Need help...please..begging..
Unknown19
New Member
United States
I'm a newb and in need of some guidance/help.
2013 VW CC Rline 6spd.
Ran Evap and SAI to set readiness, closed out vcds and now when i start the car and release the parking brake to drive I have the ABS, Traction Control and Airbag lights all on. Did a scan and below is what I got. Multiple malfunctions.:banghead:
Monday,08,July,2019,18:30:28:12016
VCDS Version: 19.6.0.6 (x64)
VIN: WVWAP7AN6DE558088   License Plate:
Chassis Type: AN-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55 56 62
          65 72
VIN: WVWAP7AN6DE558088   Mileage: 59920km-37232miles
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 06J 906 027 FD    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2 06 3951
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 0404010818070160
   Shop #: WSC 05314 000 00000
   VCID: 72E12EF26D81D1DF93-8026
               U1017 - 000 -
                    Mileage: 1118481 km
                    Date: 2004.04.08
                    Time: 17:04:34
                    RPM: 1995 /min
                    Load: 22.7 %
                    Speed: 17.0 km/h
                    Temperature: 99.0°C
                    Temperature: 46.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
000319 - Oxygen (Lambda) Sensor B1 S2
               P013F - 000 - Response too Slow Lean to Rich
                    Date: 2020.13.09
                    Time: 21:14:38
                    RPM: 1666 /min
                    Load: 7.1 %
                    Speed: 83.0 km/h
                    Temperature: 98.0°C
                    Temperature: 47.0°C
                    Voltage: 13.716 V
Readiness: 0010 0000
   Part No SW: 3AA 614 109 AP    HW: 3AA 614 109 AP
   Component: J104   C2 450M V401 0030
   Revision: --H07---    Serial number: 00000006697677
   Coding: 0000396
   Shop #: WSC 05311 000 00000
   VCID: 7BFF03D63ACB9097C0-802E
   Part No SW: 3AA 907 044 AN    HW: 3AA 907 044 AN
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0010001048
   Shop #: WSC 00015 115 00000
   VCID: 7CFD00CAF7C597AFC9-8028
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 0465
   Revision: BD421001
   Coding: 0008000000000000008802819400094C2055000840200D20E484402400C0
   VCID: 4183B13ED8A73A47DA-8014
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 030113  010 0604
   Serial number: 030113
   Coding: 00B795
   Component: RLFS  024 0042
   Serial number: Y13M02D12H21M26S56S1
   Coding: 0228DD
   Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
   Component: J234__713 VW10 HI   2118
   Revision: 25018000    Serial number: 003LDPQGGU2N
   Coding: 0012595
   VCID: 4E999A02D9F9D53F57-801A
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 0000000000D9XQ
   Subsystem 3 - Serial number: 0017.01.130000300000650081ÿ†63
   Subsystem 4 - Serial number: 650081ÿ†6332MTS640240193 ÿ†63
   Subsystem 5 - Serial number: 40193 ÿ†6342MTS636570213 ÿ†63
   Subsystem 6 - Serial number: 70213 ÿ†6351HTS6KF9POBKR ÿ†63
   Subsystem 7 - Serial number: POBKR ÿ†6361HTS6L9RRPBKJ ÿ†63
   Subsystem 8 - Serial number: RPBKJ ÿ†63727TS6RO7FPBKJ ÿ†63
   Subsystem 9 - Serial number: FPBKJ ÿ†63827TS62AS9PBKR ÿ
   Subsystem 10 - Serial number: 9PBKR ÿ
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010041    Serial number: 20130206201881
   Coding: 018A270000
   VCID: 72E12EF2A581D1DF93-8026
   Coding: E20000
   Part No SW: 3C8 920 971 B    HW: 3C8 920 971 B
   Coding: 240F00
   Shop #: WSC 05314 115 00000
   VCID: 2C5DF08A4725C72F19-8078
   Part No SW: 7N0 907 530 AJ    HW: 7N0 907 530 AJ
   Component: J533  Gateway H51 1634
   Revision:   H51       Serial number: 310113F2000377
   Coding: 469006
   VCID: 78F51CDACBFDBB8FAD-802C
                    Mileage: 33805 km
                    Date: 2016.07.15
                    Time: 12:14:34
   Part No SW: 3AA 959 433 C    HW: 3AA 959 433 C
   Component:    IMMO         042 0404
   Revision: 00042000    Serial number: VWZCZ000000000
   VCID: 3973D9DE7077628792-806C
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664272727
   Coding: 020100
   VCID: 2A51F69245D1D91FEB-807E
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H58 0319
   Serial number: VWZAZ2N0089903
   Coding: 0400040104000F000001100A
   ROD: EV_RNS315NARV2UDS_VW46.rod
   VCID: 254B05AE24CFF667C6-8070
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0555
   Revision: 12110009    Serial number: 0006481942
   Coding: 0004B7
   Shop #: WSC 05311 115 00000
   VCID: 6DDB3D8EBCBF0E274E-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000003347905
   Coding: 010490
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.302 1202
   Revision: 1BH04737    Serial number: 00130360118301
   Coding: 0000258
   VCID: 3F87B7C66E534CB7AC-806A
                    Fault Status: 00101101
                    Reset counter: 41
                    Mileage: 59901 km
                    Date: 2013.11.28
                    Time: 05:44:16
                    RPM: 2032 /min
                    Speed: 17.0 km/h
                    (no units): 7.0
                    Voltage: 13.80 V
   Component:    KSG PQ47 ELV 042 0638
   Coding: 1B910F8001862E521204141FF08A0F0E107C00
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
   Component: EZE_2         H51 1634
   Coding: 00000008
   VCID: 6FE72786BEB3FC377C-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0555
   Revision: 14110009    Serial number: 0006475714
   Coding: 0004B6
   VCID: 6ED93A82B1B9F53F77-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000003339020
   Coding: 010490
   Revision:   H19       Serial number: 00000000769835
   Coding: 0022156
   VCID: 3669D2E241698DFF7F-8062
00532 - Supply Voltage B+
                    Reset counter: 213
                    Mileage: 58932 km
                    Date: 2013.10.09
                    Time: 10:06:43
                    Voltage: 8.30 V
                    Count: 48
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 41
                    Mileage: 59901 km
                    Date: 2013.11.28
                    Time: 05:37:11
                    Voltage: 13.70 V
                    Count: 104
                    Speed: 6.0 km/h
                    Hex Value: 0x12E0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Component: AFS-ECU       H04 0111
   Coding: 071200010B000400
   VCID: 3777DFE68E6374F764-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
13705985 - Databus
                    Fault Frequency: 7
                    Reset counter: 41
                    Mileage: 59901 km
                    Date: 2019.07.08
                    Time: 05:37:10
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000196471
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   VCID: 356BD5EE946F86E776-8060
12652544 - Supply voltage
                    Reset counter: 40
                    Mileage: 58932 km
                    Date: 2019.05.19
                    Time: 10:11:24
End-------------------------(Elapsed Time: 03:00)--------------------------
I would start by fixing the Gateway Installation List.
[Select]
[19-CAN Gateway]
[Installation List]
Scroll down to 65-Tire Pressure and put a check-mark next to it.
[Save Coding].
Exit VCDS gracefully.
Cycle the ignition.
Clear the various fault codes.
Unknown19
New Member
United States
[Select]
[19-CAN Gateway]
[Installation List]
[Save Coding].
Cycle the ignition.
Hi UWE. Thank you for responding.
I had the TPMS disabled from 2014 on due to running another set of wheels w/out the sensors. Can this fault be fixed w/out placing the mark for the TPMS?
The fault in the Gateway? Nope.
I'm scratching my head as to why your ABS and traction control lights are on since your ABS has no fault codes.
Go through the car and clear fault codes in all the modules one at a time.
grant@gendan
Did you clear your ABS fault codes before posting the Scan?
As Uwe commented, you have several systems referring to ABS faults but no codes in the ABS.
Unknown19
New Member
United States
Yes. I cleared the ABS fault code before i posted the scan results. After all were cleared, and closing out VCDS. Re-cycled the ignition and everything was fine until i drove forward. Everything came back on.
Viking
C?ID=151455
So do you now have another scan where all the relevant fault codes are still showing? That's what is needed.
Viking
C?ID=151455
Well, the ABS fault code is what's needed to help, and since you cleared it already...
Have you a scan log from BEFORE you cleared that fault code? VCDS saves logs by default, even if you don't save them.
8716valver
New Member
HC423737 (2nd hand?)
Hi all. I'm Unknown19's other half and am determined to figure out the issues with our CC.
After this thread was started we had the car at the dealer for Airbag and FP recalls. The tech also scanned the car and diagnosed the cause of the faults to be the rear left wheel bearing and wheel speed sensor. I replaced both myself last week and the faults did not go away. I even have more faults now. I can delete the faults module by module but a couple of them come back right away in real time before I can even close out the module and move onto the next. Does anyone have any recommendations on what to check next?
Friday,02,August,2019,18:15:31:12016
VCDS Version: 19.6.1.0 (x64)
Mileage: 60020km-37294mi   Repair Order:
          65 72
VIN: WVWAP7AN6DE558088   Mileage: 60020km-37294miles
65-Tire Pressure -- Status: Not registered 0001
   VCID: 72E12EF26D81D1DF9F-8026
               U1017 - 000 -
                    Mileage: 789516 km
                    Date: 2003.00.06
                    Time: 00:48:24
                    RPM: 1467 /min
                    Load: 18.8 %
                    Speed: 12.0 km/h
                    Temperature: 39.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.843 V
Readiness: 0000 0100
   Component: J104   C2 450M V407 0030
   Coding: 0000396
   VCID: 7BFF03D63ACB9097CC-802E
                    Reset counter: 47
                    Mileage: 59997 km
                    Date: 2013.12.07
                    Time: 20:30:15
                    Speed: 12.0 km/h
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 18
                    Hex Value: 0x0000
                    Reset counter: 47
                    Mileage: 59997 km
                    Date: 2013.12.07
                    Time: 20:30:15
                    Speed: 12.0 km/h
                    Hex Value: 0x0001
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 18
                    Hex Value: 0x0000
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Reset counter: 7
                    Mileage: 60026 km
                    Date: 2013.12.16
                    Time: 17:54:56
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 156
                    Hex Value: 0x0000
   Revision: 00001K02
   Coding: 0010001048
   VCID: 7CFD00CAF7C597AFC5-8028
   Revision: BD421001
   VCID: 4183B13ED8A73A47D6-8014
   Coding: 00B795
   Coding: 0228DD
01259 - Fuel Pump Relay (J17)
                    Fault Status: 00101001
                    Reset counter: 46
                    Mileage: 59997 km
                    Date: 2013.12.07
                    Time: 19:35:22
                        Term 15 Off
                    Voltage: 12.15 V
   Coding: 0012595
   VCID: 4E999A02D9F9D53F5B-801A
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 13
                    Mileage: 59997 km
                    Date: 2013.12.07
                    Time: 20:30:31
   Coding: 018A270000
   VCID: 72E12EF2A581D1DF9F-8026
   Coding: E20000
365080 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
                    Reset counter: 46
                    Mileage: 59997 km
                    Date: 2019.07.17
                    Time: 19:22:07
   Coding: 240F00
   VCID: 2C5DF08A4725C72F15-8078
9453074 - Fuel Level Sensor 1
          B103E 1B [008] - Resistance Too High
                    Reset counter: 46
   Coding: 469006
   VCID: 78F51CDACBFDBB8FA1-802C
                    Fault Frequency: 16
                    Mileage: 59997 km
                    Date: 2013.12.07
                    Time: 19:03:31
   VCID: 3973D9DE707762879E-806C
   Coding: 020100
   VCID: 2A51F69245D1D91FE7-807E
   VCID: 254B05AE24CFF667CA-8070
   Coding: 0004B7
   VCID: 6DDB3D8EBCBF0E2742-8038
   Slave Driver:
   Coding: 010490
   Coding: 0000258
   VCID: 3F87B7C66E534CB7A0-806A
                    Fault Status: 11101101
                    Fault Frequency: 15
                    Reset counter: 7
                    Mileage: 59997 km
                    Date: 2013.12.07
                    Time: 20:30:16
                    RPM: 1476 /min
                    Speed: 12.0 km/h
                    (no units): 7.0
                    Voltage: 13.90 V
   Coding: 00000008
   VCID: 6FE72786BEB3FC3770-803A
   Coding: 0004B6
   VCID: 6ED93A82B1B9F53F7B-803A
   Slave Passenger:
   Coding: 010490
   Coding: 0022156
   VCID: 3669D2E241698DFF73-8062
                    Fault Status: 01101101
                    Fault Frequency: 13
                    Reset counter: 7
                    Mileage: 59997 km
                    Date: 2013.12.07
                    Time: 20:30:15
                    Voltage: 13.90 V
                    Count: 104
                    Speed: 12.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
02432 - Supply Voltage for Left Parking Brake Motor (V282)
                    Fault Status: 00101011
                    Reset counter: 47
                    Mileage: 60026 km
                    Date: 2013.12.16
                    Time: 17:48:41
                    Voltage: 11.70 V
                    Count: 29
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   VCID: 3777DFE68E6374F768-8062
   Coding: 350000
   Coding: 350000
13705985 - Databus
          U1123 00 [137] - Received Error Message
                    Fault Frequency: 14
                    Reset counter: 7
                    Mileage: 59997 km
                    Date: 2019.07.17
                    Time: 20:30:14
   VCID: 356BD5EE946F86E77A-8060
End-------------------------(Elapsed Time: 03:09)--------------------------
Wednesday,07,August,2019,12:55:23:12016
          65 72
               U1017 - 000 -
                    Temperature: 23.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 11.684 V
Readiness: 1110 0101
   Component: J104   C2 450M V408 0030
   Coding: 0000396
                    Reset counter: 8
                    Mileage: 60029 km
                    Date: 2013.12.28
                    Time: 18:44:23
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 156
                    Hex Value: 0x0000
   Revision: 00001K02
   Coding: 0010001048
   Revision: BD421001
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012595
            000 - - - MIL ON
                    Mileage: 60029 km
                    Date: 2013.12.28
                    Time: 18:43:21
   Coding: 018A270000
   Coding: E20000
   Coding: 240F00
   Coding: 469006
                    Mileage: 60029 km
                    Date: 2013.12.28
                    Time: 18:45:13
   Coding: 020100
   Coding: 0004B7
   Slave Driver:
   Coding: 010490
   Coding: 0000258
                    Reset counter: 8
                    Mileage: 60029 km
                    Date: 2013.12.28
                    Time: 18:43:21
                    (no units): 4.0
                    Voltage: 11.80 V
   Coding: 00000008
   Coding: 0004B6
   Slave Passenger:
   Coding: 010490
   Coding: 0022156
                    Fault Frequency: 12
                    Reset counter: 8
                    Mileage: 60027 km
                    Date: 2013.12.24
                    Time: 00:11:43
                    Voltage: 12.10 V
                    Count: 104
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 350000
   Coding: 350000
13705985 - Databus
                    Fault Frequency: 10
                    Reset counter: 8
                    Mileage: 60027 km
                    Date: 2019.08.03
                    Time: 00:11:42
End-------------------------(Elapsed Time: 03:06)--------------------------
8716valver
New Member
Time to measure wiring.
Maybe so. This whole thing is so odd because it started minutes after I forced evap and sai readiness. We unplugged from the inspection station obd cable, backed it out of the garage and boom the dash was all lit up.
