: R4 2.0l TDI   X24 9981
   Revision: 71X24---    Serial number:
   Coding: 001D0012042400000000
   Shop #: WSC 77879 540 394857
   ASAM Dataset: EV_ECM20TDI01103L997009J 004004
   ROD: EV_ECM20TDI01103L997009J.rod
   VCID: 3B233633F3E5F50FDFB-806E
Readiness: 0 0 0 X 1
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9436
   Revision: 05651213    Serial number: 00001211261555
   Shop #: WSC 09003 957 00200
   VCID: 2411ED4F62DBAAF78E1-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -  - Intermittent
                    Reset counter: 23
                    Mileage: 181633 km
                    Date: 2013.12.07
                    Time: 20:26:54
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU - Intermittent
                    Reset counter: 24
                    Mileage: 181635 km
                    Date: 2013.12.07
                    Time: 23:25:34
01196 - Engine-Transmission Data Bus
                    Reset counter: 23
                    Mileage: 181633 km
                    Date: 2013.12.07
                    Time: 20:26:56
   Revision: 00H31001
   Coding: C54BC0F5492200FCA31303E5921E0042A71000
   VCID: 7DA7F82BADF13B3FA1F-8028
                    Reset counter: 198
                    Mileage: 181595 km
                    Date: 2013.12.06
                    Time: 15:58:26
                    Count: 2
                    Count: 14
                    Count: 20480
                    Count: 8194
                    Count: 45056
                    Count: 256
                    Reset counter: 198
                    Mileage: 181595 km
                    Date: 2013.12.06
                    Time: 00:27:15
                    Count: 2
                    Count: 14
                    Count: 20480
                    Count: 16390
                    Count: 41728
                    Count: 514
   Part No SW: 561 907 426 A    HW: 561 907 426 A
   Component: AC Manuell    H02 0101
   Revision: 00001K07
   Coding: 0010001002
   ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 196FCCBB5919E71F2D7-804C
   Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
   Component: BCM PQ35 B+   021 0068
   Revision: BH021001
   Coding: 6F200E1B902B08D40888000116000448007100864080156064  8060000C70
   VCID: 43D34ED38B958DCF97B-8016
                    Reset counter: 198
                    Mileage: 181595 km
                    Date: 2013.12.06
                    Time: 15:58:27
                    Voltage: 12.85 V
   Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
   Component: AirbagVW10G   014 0851
   Serial number: 003MWM00JJG4
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75B7E00B9541637FE9F-8020
   Serial number: 6940000Y130000PJLC05
   Coding: 303044
   Serial number: 3572MSME716D5375ZZZ/
   Serial number: 3582MSME19021573ZZZM
   Serial number: 3516KSME361A0F21ZZZR
   Serial number: 3526KSME784D2D21ZZZ/
   Serial number: 3556LSME20500A20ZZZD
   Serial number: 3566LSME31565C1FZZZ0
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010041    Serial number: 20121114201271
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76B5E70788476867E05-8022
   Component: E221__MFL-YVJ  H07 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
   Part No SW: 561 920 970 E    HW: 561 920 970 E
   Component: KOMBI         H07 0705
   Coding: 231E01
   VCID: 1C61D5AF562B9237361-8048
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 21011303291423
   Coding: 461000
   VCID: 76B5E70788C76867E05-8022
                    Fault Status: 00110100
                    Reset counter: 198
                    Mileage: 181595 km
                    Date: 2013.12.06
                    Time: 15:58:26
   Part No SW: 561 919 965     HW: 561 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1829227R3CAE06
   VCID: 6393AE532755EDCFB7B-8036
   Component: IMMO          H07 0705
   VCID: 6A8DC377CCFFBC8774D-803E
   Component: TUER-SG FT    002 0525
   Revision: 13110009    Serial number: 0006171638
   Coding: 0404F5
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE396B313A5D50FFFB-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 199
                    Mileage: 181635 km
                    Date: 2019.07.17
                    Time: 23:34:06
131584 - Motor for Rear Window Regulator
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 212
                    Mileage: 181635 km
                    Date: 2019.07.17
                    Time: 23:34:06
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 372B2A03C34DD16F3B3-8062
                    Reset counter: 198
                    Mileage: 181635 km
                    Date: 2013.12.07
                    Time: 23:25:34
                    Voltage: 13.88 V
                        DU
                    Temperature: 36.0°C
                    RPM: 1498 /min
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030108
   VCID: 6FBBD263F79D59AF233-803A
   Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
   Component: J245 P05 FFD7  H07 0004
   Serial number: 53388786011227404000
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0005
02174 - Analog/Digital clock
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 175
                    Mileage: 154942 km
                    Date: 2018.08.28
                    Time: 06:48:24
   Component: TUER-SG BT    002 0525
   Revision: 15110009    Serial number: 0006157697
   Coding: 0404F4
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE195AF16ABD237F61-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
67074 - Motors for Central Locking
          B122B 01 [008] - Electrical Failure
                    Fault Frequency: 10
                    Reset counter: 210
                    Mileage: 182015 km
                    Date: 2019.07.21
                    Time: 10:16:50
                    Reset counter: 212
                    Mileage: 181635 km
                    Date: 2019.07.17
                    Time: 23:34:06
   Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
   Component: Radio Prem-8  H05 0008
   Revision: -----09S    Serial number: VWZ4Z7N3412901
   Coding: 0500040004000B
   VCID: 6491AD4F2E5BEAF74E1-8030
                    Reset counter: 234
                    Mileage: 145080 km
                    Date: 2018.05.01
                    Time: 12:34:05
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663891667
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2D3337FCDFCC07C4D-806E
End----------(Elapsed Time: 01:15, VBatt start/end: 12.0V/12.0V)-----------
Car is Stage 3 with EGT sensors #2-4 deleted. I am trying to log EGT #1 via Advanced Measuring Blocks function. I typed in things like "egt", "exh", "temp" and picked everything related I could find.
From the time I start the car to the time I kill it the IDE02229 Exh.gas temp.sen 1 just stays at 1200.0 °C and IDE02233 Exh.gas temp.sen 2 just stays at -273.1 °C as do #3 & #4.
The only one I found that moves and is close to what I would think the #1 sensor would be reading is the "Exhaust Model Temperature 0" value but that sounds like a calculated value and there seems to be an extra value when I only had 4 egt sensors (Exhaust Model Temperature 0, Exhaust Model Temperature 1, Exhaust Model Temperature 2, Exhaust Model Temperature 3, Exhaust Model Temperature 4).
[video]https://photos.app.goo.gl/JF3Xg8wwjVVoeKZFA[/video]
Does anyone know what value I should be looking at for EGT #1 and whether the 1200C indicates something is wrong? Thanks in advance for any help.
How about:
IDE00167-ENG167462 -- Exhaust temperature 1 bank 1
You might also look at:
IDE02230 -- Torque reduction due to exhaust temperature
Normally, I would think that an EGT reading of 1200C that never changes is definitely a sign of a problem. But in this case, "Stage 3 with EGT sensors #2-4 deleted" all bets are off, and I would urge you to TTYT (Talk To Your Tuner).
mothmonsterman
C?ID=370154
thank you for the quick response.
tried that one too, its at -40C. only values that move are the model temps (i guess those are maybe calculated?)
Monday,19,August,2019,13:14:20:01373
VIN: 1VWBN7A39DC102815 License Plate: EGT-VALUES
Address 01: Engine (03L 997 009 J)
13:13:59
IDE00167 Exhaust temperature 1 bank 1 -40.0 °C
IDE00169 Exhaust temperature 2 bank 1 -40.0 °C
IDE02229 Exh.gas temp.sen 1 1200.0 °C
IDE02230 Torque reduction due to exhaust temperature 1.0000
IDE02233 Exh.gas temp.sen 2 -273.1 °C
IDE02234 Exh.gas temp.sen 3 -273.1 °C
IDE02236 Exh.gas temp.sen 4 -273.1 °C
IDE03270 Exh.gas temp.sen 1: unconditioned voltage 0.0 mV
IDE03271 Exh.gas temp.sen 2: unconditioned voltage 0.0 mV
IDE03273 Exh.gas temp.sen 3: unconditioned voltage 0.0 mV
IDE03275 Exh.gas temp.sen 4: unconditioned voltage 0.0 mV
IDE04090 Exhaust temperature bank 1 S1/S2/S3/S4: / 1200/-40/-40/-40 °C
13:19:54
IDE05386 Exhaust model temperature 0 171.3 °C
IDE05387 Exhaust model temperature 1 1000.0 °C
IDE05388 Exhaust model temperature 2 -50.0 °C
IDE05389 Exhaust model temperature 3 -50.0 °C
IDE05390 Exhaust model temperature 4 96.0 °C
MasterTommy
Amsterdam
C?ID=295586
Its not really productive to guess this one until the heat death of the universe, since the software has been changed and specifically software regarding this very system. Talking to the one that modified it is the only way to get to know more.
mothmonsterman
C?ID=370154
Got it, thanks -- question sent to tuner. Was hoping I wasn't missing something obvious or possibly mislabeled. I will post back once I get an update.
