2010 Gti Engine Swap/Long Story with several issues.
sonofserpentine
C?ID=363694
Hello everyone,
I know it happens quite often as i have looked over the forums and seen plenty of noob questions on here but im pretty stuck. I have done alot of work to my 2010 Gti and could use some help with diagnosing where i went wrong here.
First off i purchased my Gti from a man who worked at a dealership but sold the car to me privately. (should have known there was something fishy there). i knew there was an issue but i never suspected all of this trouble to come about. After researching the best VW mechanic in the entire area of Seattle, I immediatley brought the car to a nearby "Volkswagen Specialist" shop. This mechanic had outstanding reviews and was also recommended by a few friends of mine. He was quick to diagnose the problems i had with my engine and vehicle and i ended up needing new Timing Chains, highpressure fuel pump and a rear main seal. My subframe was also cracked so after charging me $3500 dollars to do all of this i had to wait about 3 weeks before i could afford to get my car back from the shop. I finally got the money together and figured my baby would be ready to rock!!... But unfortunately not even 24hrs later my Gti's engine "seized" while i was driving completely normal doing about 35 mph down a hill on Roxbury. I was at the top of the hill when all of a sudden i went to go to 4th gear from 3rd and the car just shut off. NO power, NO nothin. Since i was on a hill, i tried quickly compression starting in 3rd once and then 2nd gear one time and failed to get it started so i pulled over and called triple A. I popped the hood thinking maybe a battery issue and i could smell what smelt like burning wires maybe. TRiple A checked the battery and tried jumping but car wouldnt do anything.:confused: I hadnt even drove the car very much at all for that 20 hour period nor did i drive aggressivley or "slam gears" like some people like to refer to it. So i did what any normal person would and had the car towed back to the "Volkswagen Specialist" to see what had happened. When i came in the next day, he told me that i needed to start looking for a new engine because the current motor "seized" :facepalm: When i asked him how exactly had the engine seized he said that he didnt know but he would help me replace it after i bought another and also informed it wouldnt be very cheap :banghead::banghead: Irritated i decided to tow my car to my newly rented home w/garage and diagnose this engine failure myself as i could not afford anymore crazy shop fees. The motor wouldnt turn by hand so i decided to pull it and i found that the inspection window for the timing chains was never replaced and there was oil all around this area.
https://photos.google.com/photo/AF1QipPOAM2xobha-YVJ5KHvMANKoKr1x3rcl704CLkf
https://photos.google.com/photo/AF1QipNjxsNrUJmGDWuyUeFNDmfSgEp75t3GSKOy7CYB
https://photos.google.com/photo/AF1QipN1hG7B4t_treY7Mdk0iUqVEHsduZFDW-DXK3G8
So after This discovery i proceeded to look for a used engine online. I found the perfect engine and decided to go hear it run as this was possible because the engine was still in the 2013 jetta. Everything sounded great engine started right up and purred so nicely but also found out the car was a lil newer so it was a cbfa instead of my ccta. looking further into it i seen the only significant difference was SAI (right?) and decided to pull the engine and pay the man selling it $1k.
When i did the swap, i used the new high pressure fuel pump that was replaced in my ccta. i also used a SAI blockoff plate where it bolts to the engine and also used the old ecm from my ccta cause i figured it does not have the SAI in the firmware so no worries there and wiring should match up to these nearly identical engines, correct?. the turbo also had to be switched out so it would fit the downpipe and i decided to use the ccta tranny as well because the cbfa had junkyard markings on the case. i figured if purchased at the junkyard and replaced it had already been in two total cars so why not just use the one thats only been in one other car and never swapped. i also replaced clutch assembly, pressure plate oil, oil filter, coolant, and lost my transponder key in the process so i tried having a locksmith come and make a new one and im almost positive he messed up my instrument cluster whilst doing so. so i have only a key to turn engine and from what i know i should be able to get the car to run for 1 second until immobilizer shuts off. my goal was to get that accomplished before i shelled out another $260 for a key from VW. Do i have to replace cluster as well? I know this is a lot to take in but imagine how i feel i have been studying this since March lol. Any help is appreciated. Here is my Auto - Scan:
Sunday,04,August,2019,12:41:57:58658
VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4505.4
VIN: WVWEV7AJ0AW064514   License Plate: BNW5405
Mileage: 185990km-115568mi   Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 52 55 56 65 77
VIN: WVWEV7AJ0AW064514   Mileage: 185990km-115568miles
17-Instruments -- Status: Malfunction 1010
25-Immobilizer -- Status: Malfunction 1010
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AM    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0030
   Revision: AAH06---    Serial number:
   Coding: 0403010A18070160
   VCID: 71BFD4EA5DA748AF357-8024
12 Faults Found:
005445 - Throttle Valve Controller
               P1545 - 000 - Malfunction - MIL ON
                    Fault Status: 11100000
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 01:21:18
                    Temperature: 26.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.938 V
005464 - Throttle Actuator (G186)
               P1558 - 000 - Electrical Malfunction
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 01:21:18
                    Temperature: 26.0°C
                    Temperature: 21.0°C
                    Voltage: 11.938 V
000568 - Manifold Pressure / Boost Sensor (G31)
               P0238 - 000 - Signal too High
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 01:21:18
                    Temperature: 26.0°C
                    Temperature: 21.0°C
                    Voltage: 11.938 V
004501 - Fuel Pressure Regulator Valve (N276)
               P1195 - 000 - Open or Short to Ground - Intermittent
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 01:21:18
                    Temperature: 26.0°C
                    Temperature: 20.0°C
                    Voltage: 11.938 V
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 000 - Open Circuit - MIL ON
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 26.0°C
                    Temperature: 21.0°C
                    Voltage: 11.811 V
001092 - EVAP Purge Control Valve (N80)
               P0444 - 000 - Circuit Open
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 01:21:32
                    RPM: 137 /min
                    Load: 97.2 %
                    Speed: 255.0 km/h
                    Temperature: 26.0°C
                    Temperature: 21.0°C
                    Voltage: 10.160 V
008200 - Intake Manifold Flap; Bank 1
               P2008 - 000 - Electrical Malfunction
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 01:21:32
                    RPM: 137 /min
                    Load: 97.2 %
                    Speed: 255.0 km/h
                    Temperature: 26.0°C
                    Temperature: 21.0°C
                    Voltage: 10.160 V
000579 - Solenoid Valve  for Boost Pressure Control (N75)
               P0243 - 000 - Malfunction
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 01:21:32
                    RPM: 137 /min
                    Load: 97.2 %
                    Speed: 255.0 km/h
                    Temperature: 26.0°C
                    Temperature: 21.0°C
                    Voltage: 10.160 V
000051 - Turbocharger Bypass Valve Control Circuit
               P0033 - 000 - Malfunction / Open Circuit
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 01:21:32
                    RPM: 137 /min
                    Load: 97.2 %
                    Speed: 255.0 km/h
                    Temperature: 26.0°C
                    Temperature: 21.0°C
                    Voltage: 10.160 V
000016 - Bank 1: Camshaft A (Intake)
               P0010 - 000 - Position Actuator Malfunction
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 01:21:32
                    RPM: 137 /min
                    Load: 97.2 %
                    Speed: 255.0 km/h
                    Temperature: 26.0°C
                    Temperature: 21.0°C
                    Voltage: 10.160 V
001378 - System Voltage
               P0562 - 000 - Too Low
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 02:52:58
                    Temperature: 30.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 9.652 V
000112 - Sensor for Ambient Air Temperature (G17)
               P0070 - 000 - Malfunction
                    Mileage: 185999 km
                    Date: 2019.08.04
                    Time: 00:28:18
                    Temperature: 25.0°C
                    Temperature: 19.0°C
                    Voltage: 12.573 V
Readiness: 1110 0101
   Part No SW: 1K0 907 379 AM    HW: 1K0 907 379 AM
   Component: ESP MK60EC1   H45 0108
   Revision: 00H45001
   Coding: 114B600CC92800FE881006E5931D00413008
   VCID: 7DA7F8DA1DFF3CCFA1F-8028
                    Reset counter: 231
                    Count: 3
                    Count: 28672
                    Count: 8208
                    Count: 43008
                    Count: 1
03391 - Coding Not Possible
                    Reset counter: 231
                    Count: 2
                    Count: 28672
                    Count: 8254
                    Count: 42752
                    Count: 1
                    Reset counter: 231
                    Count: 2
                    Count: 28672
                    Count: 8211
                    Count: 42752
                    Count: 1
                    Reset counter: 231
                    Count: 7
                    Count: 1
                    Count: 28672
                    Count: 128
                    Count: 29184
                    Count: 1
   Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 382929CE72DDD9E7329-806C
8 Faults Found:
9477489 - Motor for Air Distribution Flap
          B109D 71 [008] - Actuator stuck
                    Fault Frequency: 23
                    Reset counter: 7
                    Mileage: 185875 km
                    Date: 2019.05.23
                    Time: 00:42:05
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Motorsteuergerät - bitte Fehlerspeicher auslesen]
                    Reset counter: 16
                    Time: 00:00:00
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 16
                    Time: 00:00:00
13701968 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Steuergerät im Schalttafeleinsatz - bitte Fehlerspeicher auslesen]
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.08.04
                    Time: 00:28:22
          B10AB F0 [009] - Too Low
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.06.25
                    Time: 05:11:48
9480465 - Control Circuit for A/C Compressor
          B10A9 11 [008] - Short to Ground
                    Reset counter: 16
                    Mileage: 185999 km
                    Date: 2019.06.25
                    Time: 02:40:13
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [009] - Open or Short to Plus
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.06.25
                    Time: 00:00:09
13635840 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 16
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 02:10:37
   Part No SW: 1K0 937 087 G    HW: 1K0 937 087 G
   Component: BCM PQ35  H+  103 0576
   Revision: 00103 AD
   Coding: 6D180A3F90272A04808800815000090440050086434D8D60648020200000
   Shop #: WSC 22600 444 99999
   VCID: 353720FA654F248F29F-8060
   Component: Wischer 03070  21  0501
   Coding: 009795
10 Faults Found:
                    Reset counter: 16
                    Voltage: 12.05 V
                        Term 50 Off
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.08.04
                    Time: 01:53:47
                    Voltage: 12.30 V
                        Term 50 Off
                    Fault Status: 00101010
                    Reset counter: 16
                    Mileage: 185999 km
                    Voltage: 12.85 V
                        Term 50 Off
                    Reset counter: 16
                    Voltage: 11.95 V
                        Term 50 Off
                    Fault Status: 01101010
                    Fault Frequency: 9
                    Reset counter: 231
                    Voltage: 11.95 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 16
                    Voltage: 8.40 V
                        Term 50 Off
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 16
                    Voltage: 8.40 V
                        Term 50 Off
                    Reset counter: 16
                    Voltage: 8.00 V
                        Term 50 Off
00532 - Supply Voltage B+
                    Reset counter: 16
                    Voltage: 7.90 V
                        Term 50 Off
                    Reset counter: 16
                    Mileage: 185999 km
                    Date: 2019.08.01
                    Time: 00:00:00
                        Term 15 Off
                    Voltage: 13.65 V
                        Term 50 Off
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   019 0706
   Serial number: 003C4D071WG2
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 392F2CCA49D7C0EFCD7-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  001 0002
   Serial number: ---0000R--00046P3H00
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 3572MSME0F4E0049ZZZ$
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 3582MSME5D2F6648ZZZA
   Serial number: 3512QSME0C3D2F5AZZZ8
   Serial number: 3522QSME14433017ZZZF
   Serial number: 35627SME5F741200ZZZB
6 Faults Found:
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 185999 km
                    Date: 2019.06.25
                    Time: 00:00:02
9444117 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [136] - Open or Short to Plus
                    Mileage: 185999 km
                    Date: 2019.06.26
                    Time: 00:00:03
          U0155 00 [008] - -
                    Reset counter: 16
                    Time: 00:00:00
          [Powersupply  lower threshold fall short of]
                    Reset counter: 16
                    Mileage: 185967 km
                    Date: 2019.05.25
                    Time: 01:04:48
9483264 - Seat Occupied Recognition
          B10B4 00 [008] - Function Restriction due to Undervoltage
                    Fault Frequency: 9
                    Reset counter: 16
                    Mileage: 185967 km
                    Date: 2019.05.25
                    Time: 01:04:04
9483008 - Seat Occupied Recognition
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Reset counter: 16
                    Mileage: 185999 km
                    Date: 2019.06.25
                    Time: 12:42:35
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000532
   VCID: 78A9E9CE3EDD19E7F29-802C
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 5K6 920 970 G    HW: 5K6 920 970 G
   Component: KOMBI         H05 0206
   Coding: 270D00
   Shop #: WSC 22606 444 105560
8 Faults Found:
9453074 - Fuel Level Sensor 1
          B103E 1B [009] - Resistance Too High
                    Fault Frequency: 23
                    Reset counter: 231
9453330 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Reset counter: 231
10485833 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal electronic failure
          [Steuergerät defekt (SiWaLa)]
12604672 - Combination / Chassis CAN Bus (SAE Bus D)
          U0055 00 [008] - Malfunction
          [Datenbus Kombi/Fahrwerk defekt]
                    Fault Frequency: 20
                    Reset counter: 16
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
          [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                    Reset counter: 16
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Reset counter: 16
                    Mileage: 185999 km
                    Date: 2019.06.25
                    Time: 11:47:57
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                    Reset counter: 16
                    Mileage: 185999 km
                    Date: 2019.07.23
                    Time: 21:29:48
12666368 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Diagnose Interface: keine Kommunikation]
                    Reset counter: 16
                    Mileage: 185999 km
                    Date: 2019.07.23
                    Time: 21:29:48
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 0222
   Revision:   H16       Serial number: 4020K097071245
   Coding: E9811F07101612000000
   VCID: 6695B7B664699F17505-8032
                    Fault Frequency: 15
                    Reset counter: 15
                    Fault Frequency: 13
                    Reset counter: 15
                    Fault Status: 00101110
                    Fault Frequency: 28
                    Reset counter: 15
01304 - Radio
                    Reset counter: 15
                    Reset counter: 15
                    Mileage: 185999 km
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223T5Q9T04
   VCID: 7EA5FFD61CF927D7B85-802A
                    Reset counter: 16
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H05 0206
9456433 - Key
          B104B 31 [009] - No Signal
9456681 - Key
          B104C 29 [009] - Implausible Signal
                    Fault Frequency: 20
                    Reset counter: 16
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0140
   Revision: A1001003    Serial number: 7667482343
   Shop #: WSC 22600 444 999999
   VCID: 2809F98EA2FD4967A29-807C
                    Reset counter: 16
                    Reset counter: 16
01304 - Radio
                    Reset counter: 16
   Component: Tuer-SG         009 2107
   Coding: 0001076
   VCID: 313F14EA9D2708AF757-8064
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 74     2901
   Revision: 00H17000
   VCID: 2F3B12928B131E5F633-807A
                    Reset counter: 16
                    Voltage: 12.13 V
                        DD
                    Temperature: 23.0°C
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218198608229
   VCID: 678BBAB26FE3861F6B3-8032
          U1400 00 [008] - -
                    Fault Frequency: 7
                    Reset counter: 16
                    Mileage: 185967 km
                    Date: 2019.05.25
                    Time: 01:04:22
   Coding: 0001076
   VCID: 323D1BE6982133B70CD-8066
   Component: AFS-Steuergeraet    0142
   Coding: 1446940
   VCID: 34311DFE62353D871E1-8060
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Coding: 00000022
7 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 11100100
                    Fault Frequency: 11
                    Reset counter: 231
                    Voltage: 11.93 V
                        ABS 1
                    Reset counter: 16
                    Voltage: 11.93 V
                        ABS 1
                    Reset counter: 16
                    Voltage: 11.93 V
                        ABS 1
            000 - - - MIL ON
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 - - - MIL ON
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 - - - MIL ON
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
                    Fault Status: 11100101
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0043
   Revision: -----19S    Serial number: VWZ4Z7J1106900
   Coding: 0101000001
   VCID: 619FA4AA8147F82FA57-8034
                    Reset counter: 16
                    Reset counter: 231
                    Reset counter: 16
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           103 0521
   Coding: 018705
00667 - Ambient Temperature Signal
                    Mileage: 185999 km
                    Date: 2019.08.04
                    Time: 00:28:22
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 C    HW: 1K8 035 730 C
   Component: Telefon       H08 6600
   Revision: 00008000    Serial number: 20389520161748
   Coding: 412100
   VCID: 290FFC8AB9F7706FBD7-807C
                    Reset counter: 16
                    Reset counter: 16
01304 - Radio
                    Reset counter: 16
End----------(Elapsed Time: 01:17, VBatt start/end: 12.3V/12.3V)-----------
I know i might need to answer some questions so please lemme know how i can make this easier i just want to get this thing started & going after all this trouble and getting screwed literally over and over. The car turns over but wont start.
Vehicle Identification No.WVWEV7AJ0AW064514
ModelGolf 2,0
GO
Date of production23.07.2009
Model year2010
Sales type5K19W2
Engine CodeCCTA
Transmission CodeKZS
Emission standard7GBEmission standard ULEV 2
Seems like you're making a lot of assumptions here. Do you have wiring diagrams for both your car and the donor car?
You've got metric ton of electrical fault codes. Please clear all fault codes in each module that has them, one by one, then re-scan and let's see what comes back.
sonofserpentine
C?ID=363694
i tried to sum up every important detail without making this whole story too long and hard to understand. I have been through a lot already with this vehicle but i also have learned a lot. I meant to word my assumptions as a question because i have no one else who actually knows about this style VW. i actually have a lot of questions i refrained from asking just to keep from making it more confusing. i have cleared all fault codes and re scanned multiple times. this isnt my first time scanning either. i have tried charging the battery and also keeping on the charger while scanning. is that a bad idea? i will put a different fully charged battery in there and rescan and post as soon as i have results. i do have the wire diagram for my exact model and whats funny is the diagrams also all reference that they are the same for ccta and cbfa. very rarely do the diagrams not include one or the other for the most part minus the SAI wiring.
What makes you so cock sure, that a CBFA is the same as a CCTA besides the SAI?
sonofserpentine
C?ID=363694
well sir, like i had said, the wire diagrams that are for my vehicle reference multiple engines. When they reference the CBFA engine, it also says that its the same for the ccta engine. would you like an example? i can post the couple pages of the diagram that do so if youd like. I also have been researching this whole cbfa ccta engine difference for months now and usp motorsports also has a little printout explaining this. not only that but multiple forums i have read the same info and im wrong it wouldnt surprise me but if i was right my attitude would be the same.
Just because the WD is similar doesn't confirm such an assumption, so what else did you confirm?
Doesn't a CBFA use 3 OXS sensors as an SULEV? :rolleyes:
PRE CAT, MID CAT, POST CAT?
sonofserpentine
C?ID=363694
yes that was the only other difference car i could find was the 02 sensors. But since i used my original turbo/downpipe/exhaust from the CCTA, it shouldnt matter considering the ecm is from the ccta as well, right? i mean correct me if im wrong here because if i knew everything i wouldnt be here asking questions. i definitley dont know everything but i have done as much research as i can for this model VW and still having issues. im gonna swap the battery and post a new scan right now. sorry for such a late reply ive been working.
I'm just curious why you would go through all this and not have used your useful life warranty that would of covered this entire repair for FREE?
RETROFITS!
With what your doing now or considering will void this warranty.
Did you know all prior out of pocket costs or repairs & if related to useful life warranty are possible for reimbursement?
This is not a qualified repair to comport with conformity certificate and the CCTA and CBFA have been in production from 2008 to what about 2016?
Are you sure no other hardware conditions exist?
sonofserpentine
C?ID=363694
 Sunday,11,August,2019,00:49:09:58658
VIN: WVWEV7AJ0AW064514   License Plate: 2ND RUN NEW BATT
6 Faults Found:
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:01
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:01
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:01
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:01
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:02
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:02
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
   Revision: 00H45001
   Revision: 00006001
   Coding: 0000000000
          U1113 00 [009] - -
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:10
   Revision: 00103 AD
   Coding: 009795
   Coding: 00003031
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:11
   Coding: 0000532
   Coding: 00000130
   Coding: 270D00
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:10
   Coding: 0001076
   Revision: 00H17000
            000 - - - MIL ON
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:08
                    Battery Volts: 12.4 V
                        DD
                    Temperature: 21.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 47: Sound System        Labels:
   ROD: N/A
   VCID: 678BBAB267E3861F6B3-8032
   Coding: 0001076
   Coding: 1446940
   Coding: 00000255
   Coding: 00000022
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:09
                    Voltage: 12.35 V
                        ABS 1
            000 - - - MIL ON
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
   Coding: 0101000001
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:09
   Coding: 018705
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:09
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:09
-----------Sunday,11,August,2019,00:48:38:58658
6 Faults Found:
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:01
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:01
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:01
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:01
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:02
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:06:02
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.319 V
   Revision: 00H45001
   Revision: 00006001
   Coding: 0000000000
          U1113 00 [009] - -
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:10
   Revision: 00103 AD
   Coding: 009795
   Coding: 00003031
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:11
   Coding: 0000532
   Coding: 00000130
   Coding: 270D00
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:10
   Coding: 0001076
   Revision: 00H17000
            000 - - - MIL ON
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:08
                        DD
                    Temperature: 21.0°C
                    Count: 2
                    Count: 1
                        SteerAng n.Init
   ROD: N/A
   Coding: 0001076
   Coding: 1446940
   Coding: 00000255
   Coding: 00000022
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:09
                    Voltage: 12.35 V
                        ABS 1
            000 - - - MIL ON
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
                    Reset counter: 231
                        Invalid
                        Invalid
                        Invalid
   Coding: 0101000001
                    Reset counter: 231
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:09
   Coding: 018705
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:09
                    Mileage: 185999 km
                    Date: 2019.08.11
                    Time: 00:07:09
   Coding: 412100
End----------(Elapsed Time: 01:03, VBatt start/end: 12.3V/12.3V)-----------
   Coding: 412100
here is the new scan with a fresh battery and all codes cleared. sorry for taking so long. ive been really busy.
