Could someone assist with how to fix these errors, unable to clear faults using VCDS:
Monday,29,October,2018,14:27:36:45940
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 18.9.0.1 (x64) HEX-V2 CB: 0.4436.4
VIN: WVWZZZAUZDW053465 License Plate:
Control Module Part Number: 3Q0 035 846
Component and/or Version: MU-S-N-ER 820 0627
Software Coding: 02730008FF00000051510001000828001F0204C601200102C3
Work Shop Code: WSC 04853
VCID: 6E85CD1C601C32377CA-803B
Advanced Identification/FAZIT
Identification: GRO-633
Date: 07.09.15
Manufacturer number: 0701
Test stand number: 0686
Flash Status
Programming Attempts(application): 0/4
Programming Attempts(data): 65535/0/1/1/1/1/1/65535/1/1/1/65535/65535/1/0/0/65535/0/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535
Successful Attempts(data): 65535/0/1/1/1/1/1/65535/1/1/1/65535/65535/1/0/0/65535/0/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535
Flash Date: 00.01.01
Flash Tool Code(data): 00200 011 01357
Misc.
Hardware number: 3Q0 035 846
Workshop System Name: J794
Equipment/PR Code: FFFFFFFFFFFFFFFFFFFFFFFF
Dataset Number: V03935223SB
Dataset Version: 0001
ASAM Dataset: EV_MUStd4CDELP
ASAM Dataset Revision: 001001
Car Info
Chassis Number: WVWZZZAUZDW053465
VCDS Info:
Labels: 5G0-035-MIB-STD2.clb
ROD: EV_MUStd4CDELP_VW26.rod
Tuesday,06,August,2019,15:43:56:45940
VCDS Version 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Address 03: ABS Brakes Labels: 5Q0-907-379-IPB-V1.CLB
Control Module Part Number: 5Q0 614 517 CL HW: 5Q0 907 379 D
Component and/or Version: ESC H75 0438
Software Coding: 01FA8AA120252A6F037B060601C82980510454C0608094F300280028C0
Work Shop Code: WSC 12345 123 12345
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020 (VW37)
ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
VCID: 7DA7FA503D7A59AFA1F-8029
7 Faults Found:
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 110
Mileage: 125804 km
Date: 2019.08.06
Time: 15:39:26
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 110
Mileage: 125804 km
Date: 2019.08.06
Time: 15:39:26
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 110
Mileage: 125804 km
Date: 2019.08.06
Time: 15:39:26
0295 - Steering angle sensor
Reset counter: 110
Mileage: 125804 km
Date: 2019.08.06
Time: 15:39:26
8299 - Databus
[FCAN: Anhaenger_01_alt veraltet bit is set]
Reset counter: 110
Mileage: 125804 km
Date: 2019.08.06
Time: 15:39:26
16390 - Display for Tire Pressure Monitoring
Reset counter: 110
Mileage: 125804 km
Date: 2019.08.06
Time: 15:39:35
33000 - Longitudinal Acceleration
C10B1 29 [137] - Signal Implausible
[IPB-Sensor: Longitudinal acceleration sensor failure]
Reset counter: 110
Mileage: 125804 km
Date: 2019.08.06
Time: 15:39:26
Coding: 01
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D273A507DFA99AFE1F-8069
15875 - Steering angle sensor
Reset counter: 102
Mileage: 73900 km
Date: 2017.01.16
Time: 00:00:03
Motor status: 00
Supply voltage: 12.50 V
Temperature: 37.0 °C
KFC: 3E
KFA: 00 03
Environmental conditions: 4B
uAdSensI_U5VFiltered_xdu16: 5.07820 V
uioUdNotFilt_xdu16: 12.77 V
uAdSensI_SwitchedKl30_xdu16: 12.76 V
19204 - Databus
[ESP_02 Botschaft - SNA_Check]
Reset counter: 102
Mileage: 125570 km
Date: 2019.08.02
Time: 00:00:36
Motor status: 01
System status: Driving mode
Supply voltage: 12.25 V
Temperature: 42.0 °C
KFC: 4B
KFA: 00 04
Environmental conditions: 7F
uioUdNotFilt_xdu16: 12.33 V
uAdSensI_SwitchedKl30_xdu16: 12.34 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 01
