Good morning, i have a B9 A4. My autoscan flagged 3 faults (see below). Some of the faults are denoted "not confirmed" and others have full freeze-frame data. Can anyone explain the difference and logic between unconfirmed and confirmed faults? Additionally, what does the "tested since memory clear" indicate?, does this mean the code was cleared, and the fault has since been detected?
Sorry for all the questions!
-Alexander
-Alexander
Saturday,20,July,2019,18:54:15:30897
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUANAF48JA147522 License Plate:
Mileage: 33181km Repair Order:
Chassis Type: F4-AU49 (4M1)
Scan: 01 02 03 08 09 15 16 17 19 42 44 46 52 5F 6C 81 BB BC CA
VIN: WAUANAF48JA147522 Mileage: 33181km-20617miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC) Labels:. 06K-907-425-V2.clb
Part No SW: 8W0 906 259 J HW: 06L 907 425 C
Component: 2.0l R4 TFSI H15 0002
Revision: --H15---
Coding: 0A2500122326010E34000000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
ROD: EV_ECM20TFS020_AU49.rod
VCID: 48C959461234705716D-801C
23126 - Fuel Level Sensor Circuit
P0461 00 [096] - Implausible Signal
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 BA HW: 0CJ 927 156
Component: 0CL 20TFSINAR H05 0001
Revision: --H05--- Serial number: 0000001075
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU48.rod
VCID: 015F8462718E811F913-8054
Manual Transmission Fluid Pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180039002286
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 K HW: 8W0 907 379 J
Component: ESP9 Plus H10 0766
Coding: 18AA409928A60A9D11A34893007F4292E4258018021450881200424927A401
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 4DC76852FD56957F25B-8018
420352 - TPMS Warning; Front Left Tire
C1054 00 [096] - Pressure too Low
416768 - TPMS Warning; Front Right Tire
C1056 00 [096] - Pressure too Low
420096 - TPMS Warning; Rear Left Tire
C1058 00 [096] - Pressure too Low
417024 - TPMS Warning; Rear Right Tire
C105A 00 [096] - Pressure too Low
419840 - TPMS Warning; Rear Right Tire
C105B 00 [108] - Flat
Mileage: 31445 km
Date: 2019.05.31
Time: 15:13:57
91 00 80 17 89 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
15361536 - Databus
[Signal_DI_KL_58xd_error_(255)]
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0210
Coding: 140805095544000D10000100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44D14D762E1C5437FA5-8010
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002174385
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 6BD1931900PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CB HW: 8W0 907 063 BB
Component: BCM1 MLBevo H13 0267
Coding: 8045956254080CCD05158714182C00BB100B3108000000000000000000001A0000600002001204
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_BCM1BOSCHAU736 018006
ROD: EV_BCM1BOSCHAU736_018_AU49.rod
VCID: 7DA7F8920D76E5FFF5B-8028
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 180129 043 0813
Serial number: 89435300301802906321
Coding: 5BC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 21155112X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AK HW: 4M0 941 531 AK
Component: E1 - LDS H06 0008
Serial number: 09 01 2018 01256016
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE118121723812162
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 AB HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00689129
Subsystem 6 - Part No SW: 8W0 925 301 AT HW: 8W0 925 301 AT
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000111412006
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 G HW: 8W0 959 655 G
Component: Airbag10.44 H05 0107
Serial number: 003UQ002E6LG
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705G0051S01441
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706J0051S02203
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J180008WX930U
Subsystem 4 - Part No SW: ----------- HW: 442 061 102 18
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00BD28937B4E34G
Subsystem 5 - Part No SW: ----------- HW: 442 061 102 18
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00B528D6164825%
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 901 18
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700C7291FA263318
Subsystem 7 - Part No SW: ----------- HW: 442 0B2 901 18
Component: SideSensor_Pr 1C7 0148
Serial number: 352770099292F3F4925M
Subsystem 8 - Part No SW: ----------- HW: 442 0C1 601 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C329A8BE2A27T
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C1 601 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500BB29A8BE381A
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GB HW: 4M0 907 129 GB
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76B5E7BE2840B6A7B41-8022
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 740 B HW: 8W5 920 740 B
Component: MMA4M18BENRW H07 0518
Revision: 0518v2.0 Serial number: ULKF97G2U
Coding: 08A651C1208000080203A8401800000000000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736_AU49.rod
VCID: 3C21359656EC2CF7825-8068
16777020 - Control unit for information electronics 1
U1054 00 [008] - No Communication
[TEL_0x28 communication error bap_error_timeout heartbeat]
Reset counter: 120
Mileage: 18187 km
Date: 2018.11.01
Time: 14:56:35
Part No SW: 4M1 907 468 F HW: 4M1 907 468 E
Component: Gateway H22 0123
Revision: 7K010001 Serial number: 0147K036818205
Coding: 030100010000064029070000005900124C180000100000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 3A2D338E5CD812C7909-806E
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20180214131807 21613
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 4910526904
131723 - Body Control Module (Central Electric 2)
U0141 00 [008] - No Communications
[Timeout_Node_0x8B_DiagAdress_46_BCM2]
Reset counter: 199
Mileage: 32452 km
Date: 2019.06.28
Time: 13:25:24
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 8W0 959 593 H HW: 8W0 959 593 F
Component: TSG FS 005 0129
Serial number: 0000304953771
Coding: 001F0B204000108000000082
VCID: 4FFB725AF75AA76F577-801A
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 42DD4B6E34085A07C89-8016
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 EB HW: 8W0 907 064 DB
Component: BCM2 MLBevo 025 0387
Coding: 013400004F300080650780002201000033000000810022502F04000000040030001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
VCID: 005981667A8488179ED-8054
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1802344BS
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099773682
65896 - Databus
[Climatronic control module: Klima_03: no signal/communication]
Reset counter: 226
Mileage: 13 km
Time: 00:00:00
Supply voltages-Supply voltage: Terminal 30: 12.772 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.827 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.772 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 80
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 8W0 959 592 H HW: 8W0 959 592 F
Component: TSG BFS 005 0129
Serial number: 0000306220727
Coding: 001F0B204000108000000080
VCID: 4EC56F5EF050AE675C1-801A
Part No SW: 8W0 035 652 G HW: 8W0 035 652 A
Component: MU-HS-S-US 050 0160
Coding: 01940100FF0A000013220001061A00002F0024C401F001040A
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP_AU49.rod
VCID: 3B23368A53E22BCF8BF-806E
Subsystem 1 - Part No SW: 8W0 919 604 HW: 8W0 919 604
Component: AU49x_DU_STD H40 0008
Serial number: AUZ8Z9HBG03DT0
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8W0 919 614 N HW: 8W0 919 614 N
Component: ControlUnit_B H22 0134
Serial number: APVAK110021800041055
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0250
Coding: 0294010100002001400040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: 33331EAA7BB2E38F53F-8066
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 G HW: 8W1 713 041 J
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 18022046119206
ASAM Dataset: EV_GSMWaehlZFAU736 001017
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 372B2ABA6FCA0FAF6F7-8062
Part No SW: 8W0 959 595 H HW: 8W0 959 595 F
Component: TSG HFS 005 0129
Serial number: 0000305942286
Coding: 000F0B200000108040000080
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 51FF7422E16EB19F413-8004
Component: TSG HBFS 005 0129
Serial number: 0000305933754
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 H HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 2A8000049100
End----------(Elapsed Time: 01:52, VBatt start/end: 14.6V/14.6V)-----------
