A couple of weeks ago, the HVAC on my 2011 Audi S3 failed. That is the fan blower wouldn’t switch on. All the HVAC’s red lights including the two LCD temperature numbers - showing the left and right hand cabin temperatures selected – were all dead. The only fault code then shown by auto-scan was 08- Auto HVAC 1 fault found 01273, Fresh Air Blower V2.
A local auto-electrician removed the blower fan, connected it to a battery and it spun freely. He also checked and tightened the in- line power connectors to the blower fan. HVAC was then working apparently 100% OK. Changing the fan setting, changed the fan speed and the cooling temperature changed as the selected temperature was adjusted. The auto-electrician said this indicated the resistor was probably working ok. Cooling was effective on a warm day (26c). All fault codes were then cleared.
Just to check, a couple of days ago, I ran auto-scan (attached) which showed these faults:
• Address 01 Engine fault 1 Fault Found: 049508 - No Communications with HVAC Control Module (J301) U0164 - 008 - - Intermittent and 1 Fault Found:
• Address 08 Auto HVAC 1 fault found 01273 - Fresh Air Blower (V2) 010 - Open or Short to Plus
As HVAC appears to be working OK, I’m tempted to do nothing if and until a problem becomes more apparent. That said, if there is problem, I’d like to fix it. Any suggestions on what to check next would be appreciated.
I've attmpted to wrap code the latest autoscan here:
Wednesday,10,July,2019,21:20:09:28317
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ8P2BA110626 License Plate: J7HXX
Mileage: 167530km-104098mi Repair Order:
Chassis Type: 8P-AU35 (8P0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 52 55 56 77
VIN: WAUZZZ8P2BA110626 Mileage: 167530km-104098miles
Address 01: Engine (CDL) Labels:. 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AP HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH20--- Serial number: AUX7Z0JNFNU0MR
Coding: 0103000C180F0160
Shop #: WSC 06314 000 00000
VCID: 000590CE536D9E4F99-8054
Mileage: 167406 km
Date: 2019.06.29
Time: 18:58:57
Temperature: 46.0°C
Temperature: 50.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.557 V
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 16428012092300FA681101E6901F0081380000
VCID: 76E9F616C1A9A0FFB3-8022
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0170
Revision: 000881 Serial number: 8P0820043BN
VCID: 79F3FD2A30B7CF87DE-802C
Fault Status: 01101010
Fault Frequency: 36
Reset counter: 222
Mileage: 166259 km
Date: 2019.01.22
Time: 09:54:18
Temperature: 1.5°C
Speed: 68.9 km/h
(no units): 228.0
(no units): 248.0
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 G HW: 8P0 907 063 G
Component: BCM PQ35 M 107 0615
Revision: 00107 AF
Coding: 4E000A2FA005F000207241E00100094C427E25AA306DD928E40008840040
VCID: 3875382E8B3D168F61-806C
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Component: Innenraumuebe H04 0020
Component: LIN BACKUP HO H11 9005
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36891034717291
Coding: 000003
VCID: 489548EEFBDD660F11-801C
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H07 0200
Revision: -------- Serial number: 003FB00A3HR0
Coding: 303142413039303030384A55305238503053
ROD: EV_Airba10AURB4.rod
VCID: 4FA763F216B3B13750-801A
Serial number: 34928RB400005F93875Y
Serial number: 35028RB400005F94169N
Serial number: 35128RB400005F938E4X
Serial number: 35228RB400005F94192L
Serial number: 35547RB40000601764EI
Serial number: 35647RB4000060175E2G
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004042
VCID: 468946D631C9707FE3-8012
Component: E0221 H06 0030
Part No SW: 8P0 920 982 L HW: 8P0 920 982 L
Component: KOMBIINSTR. VDO H01 0091
Revision: D0H01004 Serial number: 224NJ004000760
Coding: 0261428
Shop #: WSC 56298 001 1048576
VCID: 42815AC61DE14C5FCF-8016
Part No SW: 8P0 907 530 B HW: 1K0 907 951
Component: J533 Gateway H42 0311
Revision: H42 Serial number: 221110F1000104
Coding: 350101
VCID: 32610A066D41FCDF5F-8066
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
VCID: 448D5CDE07F5426FFD-8010
Revision: D0H01004 Serial number: AUX7Z0JNFNU0MR
Shop #: WSC 00588 210 91753
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020202
VCID: 74EDCC1ED7D5B2EF8D-8020
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H06 0200
Revision: 0000012S Serial number: AUZBZ7LD200967
Coding: 0209725
Shop #: WSC 00588 210 91790
VCID: 346D0C1E5755F2EF4D-8060
16353 - Control Module - Internal Malfunction
014 - Defective
Fault Status: 01101110
Reset counter: 222
Mileage: 167535 km
Date: 2019.07.10
Time: 21:16:38
Bin. Bits: 11
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 P HW: 8P0 959 801 P
Component: Tuer-SG H04 0101
Coding: 0000564
VCID: 489548EE3BDD660F11-801C
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 234 3201
Revision: 00H20000
Part No SW: 8P0 959 802 P HW: 8P0 959 802 P
Coding: 0000564
VCID: 49934DEA20D79F070E-801C
Part No: 8P3 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000013
VCID: 3C7D243E7F053AAF85-8068
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0209725
014 - Defective
Reset counter: 222
Mileage: 167535 km
Date: 2019.07.10
Time: 21:16:38
Bin. Bits: 11
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005270493
Coding: 0011422
VCID: 74EDCC1E17D5B2EF8D-8020
End-------------------------(Elapsed Time: 02:17)--------------------------
