AUDI Q7 3.0TDI 2011
Gapel3
Australia
C?ID=313356
HI EVERYONE.
GOT AUDI Q7 WITH P2146 FAULT GROUP A INJECTORS MULFUNCTION.
CHECK RESISTANT OF ALL INJECTORS AROUND 181oms.WIRING LOOPS
ALL CLEAR.
TERMINAL 30 FAULT TOO.NO READING OF ANY INJECTORS 0.0mg/st
ANY IDEA.
THANK YOU
PetrolDave
Westbury, UK
C?ID=1423
First point we need to see a full unedited VCDS Auto-Scan of you car to be able to help.
Second point, posting in ALL CAPS is seen as shouting so it would be worth checking your CAPS LOCK is off.
Gapel3
Australia
C?ID=313356
Tuesday,23,July,2019,19:00:18:39620
VCDS Version: Release 19.6.1 (x64) Running on Windows 10 x64
                Address 01: Engine       Labels: 059-907-401-V2.CLB
Control Module Part Number: 4L1 910 401 H    HW: 4L0 907 401 C
  Component and/or Version: 3.0TDI EDC17  H37 0003
           Software Coding: 2A2A4012A53701020000
            Work Shop Code: WSC 31414 790 00001
              ASAM Dataset: EV_ECM30TDI0114L1910401H 001008 (AU56)
                       ROD: EV_ECM30TDI0114L1910401H.rod
                      VCID: A81CA2F5D3695F0F71-80FC
10219 - Sensor for Cylinder Head Temperature
          P017D 00 [036] - Short to Plus
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 00:43:25
                    Engine speed: 701.00 /min
                    Normed load value: 44.7 %
                    Coolant temperature: 65 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 13.940 V
                    Coolant temperature at radiator outlet: actual value: 24.6 °C
                    Heat delivery temperature in cooling system: -273.1 °C
                    Outside air temperature: 23.0 °C
                    Fuel consumption: 1.94 l/h
                    Fuel temperature: 25.4 °C
                    Engine oil temperature: 65.5 °C
5060 - Supply Voltage for Fuel Injector Group A
          P2146 00 [101] - Open Circuit
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 00:43:24
                    Engine speed: 706.50 /min
                    Normed load value: 40.0 %
                    Voltage terminal 30: 13.780 V
                    Allowed number of injections-Bits 0-7: 3
                    Injection release status-Bits 0-7: 56
                    Desired injection characteristic-Bits 0-7: 56
                    Mean injection quantity: 13.14 mg/stroke
                    Rail pressure regulation: status-Bits 0-7: 5
                    Fuel high pressure: actual value: 257700 hPa
                    Control Module temperature: 44.9 °C
PetrolDave
Westbury, UK
C?ID=1423
That's a heavily edited Auto-Scan showing only the Engine ECU, please replace it with the full unedited Auto-Scan - sometimes the details of other modules in the car are important too.
Got the OP verified. Moving to Car Repair Support.
Welcome to the VCDS forum OP
These faults look pretty straight forward to me, did you JPPSG and check fuses and for power on the consumer BUS or review the WD in RTFB?
Is ECU with water ingress?
To reiterate please post a complete auto-scan as others already aforementioned......... :rolleyes:
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Before we get started: FYI
I can maybe considered an asshole with my interrogation techniques & to extract the sometimes needed data to assist, so don't read into it, it's for your own benefit and to help you help yourself.
Gapel3
Australia
C?ID=313356
Soory guys Im new here and dont understand all your short cuts....will do full scan today and post it shortly.
Gapel3
Australia
C?ID=313356
just got ECU back and they said nothing wrong they can see.
Gapel3
Australia
C?ID=313356
Wednesday,24,July,2019,08:31:02:39620
VIN: WAUZZZ4L0BD018027   License Plate:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 18 19 28 42 46 4F 52 56 5F 62
          69 6C 6D 6F 72 76
VIN: WAUZZZ4L0BD018027   Mileage: 128070km-79579miles
Address 01: Engine (J623-CJGA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L1 910 401 H    HW: 4L0 907 401 C
   Component: 3.0TDI EDC17  H37 0003
   Revision: 53H37---    Serial number:
   Shop #: WSC 31414 790 00001
          P017D 00 [047] - Short to Plus
                    Fault Frequency: 9
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 00:43:25
          P2146 00 [175] - Open Circuit
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 00:43:24
Readiness: 1 1 0 0 1
   Part No SW: 0C8 927 750 AE    HW: 0C8 927 750 AE
   Component: AL1000 AISIN  001 1815
   Coding: 001578
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_AU56.rod
   VCID: EFAE89E936074837F0-80BA
   Revision: 00H02001
   Coding: 2196593
   VCID: B4244685D7A12BEFCD-80E0
                    Reset counter: 62
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 00:01:55
                    Count: 2113
                    Count: 128
                    Count: 32256
                    Reset counter: 62
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 00:01:50
                    Count: 128
                    Count: 2881
                    Count: 297
                    Count: 33280
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10602901687930
   Coding: 0000147
   VCID: A502ABC16C7B42674A-80F0
   Subsystem 1 - Part No: 4F0 910 132 A
   Subsystem 2 - Part No: 4F0 910 220
   Component: FBSAUDIC6 IDG   H01 0054
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AD
   Component: KLIMA 4 ZONEN H13 0060
   Revision: 00---022    Serial number: 00000030170325
   Coding: 01029456
   VCID: A502ABC1AC7B42674A-80F0
                    Reset counter: 102
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 00:01:58
                    Voltage: 9.30 V
   Part No SW: 4F0 910 279 AF    HW: 4F0 907 279
   Component: ILM Fahrer      H30 0390
   Coding: 0028121
   VCID: ED9293E1F40BBA27C2-80B8
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H12 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 62
                    Mileage: 128076 km
                    Date: 2010.04.26
                    Time: 21:15:00
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 62
                    Mileage: 128076 km
                    Date: 2010.04.26
                    Time: 21:15:00
                    Reset counter: 62
                    Mileage: 128076 km
                    Date: 2010.04.26
                    Time: 21:15:00
                    Reset counter: 62
                    Mileage: 128076 km
                    Date: 2010.04.26
                    Time: 21:15:00
                    Reset counter: 62
                    Mileage: 128076 km
                    Date: 2010.04.26
                    Time: 21:15:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 95629B017C1BD2E7DA-80C0
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D07A0JR
   Coding: 0014128
   VCID: AE1054ED398D013FBB-80FA
   Subsystem 1 - Serial number: 6332QSME017B14368
   Subsystem 2 - Serial number: 6342QSME677A0230B
   Subsystem 3 - Serial number: 6352QSME047B45109
   Subsystem 4 - Serial number: 6362QSME5478061AJ
   Subsystem 5 - Serial number: 63734SME5E722E248
   Subsystem 6 - Serial number: 63834SME01730F26-
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026103040312
   Coding: 0102142
   VCID: A71EA1C91677507778-80F2
   Component: E0221           H02 0100
   Part No SW: 4L0 920 932 J    HW: 4L0 920 932 J
   Component: KOMBIINSTR.   H10 0209
   Revision: 00000000    Serial number: FLL03R9CA
   Coding: AF56630400000008010700
   VCID: B326459912AF2CD7D4-80E6
                    Reset counter: 102
                    Mileage: 128078 km
                    Date: 2010.04.26
                    Time: 21:14:58
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 G
   Component: Heizgeraet      H09 0140
   Revision: 0000000C    Serial number: 00000009021078
   Coding: 0000101
   VCID: E08CFAD533D9E74F79-80B4
   Part No SW: 4F0 907 468 P    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0047
   Revision: LB200032    Serial number: 3200L10A01003A
   Coding: 00CF07
   VCID: BC346EA53FF1E3AF05-80E8
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790183023
   Serial number: 10301001284021200181
                    Reset counter: 102
                    Mileage: 128078 km
                    Date: 2010.04.26
                    Time: 21:04:00
                    Bin. Bits:    00000
                    Voltage: 12.30 V
                    Count: 11
02256 - Quiescent Current
                    Fault Status: 01100001
                    Reset counter: 62
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 04:56:00
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AA
   Revision: 00---010    Serial number: 00000030170409
   Coding: 0000006
   VCID: E89CE2F5DBE99F0FB1-80BC
                    Reset counter: 102
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 00:03:34
                    Voltage: 9.50 V
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 62
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 00:03:34
   Part No SW: 4F0 959 793 AA    HW: 8K0 959 793 N
   Component: TSG FA        H12 0361
   Revision:             Serial number: 0000109226985
   Coding: 011C02204041440004
   VCID: F6A0BC8D415D79FF33-80A2
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01378652990000
   Coding: 3276941
   VCID: B5227B81DCDB32E7FA-80E0
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000576131
   Coding: 0011001
   VCID: DEF0C42D09ADD1BF4B-808A
   Part No SW: 4F0 959 792 AA    HW: 8K0 959 792 N
   Component: TSG BF        H12 0361
   Revision:             Serial number: 0000109399622
   VCID: F5A2BB815C5B72E73A-80A0
   Part No SW: 4G0 035 056 D    HW: 4G0 035 056
   Component: Radio U STD   H52 0094
   Revision: AB001007    Serial number: 469K50A7604853
   Coding: 040003020100000000
   VCID: A208B0DDBD55B55F2F-80F6
   Part No SW: 4L0 035 754 E    HW: 4L0 035 754
   Component: H-BN-RW       H49 0174
   Revision: --------    Serial number: 487KZ0AB000306
   Coding: 010A0106000483EF01002305EF6300030000
   VCID: AD1253E1F48B7A2782-80F8
   Subsystem 1 - Part No: 8R0 060 884 Q
   Component: ROW 2010  0207
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0098
   Serial number: 9466KS0A0253123
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 B
   Component: E0380 Bedient  H05 0060
   Serial number: 00000001715626
   Component: CD-Database  2712
   Part No SW: 4F0 959 795 Q    HW: 8K0 959 795 F
   Component: TSG HL        H11 0361
   Revision:             Serial number: 0008000094860
   Coding: 010800204041230004
   VCID: C7DE01497637B07798-8092
                    Reset counter: 62
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 00:08:43
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Component: Anhaenger     H08 0100
   Revision: 2A001001    Serial number: 00000136902163
   Coding: 0300000000000000
   VCID: B12A4F91E8B31EC7A6-80E4
   Revision: --H04---    Serial number: 525PA8-J0X4034
   Coding: 1021101
                    Reset counter: 62
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 16:05:09
                        Reverse OFF
                    Count: 3
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H55 0500
   Revision: --H55001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: EC949EE5CF11B32FD5-80B8
   Subsystem 3 - Serial number: RD06.11.10--H55001001B0068ÿ
   Subsystem 4 - Serial number: 1B0068ÿ
00532 - Supply Voltage B+
                    Reset counter: 102
                    Mileage: 128078 km
                    Date: 2010.04.16
                    Time: 04:43:20
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Component: ILM HINTEN 2    H05 0070
   Revision: AAH05061    Serial number: 109056638-----
   VCID: E582EBC12CFB82678A-80B0
   Component: TSG HR        H11 0361
   Revision:             Serial number: 0008000094618
   Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Component: Parkhilfe 8-Kan H03 0500
   Revision: 00H03000    Serial number: 37331031102895
   Coding: 0231066
   VCID: AA1858FD05656D1F67-80FE
End----(Elapsed Time: 02:07, VBatt start/end: 14.7V/14.8V. VIgn 0.0V)------
Gapel3
Australia
C?ID=313356
all fuses good checked...
Do you have power to the injector BUS correlated to respective fuse using WD in RTFB?
Gapel3
Australia
C?ID=313356
WHATS WD RTFB?
PetrolDave
Westbury, UK
C?ID=1423
WHATS WD RTFB?
See how WD and RTFB are bold green?
On this forum that means if you hover your mouse over them a pop-up box will appear showing the meaning of the acronym :thumbs:
Gapel3
Australia
C?ID=313356
CHEERS GUYS DONT HAVE WD ....YESTERDAY GOT WEIRD THING WHICH WASN'T DOING IT BEFORE....RADIATOR FAN KICKS IN WHEN THE CAR IS EVEN LOCKED.,
Well consider the fact you have a sporadic DTC for cylinder head temp sensor maybe part of a keep alive strategy to cool things down.
