2003 Audi Allroad 2.7 Auto ABS/ESP/BRAKE/SUSPENTION LIGHTS
Chrispiazza
C?ID=377721
Hello i recently replaced the front sub-frame on the car and the front brakes and axles at the same time car was in bad need of alignment and tires so i took it to the local tire shop (car had no warning lights at the time) after tires and alignment i am getting ABS/ESP/BRAKE WARNING BEEPS 3 TIMES AND SUSPENSION LIGHT. below is the full scan i have checked all brake connections and all seem good.
any info would be appreciated
Thanks!
Thursday,15,August,2019,08:35:31:33679
VIN: WA1YD64B33N057266   License Plate:
          75 76 77
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 4Z7 907 551 S
   Component: 2.7L V6/5VT     G   0020
   Coding: 07755
   Shop #: WSC 01312
   VCID: 53F37FC032ED706F27B-5160
   WA1YD64B33N057266     AUZ7Z0B2248790
18057 - Powertrain Data Bus
            P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
17867 - Exhaust Gas Temp Sensor 2 (G236)
            P1459 - 35-10 - Implausible Signal - Intermittent
Readiness: 0000 0100
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 4Z7 927 156 M
   Component: AG5 01V 2.7l5VT USA 2122
   Coding: 01002
   Shop #: WSC 02325
   VCID: 50F970CC03FB0B771A9-5160
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389 A
   Component: ABS/ESP allrad      D56
   Coding: 06497
   Shop #: WSC 02325
   VCID: 4ACD62A4E5A731A754D-5160
            35-00 - -
01420 - High Pressure Switch Valve 1 for Electronic Stability Program (N227)
            35-00 - -
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AM
   Component: A6-Klimavollautomat 0105
   Coding: 00010
   Shop #: WSC 02325
   VCID: 6597B1186C49FEDF59F-2586
            57-00 - Electric Circuit Failure
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4Z7 959 655 J
   Component: Airbag 8.4EP        2000
   Coding: 0000607
   Shop #: WSC 02325 785 00200
   VCID: 56F586D4241F6547C05-5184
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 F
   Component: Lenkradelektronik   D01
   Coding: 01002
   Shop #: WSC 02325
   VCID: 2F3B13307E35748F633-5184
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 981 P
   Component: KOMBI+WEGFAHRS. VDO D12
   Coding: 06264
   Shop #: WSC 19411
   VCID: 33331F40922D506F07B-5160
Address 34: Level Control        Labels: 4Z7-907-553.lbl
   Part No: 4Z7 907 553 E
   Component:  - 2C1A1          D040
   Coding: 25500
   Shop #: WSC 00001
   VCID: 47CB5B90F6B5CCCF4B3-513C
            79-00 - Please Check Fault Codes
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Part No: 4B0 962 258 M
   Component: Central Lock/Alarm  D37
   Coding: 15885
   Shop #: WSC 02325
   VCID: 33331F40921D506F07B-4F0C
01562 - Rear right door
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0102
   Coding: 00001
   VCID: 2C01043C4F230F97461-4B1E
   Part No: 4Z7 907 357
   Coding: 00030
   Shop #: WSC 02325
   VCID: 04518C9C873327D7EE1-4B1E
00532 - Supply Voltage B+
   Part No: 4B0 035 195 L
   Component: symphony II NP2    0051
   Coding: 00205
   Shop #: WSC 01312
   VCID: 290FFD2840D11ABFBD7-4E62
End----------(Elapsed Time: 04:53, VBatt start/end: 12.4V/12.3V)-----------
Dana
Western PA, USA
N227 is part of N55 (providing diagram # 46/4 is correct) so I believe the alignment was unrelated.
