2010 Beetle Airbag code 00594 Airbag Igniter Circuits HELP
fastboat2003
New Member
I have a 2010 Beetle with airbag code 00594 Airbag Igniter Circuits and under that says 008 Implausible Signal.
Module is new. Got no clue where or what to do. Anybody know the fix??
fastboat2003
New Member
Thursday,11,July,2019,16:44:55:19936
VCDS Version: 19.6.1.0 (x64)
VIN: 3VWPW3AG5AM016801   License Plate: BLUE BUG
Mileage: 176370km-109591mi   Repair Order:
Chassis Type: AG (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: 3VWPW3AG5AM016801   Mileage: 176370km-109591miles
Address 01: Engine (BPS)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 CP    HW: 07K 906 032 AA
   Component: NB R5 MT        G   4573
   Revision: 1SH04---    Serial number: VWX5Z0J0197105
   VCID: 79F9DD023094B287DE-802C
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 Q
   Coding: 0019978
   VCID: 387F1806481E6B8F61-5140
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AK
   Component: 01 AIRBAG VW71      0911
   Coding: 0012337
   VCID: 000FB0E6574EE34F99-8054
   Subsystem 1 - Component: BF-Gewichtsens.
00594 - Airbag Igniter Circuits
Address 17: Instruments        Labels: None
   Part No: 1C0 920 801 K
   Component: KOMBI+WEGFAHRS. M73 V05
   Coding: 11232
   Shop #: WSC 00066
   VCID: 2345DF6AB1981857A4-4AE8
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V052
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70EFE02630EEF3CF69-4B00
Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
   Part No SW: 1C0 920 801 K    HW: 1C0 920 801 K
   Component: IMMO                X007
   Revision: xxxxxxxx    Serial number: VWX5Z0J0197105
   VCID: 2345DF6AE1981857A4-5140
Address 35: Centr. Locks        Labels: 1C0-962-258-III.lbl
   Part No: 1C0 962 258 AC
   Component: 4G Zentr.Verriegel. 0004
   Coding: 00016
   Shop #: WSC 00066
   VCID: 68DF8846083E3B0F31-4B00
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1C0 035 196 CS
   Component:  RADIO DE2         0006
   Coding: 00401
   Shop #: WSC 00066
   VCID: 72EBEA2E3EE2C1DF9F-51D4
00856 - Radio Antenna
            36-00 - Open Circuit
Address 65: Tire Pressure        Labels: None
   Part No SW: 1C0 907 273 A    HW: 1C0 907 273 A
   Component:    RDK          H02 0230
   Revision: --H02-E0    Serial number: 13115791824578
   Coding: 0100101
   VCID: 2149D562F8840A47B6-8074
End-------------------------(Elapsed Time: 04:07)--------------------------
Address 56: DTCs clearedTuesday,16,July,2019,18:42:05:19936
   Coding: 0019978
   Coding: 0012337
   Coding: 11232
   Shop #: WSC 00066
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70EFE02630EEF3CF69-4AE8
   Coding: 00016
   Shop #: WSC 00066
   VCID: 68DF8846083E3B0F31-4B1A
   Coding: 00401
   Shop #: WSC 00066
   VCID: 72EBEA2E3EE2C1DF9F-51B6
   Coding: 0100101
End-------------------------(Elapsed Time: 04:04)--------------------------
Hmmm.. That's not a fault I'm familiar with. It almost sounds like a problem internal to the airbag module.
But before you condemn it, scroll through the first 13 or so Measuring Blocks and look for anything out of place.
Also, check the ground for the airbag module.
HMC
C?ID=28246
Hi fastboat2003,
Did you change the module because you had this DTC, or did it appear after you changed the module? Was it dealer new? Has the vehicle been in a collision?
Regards HMC
PetrolDave
Westbury, UK
C?ID=1423
...and does the replacement module have the same "colour code" as the original one?
fastboat2003
New Member
Module was replace because of this DTC. This was the recommended repair from the dealer. Module was dealer brand new and ordered from VIN.
fastboat2003
New Member
So...no one here has any info that can help or has seen this before??
Correct, I for one have not seen that DTC before.
But have you looked at the measuring values like I recommended in post #4?
fastboat2003
New Member
The module is BRAND NEW......how would a brand new module and the old module have the same fault due to measuring values?????
This forum is no help at all.....
Zenerdiode
Newcastle, England
C?ID=24330
Whoah there - easy fella. If you had posted up the measuring values, we would see what the module reports what it thinks are the resistance values of the ignitors of the different SRS components. Again, as Uwe requested, did you check all of the wiring/grounds to the module?
Maybe it's not the module at fault then. It could be the wiring to the ignitors; or the ignitors themselves.
Well, I'm giving this bit of 'help' for free. Do not, under any circumstances, use your multimeter to measure the resistance of the ignitors. If your response is "Why?" - please stop before you hurt yourself - and arrange for somebody more knowledgeable to repair your vehicle.
Viking
C?ID=151455
Is there any reason why you're ignoring requests from Uwe to check certain values? Some time ago he asked...
"But before you condemn it, scroll through the first 13 or so Measuring Blocks and look for anything out of place.
Also, check the ground for the airbag module."
But you seem to avoid doing so?
