2018 Tiguan SE road legal in Germany - Radio and cluster questions
apial
Germany, Erfurt
C?ID=125504
All,
I am in the process of getting our 2018 Tiguan SE we took from the US to Germany road legal. The lights were the most work but actually quit simple (reused the rear position light cables and reconfigured them to become blinkers and reused the left reverse light cable to become the fog light).
I also work on the cluster (language) and infotainment (language and radio frequencies). Here is were I am stuck:
I coded 5F to use EU radio frequencies, which worked just fine. However, when I store a FM station its gone after a restart of the car. I was also not able to deactivate Sirius, anyone has an idea for these problems?
When I try to change the language in the cluster it actually changes for a second (so the firmware supports it) but changes back. It only supports the languages which are configured in 5F, i confirmed that by putting a German cluster in there and it switched to English immediately. Is there a way to change it without changing 5F to German and if not, is there a way to change 5F to german with VCDS or ODIS? If not, I will see if I can get a german replacement unit and see if it works after removing CP.
Thanks in advance, please see attached - full autoscan with adjustments of 17 and 5F
	SW:3Q0-035-844-B   HW:3Q0-035-844-B ---  Informationselek. I
	Bauteil:MU-S-S-US     722 0867, Codierung:02730600BE0000005100000100180A001F0500C40120050002
	EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW26.rod
	Freitag,02,August,2019,12:46:47:49457
	VCDS Version: PCI 18.9.1  Datenstand: 20190520 DS296.1
	VCID: 2E04FA5EB09B56673C1-807A
IDE00001-Produktionsmodus,00 00 00 ,3
IDE00346-Sommerzeit-Automatik,manuell ,1
IDE00758-Grundlautstärke Telefon,50 %,1
IDE00759-Grundlautstärke Sprachausgabe,50 %,1
IDE00760-Mikrofonempfindlichkeit,0 dB,1
IDE00769-Rufnummer 1 für Inforuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Rufnummer 1 für Pannenruf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-ENG117828-Aktivieren und Deaktivieren aller Entwicklungsbotschaften-Infotainment_CAN_Messages,aus ,1
IDE00820-ENG117829-Aktivieren und Deaktivieren aller Entwicklungsbotschaften-MIB_CAN_Messages,aus ,1
IDE02121-Taster für CD-Rückgabe,freigegeben ,1
IDE02122-Entwicklermodus,nicht aktiviert ,1
IDE02330-Rufnummer 2 für Inforuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Rufnummer 2 für Pannenruf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02332-Produktionsmodus deaktivieren,0 ,3
IDE02476-MAS03001-Elektrische Prüfung der Lautsprecher-Modus,automatisch ,49
IDE02476-ENG117360-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
IDE02476-ENG117378-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
IDE02476-ENG117380-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
IDE02476-ENG117382-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
IDE02476-ENG117384-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
IDE02476-ENG117386-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
IDE02476-ENG117388-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
IDE02476-ENG117390-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
IDE02476-ENG117362-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
IDE02476-ENG117364-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
IDE02476-ENG117366-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
IDE02476-ENG117368-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
IDE02476-ENG117370-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
IDE02476-ENG117372-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
IDE02476-ENG117374-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
IDE02476-ENG117376-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
IDE02502-Bestätigung der Verbauänderung,36 2D ,2
IDE02699-Rufnummer 1 für Hilferuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Rufnummer 1 (roaming) für Hilferuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG117847-Fahrzeugkonfiguration-advanced_range_display,aus ,30
IDE03471-ENG142146-Fahrzeugkonfiguration-allow_message_editing,aus ,30
IDE03471-ENG130249-Fahrzeugkonfiguration-Apple_DIO,ein ,30
IDE03471-ENG185764-Fahrzeugkonfiguration-Apple_DIO_Wireless,aus ,30
IDE03471-ENG152525-Fahrzeugkonfiguration-Baidu_Car_Life,aus ,30
IDE03471-ENG152559-Fahrzeugkonfiguration-Baidu_Car_Life_ios,aus ,30
IDE03471-ENG185765-Fahrzeugkonfiguration-Baidu_Car_Life_ios_Wireless,aus ,30
IDE03471-ENG185766-Fahrzeugkonfiguration-Baidu_Car_Life_Wireless,aus ,30
IDE03471-ENG152560-Fahrzeugkonfiguration-block_hmi_function_p_epb,gesperrt ,30
IDE03471-ENG142151-Fahrzeugkonfiguration-conditioning_variant,0 ,30
IDE03471-ENG125043-Fahrzeugkonfiguration-Dtmf_without_active_call,ein ,30
IDE03471-ENG142145-Fahrzeugkonfiguration-esim_data_only_sms_support,aus ,30
IDE03471-ENG185778-Fahrzeugkonfiguration-FoD,SWaP ,30
IDE03471-ENG130248-Fahrzeugkonfiguration-Google_GAL,ein ,30
IDE03471-ENG185779-Fahrzeugkonfiguration-Google_GAL_Wireless,aus ,30
IDE03471-ENG117850-Fahrzeugkonfiguration-gracenote_local_coverarts,aus ,30
IDE03471-ENG117851-Fahrzeugkonfiguration-gracenote_local_other,aus ,30
IDE03471-ENG117848-Fahrzeugkonfiguration-gracenote_online_coverarts,aus ,30
IDE03471-ENG117849-Fahrzeugkonfiguration-gracenote_online_other,aus ,30
IDE03471-ENG152533-Fahrzeugkonfiguration-Hybrid_Radio_additional_online_data,nicht aktiviert ,30
IDE03471-ENG152534-Fahrzeugkonfiguration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG125049-Fahrzeugkonfiguration-Joker_button_1,nicht vorhanden ,30
IDE03471-ENG125050-Fahrzeugkonfiguration-Joker_button_2,nicht vorhanden ,30
IDE03471-ENG127492-Fahrzeugkonfiguration-LGI,aus ,30
IDE03471-ENG130246-Fahrzeugkonfiguration-LTE_modul,aktiviert ,30
IDE03471-ENG142142-Fahrzeugkonfiguration-map_email_support,aus ,30
IDE03471-ENG142143-Fahrzeugkonfiguration-map_instant_messaging_support,aus ,30
IDE03471-ENG142141-Fahrzeugkonfiguration-map_sms_support,aus ,30
IDE03471-ENG142152-Fahrzeugkonfiguration-Map_Style,0 ,30
IDE03471-ENG152537-Fahrzeugkonfiguration-media_control,nicht aktiviert ,30
IDE03471-ENG138662-Fahrzeugkonfiguration-Mirror_link,ein ,30
IDE03471-ENG142148-Fahrzeugkonfiguration-MirrorLink_Country_Code,MIB_NAR ,30
IDE03471-ENG142150-Fahrzeugkonfiguration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Fahrzeugkonfiguration-my_audi,aus ,30
IDE03471-ENG117845-Fahrzeugkonfiguration-online_dictation,aus ,30
IDE03471-ENG127495-Fahrzeugkonfiguration-online_media,aus ,30
IDE03471-ENG117840-Fahrzeugkonfiguration-online_navigation,aus ,30
IDE03471-ENG117837-Fahrzeugkonfiguration-online_POI,aus ,30
IDE03471-ENG117838-Fahrzeugkonfiguration-online_POI_voice,aus ,30
IDE03471-ENG117839-Fahrzeugkonfiguration-online_portal_browser_services,aus ,30
IDE03471-ENG152553-Fahrzeugkonfiguration-online_radio,Deactivated ,30
IDE03471-ENG117841-Fahrzeugkonfiguration-online_street_view,aus ,30
IDE03471-ENG125048-Fahrzeugkonfiguration-OPS_display_in_dash_board_display_unit,aus ,30
IDE03471-ENG167521-Fahrzeugkonfiguration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Fahrzeugkonfiguration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Fahrzeugkonfiguration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Fahrzeugkonfiguration-Phone_module_operation_mode,Daten- und Sprachdienst aktiv ,30
IDE03471-ENG117844-Fahrzeugkonfiguration-picture_navi,aus ,30
IDE03471-ENG167523-Fahrzeugkonfiguration-Pilot_Parking,nicht aktiviert ,30
IDE03471-ENG167525-Fahrzeugkonfiguration-Popup_if_GPS_services_in_use,nicht aktiviert ,30
IDE03471-ENG152555-Fahrzeugkonfiguration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Fahrzeugkonfiguration-ProbeCar_lgi,aus ,30
IDE03471-ENG137646-Fahrzeugkonfiguration-ProbeCar_vzo,aus ,30
IDE03471-ENG125047-Fahrzeugkonfiguration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Fahrzeugkonfiguration-remote_HMI,aus ,30
IDE03471-ENG138661-Fahrzeugkonfiguration-RSE_software_component,aktiviert ,30
IDE03471-ENG245031-Fahrzeugkonfiguration-rvc_low_black_screen_trunk_open,nicht aktiviert ,30
IDE03471-ENG244966-Fahrzeugkonfiguration-rvc_low_black_screen_velocity_threshold,nicht aktiviert ,30
IDE03471-ENG245015-Fahrzeugkonfiguration-rvc_low_failsafe,nicht aktiviert ,30
IDE03471-ENG126143-Fahrzeugkonfiguration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Fahrzeugkonfiguration-scon_telephony,nicht aktiviert ,30
IDE03471-ENG142081-Fahrzeugkonfiguration-sd_slot_deactivation,keine Einschränkung ,30
IDE03471-ENG138660-Fahrzeugkonfiguration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Fahrzeugkonfiguration-show_volte_hmi_switch,nicht aktiviert ,30
IDE03471-ENG125045-Fahrzeugkonfiguration-Sim_card_mode_switch,nicht vorhanden ,30
IDE03471-ENG142144-Fahrzeugkonfiguration-sim_data_only_sms_support,aus ,30
IDE03471-ENG138663-Fahrzeugkonfiguration-Smartphone_interface_for_rhmi,aktiviert ,30
IDE03471-ENG126993-Fahrzeugkonfiguration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125044-Fahrzeugkonfiguration-Support_for_response_and_hold,aus ,30
IDE03471-ENG125042-Fahrzeugkonfiguration-Support_of_threeway_calling,ein ,30
IDE03471-ENG130247-Fahrzeugkonfiguration-Support_second_phone,ein ,30
IDE03471-ENG167531-Fahrzeugkonfiguration-Tencent_myCar_canceling_share_location,aus ,30
IDE03471-ENG126994-Fahrzeugkonfiguration-TPEG_availability,aus ,30
IDE03471-ENG152571-Fahrzeugkonfiguration-unblock_functions_while_piloted_driving,gesperrt ,30
IDE03471-ENG137647-Fahrzeugkonfiguration-UOTA,aus ,30
IDE03471-ENG167532-Fahrzeugkonfiguration-UOTA_2,aus ,30
IDE03471-ENG117852-Fahrzeugkonfiguration-UPnP,aus ,30
IDE03471-ENG142149-Fahrzeugkonfiguration-vehicle_leaving_sound,nicht aktiviert ,30
IDE03471-ENG142147-Fahrzeugkonfiguration-vehicle_readiness_sound,nicht aktiviert ,30
IDE03471-ENG152558-Fahrzeugkonfiguration-voice_over_lte,nicht aktiviert ,30
IDE03471-ENG117836-Fahrzeugkonfiguration-VZAPro,aus ,30
IDE03471-ENG127494-Fahrzeugkonfiguration-VZO,aus ,30
IDE03471-ENG137648-Fahrzeugkonfiguration-WiFi_Client_HMI,aus ,30
IDE03471-ENG117842-Fahrzeugkonfiguration-WIFI_Hotspot,aus ,30
IDE03471-ENG152572-Fahrzeugkonfiguration-wlan_5ghz_switch,nicht aktiviert ,30
IDE03902-Automatische Ringbruchdiagnose,Kein automatischer Start ,1
IDE04295-Bluetooth: bevorzugtes Verbindungsprofil für Telefonbuchdaten,PBAP ,1
IDE04331-Auswahl der Freischaltcodes einer SWaP Funktion,FF FF FF FF ,4
IDE04521-Sporadische Ringbruchdetektion,optisch ,1
IDE04522-Weckfähigkeit am optischen Datenbus,aus ,1
IDE04550-Bluetooth: Sniff-Mode,aus ,1
IDE05113-Infotainment Recorder,aktiviert ,1
IDE06425-Rollenprüfstandmodus: funktional,nicht aktiviert ,1
IDE10221-MAS00839-Audio Management Eingangsverstärkung Generation 2-TV-Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Eingangsverstärkung Generation 2-Satellitenradio,5 ,40
IDE10221-MAS01984-Audio Management Eingangsverstärkung Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Eingangsverstärkung Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Eingangsverstärkung Generation 2-Digitalradio (DAB),-128 ,40
IDE10221-ENG125854-Audio Management Eingangsverstärkung Generation 2-Exbox_DMB,-128 ,40
IDE10221-ENG117430-Audio Management Eingangsverstärkung Generation 2-HFP,-128 ,40
IDE10221-ENG125846-Audio Management Eingangsverstärkung Generation 2-Media_Airplay,-128 ,40
IDE10221-ENG125837-Audio Management Eingangsverstärkung Generation 2-Media_AUX_Adapter,-128 ,40
IDE10221-ENG125836-Audio Management Eingangsverstärkung Generation 2-Media_AUXIN,-128 ,40
IDE10221-ENG125843-Audio Management Eingangsverstärkung Generation 2-Media_Bluray,-128 ,40
IDE10221-ENG125841-Audio Management Eingangsverstärkung Generation 2-Media_BTDevice,-128 ,40
IDE10221-ENG125838-Audio Management Eingangsverstärkung Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125848-Audio Management Eingangsverstärkung Generation 2-Media_Cloud,-128 ,40
IDE10221-ENG125839-Audio Management Eingangsverstärkung Generation 2-Media_DVD,-128 ,40
IDE10221-ENG125844-Audio Management Eingangsverstärkung Generation 2-Media_HDMI,-128 ,40
IDE10221-ENG125840-Audio Management Eingangsverstärkung Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125847-Audio Management Eingangsverstärkung Generation 2-Media_UPNP,-128 ,40
IDE10221-ENG125855-Audio Management Eingangsverstärkung Generation 2-Mirrorlink,-128 ,40
IDE10221-ENG125859-Audio Management Eingangsverstärkung Generation 2-Phone_Ringer_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Eingangsverstärkung Generation 2-Phone_Ringer_OB,-3 ,40
IDE10221-ENG125858-Audio Management Eingangsverstärkung Generation 2-Phone_Voice,-128 ,40
IDE10221-ENG125842-Audio Management Eingangsverstärkung Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Eingangsverstärkung Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125853-Audio Management Eingangsverstärkung Generation 2-Tone_Messaging,-128 ,40
IDE10221-ENG125852-Audio Management Eingangsverstärkung Generation 2-Tone_Touchscreen,6 ,40
IDE10221-ENG125851-Audio Management Eingangsverstärkung Generation 2-Tone_Warning,-128 ,40
IDE10221-ENG125856-Audio Management Eingangsverstärkung Generation 2-TTS_Nav,-128 ,40
IDE10221-ENG125857-Audio Management Eingangsverstärkung Generation 2-TTS_SDS,-128 ,40
IDE10221-ENG125845-Audio Management Eingangsverstärkung Generation 2-Tuner_Online,-128 ,40
IDE10221-ENG125849-Audio Management Eingangsverstärkung Generation 2-Tuner_Personal,-128 ,40
IDE10221-ENG125835-Audio Management Eingangsverstärkung Generation 2-Tuner_TI,-128 ,40
IDE10221-ENG125861-Audio Management Eingangsverstärkung Generation 2-TV_AV_IN,-128 ,40
IDE10480-MAS10741-Schnittstelle für externen Medien: Aktivierung-Anschluss 1,aktiviert ,4
IDE10480-MAS10742-Schnittstelle für externen Medien: Aktivierung-Anschluss 2,aktiviert ,4
IDE10480-MAS10743-Schnittstelle für externen Medien: Aktivierung-Anschluss 3,nicht aktiviert ,4
IDE10480-MAS10744-Schnittstelle für externen Medien: Aktivierung-Anschluss 4,nicht aktiviert ,4
IDE10604-Menü-Einträge für mobile Online-Dienste,nicht aktiviert ,1
IDE11122-Länderkennung Verkaufsland HMI,US ,2
IDE11502-ENG127601-Gesperrte Menüinhalte-FB_CAR_0,blocked ,21
IDE11502-ENG127602-Gesperrte Menüinhalte-FB_CAR_1,non_blocked ,21
IDE11502-ENG127611-Gesperrte Menüinhalte-FB_CAR_10,non_blocked ,21
IDE11502-ENG127612-Gesperrte Menüinhalte-FB_CAR_11,blocked ,21
IDE11502-ENG127613-Gesperrte Menüinhalte-FB_CAR_12,blocked ,21
IDE11502-ENG127614-Gesperrte Menüinhalte-FB_CAR_13,non_blocked ,21
IDE11502-ENG127615-Gesperrte Menüinhalte-FB_CAR_14,non_blocked ,21
IDE11502-ENG127616-Gesperrte Menüinhalte-FB_CAR_15,non_blocked ,21
IDE11502-ENG127617-Gesperrte Menüinhalte-FB_CAR_16,non_blocked ,21
IDE11502-ENG127618-Gesperrte Menüinhalte-FB_CAR_17,non_blocked ,21
IDE11502-ENG127619-Gesperrte Menüinhalte-FB_CAR_18,non_blocked ,21
IDE11502-ENG127620-Gesperrte Menüinhalte-FB_CAR_19,non_blocked ,21
IDE11502-ENG127603-Gesperrte Menüinhalte-FB_CAR_2,blocked ,21
IDE11502-ENG127621-Gesperrte Menüinhalte-FB_CAR_20,non_blocked ,21
IDE11502-ENG127622-Gesperrte Menüinhalte-FB_CAR_21,non_blocked ,21
IDE11502-ENG127623-Gesperrte Menüinhalte-FB_CAR_22,non_blocked ,21
IDE11502-ENG127624-Gesperrte Menüinhalte-FB_CAR_23,non_blocked ,21
IDE11502-ENG127604-Gesperrte Menüinhalte-FB_CAR_3,blocked ,21
IDE11502-ENG127605-Gesperrte Menüinhalte-FB_CAR_4,non_blocked ,21
IDE11502-ENG127606-Gesperrte Menüinhalte-FB_CAR_5,non_blocked ,21
IDE11502-ENG127607-Gesperrte Menüinhalte-FB_CAR_6,non_blocked ,21
IDE11502-ENG127608-Gesperrte Menüinhalte-FB_CAR_7,blocked ,21
IDE11502-ENG127609-Gesperrte Menüinhalte-FB_CAR_8,non_blocked ,21
IDE11502-ENG127610-Gesperrte Menüinhalte-FB_CAR_9,non_blocked ,21
IDE11502-ENG127521-Gesperrte Menüinhalte-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Gesperrte Menüinhalte-FB_MEDIA_1,blocked ,21
IDE11502-ENG127531-Gesperrte Menüinhalte-FB_MEDIA_10,blocked ,21
IDE11502-ENG127532-Gesperrte Menüinhalte-FB_MEDIA_11,blocked ,21
IDE11502-ENG127533-Gesperrte Menüinhalte-FB_MEDIA_12,blocked ,21
IDE11502-ENG127534-Gesperrte Menüinhalte-FB_MEDIA_13,blocked ,21
IDE11502-ENG127535-Gesperrte Menüinhalte-FB_MEDIA_14,non_blocked ,21
IDE11502-ENG127536-Gesperrte Menüinhalte-FB_MEDIA_15,blocked ,21
IDE11502-ENG127537-Gesperrte Menüinhalte-FB_MEDIA_16,non_blocked ,21
IDE11502-ENG127538-Gesperrte Menüinhalte-FB_MEDIA_17,non_blocked ,21
IDE11502-ENG127539-Gesperrte Menüinhalte-FB_MEDIA_18,non_blocked ,21
IDE11502-ENG127540-Gesperrte Menüinhalte-FB_MEDIA_19,non_blocked ,21
IDE11502-ENG127523-Gesperrte Menüinhalte-FB_MEDIA_2,non_blocked ,21
IDE11502-ENG127541-Gesperrte Menüinhalte-FB_MEDIA_20,non_blocked ,21
IDE11502-ENG127542-Gesperrte Menüinhalte-FB_MEDIA_21,non_blocked ,21
IDE11502-ENG127543-Gesperrte Menüinhalte-FB_MEDIA_22,non_blocked ,21
IDE11502-ENG127544-Gesperrte Menüinhalte-FB_MEDIA_23,non_blocked ,21
IDE11502-ENG127524-Gesperrte Menüinhalte-FB_MEDIA_3,blocked ,21
IDE11502-ENG127525-Gesperrte Menüinhalte-FB_MEDIA_4,blocked ,21
IDE11502-ENG127526-Gesperrte Menüinhalte-FB_MEDIA_5,blocked ,21
IDE11502-ENG127527-Gesperrte Menüinhalte-FB_MEDIA_6,non_blocked ,21
IDE11502-ENG127528-Gesperrte Menüinhalte-FB_MEDIA_7,non_blocked ,21
IDE11502-ENG127529-Gesperrte Menüinhalte-FB_MEDIA_8,blocked ,21
IDE11502-ENG127530-Gesperrte Menüinhalte-FB_MEDIA_9,blocked ,21
IDE11502-ENG127625-Gesperrte Menüinhalte-FB_MISC_0,blocked ,21
IDE11502-ENG127626-Gesperrte Menüinhalte-FB_MISC_1,non_blocked ,21
IDE11502-ENG127635-Gesperrte Menüinhalte-FB_MISC_10,blocked ,21
IDE11502-ENG127636-Gesperrte Menüinhalte-FB_MISC_11,blocked ,21
IDE11502-ENG127637-Gesperrte Menüinhalte-FB_MISC_12,blocked ,21
IDE11502-ENG127638-Gesperrte Menüinhalte-FB_MISC_13,blocked ,21
IDE11502-ENG127639-Gesperrte Menüinhalte-FB_MISC_14,blocked ,21
IDE11502-ENG127640-Gesperrte Menüinhalte-FB_MISC_15,non_blocked ,21
IDE11502-ENG127641-Gesperrte Menüinhalte-FB_MISC_16,non_blocked ,21
IDE11502-ENG127642-Gesperrte Menüinhalte-FB_MISC_17,non_blocked ,21
IDE11502-ENG127643-Gesperrte Menüinhalte-FB_MISC_18,blocked ,21
IDE11502-ENG127644-Gesperrte Menüinhalte-FB_MISC_19,blocked ,21
IDE11502-ENG127627-Gesperrte Menüinhalte-FB_MISC_2,blocked ,21
IDE11502-ENG127645-Gesperrte Menüinhalte-FB_MISC_20,blocked ,21
IDE11502-ENG127646-Gesperrte Menüinhalte-FB_MISC_21,non_blocked ,21
IDE11502-ENG127647-Gesperrte Menüinhalte-FB_MISC_22,blocked ,21
IDE11502-ENG127648-Gesperrte Menüinhalte-FB_MISC_23,non_blocked ,21
IDE11502-ENG127649-Gesperrte Menüinhalte-FB_MISC_24,non_blocked ,21
IDE11502-ENG127650-Gesperrte Menüinhalte-FB_MISC_25,non_blocked ,21
IDE11502-ENG127651-Gesperrte Menüinhalte-FB_MISC_26,non_blocked ,21
IDE11502-ENG127652-Gesperrte Menüinhalte-FB_MISC_27,non_blocked ,21
IDE11502-ENG127653-Gesperrte Menüinhalte-FB_MISC_28,non_blocked ,21
IDE11502-ENG127654-Gesperrte Menüinhalte-FB_MISC_29,non_blocked ,21
IDE11502-ENG127628-Gesperrte Menüinhalte-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Gesperrte Menüinhalte-FB_MISC_30,non_blocked ,21
IDE11502-ENG127656-Gesperrte Menüinhalte-FB_MISC_31,non_blocked ,21
IDE11502-ENG127657-Gesperrte Menüinhalte-FB_MISC_32,non_blocked ,21
IDE11502-ENG127658-Gesperrte Menüinhalte-FB_MISC_33,non_blocked ,21
IDE11502-ENG127659-Gesperrte Menüinhalte-FB_MISC_34,non_blocked ,21
IDE11502-ENG127660-Gesperrte Menüinhalte-FB_MISC_35,non_blocked ,21
IDE11502-ENG127661-Gesperrte Menüinhalte-FB_MISC_36,non_blocked ,21
IDE11502-ENG127662-Gesperrte Menüinhalte-FB_MISC_37,non_blocked ,21
IDE11502-ENG127663-Gesperrte Menüinhalte-FB_MISC_38,non_blocked ,21
IDE11502-ENG127664-Gesperrte Menüinhalte-FB_MISC_39,non_blocked ,21
IDE11502-ENG127629-Gesperrte Menüinhalte-FB_MISC_4,non_blocked ,21
IDE11502-ENG127665-Gesperrte Menüinhalte-FB_MISC_40,non_blocked ,21
IDE11502-ENG127666-Gesperrte Menüinhalte-FB_MISC_41,non_blocked ,21
IDE11502-ENG127667-Gesperrte Menüinhalte-FB_MISC_42,non_blocked ,21
IDE11502-ENG127668-Gesperrte Menüinhalte-FB_MISC_43,non_blocked ,21
IDE11502-ENG127669-Gesperrte Menüinhalte-FB_MISC_44,blocked ,21
IDE11502-ENG127670-Gesperrte Menüinhalte-FB_MISC_45,blocked ,21
IDE11502-ENG127671-Gesperrte Menüinhalte-FB_MISC_46,blocked ,21
IDE11502-ENG127672-Gesperrte Menüinhalte-FB_MISC_47,blocked ,21
IDE11502-ENG127630-Gesperrte Menüinhalte-FB_MISC_5,blocked ,21
IDE11502-ENG127631-Gesperrte Menüinhalte-FB_MISC_6,non_blocked ,21
IDE11502-ENG127632-Gesperrte Menüinhalte-FB_MISC_7,non_blocked ,21
IDE11502-ENG127633-Gesperrte Menüinhalte-FB_MISC_8,non_blocked ,21
IDE11502-ENG127634-Gesperrte Menüinhalte-FB_MISC_9,blocked ,21
IDE11502-ENG127561-Gesperrte Menüinhalte-FB_NAV_0,blocked ,21
IDE11502-ENG127562-Gesperrte Menüinhalte-FB_NAV_1,non_blocked ,21
IDE11502-ENG127571-Gesperrte Menüinhalte-FB_NAV_10,non_blocked ,21
IDE11502-ENG127572-Gesperrte Menüinhalte-FB_NAV_11,non_blocked ,21
IDE11502-ENG127573-Gesperrte Menüinhalte-FB_NAV_12,non_blocked ,21
IDE11502-ENG127574-Gesperrte Menüinhalte-FB_NAV_13,non_blocked ,21
IDE11502-ENG127575-Gesperrte Menüinhalte-FB_NAV_14,non_blocked ,21
IDE11502-ENG127576-Gesperrte Menüinhalte-FB_NAV_15,non_blocked ,21
IDE11502-ENG127577-Gesperrte Menüinhalte-FB_NAV_16,non_blocked ,21
IDE11502-ENG127578-Gesperrte Menüinhalte-FB_NAV_17,non_blocked ,21
IDE11502-ENG127579-Gesperrte Menüinhalte-FB_NAV_18,non_blocked ,21
IDE11502-ENG127580-Gesperrte Menüinhalte-FB_NAV_19,non_blocked ,21
IDE11502-ENG127563-Gesperrte Menüinhalte-FB_NAV_2,non_blocked ,21
IDE11502-ENG127581-Gesperrte Menüinhalte-FB_NAV_20,non_blocked ,21
IDE11502-ENG127582-Gesperrte Menüinhalte-FB_NAV_21,blocked ,21
IDE11502-ENG127583-Gesperrte Menüinhalte-FB_NAV_22,non_blocked ,21
IDE11502-ENG127584-Gesperrte Menüinhalte-FB_NAV_23,non_blocked ,21
IDE11502-ENG127585-Gesperrte Menüinhalte-FB_NAV_24,non_blocked ,21
IDE11502-ENG127586-Gesperrte Menüinhalte-FB_NAV_25,non_blocked ,21
IDE11502-ENG127587-Gesperrte Menüinhalte-FB_NAV_26,non_blocked ,21
IDE11502-ENG127588-Gesperrte Menüinhalte-FB_NAV_27,non_blocked ,21
IDE11502-ENG127589-Gesperrte Menüinhalte-FB_NAV_28,non_blocked ,21
IDE11502-ENG127590-Gesperrte Menüinhalte-FB_NAV_29,non_blocked ,21
IDE11502-ENG127564-Gesperrte Menüinhalte-FB_NAV_3,non_blocked ,21
IDE11502-ENG127591-Gesperrte Menüinhalte-FB_NAV_30,non_blocked ,21
IDE11502-ENG127592-Gesperrte Menüinhalte-FB_NAV_31,non_blocked ,21
IDE11502-ENG127593-Gesperrte Menüinhalte-FB_NAV_32,non_blocked ,21
IDE11502-ENG127594-Gesperrte Menüinhalte-FB_NAV_33,non_blocked ,21
IDE11502-ENG127595-Gesperrte Menüinhalte-FB_NAV_34,non_blocked ,21
IDE11502-ENG127596-Gesperrte Menüinhalte-FB_NAV_35,non_blocked ,21
IDE11502-ENG127597-Gesperrte Menüinhalte-FB_NAV_36,non_blocked ,21
IDE11502-ENG127598-Gesperrte Menüinhalte-FB_NAV_37,non_blocked ,21
IDE11502-ENG127599-Gesperrte Menüinhalte-FB_NAV_38,non_blocked ,21
IDE11502-ENG127600-Gesperrte Menüinhalte-FB_NAV_39,non_blocked ,21
IDE11502-ENG127565-Gesperrte Menüinhalte-FB_NAV_4,blocked ,21
IDE11502-ENG127566-Gesperrte Menüinhalte-FB_NAV_5,non_blocked ,21
IDE11502-ENG127567-Gesperrte Menüinhalte-FB_NAV_6,blocked ,21
IDE11502-ENG127568-Gesperrte Menüinhalte-FB_NAV_7,non_blocked ,21
IDE11502-ENG127569-Gesperrte Menüinhalte-FB_NAV_8,non_blocked ,21
IDE11502-ENG127570-Gesperrte Menüinhalte-FB_NAV_9,blocked ,21
IDE11502-ENG127545-Gesperrte Menüinhalte-FB_PHONE_0,blocked ,21
IDE11502-ENG127546-Gesperrte Menüinhalte-FB_PHONE_1,non_blocked ,21
IDE11502-ENG127555-Gesperrte Menüinhalte-FB_PHONE_10,non_blocked ,21
IDE11502-ENG127556-Gesperrte Menüinhalte-FB_PHONE_11,non_blocked ,21
IDE11502-ENG127557-Gesperrte Menüinhalte-FB_PHONE_12,non_blocked ,21
IDE11502-ENG127558-Gesperrte Menüinhalte-FB_PHONE_13,non_blocked ,21
IDE11502-ENG127559-Gesperrte Menüinhalte-FB_PHONE_14,non_blocked ,21
IDE11502-ENG127560-Gesperrte Menüinhalte-FB_PHONE_15,non_blocked ,21
IDE11502-ENG127547-Gesperrte Menüinhalte-FB_PHONE_2,non_blocked ,21
IDE11502-ENG127548-Gesperrte Menüinhalte-FB_PHONE_3,non_blocked ,21
IDE11502-ENG127549-Gesperrte Menüinhalte-FB_PHONE_4,blocked ,21
IDE11502-ENG127550-Gesperrte Menüinhalte-FB_PHONE_5,blocked ,21
IDE11502-ENG127551-Gesperrte Menüinhalte-FB_PHONE_6,blocked ,21
IDE11502-ENG127552-Gesperrte Menüinhalte-FB_PHONE_7,blocked ,21
IDE11502-ENG127553-Gesperrte Menüinhalte-FB_PHONE_8,non_blocked ,21
IDE11502-ENG127554-Gesperrte Menüinhalte-FB_PHONE_9,non_blocked ,21
IDE11502-ENG127505-Gesperrte Menüinhalte-FB_TUNER_0,non_blocked ,21
IDE11502-ENG127506-Gesperrte Menüinhalte-FB_TUNER_1,non_blocked ,21
IDE11502-ENG127515-Gesperrte Menüinhalte-FB_TUNER_10,non_blocked ,21
IDE11502-ENG127516-Gesperrte Menüinhalte-FB_TUNER_11,non_blocked ,21
IDE11502-ENG127517-Gesperrte Menüinhalte-FB_TUNER_12,non_blocked ,21
IDE11502-ENG127518-Gesperrte Menüinhalte-FB_TUNER_13,non_blocked ,21
IDE11502-ENG127519-Gesperrte Menüinhalte-FB_TUNER_14,non_blocked ,21
IDE11502-ENG127520-Gesperrte Menüinhalte-FB_TUNER_15,non_blocked ,21
IDE11502-ENG127507-Gesperrte Menüinhalte-FB_TUNER_2,non_blocked ,21
IDE11502-ENG127508-Gesperrte Menüinhalte-FB_TUNER_3,blocked ,21
IDE11502-ENG127509-Gesperrte Menüinhalte-FB_TUNER_4,blocked ,21
IDE11502-ENG127510-Gesperrte Menüinhalte-FB_TUNER_5,blocked ,21
IDE11502-ENG127511-Gesperrte Menüinhalte-FB_TUNER_6,blocked ,21
IDE11502-ENG127512-Gesperrte Menüinhalte-FB_TUNER_7,blocked ,21
IDE11502-ENG127513-Gesperrte Menüinhalte-FB_TUNER_8,non_blocked ,21
IDE11502-ENG127514-Gesperrte Menüinhalte-FB_TUNER_9,non_blocked ,21
IDE11503-Tuner für Satellitenradio: voraktiviertes Abonnement,05 ,1
IDE11524-ENG142156-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-climate_mastet_0x42,nicht aktiviert ,192
IDE11524-ENG142157-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-climate_mastet_0x42_msg_bus,nicht aktiviert ,192
IDE11524-ENG142158-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-connection_manager_0x47,nicht aktiviert ,192
IDE11524-ENG142159-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-connection_manager_0x47_msg_bus,nicht aktiviert ,192
IDE11524-ENG152529-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-daf_profile_0x51,nicht aktiviert ,192
IDE11524-ENG152530-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-daf_profile_0x51_msg_bus,nicht aktiviert ,192
IDE11524-ENG137043-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-display_configuration_0x45,nicht aktiviert ,192
IDE11524-ENG137044-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-display_configuration_0x45_msg_bus,nicht aktiviert ,192
IDE11524-ENG185772-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-engine_functions_0x5D,nicht aktiviert ,192
IDE11524-ENG185773-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-engine_functions_0x5D_msg_bus,nicht aktiviert ,192
IDE11524-ENG142168-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-fas_profile_0x4D,nicht aktiviert ,192
IDE11524-ENG142169-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-fas_profile_0x4D_msg_bus,nicht aktiviert ,192
IDE11524-ENG142154-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-front_traffic_assist_0x41,nicht aktiviert ,192
IDE11524-ENG142155-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-front_traffic_assist_0x41_msg_bus,nicht aktiviert ,192
IDE11524-ENG152535-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-infotainmentsettings_profile_0x50,nicht aktiviert ,192
IDE11524-ENG152536-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-infotainmentsettings_profile_0x50_msg_bus,nicht aktiviert ,192
IDE11524-ENG185787-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-mascot_0x83,nicht aktiviert ,192
IDE11524-ENG185788-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-mascot_0x83_msg_bus,nicht aktiviert ,192
IDE11524-ENG152569-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-remote_services_profile_0x4E,nicht aktiviert ,192
IDE11524-ENG152570-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-remote_services_profile_0x4E_msg_bus,nicht aktiviert ,192
IDE11524-ENG139202-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-Soundcontrol_0x44,nicht aktiviert ,192
IDE11524-ENG139203-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-Soundcontrol_0x44_msg_bus,nicht aktiviert ,192
IDE11524-ENG127678-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-spoiler_0x40,nicht aktiviert ,192
IDE11524-ENG127679-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-spoiler_0x40_msg_bus,nicht aktiviert ,192
IDE11524-ENG142162-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-statistic_0x4A,nicht aktiviert ,192
IDE11524-ENG142163-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-statistic_0x4A_msg_bus,nicht aktiviert ,192
IDE11524-ENG142164-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_front_0x4B,nicht aktiviert ,192
IDE11524-ENG142165-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_front_0x4B_msg_bus,nicht aktiviert ,192
IDE11524-ENG142166-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_rear_0x4C,nicht aktiviert ,192
IDE11524-ENG142167-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_rear_0x4C_msg_bus,nicht aktiviert ,192
IDE11524-ENG185817-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-vas_0x54,nicht aktiviert ,192
IDE11524-ENG185818-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-vas_0x54_msg_bus,nicht aktiviert ,192
IDE11524-ENG142160-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-wireless_charging_0x48,nicht aktiviert ,192
IDE11524-ENG142161-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-wireless_charging_0x48_msg_bus,nicht aktiviert ,192
IDE13183-De-/Aktivierung der Popups für aktive Trackingdienste,00 00 00 00 ,4
MAS00951-Bluetooth,ein ,1
MAS01968-Lüfter,normal ,1
MAS02809-MAS02870-Frequenz für Prüfton-Hochton Frequenzbereich,4000 Hz,6
MAS02809-MAS02871-Frequenz für Prüfton-Mittelton Frequenzbereich,1000 Hz,6
MAS02809-MAS02872-Frequenz für Prüfton-Tiefton Frequenzbereich,100 Hz,6
MAS03782-WLAN,ein ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,nicht aktiviert ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,nicht aktiviert ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,nicht aktiviert ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,nicht aktiviert ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,nicht aktiviert ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,nicht aktiviert ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,nicht aktiviert ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,nicht aktiviert ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,nicht aktiviert ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,nicht aktiviert ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,nicht aktiviert ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,nicht aktiviert ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,nicht aktiviert ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,nicht aktiviert ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,aktiviert ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,aktiviert ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,nicht aktiviert ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,nicht aktiviert ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,nicht aktiviert ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,nicht aktiviert ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,nicht aktiviert ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,nicht aktiviert ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,nicht aktiviert ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,aktiviert ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,aktiviert ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,nicht aktiviert ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,nicht aktiviert ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,nicht aktiviert ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,aktiviert ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,aktiviert ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,nicht aktiviert ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,aktiviert ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,aktiviert ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,nicht aktiviert ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,aktiviert ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,aktiviert ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,nicht aktiviert ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,aktiviert ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,aktiviert ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,nicht aktiviert ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,aktiviert ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,aktiviert ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,nicht aktiviert ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,aktiviert ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,aktiviert ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,nicht aktiviert ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,aktiviert ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,aktiviert ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,nicht aktiviert ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,aktiviert ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,aktiviert ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,nicht aktiviert ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,aktiviert ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,aktiviert ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,nicht aktiviert ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,nicht aktiviert ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,nicht aktiviert ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,nicht aktiviert ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,nicht aktiviert ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,nicht aktiviert ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,nicht aktiviert ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,nicht aktiviert ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,nicht aktiviert ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,aktiviert ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,aktiviert ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,nicht aktiviert ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,nicht aktiviert ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,nicht aktiviert ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,aktiviert ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,aktiviert ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,nicht aktiviert ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,aktiviert ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,aktiviert ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,nicht aktiviert ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,nicht aktiviert ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,nicht aktiviert ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,nicht aktiviert ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,nicht aktiviert ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,aktiviert ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,aktiviert ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,nicht aktiviert ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,nicht aktiviert ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,nicht aktiviert ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,nicht aktiviert ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,nicht aktiviert ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,nicht aktiviert ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,nicht aktiviert ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,nicht aktiviert ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,nicht aktiviert ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,aktiviert ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,aktiviert ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,nicht aktiviert ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,nicht aktiviert ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,nicht aktiviert ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,aktiviert ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,aktiviert ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,nicht aktiviert ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,nicht aktiviert ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,nicht aktiviert ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,nicht aktiviert ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,nicht aktiviert ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,nicht aktiviert ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,nicht aktiviert ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,nicht aktiviert ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,nicht aktiviert ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,nicht aktiviert ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,nicht aktiviert ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,aktiviert ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,aktiviert ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,nicht aktiviert ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,nicht aktiviert ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,nicht aktiviert ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,nicht aktiviert ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,nicht aktiviert ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,nicht aktiviert ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,nicht aktiviert ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,nicht aktiviert ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,nicht aktiviert ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,nicht aktiviert ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,nicht aktiviert ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,nicht aktiviert ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,nicht aktiviert ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,nicht aktiviert ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,nicht aktiviert ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,nicht aktiviert ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,nicht aktiviert ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,aktiviert ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,aktiviert ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,nicht aktiviert ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,aktiviert ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,aktiviert ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,nicht aktiviert ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,nicht aktiviert ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,nicht aktiviert ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,aktiviert ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,aktiviert ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,nicht aktiviert ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,aktiviert ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,aktiviert ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,nicht aktiviert ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,nicht aktiviert ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,nicht aktiviert ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,nicht aktiviert ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Datenbus Extended ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,nicht aktiviert ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Datenbus Fahrwerk ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,nicht aktiviert ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,nicht aktiviert ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,nicht aktiviert ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,nicht aktiviert ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,aktiviert ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Klemme 15 ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,nicht aktiviert ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Datenbus Antrieb ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,aktiviert ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,aktiviert ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Datenbus Fahrwerk ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,aktiviert ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,aktiviert ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,nicht aktiviert ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,aktiviert ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,nicht aktiviert ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,aktiviert ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,nicht aktiviert ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,nicht aktiviert ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,nicht aktiviert ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Datenbus Komfort ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,aktiviert ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Datenbus Komfort ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,nicht aktiviert ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,nicht aktiviert ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,aktiviert ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Datenbus Komfort ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,nicht aktiviert ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,aktiviert ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,nicht aktiviert ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,nicht aktiviert ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Datenbus Antrieb ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,aktiviert ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,nicht aktiviert ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Datenbus Extended ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,aktiviert ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,nicht aktiviert ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Datenbus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,aktiviert ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,nicht aktiviert ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,nicht aktiviert ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,nicht aktiviert ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Klemme 15 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,nicht aktiviert ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Datenbus Komfort ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,nicht aktiviert ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Datenbus Extended ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,nicht aktiviert ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Datenbus Infotainment ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,nicht aktiviert ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,nicht aktiviert ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Datenbus Antrieb ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,nicht aktiviert ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Datenbus Komfort ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,nicht aktiviert ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Datenbus Komfort ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,nicht aktiviert ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Datenbus Komfort ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,aktiviert ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,nicht aktiviert ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,nicht aktiviert ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,nicht aktiviert ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Datenbus Komfort ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,nicht aktiviert ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,aktiviert ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Datenbus Extended ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,aktiviert ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Datenbus Fahrwerk ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,nicht aktiviert ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Datenbus Extended ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,nicht aktiviert ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Datenbus Komfort ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,nicht aktiviert ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,nicht aktiviert ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Klemme 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,aktiviert ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,aktiviert ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,nicht aktiviert ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,aktiviert ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Datenbus Komfort ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,nicht verfügbar ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Datenbus Komfort ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,nicht verfügbar ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Datenbus Infotainment ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,verfügbar ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Datenbus Infotainment ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,nicht verfügbar ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Datenbus Antrieb ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,nicht verfügbar ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Datenbus Fahrwerk ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,nicht verfügbar ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Datenbus Komfort ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Datenbus Komfort ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,nicht verfügbar ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,verfügbar ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Datenbus Komfort ,8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,aus ,10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,aus ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,aus ,10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,aus ,10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,aus ,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,aktiviert ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,aktiviert ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,aktiviert ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,aktiviert ,5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,nicht aktiviert ,5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,nicht aktiviert ,5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,nicht aktiviert ,5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,nicht aktiviert ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,aktiviert ,5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,nicht aktiviert ,5
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
	SW:5NA-920-850-B   HW:5NA-920-850-B ---  Schalttafeleinsatz
	Bauteil:KOMBI         380 0310, Codierung:0BA40C1AA388CF0500882B0954000000A0000000
	EV_DashBoardVDDMQBAB,009060,EV_DashBoardVDDMQBAB_009_VW37.rod
	Freitag,02,August,2019,12:46:05:49457
	VCDS Version: PCI 18.9.1  Datenstand: 20190520 DS296.1
	VCID: 3E24CA1E60FBA6E7AC1-806A
IDE00295-Öltemperaturanzeige,ein ,1
IDE00301-Wegstrecke,8976 km,3
IDE00342-WIV: Rücksetzen der WIV,Warnung aktiv ,1
IDE00343-Sprachvariante,Englisch (US) ,1
IDE00345-MAS00234-MFA3-Reset-MFA-Taste RESET / OK,manueller Reset: nicht möglich ,3
IDE00345-MAS05463-MFA3-Reset-Nachtankerkennung Benzin / Diesel,MFA3-Reset ,3
IDE00345-MAS05464-MFA3-Reset-Nachtankerkennung Gas,MFA3-Reset ,3
IDE00345-MAS12879-MFA3-Reset-Nachtankerkennung Elektro,MFA3-Reset ,3
IDE00499-Anzeigekorrektur Verbräuche und Reichweite,100 %,1
IDE00500-Stunde,12 H,1
IDE00501-Minute,46 min,1
IDE00502-Jahr,2019 yr,2
IDE00503-Monat,8 mon,1
IDE00504-Tag,2 d,1
IDE00510-WIV: Wegstrecke ab Inspektion,8977 km,3
IDE00511-WIV: Zeit ab Inspektion,373 d,2
IDE00512-WIV: Minwert Km-Fahrleistung/Inspektion,15000 km,2
IDE00513-WIV: Maxwert Km-Fahrleistung/Inspektion,30000 km,2
IDE00514-WIV: Maxwert der Zeit zwischen den Inspektionen,730 d,2
IDE00515-WIV: Ölqualität,schlechte Ölqualität ,1
IDE00517-WIV: Rußeintrag,0 km,2
IDE00518-WIV: thermische Belastung,20100 km,2
IDE00819-Tageszähler,371 d,2
IDE00820-Aktivieren und Deaktivieren aller Entwicklungsbotschaften,nicht aktiv ,1
IDE00827-WIV: Minwert der Zeit zwischen den Inspektionen,365 d,2
IDE01153-SIA: Maxwert der Strecke bis Service,16100 km,2
IDE01154-SIA: Maxwert der Zeit bis Service,365 d,2
IDE02489-Displaydarstellung,Variante 1 ,1
IDE02818-IDE02689-Offset für Werte der Tankkalibrierung (-eichung)-Tank Vollkalibrierung (-eichung),-12.8 l,5
IDE02818-MAS02376-Offset für Werte der Tankkalibrierung (-eichung)-Offset Geber 1,-12.8 l,5
IDE02818-MAS02377-Offset für Werte der Tankkalibrierung (-eichung)-Offset Geber 2,-12.8 l,5
IDE02818-MAS02378-Offset für Werte der Tankkalibrierung (-eichung)-Offset Geber 3,12.7 l,5
IDE02818-MAS02379-Offset für Werte der Tankkalibrierung (-eichung)-Offset Geber 4,12.7 l,5
IDE03329-Fahrprofil für Restreichweite,8.3 l/100km,2
IDE03346-IDE00301-Eingestellte Einheiten-Wegstrecke,Kilometer ,3
IDE03346-MAS01230-Eingestellte Einheiten-Datum,mm_dd_jj ,3
IDE03346-MAS01456-Eingestellte Einheiten-Geschwindigkeit,Kilometer pro Stunde ,3
IDE03346-MAS02201-Eingestellte Einheiten-Temperatur,Grad Celsius ,3
IDE03346-MAS02957-Eingestellte Einheiten-Uhrzeit,24h ,3
IDE03346-MAS03032-Eingestellte Einheiten-Volumen,Liter ,3
IDE03346-MAS03034-Eingestellte Einheiten-Druck,bar ,3
IDE03346-MAS05637-Eingestellte Einheiten-Verbrauch CNG (komprimiertes Erdgas),kg pro 100 km ,3
IDE03346-MAS05638-Eingestellte Einheiten-Verbrauch Benzin / Diesel / LPG (Flüssig-/Autogas),Liter pro 100 km ,3
IDE03346-MAS05875-Eingestellte Einheiten-Durchschnittsverbrauch Elektroantrieb,kWh pro 100 km ,3
IDE03346-MAS13665-Eingestellte Einheiten-Anhänge-/Stützlast Masse,Kilogramm (kg) ,3
IDE03348-MAS01456-Geschwindigkeitswarnung-Geschwindigkeit,0 ,2
IDE03348-MAS01561-Geschwindigkeitswarnung-Einheit,Kilometer pro Stunde ,2
IDE03348-Geschwindigkeitswarnung-,nicht aktiv ,2
IDE03349-Fix:Max. Fahrstrecke bis nächste laufleistungsabhängige Inspekt,32200 km,2
IDE03350-FIX: Maximale Zeit bis zur nächsten zeitabhängigen Inspektion,730 d,2
IDE03351-FIX:Fahrstrecke seit letzter laufleistungsabhängiger Inspektion,8900 km,2
IDE03352-FIX: Zeit seit letzter zeitabhängiger Inspektion,373 d,2
IDE03372-Quelle für Synchronisation der Uhrzeit,GPS ,1
IDE03568-ENG119828-Service-Key Einstellungen-p_deactivate_SK_Function,ein ,5
IDE03568-ENG99943-Service-Key Einstellungen-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-Key Einstellungen-p_main_switch_Basic,ein ,5
IDE03568-ENG102414-Service-Key Einstellungen-p_main_switch_keyless,ein ,5
IDE03568-ENG102611-Service-Key Einstellungen-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-Key Einstellungen-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-Key Einstellungen-p_write_distance,20 km,5
IDE03867-Gurtwarnung deaktivieren,nein ,1
IDE05930-Servicevorwarnung in Tage,30 d,1
IDE05931-FIX: Rücksetzwert für die nächsten laufleistungsabh. Inspekt.,32200 km,2
IDE05932-FIX: Rücksetzwert für die nächsten zeitabhängigen Inspektionen,730 d,2
IDE05971-Schnittstellensteuergerät für Fahrzeugortungssystem,nicht verbaut ,1
IDE06425-Rollenprüfstandmodus: funktional,nicht aktiviert ,1
IDE06588-Zündung aktiv Meldung: Auslöser,Fahrertür ,1
IDE06922-Anzeige Spannungsfreiheit,Unbekannt (2),1
IDE07221-Zylinderabschaltung,Anzeige ,1
IDE11086-Servicevorwarnung,30 d,1
IDE11932-MAS01877-Display Farbabgleich-Rot,0 ,3
IDE11932-MAS01878-Display Farbabgleich-Grün,0 ,3
IDE11932-MAS01879-Display Farbabgleich-Blau,0 ,3
IDE12226-MAS03686-Anzeigen Längsregelkoordinator-Automatische Distanzregelung,nicht aktiv ,1
IDE12226-MAS05203-Anzeigen Längsregelkoordinator-GRA,nicht aktiv ,1
IDE12226-MAS10720-Anzeigen Längsregelkoordinator-Geschwindigkeitsbegrenzer,nicht aktiv ,1
MAS03685-Digitaltachometer,Anzeige ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,10 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1E ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0E ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
ENG119874-Gas_functionality,nicht aktiv ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
ENG119882-init_fuel_algorithm,nein ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG119825-Picture_Upload_Download,nicht aktiv ,1
ENG126396-Scale_switching_algorithm,lowbeam_foglight ,1
ENG119876-Service_Key_Clear_All_Counter,ja ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,nicht aktiv ,4
Somnus
SLC, USA
C?ID=215931
I believe the 5F Languages are set using parameterization. When I put a Discover Media in my GTI I had to upload the parameter files with VCP, one of which was the Language packs.
Although, I could very well be wrong, I'm still pretty new to all this.
downtime
C?ID=280813
^ you are correct. That is the way to add languages to the MIB unit.
apial
Germany, Erfurt
C?ID=125504
Thank you guys! Do I assume right that this only changes the ability to install EU updates? Meaning after I have changed the language parameter, I would need the EU update to install on the system?
downtime
C?ID=280813
Not an update, new dataset. Different thing. Datasets contain parameters with what you can modify the characteristics how the system performs. Like change the language packs, change the audio profile etc.
Vcds is not able to update datasets they need to be flashed to the units eeprom
apial
Germany, Erfurt
C?ID=125504
Got it.
As I want to get DAB instead of the dead Sirius anyway, I went ahead and bought a 5F from a german Tiguan. Will see if ODIS automatically changes the dataset back to NAR when I remove CP.
If it does, I can still go ahead and order VCP...
I found a thread for MIB2 in 2017+ Audi models saying that the language parameters cannot be overwritten via VCP (OBD) anymore but that you have to gain physical Telnet access to the unit. Any knowledge if this is the same for the VW 5Fs?
Anyhow, lets hope it stays german after removing CP, I will update this thread anyway with the result.
downtime
C?ID=280813
If you only remove CP, it should not change anything in ODIS. If you run the online coding and parameterization of the unit, then bye bye languages. Is the speaker configuration the same on both yours and the german Tiguan? If not, that will probably pose a problem.
Remember to restore feature enable codes to the new unit. Otherwise you don't have navi or bluetooth.
apial
Germany, Erfurt
C?ID=125504
@Downtime
Its possible that the speakers are different as I believe the one I bought is a HIGH model, not standard but not 100% certain by the part number (has the MOST connector though).
I will see if it has audio problems after CP removal and coding, was really cheap for test purposes so not to concerned about this.
Will restore features but the US SE model has nothing fancy besides APP LINK and BT but no NAVI
@All
I found some answers to my other questions myself, maybe they help someone:
Sirius deactivation:
- It looks like Sirius CANT be deactivated according to all the research I did on this. Makes sense I guess, as Sirius wants to stay present in case a (new) customer decides to reactive his subscription
Radio preset store problem:
- Are resolved and were caused by incorrect coding. The 5F through an "incorrect coding" DTC and therefor didn't store ANY settings of the radio anymore, this also affected other settings like audio balance ect. and not only the radio presets
- I went ahead and re-coded the unit with ODIS/FAZIT to factory specs and than went ahead and just changed the FM frequencies from NAR to EU. Now works like a charm and I will change the other codings step by step and see which one it didn't like.
apial
Germany, Erfurt
C?ID=125504
Hi Folks,
making progress here and want to give an update. New unit came, plugged in and changed language to German. As assumed, cluster changed instantly to German as well :D
It had Appconnect and BT activated but Voice was missing. Removed CP which worked fine but than App Connect ect. was gone as expected.
Problem was, that SVM process detects a wrong module for the car and does not allow any adaptions. LUCKILY ODIS allows restore of FEC codes by VIN and strangely didn't care about the non matching module during this process.
All functions restored including Appconnect, BT and Voice. It also checked SW version during this process but did not change back to NAR image, so still German available. Also DAB is still active :D
So now its homework to code with VCDS and than I believe we will be fine beside the wrong software DTC which I dont really care about as long as it works....
Will keep you posted.
apial
Germany, Erfurt
C?ID=125504
Wow, super cool thanks!! Promised my wife to come to bed, will try this tomorrow ;)
apial
Germany, Erfurt
C?ID=125504
Gentleman,
making great progress here, THANKS AGAIN FOR THE SUPPORT! Was able to remove the SVM DTC according to the manual.
No other errors and everything works. Spend a couple hours to optimize coding and adaption as I left the german base config on the module. Reason is, that this config also activated DAB station pictures ect. which was not the case with the US adaption.
I am 99% done, only some menus are still there like park assist but I am sure I will figure out howto remove them, if not I post again. Nice side affect, the german config also activates all setting while in motion, US module locked while driving.
In terms of DAB antenna, I found an awesome solution were you use a splitter and new amplifier in the back. With this solution, you can use the original window antenna and do not have to move a new cable through the car. Not sure if its allowed to post the shop link, so if anyone needs this info, shoot me a PM.
downtime
C?ID=280813
You can remove the excess menus from 5F module adaptations. Gen2 menu items. PDC change eto not active and so on.
apial
Germany, Erfurt
C?ID=125504
So I am generally done but have 2 problems left which hopefully someone has an idea (worked several hours comparing adaptions and coding):
1. Backup camera
Problem:
As visible in the picture, camera screen shows no options on the right side, like the different views (it does with the other 5F). Also, when moving from P to D, the camera screen stays on (which is OK) but is blacked out (with the other 5F it stay on but still shows camera picture) see below as well.
Tried to resolve:
I compared coding, the USA 5F has Byte 19 bit 4 NOT active, so now low camera installed. The German 5F has this bit active, when I deactivate it, the camere is not coming on at all. So my guess is, its not a low camera BUT I find no other coding to activate it? Also did not find anything in the adaptions in regards to camera.
Last but not least, I have the feeling that after starting the car, the camera takes for ever to come on with the german 5F, much faster with the USA one. Once the system runs, there is no speed difference.
2. Instrument cluster lighting
Problem:
I have no option in the "lights" menu to regulate the instrument cluster lighting:
Tried to resolve:
Same as for the camera, checked coding and adaptions, but cant find something specific. As soon as I put the USA 5F on, its back again, so shouldn't be a problem with the german cluster.
Adaptions German 5F
	SW:3Q0-035-842-C   HW:3Q0-035-842-C ---  Informationselek. I
	Bauteil:MU-S-D-ER     724 0891, Codierung:02730600BE00000051110101008808001F0500D40120850002
	EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
	Samstag,24,August,2019,22:01:08:49457
	VCDS Version: PCI 19.6.1  Datenstand: 20190807 DS308.0
	VCID: 2D06FD52BD9D2D7F51F-8078
IDE00001-Produktionsmodus,00 00 00 ,3
IDE00346-Sommerzeit-Automatik,manuell ,1
IDE00758-Grundlautstärke Telefon,50 %,1
IDE00759-Grundlautstärke Sprachausgabe,50 %,1
IDE00760-Mikrofonempfindlichkeit,0 dB,1
IDE00769-Rufnummer 1 für Inforuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Rufnummer 1 für Pannenruf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-ENG117828-Aktivieren und Deaktivieren aller Entwicklungsbotschaften-Infotainment_CAN_Messages,aus ,1
IDE00820-ENG117829-Aktivieren und Deaktivieren aller Entwicklungsbotschaften-MIB_CAN_Messages,aus ,1
IDE02121-Taster für CD-Rückgabe,freigegeben ,1
IDE02122-Entwicklermodus,aktiviert ,1
IDE02330-Rufnummer 2 für Inforuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Rufnummer 2 für Pannenruf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02332-Produktionsmodus deaktivieren,0 ,3
IDE02476-MAS03001-Elektrische Prüfung der Lautsprecher-Modus,automatisch ,49
IDE02476-ENG117360-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
IDE02476-ENG117378-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
IDE02476-ENG117380-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
IDE02476-ENG117382-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
IDE02476-ENG117384-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
IDE02476-ENG117386-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
IDE02476-ENG117388-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
IDE02476-ENG117390-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
IDE02476-ENG117362-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
IDE02476-ENG117364-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
IDE02476-ENG117366-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
IDE02476-ENG117368-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
IDE02476-ENG117370-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
IDE02476-ENG117372-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
IDE02476-ENG117374-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
IDE02476-ENG117376-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
IDE02502-Bestätigung der Verbauänderung,73 7F ,2
IDE02699-Rufnummer 1 für Hilferuf,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Rufnummer 1 (roaming) für Hilferuf,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG117847-Fahrzeugkonfiguration-advanced_range_display,aus ,30
IDE03471-ENG249824-Fahrzeugkonfiguration-AliBox,aus ,30
IDE03471-ENG142146-Fahrzeugkonfiguration-allow_message_editing,aus ,30
IDE03471-ENG130249-Fahrzeugkonfiguration-Apple_DIO,ein ,30
IDE03471-ENG185764-Fahrzeugkonfiguration-Apple_DIO_Wireless,aus ,30
IDE03471-ENG152525-Fahrzeugkonfiguration-Baidu_Car_Life,aus ,30
IDE03471-ENG152559-Fahrzeugkonfiguration-Baidu_Car_Life_ios,aus ,30
IDE03471-ENG185765-Fahrzeugkonfiguration-Baidu_Car_Life_ios_Wireless,aus ,30
IDE03471-ENG185766-Fahrzeugkonfiguration-Baidu_Car_Life_Wireless,aus ,30
IDE03471-ENG152560-Fahrzeugkonfiguration-block_hmi_function_p_epb,gesperrt ,30
IDE03471-ENG142151-Fahrzeugkonfiguration-conditioning_variant,0 ,30
IDE03471-ENG263540-Fahrzeugkonfiguration-correction_e_mileage,0 ,30
IDE03471-ENG125043-Fahrzeugkonfiguration-Dtmf_without_active_call,ein ,30
IDE03471-ENG142145-Fahrzeugkonfiguration-esim_data_only_sms_support,aus ,30
IDE03471-ENG185778-Fahrzeugkonfiguration-FoD,SWaP ,30
IDE03471-ENG130248-Fahrzeugkonfiguration-Google_GAL,ein ,30
IDE03471-ENG185779-Fahrzeugkonfiguration-Google_GAL_Wireless,aus ,30
IDE03471-ENG117850-Fahrzeugkonfiguration-gracenote_local_coverarts,aus ,30
IDE03471-ENG117851-Fahrzeugkonfiguration-gracenote_local_other,aus ,30
IDE03471-ENG117848-Fahrzeugkonfiguration-gracenote_online_coverarts,aus ,30
IDE03471-ENG117849-Fahrzeugkonfiguration-gracenote_online_other,aus ,30
IDE03471-ENG152533-Fahrzeugkonfiguration-Hybrid_Radio_additional_online_data,nicht aktiviert ,30
IDE03471-ENG152534-Fahrzeugkonfiguration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG261211-Fahrzeugkonfiguration-internet_over_WLAN_default_setting,aus ,30
IDE03471-ENG125049-Fahrzeugkonfiguration-Joker_button_1,nicht vorhanden ,30
IDE03471-ENG125050-Fahrzeugkonfiguration-Joker_button_2,nicht vorhanden ,30
IDE03471-ENG127492-Fahrzeugkonfiguration-LGI,aus ,30
IDE03471-ENG130246-Fahrzeugkonfiguration-LTE_modul,aktiviert ,30
IDE03471-ENG142142-Fahrzeugkonfiguration-map_email_support,aus ,30
IDE03471-ENG142143-Fahrzeugkonfiguration-map_instant_messaging_support,aus ,30
IDE03471-ENG142141-Fahrzeugkonfiguration-map_sms_support,aus ,30
IDE03471-ENG142152-Fahrzeugkonfiguration-Map_Style,0 ,30
IDE03471-ENG152537-Fahrzeugkonfiguration-media_control,nicht aktiviert ,30
IDE03471-ENG138662-Fahrzeugkonfiguration-Mirror_link,ein ,30
IDE03471-ENG142148-Fahrzeugkonfiguration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Fahrzeugkonfiguration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Fahrzeugkonfiguration-my_audi,aus ,30
IDE03471-ENG117845-Fahrzeugkonfiguration-online_dictation,aus ,30
IDE03471-ENG127495-Fahrzeugkonfiguration-online_media,aus ,30
IDE03471-ENG117840-Fahrzeugkonfiguration-online_navigation,aus ,30
IDE03471-ENG117837-Fahrzeugkonfiguration-online_POI,aus ,30
IDE03471-ENG117838-Fahrzeugkonfiguration-online_POI_voice,aus ,30
IDE03471-ENG117839-Fahrzeugkonfiguration-online_portal_browser_services,aus ,30
IDE03471-ENG152553-Fahrzeugkonfiguration-online_radio,Deactivated ,30
IDE03471-ENG117841-Fahrzeugkonfiguration-online_street_view,aus ,30
IDE03471-ENG125048-Fahrzeugkonfiguration-OPS_display_in_dash_board_display_unit,aus ,30
IDE03471-ENG167521-Fahrzeugkonfiguration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Fahrzeugkonfiguration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Fahrzeugkonfiguration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Fahrzeugkonfiguration-Phone_module_operation_mode,Daten- und Sprachdienst aktiv ,30
IDE03471-ENG117844-Fahrzeugkonfiguration-picture_navi,aus ,30
IDE03471-ENG167523-Fahrzeugkonfiguration-Pilot_Parking,nicht aktiviert ,30
IDE03471-ENG167525-Fahrzeugkonfiguration-Popup_if_GPS_services_in_use,nicht aktiviert ,30
IDE03471-ENG152555-Fahrzeugkonfiguration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Fahrzeugkonfiguration-ProbeCar_lgi,aus ,30
IDE03471-ENG137646-Fahrzeugkonfiguration-ProbeCar_vzo,aus ,30
IDE03471-ENG125047-Fahrzeugkonfiguration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Fahrzeugkonfiguration-remote_HMI,aus ,30
IDE03471-ENG138661-Fahrzeugkonfiguration-RSE_software_component,aktiviert ,30
IDE03471-ENG245031-Fahrzeugkonfiguration-rvc_low_black_screen_trunk_open,nicht aktiviert ,30
IDE03471-ENG244966-Fahrzeugkonfiguration-rvc_low_black_screen_velocity_threshold,nicht aktiviert ,30
IDE03471-ENG245015-Fahrzeugkonfiguration-rvc_low_failsafe,nicht aktiviert ,30
IDE03471-ENG126143-Fahrzeugkonfiguration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Fahrzeugkonfiguration-scon_telephony,nicht aktiviert ,30
IDE03471-ENG142081-Fahrzeugkonfiguration-sd_slot_deactivation,keine Einschränkung ,30
IDE03471-ENG138660-Fahrzeugkonfiguration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Fahrzeugkonfiguration-show_volte_hmi_switch,nicht aktiviert ,30
IDE03471-ENG125045-Fahrzeugkonfiguration-Sim_card_mode_switch,nicht vorhanden ,30
IDE03471-ENG142144-Fahrzeugkonfiguration-sim_data_only_sms_support,aus ,30
IDE03471-ENG138663-Fahrzeugkonfiguration-Smartphone_interface_for_rhmi,aktiviert ,30
IDE03471-ENG126993-Fahrzeugkonfiguration-Station_Logo_DB_Mode,1 ,30
IDE03471-ENG125044-Fahrzeugkonfiguration-Support_for_response_and_hold,aus ,30
IDE03471-ENG125042-Fahrzeugkonfiguration-Support_of_threeway_calling,aus ,30
IDE03471-ENG130247-Fahrzeugkonfiguration-Support_second_phone,ein ,30
IDE03471-ENG167531-Fahrzeugkonfiguration-Tencent_myCar_canceling_share_location,aus ,30
IDE03471-ENG126994-Fahrzeugkonfiguration-TPEG_availability,aus ,30
IDE03471-ENG152571-Fahrzeugkonfiguration-unblock_functions_while_piloted_driving,gesperrt ,30
IDE03471-ENG137647-Fahrzeugkonfiguration-UOTA,aus ,30
IDE03471-ENG167532-Fahrzeugkonfiguration-UOTA_2,aus ,30
IDE03471-ENG117852-Fahrzeugkonfiguration-UPnP,aus ,30
IDE03471-ENG142149-Fahrzeugkonfiguration-vehicle_leaving_sound,nicht aktiviert ,30
IDE03471-ENG142147-Fahrzeugkonfiguration-vehicle_readiness_sound,nicht aktiviert ,30
IDE03471-ENG152558-Fahrzeugkonfiguration-voice_over_lte,nicht aktiviert ,30
IDE03471-ENG117836-Fahrzeugkonfiguration-VZAPro,aus ,30
IDE03471-ENG127494-Fahrzeugkonfiguration-VZO,aus ,30
IDE03471-ENG137648-Fahrzeugkonfiguration-WiFi_Client_HMI,aus ,30
IDE03471-ENG117842-Fahrzeugkonfiguration-WIFI_Hotspot,aus ,30
IDE03471-ENG152572-Fahrzeugkonfiguration-wlan_5ghz_switch,nicht aktiviert ,30
IDE03902-Automatische Ringbruchdiagnose,Kein automatischer Start ,1
IDE04295-Bluetooth: bevorzugtes Verbindungsprofil für Telefonbuchdaten,PBAP ,1
IDE04331-Auswahl der Freischaltcodes einer SWaP Funktion,FF FF FF FF ,4
IDE04521-Sporadische Ringbruchdetektion,optisch ,1
IDE04522-Weckfähigkeit am optischen Datenbus,aus ,1
IDE04550-Bluetooth: Sniff-Mode,aus ,1
IDE05113-Infotainment Recorder,aktiviert ,1
IDE10221-MAS00839-Audio Management Eingangsverstärkung Generation 2-TV-Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Eingangsverstärkung Generation 2-Satellitenradio,5 ,40
IDE10221-MAS01984-Audio Management Eingangsverstärkung Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Eingangsverstärkung Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Eingangsverstärkung Generation 2-Digitalradio (DAB),-128 ,40
IDE10221-ENG125854-Audio Management Eingangsverstärkung Generation 2-Exbox_DMB,-128 ,40
IDE10221-ENG117430-Audio Management Eingangsverstärkung Generation 2-HFP,-128 ,40
IDE10221-ENG125846-Audio Management Eingangsverstärkung Generation 2-Media_Airplay,-128 ,40
IDE10221-ENG125837-Audio Management Eingangsverstärkung Generation 2-Media_AUX_Adapter,-128 ,40
IDE10221-ENG125836-Audio Management Eingangsverstärkung Generation 2-Media_AUXIN,-128 ,40
IDE10221-ENG125843-Audio Management Eingangsverstärkung Generation 2-Media_Bluray,-128 ,40
IDE10221-ENG125841-Audio Management Eingangsverstärkung Generation 2-Media_BTDevice,-128 ,40
IDE10221-ENG125838-Audio Management Eingangsverstärkung Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125848-Audio Management Eingangsverstärkung Generation 2-Media_Cloud,-128 ,40
IDE10221-ENG125839-Audio Management Eingangsverstärkung Generation 2-Media_DVD,-128 ,40
IDE10221-ENG125844-Audio Management Eingangsverstärkung Generation 2-Media_HDMI,-128 ,40
IDE10221-ENG125840-Audio Management Eingangsverstärkung Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125847-Audio Management Eingangsverstärkung Generation 2-Media_UPNP,-128 ,40
IDE10221-ENG125855-Audio Management Eingangsverstärkung Generation 2-Mirrorlink,-128 ,40
IDE10221-ENG125859-Audio Management Eingangsverstärkung Generation 2-Phone_Ringer_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Eingangsverstärkung Generation 2-Phone_Ringer_OB,-3 ,40
IDE10221-ENG125858-Audio Management Eingangsverstärkung Generation 2-Phone_Voice,-128 ,40
IDE10221-ENG125842-Audio Management Eingangsverstärkung Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Eingangsverstärkung Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125853-Audio Management Eingangsverstärkung Generation 2-Tone_Messaging,-128 ,40
IDE10221-ENG125852-Audio Management Eingangsverstärkung Generation 2-Tone_Touchscreen,6 ,40
IDE10221-ENG125851-Audio Management Eingangsverstärkung Generation 2-Tone_Warning,-128 ,40
IDE10221-ENG125856-Audio Management Eingangsverstärkung Generation 2-TTS_Nav,-128 ,40
IDE10221-ENG125857-Audio Management Eingangsverstärkung Generation 2-TTS_SDS,-128 ,40
IDE10221-ENG125845-Audio Management Eingangsverstärkung Generation 2-Tuner_Online,-128 ,40
IDE10221-ENG125849-Audio Management Eingangsverstärkung Generation 2-Tuner_Personal,-128 ,40
IDE10221-ENG125835-Audio Management Eingangsverstärkung Generation 2-Tuner_TI,-128 ,40
IDE10221-ENG125861-Audio Management Eingangsverstärkung Generation 2-TV_AV_IN,-128 ,40
IDE10480-MAS10741-Schnittstelle für externen Medien: Aktivierung-Anschluss 1,aktiviert ,4
IDE10480-MAS10742-Schnittstelle für externen Medien: Aktivierung-Anschluss 2,aktiviert ,4
IDE10480-MAS10743-Schnittstelle für externen Medien: Aktivierung-Anschluss 3,nicht aktiviert ,4
IDE10480-MAS10744-Schnittstelle für externen Medien: Aktivierung-Anschluss 4,nicht aktiviert ,4
IDE10604-Menü-Einträge für mobile Online-Dienste,nicht aktiviert ,1
IDE11122-Länderkennung Verkaufsland HMI,GB ,2
IDE11502-ENG127601-Gesperrte Menüinhalte-FB_CAR_0,non_blocked ,21
IDE11502-ENG127602-Gesperrte Menüinhalte-FB_CAR_1,non_blocked ,21
IDE11502-ENG127611-Gesperrte Menüinhalte-FB_CAR_10,non_blocked ,21
IDE11502-ENG127612-Gesperrte Menüinhalte-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Gesperrte Menüinhalte-FB_CAR_12,non_blocked ,21
IDE11502-ENG127614-Gesperrte Menüinhalte-FB_CAR_13,non_blocked ,21
IDE11502-ENG127615-Gesperrte Menüinhalte-FB_CAR_14,non_blocked ,21
IDE11502-ENG127616-Gesperrte Menüinhalte-FB_CAR_15,non_blocked ,21
IDE11502-ENG127617-Gesperrte Menüinhalte-FB_CAR_16,non_blocked ,21
IDE11502-ENG127618-Gesperrte Menüinhalte-FB_CAR_17,non_blocked ,21
IDE11502-ENG127619-Gesperrte Menüinhalte-FB_CAR_18,non_blocked ,21
IDE11502-ENG127620-Gesperrte Menüinhalte-FB_CAR_19,non_blocked ,21
IDE11502-ENG127603-Gesperrte Menüinhalte-FB_CAR_2,non_blocked ,21
IDE11502-ENG127621-Gesperrte Menüinhalte-FB_CAR_20,non_blocked ,21
IDE11502-ENG127622-Gesperrte Menüinhalte-FB_CAR_21,non_blocked ,21
IDE11502-ENG127623-Gesperrte Menüinhalte-FB_CAR_22,non_blocked ,21
IDE11502-ENG127624-Gesperrte Menüinhalte-FB_CAR_23,non_blocked ,21
IDE11502-ENG127604-Gesperrte Menüinhalte-FB_CAR_3,non_blocked ,21
IDE11502-ENG127605-Gesperrte Menüinhalte-FB_CAR_4,non_blocked ,21
IDE11502-ENG127606-Gesperrte Menüinhalte-FB_CAR_5,non_blocked ,21
IDE11502-ENG127607-Gesperrte Menüinhalte-FB_CAR_6,non_blocked ,21
IDE11502-ENG127608-Gesperrte Menüinhalte-FB_CAR_7,non_blocked ,21
IDE11502-ENG127609-Gesperrte Menüinhalte-FB_CAR_8,non_blocked ,21
IDE11502-ENG127610-Gesperrte Menüinhalte-FB_CAR_9,non_blocked ,21
IDE11502-ENG127521-Gesperrte Menüinhalte-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Gesperrte Menüinhalte-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Gesperrte Menüinhalte-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Gesperrte Menüinhalte-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Gesperrte Menüinhalte-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Gesperrte Menüinhalte-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127535-Gesperrte Menüinhalte-FB_MEDIA_14,non_blocked ,21
IDE11502-ENG127536-Gesperrte Menüinhalte-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127537-Gesperrte Menüinhalte-FB_MEDIA_16,non_blocked ,21
IDE11502-ENG127538-Gesperrte Menüinhalte-FB_MEDIA_17,non_blocked ,21
IDE11502-ENG127539-Gesperrte Menüinhalte-FB_MEDIA_18,non_blocked ,21
IDE11502-ENG127540-Gesperrte Menüinhalte-FB_MEDIA_19,non_blocked ,21
IDE11502-ENG127523-Gesperrte Menüinhalte-FB_MEDIA_2,non_blocked ,21
IDE11502-ENG127541-Gesperrte Menüinhalte-FB_MEDIA_20,non_blocked ,21
IDE11502-ENG127542-Gesperrte Menüinhalte-FB_MEDIA_21,non_blocked ,21
IDE11502-ENG127543-Gesperrte Menüinhalte-FB_MEDIA_22,non_blocked ,21
IDE11502-ENG127544-Gesperrte Menüinhalte-FB_MEDIA_23,non_blocked ,21
IDE11502-ENG127524-Gesperrte Menüinhalte-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Gesperrte Menüinhalte-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Gesperrte Menüinhalte-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127527-Gesperrte Menüinhalte-FB_MEDIA_6,non_blocked ,21
IDE11502-ENG127528-Gesperrte Menüinhalte-FB_MEDIA_7,non_blocked ,21
IDE11502-ENG127529-Gesperrte Menüinhalte-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Gesperrte Menüinhalte-FB_MEDIA_9,non_blocked ,21
IDE11502-ENG127625-Gesperrte Menüinhalte-FB_MISC_0,non_blocked ,21
IDE11502-ENG127626-Gesperrte Menüinhalte-FB_MISC_1,non_blocked ,21
IDE11502-ENG127635-Gesperrte Menüinhalte-FB_MISC_10,non_blocked ,21
IDE11502-ENG127636-Gesperrte Menüinhalte-FB_MISC_11,non_blocked ,21
IDE11502-ENG127637-Gesperrte Menüinhalte-FB_MISC_12,non_blocked ,21
IDE11502-ENG127638-Gesperrte Menüinhalte-FB_MISC_13,non_blocked ,21
IDE11502-ENG127639-Gesperrte Menüinhalte-FB_MISC_14,non_blocked ,21
IDE11502-ENG127640-Gesperrte Menüinhalte-FB_MISC_15,non_blocked ,21
IDE11502-ENG127641-Gesperrte Menüinhalte-FB_MISC_16,non_blocked ,21
IDE11502-ENG127642-Gesperrte Menüinhalte-FB_MISC_17,non_blocked ,21
IDE11502-ENG127643-Gesperrte Menüinhalte-FB_MISC_18,non_blocked ,21
IDE11502-ENG127644-Gesperrte Menüinhalte-FB_MISC_19,non_blocked ,21
IDE11502-ENG127627-Gesperrte Menüinhalte-FB_MISC_2,non_blocked ,21
IDE11502-ENG127645-Gesperrte Menüinhalte-FB_MISC_20,non_blocked ,21
IDE11502-ENG127646-Gesperrte Menüinhalte-FB_MISC_21,non_blocked ,21
IDE11502-ENG127647-Gesperrte Menüinhalte-FB_MISC_22,non_blocked ,21
IDE11502-ENG127648-Gesperrte Menüinhalte-FB_MISC_23,non_blocked ,21
IDE11502-ENG127649-Gesperrte Menüinhalte-FB_MISC_24,non_blocked ,21
IDE11502-ENG127650-Gesperrte Menüinhalte-FB_MISC_25,non_blocked ,21
IDE11502-ENG127651-Gesperrte Menüinhalte-FB_MISC_26,non_blocked ,21
IDE11502-ENG127652-Gesperrte Menüinhalte-FB_MISC_27,non_blocked ,21
IDE11502-ENG127653-Gesperrte Menüinhalte-FB_MISC_28,non_blocked ,21
IDE11502-ENG127654-Gesperrte Menüinhalte-FB_MISC_29,non_blocked ,21
IDE11502-ENG127628-Gesperrte Menüinhalte-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Gesperrte Menüinhalte-FB_MISC_30,non_blocked ,21
IDE11502-ENG127656-Gesperrte Menüinhalte-FB_MISC_31,non_blocked ,21
IDE11502-ENG127657-Gesperrte Menüinhalte-FB_MISC_32,non_blocked ,21
IDE11502-ENG127658-Gesperrte Menüinhalte-FB_MISC_33,non_blocked ,21
IDE11502-ENG127659-Gesperrte Menüinhalte-FB_MISC_34,non_blocked ,21
IDE11502-ENG127660-Gesperrte Menüinhalte-FB_MISC_35,non_blocked ,21
IDE11502-ENG127661-Gesperrte Menüinhalte-FB_MISC_36,non_blocked ,21
IDE11502-ENG127662-Gesperrte Menüinhalte-FB_MISC_37,non_blocked ,21
IDE11502-ENG127663-Gesperrte Menüinhalte-FB_MISC_38,non_blocked ,21
IDE11502-ENG127664-Gesperrte Menüinhalte-FB_MISC_39,non_blocked ,21
IDE11502-ENG127629-Gesperrte Menüinhalte-FB_MISC_4,non_blocked ,21
IDE11502-ENG127665-Gesperrte Menüinhalte-FB_MISC_40,non_blocked ,21
IDE11502-ENG127666-Gesperrte Menüinhalte-FB_MISC_41,non_blocked ,21
IDE11502-ENG127667-Gesperrte Menüinhalte-FB_MISC_42,non_blocked ,21
IDE11502-ENG127668-Gesperrte Menüinhalte-FB_MISC_43,non_blocked ,21
IDE11502-ENG127669-Gesperrte Menüinhalte-FB_MISC_44,non_blocked ,21
IDE11502-ENG127670-Gesperrte Menüinhalte-FB_MISC_45,non_blocked ,21
IDE11502-ENG127671-Gesperrte Menüinhalte-FB_MISC_46,non_blocked ,21
IDE11502-ENG127672-Gesperrte Menüinhalte-FB_MISC_47,non_blocked ,21
IDE11502-ENG127630-Gesperrte Menüinhalte-FB_MISC_5,non_blocked ,21
IDE11502-ENG127631-Gesperrte Menüinhalte-FB_MISC_6,non_blocked ,21
IDE11502-ENG127632-Gesperrte Menüinhalte-FB_MISC_7,non_blocked ,21
IDE11502-ENG127633-Gesperrte Menüinhalte-FB_MISC_8,non_blocked ,21
IDE11502-ENG127634-Gesperrte Menüinhalte-FB_MISC_9,non_blocked ,21
IDE11502-ENG127561-Gesperrte Menüinhalte-FB_NAV_0,non_blocked ,21
IDE11502-ENG127562-Gesperrte Menüinhalte-FB_NAV_1,non_blocked ,21
IDE11502-ENG127571-Gesperrte Menüinhalte-FB_NAV_10,non_blocked ,21
IDE11502-ENG127572-Gesperrte Menüinhalte-FB_NAV_11,non_blocked ,21
IDE11502-ENG127573-Gesperrte Menüinhalte-FB_NAV_12,non_blocked ,21
IDE11502-ENG127574-Gesperrte Menüinhalte-FB_NAV_13,non_blocked ,21
IDE11502-ENG127575-Gesperrte Menüinhalte-FB_NAV_14,non_blocked ,21
IDE11502-ENG127576-Gesperrte Menüinhalte-FB_NAV_15,non_blocked ,21
IDE11502-ENG127577-Gesperrte Menüinhalte-FB_NAV_16,non_blocked ,21
IDE11502-ENG127578-Gesperrte Menüinhalte-FB_NAV_17,non_blocked ,21
IDE11502-ENG127579-Gesperrte Menüinhalte-FB_NAV_18,non_blocked ,21
IDE11502-ENG127580-Gesperrte Menüinhalte-FB_NAV_19,non_blocked ,21
IDE11502-ENG127563-Gesperrte Menüinhalte-FB_NAV_2,non_blocked ,21
IDE11502-ENG127581-Gesperrte Menüinhalte-FB_NAV_20,non_blocked ,21
IDE11502-ENG127582-Gesperrte Menüinhalte-FB_NAV_21,non_blocked ,21
IDE11502-ENG127583-Gesperrte Menüinhalte-FB_NAV_22,non_blocked ,21
IDE11502-ENG127584-Gesperrte Menüinhalte-FB_NAV_23,non_blocked ,21
IDE11502-ENG127585-Gesperrte Menüinhalte-FB_NAV_24,non_blocked ,21
IDE11502-ENG127586-Gesperrte Menüinhalte-FB_NAV_25,non_blocked ,21
IDE11502-ENG127587-Gesperrte Menüinhalte-FB_NAV_26,non_blocked ,21
IDE11502-ENG127588-Gesperrte Menüinhalte-FB_NAV_27,non_blocked ,21
IDE11502-ENG127589-Gesperrte Menüinhalte-FB_NAV_28,non_blocked ,21
IDE11502-ENG127590-Gesperrte Menüinhalte-FB_NAV_29,non_blocked ,21
IDE11502-ENG127564-Gesperrte Menüinhalte-FB_NAV_3,non_blocked ,21
IDE11502-ENG127591-Gesperrte Menüinhalte-FB_NAV_30,non_blocked ,21
IDE11502-ENG127592-Gesperrte Menüinhalte-FB_NAV_31,non_blocked ,21
IDE11502-ENG127593-Gesperrte Menüinhalte-FB_NAV_32,non_blocked ,21
IDE11502-ENG127594-Gesperrte Menüinhalte-FB_NAV_33,non_blocked ,21
IDE11502-ENG127595-Gesperrte Menüinhalte-FB_NAV_34,non_blocked ,21
IDE11502-ENG127596-Gesperrte Menüinhalte-FB_NAV_35,non_blocked ,21
IDE11502-ENG127597-Gesperrte Menüinhalte-FB_NAV_36,non_blocked ,21
IDE11502-ENG127598-Gesperrte Menüinhalte-FB_NAV_37,non_blocked ,21
IDE11502-ENG127599-Gesperrte Menüinhalte-FB_NAV_38,non_blocked ,21
IDE11502-ENG127600-Gesperrte Menüinhalte-FB_NAV_39,non_blocked ,21
IDE11502-ENG127565-Gesperrte Menüinhalte-FB_NAV_4,non_blocked ,21
IDE11502-ENG127566-Gesperrte Menüinhalte-FB_NAV_5,non_blocked ,21
IDE11502-ENG127567-Gesperrte Menüinhalte-FB_NAV_6,non_blocked ,21
IDE11502-ENG127568-Gesperrte Menüinhalte-FB_NAV_7,non_blocked ,21
IDE11502-ENG127569-Gesperrte Menüinhalte-FB_NAV_8,non_blocked ,21
IDE11502-ENG127570-Gesperrte Menüinhalte-FB_NAV_9,non_blocked ,21
IDE11502-ENG127545-Gesperrte Menüinhalte-FB_PHONE_0,non_blocked ,21
IDE11502-ENG127546-Gesperrte Menüinhalte-FB_PHONE_1,non_blocked ,21
IDE11502-ENG127555-Gesperrte Menüinhalte-FB_PHONE_10,non_blocked ,21
IDE11502-ENG127556-Gesperrte Menüinhalte-FB_PHONE_11,non_blocked ,21
IDE11502-ENG127557-Gesperrte Menüinhalte-FB_PHONE_12,non_blocked ,21
IDE11502-ENG127558-Gesperrte Menüinhalte-FB_PHONE_13,non_blocked ,21
IDE11502-ENG127559-Gesperrte Menüinhalte-FB_PHONE_14,non_blocked ,21
IDE11502-ENG127560-Gesperrte Menüinhalte-FB_PHONE_15,non_blocked ,21
IDE11502-ENG127547-Gesperrte Menüinhalte-FB_PHONE_2,non_blocked ,21
IDE11502-ENG127548-Gesperrte Menüinhalte-FB_PHONE_3,non_blocked ,21
IDE11502-ENG127549-Gesperrte Menüinhalte-FB_PHONE_4,non_blocked ,21
IDE11502-ENG127550-Gesperrte Menüinhalte-FB_PHONE_5,non_blocked ,21
IDE11502-ENG127551-Gesperrte Menüinhalte-FB_PHONE_6,non_blocked ,21
IDE11502-ENG127552-Gesperrte Menüinhalte-FB_PHONE_7,non_blocked ,21
IDE11502-ENG127553-Gesperrte Menüinhalte-FB_PHONE_8,non_blocked ,21
IDE11502-ENG127554-Gesperrte Menüinhalte-FB_PHONE_9,non_blocked ,21
IDE11502-ENG127505-Gesperrte Menüinhalte-FB_TUNER_0,non_blocked ,21
IDE11502-ENG127506-Gesperrte Menüinhalte-FB_TUNER_1,non_blocked ,21
IDE11502-ENG127515-Gesperrte Menüinhalte-FB_TUNER_10,non_blocked ,21
IDE11502-ENG127516-Gesperrte Menüinhalte-FB_TUNER_11,non_blocked ,21
IDE11502-ENG127517-Gesperrte Menüinhalte-FB_TUNER_12,non_blocked ,21
IDE11502-ENG127518-Gesperrte Menüinhalte-FB_TUNER_13,non_blocked ,21
IDE11502-ENG127519-Gesperrte Menüinhalte-FB_TUNER_14,non_blocked ,21
IDE11502-ENG127520-Gesperrte Menüinhalte-FB_TUNER_15,non_blocked ,21
IDE11502-ENG127507-Gesperrte Menüinhalte-FB_TUNER_2,non_blocked ,21
IDE11502-ENG127508-Gesperrte Menüinhalte-FB_TUNER_3,non_blocked ,21
IDE11502-ENG127509-Gesperrte Menüinhalte-FB_TUNER_4,non_blocked ,21
IDE11502-ENG127510-Gesperrte Menüinhalte-FB_TUNER_5,non_blocked ,21
IDE11502-ENG127511-Gesperrte Menüinhalte-FB_TUNER_6,non_blocked ,21
IDE11502-ENG127512-Gesperrte Menüinhalte-FB_TUNER_7,non_blocked ,21
IDE11502-ENG127513-Gesperrte Menüinhalte-FB_TUNER_8,non_blocked ,21
IDE11502-ENG127514-Gesperrte Menüinhalte-FB_TUNER_9,non_blocked ,21
IDE11524-ENG249835-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-chassis_control_0x57,nicht aktiviert ,192
IDE11524-ENG249836-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-chassis_control_0x57_msg_bus,nicht aktiviert ,192
IDE11524-ENG142156-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-climate_mastet_0x42,nicht aktiviert ,192
IDE11524-ENG142157-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-climate_mastet_0x42_msg_bus,nicht aktiviert ,192
IDE11524-ENG142158-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-connection_manager_0x47,nicht aktiviert ,192
IDE11524-ENG142159-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-connection_manager_0x47_msg_bus,nicht aktiviert ,192
IDE11524-ENG249837-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-convertibleTop_0x6C,nicht aktiviert ,192
IDE11524-ENG249838-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-convertibleTop_0x6C_msg_bus,nicht aktiviert ,192
IDE11524-ENG152529-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-daf_profile_0x51,nicht aktiviert ,192
IDE11524-ENG152530-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-daf_profile_0x51_msg_bus,nicht aktiviert ,192
IDE11524-ENG137043-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-display_configuration_0x45,nicht aktiviert ,192
IDE11524-ENG137044-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-display_configuration_0x45_msg_bus,nicht aktiviert ,192
IDE11524-ENG185772-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-engine_functions_0x5D,nicht aktiviert ,192
IDE11524-ENG185773-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-engine_functions_0x5D_msg_bus,nicht aktiviert ,192
IDE11524-ENG142168-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-fas_profile_0x4D,nicht aktiviert ,192
IDE11524-ENG142169-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-fas_profile_0x4D_msg_bus,nicht aktiviert ,192
IDE11524-ENG142154-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-front_traffic_assist_0x41,nicht aktiviert ,192
IDE11524-ENG142155-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-front_traffic_assist_0x41_msg_bus,nicht aktiviert ,192
IDE11524-ENG152535-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-infotainmentsettings_profile_0x50,nicht aktiviert ,192
IDE11524-ENG152536-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-infotainmentsettings_profile_0x50_msg_bus,nicht aktiviert ,192
IDE11524-ENG248719-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-ITM_0x65,nicht aktiviert ,192
IDE11524-ENG248720-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-ITM_0x65_msg_bus,nicht aktiviert ,192
IDE11524-ENG249902-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-lift_0x64,nicht aktiviert ,192
IDE11524-ENG249903-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-lift_0x64_msg_bus,nicht aktiviert ,192
IDE11524-ENG185787-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-mascot_0x83,nicht aktiviert ,192
IDE11524-ENG185788-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-mascot_0x83_msg_bus,nicht aktiviert ,192
IDE11524-ENG152569-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-remote_services_profile_0x4E,nicht aktiviert ,192
IDE11524-ENG152570-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-remote_services_profile_0x4E_msg_bus,nicht aktiviert ,192
IDE11524-ENG139202-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-Soundcontrol_0x44,nicht aktiviert ,192
IDE11524-ENG139203-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-Soundcontrol_0x44_msg_bus,nicht aktiviert ,192
IDE11524-ENG127678-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-spoiler_0x40,nicht aktiviert ,192
IDE11524-ENG127679-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-spoiler_0x40_msg_bus,nicht aktiviert ,192
IDE11524-ENG142162-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-statistic_0x4A,nicht aktiviert ,192
IDE11524-ENG142163-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-statistic_0x4A_msg_bus,nicht aktiviert ,192
IDE11524-ENG142164-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_front_0x4B,nicht aktiviert ,192
IDE11524-ENG142165-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_front_0x4B_msg_bus,nicht aktiviert ,192
IDE11524-ENG142166-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_rear_0x4C,nicht aktiviert ,192
IDE11524-ENG142167-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_rear_0x4C_msg_bus,nicht aktiviert ,192
IDE11524-ENG185817-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-vas_0x54,nicht aktiviert ,192
IDE11524-ENG185818-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-vas_0x54_msg_bus,nicht aktiviert ,192
IDE11524-ENG142160-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-wireless_charging_0x48,nicht aktiviert ,192
IDE11524-ENG142161-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-wireless_charging_0x48_msg_bus,nicht aktiviert ,192
IDE13183-De-/Aktivierung der Popups für aktive Trackingdienste,00 00 00 00 ,4
MAS00951-Bluetooth,ein ,1
MAS01968-Lüfter,normal ,1
MAS02809-MAS02870-Frequenz für Prüfton-Hochton Frequenzbereich,4000 Hz,6
MAS02809-MAS02871-Frequenz für Prüfton-Mittelton Frequenzbereich,1000 Hz,6
MAS02809-MAS02872-Frequenz für Prüfton-Tiefton Frequenzbereich,100 Hz,6
MAS03782-WLAN,ein ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,nicht aktiviert ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,nicht aktiviert ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,nicht aktiviert ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,nicht aktiviert ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,nicht aktiviert ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,nicht aktiviert ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,nicht aktiviert ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,nicht aktiviert ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,nicht aktiviert ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,nicht aktiviert ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,nicht aktiviert ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,nicht aktiviert ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,nicht aktiviert ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,nicht aktiviert ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,nicht aktiviert ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,nicht aktiviert ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,nicht aktiviert ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,nicht aktiviert ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,nicht aktiviert ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,nicht aktiviert ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,nicht aktiviert ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,nicht aktiviert ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,aktiviert ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,aktiviert ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,nicht aktiviert ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,nicht aktiviert ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,nicht aktiviert ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,aktiviert ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,aktiviert ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,nicht aktiviert ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,aktiviert ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,aktiviert ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,nicht aktiviert ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,aktiviert ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,aktiviert ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,nicht aktiviert ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,aktiviert ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,aktiviert ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,nicht aktiviert ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,aktiviert ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,aktiviert ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,nicht aktiviert ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,aktiviert ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,aktiviert ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,nicht aktiviert ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,aktiviert ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,aktiviert ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,nicht aktiviert ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,aktiviert ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,aktiviert ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,nicht aktiviert ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,aktiviert ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,aktiviert ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,nicht aktiviert ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,nicht aktiviert ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,nicht aktiviert ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,nicht aktiviert ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,nicht aktiviert ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,nicht aktiviert ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,nicht aktiviert ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,nicht aktiviert ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,nicht aktiviert ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,nicht aktiviert ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,nicht aktiviert ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,nicht aktiviert ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,nicht aktiviert ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,aktiviert ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,aktiviert ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,nicht aktiviert ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,aktiviert ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,aktiviert ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,nicht aktiviert ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,nicht aktiviert ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,nicht aktiviert ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,nicht aktiviert ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,nicht aktiviert ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,aktiviert ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,aktiviert ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,nicht aktiviert ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,nicht aktiviert ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,nicht aktiviert ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,nicht aktiviert ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,nicht aktiviert ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,nicht aktiviert ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,nicht aktiviert ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,nicht aktiviert ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,nicht aktiviert ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,nicht aktiviert ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,nicht aktiviert ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,nicht aktiviert ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,nicht aktiviert ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,aktiviert ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,aktiviert ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,nicht aktiviert ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,nicht aktiviert ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,nicht aktiviert ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,nicht aktiviert ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,nicht aktiviert ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,nicht aktiviert ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,nicht aktiviert ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,nicht aktiviert ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,nicht aktiviert ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,nicht aktiviert ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,nicht aktiviert ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,aktiviert ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,aktiviert ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,nicht aktiviert ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,nicht aktiviert ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,nicht aktiviert ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,nicht aktiviert ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,nicht aktiviert ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,nicht aktiviert ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,nicht aktiviert ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,nicht aktiviert ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,nicht aktiviert ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,nicht aktiviert ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,nicht aktiviert ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,nicht aktiviert ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,nicht aktiviert ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,nicht aktiviert ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,nicht aktiviert ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,nicht aktiviert ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,nicht aktiviert ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,aktiviert ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,aktiviert ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,nicht aktiviert ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,aktiviert ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,aktiviert ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,nicht aktiviert ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,nicht aktiviert ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,nicht aktiviert ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,aktiviert ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,aktiviert ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,nicht aktiviert ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,aktiviert ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,aktiviert ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,nicht aktiviert ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,nicht aktiviert ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,nicht aktiviert ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,nicht aktiviert ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Datenbus Extended ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,nicht aktiviert ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Datenbus Fahrwerk ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,nicht aktiviert ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,nicht aktiviert ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,nicht aktiviert ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,nicht aktiviert ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,aktiviert ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Klemme 15 ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,nicht aktiviert ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Datenbus Antrieb ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,aktiviert ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,aktiviert ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Datenbus Fahrwerk ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,aktiviert ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,aktiviert ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,nicht aktiviert ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,aktiviert ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,nicht aktiviert ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,aktiviert ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,nicht aktiviert ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,nicht aktiviert ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,nicht aktiviert ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Datenbus Komfort ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,nicht aktiviert ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Datenbus Komfort ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,nicht aktiviert ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,nicht aktiviert ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,aktiviert ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Datenbus Komfort ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,nicht aktiviert ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,aktiviert ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,nicht aktiviert ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,nicht aktiviert ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Datenbus Antrieb ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,aktiviert ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,nicht aktiviert ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Datenbus Extended ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,aktiviert ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,nicht aktiviert ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Datenbus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,aktiviert ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,nicht aktiviert ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,nicht aktiviert ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,nicht aktiviert ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,nicht aktiviert ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,nicht aktiviert ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Datenbus Komfort ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,nicht aktiviert ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Datenbus Extended ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,nicht aktiviert ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Datenbus Infotainment ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,nicht aktiviert ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,nicht aktiviert ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Datenbus Antrieb ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,nicht aktiviert ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Datenbus Komfort ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,nicht aktiviert ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Datenbus Komfort ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,nicht aktiviert ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Datenbus Komfort ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,aktiviert ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,nicht aktiviert ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,nicht aktiviert ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,nicht aktiviert ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Datenbus Komfort ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,nicht aktiviert ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,aktiviert ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Datenbus Extended ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,aktiviert ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Datenbus Fahrwerk ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,nicht aktiviert ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Datenbus Extended ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,nicht aktiviert ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Datenbus Komfort ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,nicht aktiviert ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,nicht aktiviert ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Klemme 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,aktiviert ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,aktiviert ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,nicht aktiviert ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,nicht aktiviert ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,aktiviert ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Datenbus Komfort ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,nicht verfügbar ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Datenbus Komfort ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,nicht verfügbar ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Datenbus Infotainment ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,verfügbar ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Datenbus Infotainment ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,nicht verfügbar ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Datenbus Antrieb ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,nicht verfügbar ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Datenbus Fahrwerk ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,nicht verfügbar ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Datenbus Komfort ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Datenbus Komfort ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,nicht verfügbar ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,verfügbar ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Datenbus Komfort ,8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,aus ,10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,aus ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,aus ,10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,aus ,10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,aus ,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,aktiviert ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,aktiviert ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,nicht aktiviert ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,aktiviert ,5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,nicht aktiviert ,5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,nicht aktiviert ,5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,nicht aktiviert ,5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,nicht aktiviert ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,nicht aktiviert ,5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,nicht aktiviert ,5
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
Dauer: 00:50
Adaptions USA 5F
	SW:3Q0-035-844-B   HW:3Q0-035-844-B ---  Informationselek. I
	Bauteil:MU-S-S-US     722 0867, Codierung:02730600BE00000051210001001808001F0500C40120050002
	EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
	Sonntag,11,August,2019,21:24:57:49457
	VCDS Version: PCI 19.6.1  Datenstand: 20190807 DS308.0
	VCID: 2E04FA5EB09B5667685-807A
IDE00001-Produktionsmodus,00 00 00 ,3
IDE00346-Sommerzeit-Automatik,manuell ,1
IDE00758-Grundlautstärke Telefon,50 %,1
IDE00759-Grundlautstärke Sprachausgabe,50 %,1
IDE00760-Mikrofonempfindlichkeit,0 dB,1
IDE00769-Rufnummer 1 für Inforuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Rufnummer 1 für Pannenruf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-ENG117828-Aktivieren und Deaktivieren aller Entwicklungsbotschaften-Infotainment_CAN_Messages,aus ,1
IDE00820-ENG117829-Aktivieren und Deaktivieren aller Entwicklungsbotschaften-MIB_CAN_Messages,aus ,1
IDE02121-Taster für CD-Rückgabe,freigegeben ,1
IDE02122-Entwicklermodus,nicht aktiviert ,1
IDE02330-Rufnummer 2 für Inforuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Rufnummer 2 für Pannenruf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02332-Produktionsmodus deaktivieren,0 ,3
IDE02476-MAS03001-Elektrische Prüfung der Lautsprecher-Modus,automatisch ,49
IDE02476-ENG117360-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
IDE02476-ENG117378-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
IDE02476-ENG117380-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
IDE02476-ENG117382-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
IDE02476-ENG117384-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
IDE02476-ENG117386-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
IDE02476-ENG117388-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
IDE02476-ENG117390-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
IDE02476-ENG117362-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
IDE02476-ENG117364-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
IDE02476-ENG117366-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
IDE02476-ENG117368-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
IDE02476-ENG117370-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
IDE02476-ENG117372-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
IDE02476-ENG117374-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
IDE02476-ENG117376-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
IDE02502-Bestätigung der Verbauänderung,36 2D ,2
IDE02699-Rufnummer 1 für Hilferuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Rufnummer 1 (roaming) für Hilferuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG117847-Fahrzeugkonfiguration-advanced_range_display,aus ,30
IDE03471-ENG249824-Fahrzeugkonfiguration-AliBox,aus ,30
IDE03471-ENG142146-Fahrzeugkonfiguration-allow_message_editing,aus ,30
IDE03471-ENG130249-Fahrzeugkonfiguration-Apple_DIO,ein ,30
IDE03471-ENG185764-Fahrzeugkonfiguration-Apple_DIO_Wireless,aus ,30
IDE03471-ENG152525-Fahrzeugkonfiguration-Baidu_Car_Life,aus ,30
IDE03471-ENG152559-Fahrzeugkonfiguration-Baidu_Car_Life_ios,aus ,30
IDE03471-ENG185765-Fahrzeugkonfiguration-Baidu_Car_Life_ios_Wireless,aus ,30
IDE03471-ENG185766-Fahrzeugkonfiguration-Baidu_Car_Life_Wireless,aus ,30
IDE03471-ENG152560-Fahrzeugkonfiguration-block_hmi_function_p_epb,gesperrt ,30
IDE03471-ENG142151-Fahrzeugkonfiguration-conditioning_variant,0 ,30
IDE03471-ENG263540-Fahrzeugkonfiguration-correction_e_mileage,0 ,30
IDE03471-ENG125043-Fahrzeugkonfiguration-Dtmf_without_active_call,ein ,30
IDE03471-ENG142145-Fahrzeugkonfiguration-esim_data_only_sms_support,aus ,30
IDE03471-ENG185778-Fahrzeugkonfiguration-FoD,SWaP ,30
IDE03471-ENG130248-Fahrzeugkonfiguration-Google_GAL,ein ,30
IDE03471-ENG185779-Fahrzeugkonfiguration-Google_GAL_Wireless,aus ,30
IDE03471-ENG117850-Fahrzeugkonfiguration-gracenote_local_coverarts,aus ,30
IDE03471-ENG117851-Fahrzeugkonfiguration-gracenote_local_other,aus ,30
IDE03471-ENG117848-Fahrzeugkonfiguration-gracenote_online_coverarts,aus ,30
IDE03471-ENG117849-Fahrzeugkonfiguration-gracenote_online_other,aus ,30
IDE03471-ENG152533-Fahrzeugkonfiguration-Hybrid_Radio_additional_online_data,nicht aktiviert ,30
IDE03471-ENG152534-Fahrzeugkonfiguration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG261211-Fahrzeugkonfiguration-internet_over_WLAN_default_setting,aus ,30
IDE03471-ENG125049-Fahrzeugkonfiguration-Joker_button_1,nicht vorhanden ,30
IDE03471-ENG125050-Fahrzeugkonfiguration-Joker_button_2,nicht vorhanden ,30
IDE03471-ENG127492-Fahrzeugkonfiguration-LGI,aus ,30
IDE03471-ENG130246-Fahrzeugkonfiguration-LTE_modul,aktiviert ,30
IDE03471-ENG142142-Fahrzeugkonfiguration-map_email_support,aus ,30
IDE03471-ENG142143-Fahrzeugkonfiguration-map_instant_messaging_support,aus ,30
IDE03471-ENG142141-Fahrzeugkonfiguration-map_sms_support,aus ,30
IDE03471-ENG142152-Fahrzeugkonfiguration-Map_Style,0 ,30
IDE03471-ENG152537-Fahrzeugkonfiguration-media_control,nicht aktiviert ,30
IDE03471-ENG138662-Fahrzeugkonfiguration-Mirror_link,ein ,30
IDE03471-ENG142148-Fahrzeugkonfiguration-MirrorLink_Country_Code,MIB_NAR ,30
IDE03471-ENG142150-Fahrzeugkonfiguration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Fahrzeugkonfiguration-my_audi,aus ,30
IDE03471-ENG117845-Fahrzeugkonfiguration-online_dictation,aus ,30
IDE03471-ENG127495-Fahrzeugkonfiguration-online_media,aus ,30
IDE03471-ENG117840-Fahrzeugkonfiguration-online_navigation,aus ,30
IDE03471-ENG117837-Fahrzeugkonfiguration-online_POI,aus ,30
IDE03471-ENG117838-Fahrzeugkonfiguration-online_POI_voice,aus ,30
IDE03471-ENG117839-Fahrzeugkonfiguration-online_portal_browser_services,aus ,30
IDE03471-ENG152553-Fahrzeugkonfiguration-online_radio,Deactivated ,30
IDE03471-ENG117841-Fahrzeugkonfiguration-online_street_view,aus ,30
IDE03471-ENG125048-Fahrzeugkonfiguration-OPS_display_in_dash_board_display_unit,aus ,30
IDE03471-ENG167521-Fahrzeugkonfiguration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Fahrzeugkonfiguration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Fahrzeugkonfiguration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Fahrzeugkonfiguration-Phone_module_operation_mode,Daten- und Sprachdienst aktiv ,30
IDE03471-ENG117844-Fahrzeugkonfiguration-picture_navi,aus ,30
IDE03471-ENG167523-Fahrzeugkonfiguration-Pilot_Parking,nicht aktiviert ,30
IDE03471-ENG167525-Fahrzeugkonfiguration-Popup_if_GPS_services_in_use,nicht aktiviert ,30
IDE03471-ENG152555-Fahrzeugkonfiguration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Fahrzeugkonfiguration-ProbeCar_lgi,aus ,30
IDE03471-ENG137646-Fahrzeugkonfiguration-ProbeCar_vzo,aus ,30
IDE03471-ENG125047-Fahrzeugkonfiguration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Fahrzeugkonfiguration-remote_HMI,aus ,30
IDE03471-ENG138661-Fahrzeugkonfiguration-RSE_software_component,aktiviert ,30
IDE03471-ENG245031-Fahrzeugkonfiguration-rvc_low_black_screen_trunk_open,nicht aktiviert ,30
IDE03471-ENG244966-Fahrzeugkonfiguration-rvc_low_black_screen_velocity_threshold,nicht aktiviert ,30
IDE03471-ENG245015-Fahrzeugkonfiguration-rvc_low_failsafe,nicht aktiviert ,30
IDE03471-ENG126143-Fahrzeugkonfiguration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Fahrzeugkonfiguration-scon_telephony,nicht aktiviert ,30
IDE03471-ENG142081-Fahrzeugkonfiguration-sd_slot_deactivation,keine Einschränkung ,30
IDE03471-ENG138660-Fahrzeugkonfiguration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Fahrzeugkonfiguration-show_volte_hmi_switch,nicht aktiviert ,30
IDE03471-ENG125045-Fahrzeugkonfiguration-Sim_card_mode_switch,nicht vorhanden ,30
IDE03471-ENG142144-Fahrzeugkonfiguration-sim_data_only_sms_support,aus ,30
IDE03471-ENG138663-Fahrzeugkonfiguration-Smartphone_interface_for_rhmi,aktiviert ,30
IDE03471-ENG126993-Fahrzeugkonfiguration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125044-Fahrzeugkonfiguration-Support_for_response_and_hold,aus ,30
IDE03471-ENG125042-Fahrzeugkonfiguration-Support_of_threeway_calling,ein ,30
IDE03471-ENG130247-Fahrzeugkonfiguration-Support_second_phone,ein ,30
IDE03471-ENG167531-Fahrzeugkonfiguration-Tencent_myCar_canceling_share_location,aus ,30
IDE03471-ENG126994-Fahrzeugkonfiguration-TPEG_availability,aus ,30
IDE03471-ENG152571-Fahrzeugkonfiguration-unblock_functions_while_piloted_driving,gesperrt ,30
IDE03471-ENG137647-Fahrzeugkonfiguration-UOTA,aus ,30
IDE03471-ENG167532-Fahrzeugkonfiguration-UOTA_2,aus ,30
IDE03471-ENG117852-Fahrzeugkonfiguration-UPnP,aus ,30
IDE03471-ENG142149-Fahrzeugkonfiguration-vehicle_leaving_sound,nicht aktiviert ,30
IDE03471-ENG142147-Fahrzeugkonfiguration-vehicle_readiness_sound,nicht aktiviert ,30
IDE03471-ENG152558-Fahrzeugkonfiguration-voice_over_lte,nicht aktiviert ,30
IDE03471-ENG117836-Fahrzeugkonfiguration-VZAPro,aus ,30
IDE03471-ENG127494-Fahrzeugkonfiguration-VZO,aus ,30
IDE03471-ENG137648-Fahrzeugkonfiguration-WiFi_Client_HMI,aus ,30
IDE03471-ENG117842-Fahrzeugkonfiguration-WIFI_Hotspot,aus ,30
IDE03471-ENG152572-Fahrzeugkonfiguration-wlan_5ghz_switch,nicht aktiviert ,30
IDE03902-Automatische Ringbruchdiagnose,Kein automatischer Start ,1
IDE04295-Bluetooth: bevorzugtes Verbindungsprofil für Telefonbuchdaten,PBAP ,1
IDE04331-Auswahl der Freischaltcodes einer SWaP Funktion,FF FF FF FF ,4
IDE04521-Sporadische Ringbruchdetektion,optisch ,1
IDE04522-Weckfähigkeit am optischen Datenbus,aus ,1
IDE04550-Bluetooth: Sniff-Mode,aus ,1
IDE05113-Infotainment Recorder,aktiviert ,1
IDE06425-Rollenprüfstandmodus: funktional,nicht aktiviert ,1
IDE10221-MAS00839-Audio Management Eingangsverstärkung Generation 2-TV-Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Eingangsverstärkung Generation 2-Satellitenradio,5 ,40
IDE10221-MAS01984-Audio Management Eingangsverstärkung Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Eingangsverstärkung Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Eingangsverstärkung Generation 2-Digitalradio (DAB),-128 ,40
IDE10221-ENG125854-Audio Management Eingangsverstärkung Generation 2-Exbox_DMB,-128 ,40
IDE10221-ENG117430-Audio Management Eingangsverstärkung Generation 2-HFP,-128 ,40
IDE10221-ENG125846-Audio Management Eingangsverstärkung Generation 2-Media_Airplay,-128 ,40
IDE10221-ENG125837-Audio Management Eingangsverstärkung Generation 2-Media_AUX_Adapter,-128 ,40
IDE10221-ENG125836-Audio Management Eingangsverstärkung Generation 2-Media_AUXIN,-128 ,40
IDE10221-ENG125843-Audio Management Eingangsverstärkung Generation 2-Media_Bluray,-128 ,40
IDE10221-ENG125841-Audio Management Eingangsverstärkung Generation 2-Media_BTDevice,-128 ,40
IDE10221-ENG125838-Audio Management Eingangsverstärkung Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125848-Audio Management Eingangsverstärkung Generation 2-Media_Cloud,-128 ,40
IDE10221-ENG125839-Audio Management Eingangsverstärkung Generation 2-Media_DVD,-128 ,40
IDE10221-ENG125844-Audio Management Eingangsverstärkung Generation 2-Media_HDMI,-128 ,40
IDE10221-ENG125840-Audio Management Eingangsverstärkung Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125847-Audio Management Eingangsverstärkung Generation 2-Media_UPNP,-128 ,40
IDE10221-ENG125855-Audio Management Eingangsverstärkung Generation 2-Mirrorlink,-128 ,40
IDE10221-ENG125859-Audio Management Eingangsverstärkung Generation 2-Phone_Ringer_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Eingangsverstärkung Generation 2-Phone_Ringer_OB,-3 ,40
IDE10221-ENG125858-Audio Management Eingangsverstärkung Generation 2-Phone_Voice,-128 ,40
IDE10221-ENG125842-Audio Management Eingangsverstärkung Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Eingangsverstärkung Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125853-Audio Management Eingangsverstärkung Generation 2-Tone_Messaging,-128 ,40
IDE10221-ENG125852-Audio Management Eingangsverstärkung Generation 2-Tone_Touchscreen,6 ,40
IDE10221-ENG125851-Audio Management Eingangsverstärkung Generation 2-Tone_Warning,-128 ,40
IDE10221-ENG125856-Audio Management Eingangsverstärkung Generation 2-TTS_Nav,-128 ,40
IDE10221-ENG125857-Audio Management Eingangsverstärkung Generation 2-TTS_SDS,-128 ,40
IDE10221-ENG125845-Audio Management Eingangsverstärkung Generation 2-Tuner_Online,-128 ,40
IDE10221-ENG125849-Audio Management Eingangsverstärkung Generation 2-Tuner_Personal,-128 ,40
IDE10221-ENG125835-Audio Management Eingangsverstärkung Generation 2-Tuner_TI,-128 ,40
IDE10221-ENG125861-Audio Management Eingangsverstärkung Generation 2-TV_AV_IN,-128 ,40
IDE10480-MAS10741-Schnittstelle für externen Medien: Aktivierung-Anschluss 1,aktiviert ,4
IDE10480-MAS10742-Schnittstelle für externen Medien: Aktivierung-Anschluss 2,aktiviert ,4
IDE10480-MAS10743-Schnittstelle für externen Medien: Aktivierung-Anschluss 3,nicht aktiviert ,4
IDE10480-MAS10744-Schnittstelle für externen Medien: Aktivierung-Anschluss 4,nicht aktiviert ,4
IDE10604-Menü-Einträge für mobile Online-Dienste,nicht aktiviert ,1
IDE11122-Länderkennung Verkaufsland HMI,US ,2
IDE11502-ENG127601-Gesperrte Menüinhalte-FB_CAR_0,blocked ,21
IDE11502-ENG127602-Gesperrte Menüinhalte-FB_CAR_1,non_blocked ,21
IDE11502-ENG127611-Gesperrte Menüinhalte-FB_CAR_10,non_blocked ,21
IDE11502-ENG127612-Gesperrte Menüinhalte-FB_CAR_11,blocked ,21
IDE11502-ENG127613-Gesperrte Menüinhalte-FB_CAR_12,blocked ,21
IDE11502-ENG127614-Gesperrte Menüinhalte-FB_CAR_13,non_blocked ,21
IDE11502-ENG127615-Gesperrte Menüinhalte-FB_CAR_14,non_blocked ,21
IDE11502-ENG127616-Gesperrte Menüinhalte-FB_CAR_15,non_blocked ,21
IDE11502-ENG127617-Gesperrte Menüinhalte-FB_CAR_16,non_blocked ,21
IDE11502-ENG127618-Gesperrte Menüinhalte-FB_CAR_17,non_blocked ,21
IDE11502-ENG127619-Gesperrte Menüinhalte-FB_CAR_18,non_blocked ,21
IDE11502-ENG127620-Gesperrte Menüinhalte-FB_CAR_19,non_blocked ,21
IDE11502-ENG127603-Gesperrte Menüinhalte-FB_CAR_2,blocked ,21
IDE11502-ENG127621-Gesperrte Menüinhalte-FB_CAR_20,non_blocked ,21
IDE11502-ENG127622-Gesperrte Menüinhalte-FB_CAR_21,non_blocked ,21
IDE11502-ENG127623-Gesperrte Menüinhalte-FB_CAR_22,non_blocked ,21
IDE11502-ENG127624-Gesperrte Menüinhalte-FB_CAR_23,non_blocked ,21
IDE11502-ENG127604-Gesperrte Menüinhalte-FB_CAR_3,blocked ,21
IDE11502-ENG127605-Gesperrte Menüinhalte-FB_CAR_4,non_blocked ,21
IDE11502-ENG127606-Gesperrte Menüinhalte-FB_CAR_5,non_blocked ,21
IDE11502-ENG127607-Gesperrte Menüinhalte-FB_CAR_6,non_blocked ,21
IDE11502-ENG127608-Gesperrte Menüinhalte-FB_CAR_7,blocked ,21
IDE11502-ENG127609-Gesperrte Menüinhalte-FB_CAR_8,non_blocked ,21
IDE11502-ENG127610-Gesperrte Menüinhalte-FB_CAR_9,non_blocked ,21
IDE11502-ENG127521-Gesperrte Menüinhalte-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Gesperrte Menüinhalte-FB_MEDIA_1,blocked ,21
IDE11502-ENG127531-Gesperrte Menüinhalte-FB_MEDIA_10,blocked ,21
IDE11502-ENG127532-Gesperrte Menüinhalte-FB_MEDIA_11,blocked ,21
IDE11502-ENG127533-Gesperrte Menüinhalte-FB_MEDIA_12,blocked ,21
IDE11502-ENG127534-Gesperrte Menüinhalte-FB_MEDIA_13,blocked ,21
IDE11502-ENG127535-Gesperrte Menüinhalte-FB_MEDIA_14,non_blocked ,21
IDE11502-ENG127536-Gesperrte Menüinhalte-FB_MEDIA_15,blocked ,21
IDE11502-ENG127537-Gesperrte Menüinhalte-FB_MEDIA_16,non_blocked ,21
IDE11502-ENG127538-Gesperrte Menüinhalte-FB_MEDIA_17,non_blocked ,21
IDE11502-ENG127539-Gesperrte Menüinhalte-FB_MEDIA_18,non_blocked ,21
IDE11502-ENG127540-Gesperrte Menüinhalte-FB_MEDIA_19,non_blocked ,21
IDE11502-ENG127523-Gesperrte Menüinhalte-FB_MEDIA_2,non_blocked ,21
IDE11502-ENG127541-Gesperrte Menüinhalte-FB_MEDIA_20,non_blocked ,21
IDE11502-ENG127542-Gesperrte Menüinhalte-FB_MEDIA_21,non_blocked ,21
IDE11502-ENG127543-Gesperrte Menüinhalte-FB_MEDIA_22,non_blocked ,21
IDE11502-ENG127544-Gesperrte Menüinhalte-FB_MEDIA_23,non_blocked ,21
IDE11502-ENG127524-Gesperrte Menüinhalte-FB_MEDIA_3,blocked ,21
IDE11502-ENG127525-Gesperrte Menüinhalte-FB_MEDIA_4,blocked ,21
IDE11502-ENG127526-Gesperrte Menüinhalte-FB_MEDIA_5,blocked ,21
IDE11502-ENG127527-Gesperrte Menüinhalte-FB_MEDIA_6,non_blocked ,21
IDE11502-ENG127528-Gesperrte Menüinhalte-FB_MEDIA_7,non_blocked ,21
IDE11502-ENG127529-Gesperrte Menüinhalte-FB_MEDIA_8,blocked ,21
IDE11502-ENG127530-Gesperrte Menüinhalte-FB_MEDIA_9,blocked ,21
IDE11502-ENG127625-Gesperrte Menüinhalte-FB_MISC_0,blocked ,21
IDE11502-ENG127626-Gesperrte Menüinhalte-FB_MISC_1,non_blocked ,21
IDE11502-ENG127635-Gesperrte Menüinhalte-FB_MISC_10,blocked ,21
IDE11502-ENG127636-Gesperrte Menüinhalte-FB_MISC_11,blocked ,21
IDE11502-ENG127637-Gesperrte Menüinhalte-FB_MISC_12,blocked ,21
IDE11502-ENG127638-Gesperrte Menüinhalte-FB_MISC_13,blocked ,21
IDE11502-ENG127639-Gesperrte Menüinhalte-FB_MISC_14,blocked ,21
IDE11502-ENG127640-Gesperrte Menüinhalte-FB_MISC_15,non_blocked ,21
IDE11502-ENG127641-Gesperrte Menüinhalte-FB_MISC_16,non_blocked ,21
IDE11502-ENG127642-Gesperrte Menüinhalte-FB_MISC_17,non_blocked ,21
IDE11502-ENG127643-Gesperrte Menüinhalte-FB_MISC_18,blocked ,21
IDE11502-ENG127644-Gesperrte Menüinhalte-FB_MISC_19,blocked ,21
IDE11502-ENG127627-Gesperrte Menüinhalte-FB_MISC_2,blocked ,21
IDE11502-ENG127645-Gesperrte Menüinhalte-FB_MISC_20,blocked ,21
IDE11502-ENG127646-Gesperrte Menüinhalte-FB_MISC_21,non_blocked ,21
IDE11502-ENG127647-Gesperrte Menüinhalte-FB_MISC_22,blocked ,21
IDE11502-ENG127648-Gesperrte Menüinhalte-FB_MISC_23,non_blocked ,21
IDE11502-ENG127649-Gesperrte Menüinhalte-FB_MISC_24,non_blocked ,21
IDE11502-ENG127650-Gesperrte Menüinhalte-FB_MISC_25,non_blocked ,21
IDE11502-ENG127651-Gesperrte Menüinhalte-FB_MISC_26,non_blocked ,21
IDE11502-ENG127652-Gesperrte Menüinhalte-FB_MISC_27,non_blocked ,21
IDE11502-ENG127653-Gesperrte Menüinhalte-FB_MISC_28,non_blocked ,21
IDE11502-ENG127654-Gesperrte Menüinhalte-FB_MISC_29,non_blocked ,21
IDE11502-ENG127628-Gesperrte Menüinhalte-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Gesperrte Menüinhalte-FB_MISC_30,non_blocked ,21
IDE11502-ENG127656-Gesperrte Menüinhalte-FB_MISC_31,non_blocked ,21
IDE11502-ENG127657-Gesperrte Menüinhalte-FB_MISC_32,non_blocked ,21
IDE11502-ENG127658-Gesperrte Menüinhalte-FB_MISC_33,non_blocked ,21
IDE11502-ENG127659-Gesperrte Menüinhalte-FB_MISC_34,non_blocked ,21
IDE11502-ENG127660-Gesperrte Menüinhalte-FB_MISC_35,non_blocked ,21
IDE11502-ENG127661-Gesperrte Menüinhalte-FB_MISC_36,non_blocked ,21
IDE11502-ENG127662-Gesperrte Menüinhalte-FB_MISC_37,non_blocked ,21
IDE11502-ENG127663-Gesperrte Menüinhalte-FB_MISC_38,non_blocked ,21
IDE11502-ENG127664-Gesperrte Menüinhalte-FB_MISC_39,non_blocked ,21
IDE11502-ENG127629-Gesperrte Menüinhalte-FB_MISC_4,non_blocked ,21
IDE11502-ENG127665-Gesperrte Menüinhalte-FB_MISC_40,non_blocked ,21
IDE11502-ENG127666-Gesperrte Menüinhalte-FB_MISC_41,non_blocked ,21
IDE11502-ENG127667-Gesperrte Menüinhalte-FB_MISC_42,non_blocked ,21
IDE11502-ENG127668-Gesperrte Menüinhalte-FB_MISC_43,non_blocked ,21
IDE11502-ENG127669-Gesperrte Menüinhalte-FB_MISC_44,blocked ,21
IDE11502-ENG127670-Gesperrte Menüinhalte-FB_MISC_45,blocked ,21
IDE11502-ENG127671-Gesperrte Menüinhalte-FB_MISC_46,blocked ,21
IDE11502-ENG127672-Gesperrte Menüinhalte-FB_MISC_47,blocked ,21
IDE11502-ENG127630-Gesperrte Menüinhalte-FB_MISC_5,blocked ,21
IDE11502-ENG127631-Gesperrte Menüinhalte-FB_MISC_6,non_blocked ,21
IDE11502-ENG127632-Gesperrte Menüinhalte-FB_MISC_7,non_blocked ,21
IDE11502-ENG127633-Gesperrte Menüinhalte-FB_MISC_8,non_blocked ,21
IDE11502-ENG127634-Gesperrte Menüinhalte-FB_MISC_9,blocked ,21
IDE11502-ENG127561-Gesperrte Menüinhalte-FB_NAV_0,blocked ,21
IDE11502-ENG127562-Gesperrte Menüinhalte-FB_NAV_1,non_blocked ,21
IDE11502-ENG127571-Gesperrte Menüinhalte-FB_NAV_10,non_blocked ,21
IDE11502-ENG127572-Gesperrte Menüinhalte-FB_NAV_11,non_blocked ,21
IDE11502-ENG127573-Gesperrte Menüinhalte-FB_NAV_12,non_blocked ,21
IDE11502-ENG127574-Gesperrte Menüinhalte-FB_NAV_13,non_blocked ,21
IDE11502-ENG127575-Gesperrte Menüinhalte-FB_NAV_14,non_blocked ,21
IDE11502-ENG127576-Gesperrte Menüinhalte-FB_NAV_15,non_blocked ,21
IDE11502-ENG127577-Gesperrte Menüinhalte-FB_NAV_16,non_blocked ,21
IDE11502-ENG127578-Gesperrte Menüinhalte-FB_NAV_17,non_blocked ,21
IDE11502-ENG127579-Gesperrte Menüinhalte-FB_NAV_18,non_blocked ,21
IDE11502-ENG127580-Gesperrte Menüinhalte-FB_NAV_19,non_blocked ,21
IDE11502-ENG127563-Gesperrte Menüinhalte-FB_NAV_2,non_blocked ,21
IDE11502-ENG127581-Gesperrte Menüinhalte-FB_NAV_20,non_blocked ,21
IDE11502-ENG127582-Gesperrte Menüinhalte-FB_NAV_21,blocked ,21
IDE11502-ENG127583-Gesperrte Menüinhalte-FB_NAV_22,non_blocked ,21
IDE11502-ENG127584-Gesperrte Menüinhalte-FB_NAV_23,non_blocked ,21
IDE11502-ENG127585-Gesperrte Menüinhalte-FB_NAV_24,non_blocked ,21
IDE11502-ENG127586-Gesperrte Menüinhalte-FB_NAV_25,non_blocked ,21
IDE11502-ENG127587-Gesperrte Menüinhalte-FB_NAV_26,non_blocked ,21
IDE11502-ENG127588-Gesperrte Menüinhalte-FB_NAV_27,non_blocked ,21
IDE11502-ENG127589-Gesperrte Menüinhalte-FB_NAV_28,non_blocked ,21
IDE11502-ENG127590-Gesperrte Menüinhalte-FB_NAV_29,non_blocked ,21
IDE11502-ENG127564-Gesperrte Menüinhalte-FB_NAV_3,non_blocked ,21
IDE11502-ENG127591-Gesperrte Menüinhalte-FB_NAV_30,non_blocked ,21
IDE11502-ENG127592-Gesperrte Menüinhalte-FB_NAV_31,non_blocked ,21
IDE11502-ENG127593-Gesperrte Menüinhalte-FB_NAV_32,non_blocked ,21
IDE11502-ENG127594-Gesperrte Menüinhalte-FB_NAV_33,non_blocked ,21
IDE11502-ENG127595-Gesperrte Menüinhalte-FB_NAV_34,non_blocked ,21
IDE11502-ENG127596-Gesperrte Menüinhalte-FB_NAV_35,non_blocked ,21
IDE11502-ENG127597-Gesperrte Menüinhalte-FB_NAV_36,non_blocked ,21
IDE11502-ENG127598-Gesperrte Menüinhalte-FB_NAV_37,non_blocked ,21
IDE11502-ENG127599-Gesperrte Menüinhalte-FB_NAV_38,non_blocked ,21
IDE11502-ENG127600-Gesperrte Menüinhalte-FB_NAV_39,non_blocked ,21
IDE11502-ENG127565-Gesperrte Menüinhalte-FB_NAV_4,blocked ,21
IDE11502-ENG127566-Gesperrte Menüinhalte-FB_NAV_5,non_blocked ,21
IDE11502-ENG127567-Gesperrte Menüinhalte-FB_NAV_6,blocked ,21
IDE11502-ENG127568-Gesperrte Menüinhalte-FB_NAV_7,non_blocked ,21
IDE11502-ENG127569-Gesperrte Menüinhalte-FB_NAV_8,non_blocked ,21
IDE11502-ENG127570-Gesperrte Menüinhalte-FB_NAV_9,blocked ,21
IDE11502-ENG127545-Gesperrte Menüinhalte-FB_PHONE_0,blocked ,21
IDE11502-ENG127546-Gesperrte Menüinhalte-FB_PHONE_1,non_blocked ,21
IDE11502-ENG127555-Gesperrte Menüinhalte-FB_PHONE_10,non_blocked ,21
IDE11502-ENG127556-Gesperrte Menüinhalte-FB_PHONE_11,non_blocked ,21
IDE11502-ENG127557-Gesperrte Menüinhalte-FB_PHONE_12,non_blocked ,21
IDE11502-ENG127558-Gesperrte Menüinhalte-FB_PHONE_13,non_blocked ,21
IDE11502-ENG127559-Gesperrte Menüinhalte-FB_PHONE_14,non_blocked ,21
IDE11502-ENG127560-Gesperrte Menüinhalte-FB_PHONE_15,non_blocked ,21
IDE11502-ENG127547-Gesperrte Menüinhalte-FB_PHONE_2,non_blocked ,21
IDE11502-ENG127548-Gesperrte Menüinhalte-FB_PHONE_3,non_blocked ,21
IDE11502-ENG127549-Gesperrte Menüinhalte-FB_PHONE_4,blocked ,21
IDE11502-ENG127550-Gesperrte Menüinhalte-FB_PHONE_5,blocked ,21
IDE11502-ENG127551-Gesperrte Menüinhalte-FB_PHONE_6,blocked ,21
IDE11502-ENG127552-Gesperrte Menüinhalte-FB_PHONE_7,blocked ,21
IDE11502-ENG127553-Gesperrte Menüinhalte-FB_PHONE_8,non_blocked ,21
IDE11502-ENG127554-Gesperrte Menüinhalte-FB_PHONE_9,non_blocked ,21
IDE11502-ENG127505-Gesperrte Menüinhalte-FB_TUNER_0,non_blocked ,21
IDE11502-ENG127506-Gesperrte Menüinhalte-FB_TUNER_1,non_blocked ,21
IDE11502-ENG127515-Gesperrte Menüinhalte-FB_TUNER_10,non_blocked ,21
IDE11502-ENG127516-Gesperrte Menüinhalte-FB_TUNER_11,non_blocked ,21
IDE11502-ENG127517-Gesperrte Menüinhalte-FB_TUNER_12,non_blocked ,21
IDE11502-ENG127518-Gesperrte Menüinhalte-FB_TUNER_13,non_blocked ,21
IDE11502-ENG127519-Gesperrte Menüinhalte-FB_TUNER_14,non_blocked ,21
IDE11502-ENG127520-Gesperrte Menüinhalte-FB_TUNER_15,non_blocked ,21
IDE11502-ENG127507-Gesperrte Menüinhalte-FB_TUNER_2,non_blocked ,21
IDE11502-ENG127508-Gesperrte Menüinhalte-FB_TUNER_3,blocked ,21
IDE11502-ENG127509-Gesperrte Menüinhalte-FB_TUNER_4,blocked ,21
IDE11502-ENG127510-Gesperrte Menüinhalte-FB_TUNER_5,blocked ,21
IDE11502-ENG127511-Gesperrte Menüinhalte-FB_TUNER_6,blocked ,21
IDE11502-ENG127512-Gesperrte Menüinhalte-FB_TUNER_7,blocked ,21
IDE11502-ENG127513-Gesperrte Menüinhalte-FB_TUNER_8,non_blocked ,21
IDE11502-ENG127514-Gesperrte Menüinhalte-FB_TUNER_9,non_blocked ,21
IDE11503-Tuner für Satellitenradio: voraktiviertes Abonnement,05 ,1
IDE11524-ENG249835-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-chassis_control_0x57,nicht aktiviert ,192
IDE11524-ENG249836-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-chassis_control_0x57_msg_bus,nicht aktiviert ,192
IDE11524-ENG142156-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-climate_mastet_0x42,nicht aktiviert ,192
IDE11524-ENG142157-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-climate_mastet_0x42_msg_bus,nicht aktiviert ,192
IDE11524-ENG142158-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-connection_manager_0x47,nicht aktiviert ,192
IDE11524-ENG142159-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-connection_manager_0x47_msg_bus,nicht aktiviert ,192
IDE11524-ENG249837-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-convertibleTop_0x6C,nicht aktiviert ,192
IDE11524-ENG249838-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-convertibleTop_0x6C_msg_bus,nicht aktiviert ,192
IDE11524-ENG152529-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-daf_profile_0x51,nicht aktiviert ,192
IDE11524-ENG152530-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-daf_profile_0x51_msg_bus,nicht aktiviert ,192
IDE11524-ENG137043-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-display_configuration_0x45,nicht aktiviert ,192
IDE11524-ENG137044-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-display_configuration_0x45_msg_bus,nicht aktiviert ,192
IDE11524-ENG185772-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-engine_functions_0x5D,nicht aktiviert ,192
IDE11524-ENG185773-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-engine_functions_0x5D_msg_bus,nicht aktiviert ,192
IDE11524-ENG142168-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-fas_profile_0x4D,nicht aktiviert ,192
IDE11524-ENG142169-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-fas_profile_0x4D_msg_bus,nicht aktiviert ,192
IDE11524-ENG142154-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-front_traffic_assist_0x41,nicht aktiviert ,192
IDE11524-ENG142155-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-front_traffic_assist_0x41_msg_bus,nicht aktiviert ,192
IDE11524-ENG152535-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-infotainmentsettings_profile_0x50,nicht aktiviert ,192
IDE11524-ENG152536-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-infotainmentsettings_profile_0x50_msg_bus,nicht aktiviert ,192
IDE11524-ENG248719-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-ITM_0x65,nicht aktiviert ,192
IDE11524-ENG248720-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-ITM_0x65_msg_bus,nicht aktiviert ,192
IDE11524-ENG249902-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-lift_0x64,nicht aktiviert ,192
IDE11524-ENG249903-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-lift_0x64_msg_bus,nicht aktiviert ,192
IDE11524-ENG185787-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-mascot_0x83,nicht aktiviert ,192
IDE11524-ENG185788-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-mascot_0x83_msg_bus,nicht aktiviert ,192
IDE11524-ENG152569-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-remote_services_profile_0x4E,nicht aktiviert ,192
IDE11524-ENG152570-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-remote_services_profile_0x4E_msg_bus,nicht aktiviert ,192
IDE11524-ENG139202-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-Soundcontrol_0x44,nicht aktiviert ,192
IDE11524-ENG139203-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-Soundcontrol_0x44_msg_bus,nicht aktiviert ,192
IDE11524-ENG127678-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-spoiler_0x40,nicht aktiviert ,192
IDE11524-ENG127679-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-spoiler_0x40_msg_bus,nicht aktiviert ,192
IDE11524-ENG142162-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-statistic_0x4A,nicht aktiviert ,192
IDE11524-ENG142163-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-statistic_0x4A_msg_bus,nicht aktiviert ,192
IDE11524-ENG142164-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_front_0x4B,nicht aktiviert ,192
IDE11524-ENG142165-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_front_0x4B_msg_bus,nicht aktiviert ,192
IDE11524-ENG142166-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_rear_0x4C,nicht aktiviert ,192
IDE11524-ENG142167-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_rear_0x4C_msg_bus,nicht aktiviert ,192
IDE11524-ENG185817-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-vas_0x54,nicht aktiviert ,192
IDE11524-ENG185818-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-vas_0x54_msg_bus,nicht aktiviert ,192
IDE11524-ENG142160-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-wireless_charging_0x48,nicht aktiviert ,192
IDE11524-ENG142161-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-wireless_charging_0x48_msg_bus,nicht aktiviert ,192
IDE13183-De-/Aktivierung der Popups für aktive Trackingdienste,00 00 00 00 ,4
MAS00951-Bluetooth,ein ,1
MAS01968-Lüfter,normal ,1
MAS02809-MAS02870-Frequenz für Prüfton-Hochton Frequenzbereich,4000 Hz,6
MAS02809-MAS02871-Frequenz für Prüfton-Mittelton Frequenzbereich,1000 Hz,6
MAS02809-MAS02872-Frequenz für Prüfton-Tiefton Frequenzbereich,100 Hz,6
MAS03782-WLAN,ein ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,nicht aktiviert ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,nicht aktiviert ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,nicht aktiviert ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,nicht aktiviert ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,nicht aktiviert ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,nicht aktiviert ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,nicht aktiviert ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,nicht aktiviert ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,nicht aktiviert ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,nicht aktiviert ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,nicht aktiviert ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,nicht aktiviert ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,nicht aktiviert ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,nicht aktiviert ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,aktiviert ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,aktiviert ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,nicht aktiviert ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,nicht aktiviert ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,nicht aktiviert ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,nicht aktiviert ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,nicht aktiviert ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,nicht aktiviert ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,nicht aktiviert ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,aktiviert ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,aktiviert ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,nicht aktiviert ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,nicht aktiviert ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,nicht aktiviert ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,aktiviert ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,aktiviert ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,nicht aktiviert ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,aktiviert ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,aktiviert ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,nicht aktiviert ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,aktiviert ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,aktiviert ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,nicht aktiviert ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,aktiviert ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,aktiviert ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,nicht aktiviert ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,aktiviert ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,aktiviert ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,nicht aktiviert ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,aktiviert ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,aktiviert ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,nicht aktiviert ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,aktiviert ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,aktiviert ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,nicht aktiviert ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,aktiviert ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,aktiviert ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,nicht aktiviert ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,aktiviert ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,aktiviert ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,nicht aktiviert ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,nicht aktiviert ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,nicht aktiviert ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,nicht aktiviert ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,nicht aktiviert ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,nicht aktiviert ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,nicht aktiviert ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,nicht aktiviert ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,nicht aktiviert ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,aktiviert ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,aktiviert ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,nicht aktiviert ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,nicht aktiviert ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,nicht aktiviert ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,aktiviert ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,aktiviert ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,nicht aktiviert ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,aktiviert ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,aktiviert ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,nicht aktiviert ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,nicht aktiviert ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,nicht aktiviert ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,nicht aktiviert ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,nicht aktiviert ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,aktiviert ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,aktiviert ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,nicht aktiviert ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,nicht aktiviert ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,nicht aktiviert ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,nicht aktiviert ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,nicht aktiviert ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,nicht aktiviert ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,nicht aktiviert ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,nicht aktiviert ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,nicht aktiviert ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,aktiviert ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,aktiviert ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,nicht aktiviert ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,nicht aktiviert ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,nicht aktiviert ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,aktiviert ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,aktiviert ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,nicht aktiviert ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,nicht aktiviert ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,nicht aktiviert ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,nicht aktiviert ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,nicht aktiviert ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,nicht aktiviert ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,nicht aktiviert ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,nicht aktiviert ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,nicht aktiviert ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,nicht aktiviert ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,nicht aktiviert ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,aktiviert ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,aktiviert ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,nicht aktiviert ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,nicht aktiviert ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,nicht aktiviert ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,nicht aktiviert ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,nicht aktiviert ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,nicht aktiviert ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,nicht aktiviert ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,nicht aktiviert ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,nicht aktiviert ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,nicht aktiviert ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,nicht aktiviert ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,nicht aktiviert ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,nicht aktiviert ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,nicht aktiviert ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,nicht aktiviert ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,nicht aktiviert ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,nicht aktiviert ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,aktiviert ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,aktiviert ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,nicht aktiviert ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,aktiviert ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,aktiviert ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,nicht aktiviert ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,nicht aktiviert ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,nicht aktiviert ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,aktiviert ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,aktiviert ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,nicht aktiviert ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,aktiviert ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,aktiviert ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,nicht aktiviert ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,nicht aktiviert ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,nicht aktiviert ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,nicht aktiviert ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,nicht aktiviert ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Datenbus Extended ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,nicht aktiviert ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Datenbus Fahrwerk ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,nicht aktiviert ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,nicht aktiviert ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,nicht aktiviert ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,nicht aktiviert ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,aktiviert ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Klemme 15 ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,nicht aktiviert ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Datenbus Antrieb ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,aktiviert ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,aktiviert ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Datenbus Fahrwerk ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,aktiviert ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,aktiviert ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,nicht aktiviert ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,aktiviert ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,nicht aktiviert ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,aktiviert ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,nicht aktiviert ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,nicht aktiviert ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,nicht aktiviert ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Datenbus Komfort ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,aktiviert ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Datenbus Komfort ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,nicht aktiviert ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,nicht aktiviert ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,aktiviert ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Datenbus Komfort ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,nicht aktiviert ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,aktiviert ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,nicht aktiviert ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,nicht aktiviert ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Datenbus Antrieb ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,aktiviert ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,nicht aktiviert ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Datenbus Extended ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,aktiviert ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,nicht aktiviert ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Datenbus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,aktiviert ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,nicht aktiviert ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,nicht aktiviert ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,nicht aktiviert ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Klemme 15 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,nicht aktiviert ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Datenbus Komfort ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,nicht aktiviert ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Datenbus Extended ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,nicht aktiviert ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Datenbus Infotainment ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,nicht aktiviert ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,nicht aktiviert ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Datenbus Antrieb ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,nicht aktiviert ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Datenbus Komfort ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,nicht aktiviert ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Datenbus Komfort ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,nicht aktiviert ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Datenbus Komfort ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,aktiviert ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,nicht aktiviert ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,nicht aktiviert ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,nicht aktiviert ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Datenbus Komfort ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,nicht aktiviert ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,aktiviert ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Datenbus Extended ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,aktiviert ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Datenbus Fahrwerk ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,nicht aktiviert ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Datenbus Extended ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,nicht aktiviert ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Datenbus Komfort ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,nicht aktiviert ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,nicht aktiviert ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Klemme 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,aktiviert ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Datenbus Komfort ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,aktiviert ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,nicht aktiviert ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Datenbus Infotainment ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,aktiviert ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Datenbus Komfort ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,nicht verfügbar ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Datenbus Komfort ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,nicht verfügbar ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Datenbus Infotainment ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,verfügbar ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Datenbus Infotainment ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,nicht verfügbar ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Datenbus Antrieb ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,nicht verfügbar ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Datenbus Fahrwerk ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,nicht verfügbar ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Datenbus Komfort ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Datenbus Komfort ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,nicht verfügbar ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,verfügbar ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Datenbus Komfort ,8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,aus ,10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,aus ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,aus ,10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,aus ,10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,aus ,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,aktiviert ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,aktiviert ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,aktiviert ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,aktiviert ,5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,nicht aktiviert ,5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,nicht aktiviert ,5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,nicht aktiviert ,5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,nicht aktiviert ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,aktiviert ,5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,nicht aktiviert ,5
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
Dauer: 00:51
DV52
C?ID=194404
apial: I'm not sure if it will help - and perhaps the missing piece of the jigsaw puzzle resides in the engineering menu - but HERE'S a copy of an MS excel spreadsheet showing a side-by-side comparison of each adaptation channel setting for the 2 x admaps in your post.
I've sorted the results so that the 70 x adaptation channels with different settings are shown first (2nd level sort criteria is the channel tag number)
I can make no comment about the relevance of these 70 x channels to your issue
EDIT: Ooops................. and here's how the module code-strings compare:
Name	German		        USA
Byte	Hex	Binary	        Hex	Binary
0	02	00000010	02	00000010
1	73	01110011	73	01110011
2	06	00000110	06	00000110
3	00	00000000	00	00000000
4	BE	10111110	BE	10111110
5	00	00000000	00	00000000
6	00	00000000	00	00000000
7	00	00000000	00	00000000
8	51	01010001	51	01010001
9	11	00010001	21	00100001
10	01	00000001	00	00000000
11	01	00000001	01	00000001
12	00	00000000	00	00000000
13	88	10001000	18	00011000
14	08	00001000	08	00001000
15	00	00000000	00	00000000
16	1F	00011111	1F	00011111
17	05	00000101	05	00000101
18	00	00000000	00	00000000
19	D4	11010100	C4	11000100
20	01	00000001	01	00000001
21	20	00100000	20	00100000
22	85	10000101	05	00000101
23	00	00000000	00	00000000
apial
Germany, Erfurt
C?ID=125504
@Don
Thank you for that, helped me to find the issue. Any accessible tool to compare them like you or some excel/bash voodoo? Here is the result in case someone else runs into this problem:
Illumination:
Showed up after activating ambient lighting menu. My theory is that it needs the ambient lighting and than gets the info from the BCM what to really show - same as for the DRL you configure in 09 and not 5F.
Camera:
The missing piece was ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus which was not set to INFOBUS. As I assume VPS stands for Virtual Parking System that makes sense and without this setting it could turn the camera on without the "camera low" coding. I could now remove this coding, camera comes on super fast and all options available.
@All
Again THANK you for all your help, this project is completed and the car passed German inspection today :)
