Need help, where is oil temperature sensor located?
daisy
C?ID=290770
Hi guys,
I have 2012 Volkswagen Passat TDI. I am trying to figure out where is the oil temperature sensor g509 located? Is it inside the transmission, meaning you have to take apart the tranny to change it? Is it on the housing exterior? Any pictures, diagrams and information would be highly appreciated.
Thanks!!!
Log-7QKP428-1VWCN7A35CC060811-387920km-241042mi-073119.txt
Wednesday,31,July,2019,13:32:33:42313
VCDS Version: 19.6.1.0 (x64)
VIN: 1VWCN7A35CC060811   License Plate: 7QKP428
Mileage: 387920km-241042mi   Repair Order: 073119
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
           52 56 62 72 77
VIN: 1VWCN7A35CC060811   Mileage: 387920km-241042miles
Address 01: Engine (J623-CKRA)       Labels:. 03L-906-022-CFC.clb
    Part No SW: 03L 997 009 J    HW: 03L 907 309 S
    Component: R4 2.0l TDI   H21 9982
    Revision: 71H21---    Serial number:
    Coding: 001D0012042400008000
    Shop #: WSC 26061 444 00000
    ASAM Dataset: EV_ECM20TDI01103L997009J 004005
    ROD: EV_ECM20TDI01103L997009J.rod
    VCID: 3B74BECFB2C0E9978C-806E
38303 - NOx Sensor 1 Bank 1
           P2201 00 [100] - Implausible Signal
                     Mileage: 386457 km
                     Date: 2019.07.10
                     Time: 20:38:22
                     Coolant temperature: 95 °C
                     Intake air temperature: 49 °C
                     Voltage terminal 30: 12.760 V
                     Air mass: actual value (mg/stroke): 0.0 mg/stroke
                     Mean injection quantity: 0.00 mg/stroke
                     EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                     NOx Emission NOx-Sensor: 0 ppm
                     Air mass for release of NOx sensor 1 offset test: 0.0 g
                     Calculated efficiency of NOx conversion: 0.949
    Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
    Component: GSG DSG AG6     512 9435
    Revision: 05551213    Serial number: 00001112090944
    Shop #: WSC 40321 001 1048576
    VCID: 26427FBB9142447FC3-8072
18172 - Transmission Temperature Monitoring
             P1764 - 001 -  - Intermittent
                     Fault Status: 00100001
                     Fault Frequency: 10
                     Reset counter: 5
                     Mileage: 386838 km
                     Date: 2013.12.09
                     Time: 17:43:54
00564 - Please Contact Ross-Tech
                     Fault Status: 00101100
                     Reset counter: 37
                     Mileage: 387455 km
                     Date: 2013.12.15
                     Time: 18:16:23
19143 - Unexpected / Implausible Mechanical Gear Disengagement
             P2711 - 007 -  - Intermittent
                     Fault Status: 00100111
                     Reset counter: 38
                     Mileage: 387779 km
                     Date: 2013.12.16
                     Time: 20:58:15
    Revision: 00H31001
    Coding: C54BC0F5492800FAA31303E5921A0042A71000
    Shop #: WSC 09003 957 00200
    VCID: 7DF070D7E45427A7F2-8028
02214 - Tire Pressure Warning
             002 - Lower Limit Exceeded
                     Fault Status: 01100010
                     Reset counter: 33
                     Mileage: 384084 km
                     Date: 2013.11.01
                     Time: 18:12:17
                     Count: 32768
                     Count: 4608
                     Count: 16401
                     Count: 49154
                     Count: 1531
    Revision: 00085000    Serial number: 0161487923
    Coding: 130C0C
    VCID: 346695F39F9E26EF4D-8060
    Part No SW: 561 907 044 H    HW: 561 907 044 H
    Component: Climatronic   043 0202
    Revision: 00001001
    Coding: 0010001012
    ROD: EV_ACClimaBHBVW411_VW41.rod
    VCID: 1C365D53170E8EAF65-8048
    Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
    Component: BCM PQ35 H+   121 0164
    Revision: BL121001
    Coding: 6F200E3B982B08D4088802013600814800710086458005F0648060009C70
    VCID: 74E655F3D71E66EF8D-8020
    Component: RLS 030212 05  54  0403
    Coding: 06300A
                     Fault Status: 00101010
                     Fault Frequency: 45
                     Reset counter: 66
                     Mileage: 381252 km
                     Date: 2013.10.04
                     Time: 21:44:38
                     Voltage: 14.20 V
                     Fault Status: 01101010
                     Fault Frequency: 80
                     Reset counter: 34
                     Mileage: 378963 km
                     Date: 2013.09.05
                     Time: 12:57:35
                     Voltage: 12.00 V
    Part No SW: 5C0 959 655     HW: 5C0 959 655
    Component: AirbagVW10G   013 0809
    Serial number: 003ENM01EMZ5
    Coding: 00003548
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
    ROD: EV_AirbaVW10SMEVW360.rod
    VCID: 6FEC5A9FB638453770-803A
    Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
    Component: BF-Gewichtss.  H10 0045
    Serial number: 6940000Y120000AUAB0V
    Coding: 303047
    Serial number: 3572MSME326F3068ZZZ-
    Serial number: 3582MSME47507466ZZZX
    Serial number: 3516KSME574E1417ZZZW
    Serial number: 3526KSME23681F16ZZZW
    Serial number: 3556LSME3A201414ZZZJ
    Serial number: 3566LSME34051414ZZZH
    Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
    Revision: FF010040    Serial number: 20110729100513
    Coding: 000A140000
    ROD: EV_SMLSNGVOLWS.rod
    VCID: 7DF070D7EC5427A7F2-8028
    Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
Labels: 3C8-959-537.CLB
    Component: E221__MFL-YVJ  H06 0022
    Coding: E20000
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
    Part No SW: 561 920 970 C    HW: 561 920 970 C
    Component: KOMBI         H07 0507
    Coding: 231E01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
    VCID: 1A3A5B4B1D3AF09F77-804E
    Part No SW: 7N0 907 530 P    HW: 1K0 907 951
    Component: J533  Gateway H40 1623
    Revision:   H40       Serial number: 07021201290602
    Coding: 461000
    VCID: 3D70B0D7A4D4E7A7B2-8068
    Component: IMMO          H07 0507
    Coding: 000007
    VCID: 6ADA4B8B8DDAA01F27-803E
    Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
    Component: ELV-PQ35      H20 0230
    Revision: 00000000    Serial number: 11000274387004
    Coding: 4900000000000000
    ROD: EV_ELVMarquMPVW36X.rod
    VCID: 2E52879B71B20C3F3B-807A
    Revision: A1001003    Serial number: 7661543498
    VCID: 29587487405C6B07EE-807C
    Part No SW: 561 959 760     HW: 561 959 760
    Component: MEM-FS        H04 0181
    Revision: AA000000    Serial number: 00000022806321
    Coding: 0000000000000000000000000000000000000000000000
    VCID: 60CE29A373E6EA4FF9-8034
    Part No SW: 3C8 035 684 E    HW: 3C8 035 684 E
    Component: RNS-MID       H61 3690
    Revision: AB001001    Serial number: VWZ6Z7M4047073
    Coding: 04090002010000A6000B
    VCID: 2D50809774B4772702-8078
                     Fault Frequency: 238
                     Reset counter: 74
                     Mileage: 378920 km
    Part No SW: 561 959 701 A    HW: 3C0 959 793 C
    Component: TUER-SG FT    002 0525
    Revision: 12110009    Serial number: 0003494557
    Coding: 0405FD
    ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
    ROD: EV_TSGFPQ25BRFVW46X.rod
    Slave Driver:
    Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels:
1K0-959-70X-GEN4.CLB
    Component: J388__TSG_HL  004 4472
    Coding: 800000
    Part No: 1K0 909 144 N
    Component: EPS_ZFLS Kl. 290    3301
    Revision: 00H22000
    VCID: 3560A8F75CE43FE77A-8060
Address 47: Sound System (R12)       Labels: None
    Part No HW: 5C6 035 456
    Component: KonzernAmp10K H07 0468
    Revision: --------    Serial number: EAA083A0006189
    VCID: 55A0087734A41FE79A-8000
    Component: EZE_2         H40 1623
    Coding: 01030108
    VCID: 6FEC5A9FBE38453770-803A
    Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
    Component: J245 P05 FFD7  H07 0004
    Serial number: 53388786011134400591
    Coding: 181100
    Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
    Component: Analoguhr  008 0004
    Part No SW: 561 959 702 A    HW: 3C0 959 792 C
    Component: TUER-SG BT    002 0525
    Revision: 14110009    Serial number: 0003546138
    Coding: 0405FC
    ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
    ROD: EV_TSGBPQ25BRFVW46X.rod
    VCID: 1D3050570C1487A792-8048
    Slave Passenger:
    Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels:
    Component: J389__TSG_HR  004 4472
    Coding: 800000
                     Reset counter: 74
                     Mileage: 378920 km
    Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
    Component: TELEFON       H09 2902
    Revision: 1B001001    Serial number: 00007661523680
    Coding: 0A10040000010110
    ASAM Dataset: EV_UHVNA A01719
    ROD: UHVNA.rod
    VCID: 275C72BF5E485D77F8-8072
End-------------------------(Elapsed Time: 03:31)--------------------------
                 Address 02: Auto Trans  (02E 300 057 P)
14:58:50 Group 019
   93.0°C  Temperature Transmission Fluid
   99.0°C  Temperature Control Module
   94.0°C  Temperature Clutch Oil (G509)
   Idle  Idle Status
14:58:59 Group 019
   Idle  Idle Status
14:58:59 Group 019
   Idle  Idle Status
14:59:00 Group 019
   Idle  Idle Status
14:59:07 Group 019
   Idle  Idle Status
14:59:09 Group 019
   101.0°C  Temperature Control Module
   Idle  Idle Status
14:59:10 Group 019
   Idle  Idle Status
14:59:13 Group 019
   Idle  Idle Status
14:59:13 Group 019
   Idle  Idle Status
14:59:14 Group 019
   Idle  Idle Status
14:59:54 Group 019
   Idle  Idle Status
14:59:57 Group 019
   Idle  Idle Status
14:59:57 Group 019
   Idle  Idle Status
I always thought this guys site was cool
https://axleaddict.com/auto-repair/The-Mechatronics-of-the-Volkswagen-Dual-Clutch-Transmission
daisy
C?ID=290770
Jeff
Please provide me with diagrams or actual links to whatver can point the location of G509. I tried the link you told me, and it is asking for subscription. Registration is free, but anything else you click on you need to pay for a pdf. I am greatful for gour help, but really do not want to subscribe to anything at this moment.
Thanks,
Daisy
It is inside the transmission, behind the mechatronics. Please see the factory repair manual:
https://erwin.vw.com/erwin/showHome.do
Zenerdiode
Newcastle, England
C?ID=24330
...it is asking for subscription. Registration is free, but anything else you click on you need to pay for a pdf.
We all do, I'm afraid. However, the sub is well worth it; not least because it is the real factory data. Please don't worry about subscribing, you'll never get spam-bombed from Erwin.
Thanks,
Daisy
Ross-Tech is averse to interacting with VW's lawyers. Thus we will not distribute their (or anyone else's) copyrighted content. Sorry.
