Lane Assist Coding
   #21
hadez16
C?ID=289891
I had a customer who retrofitted the stalk and I did the coding for Lane Assist, and the car did not have side assist.
   #22
Mike_Jones
C?ID=18137
Did you take a scan of the car by any chance?
   #23
Mike_Jones
C?ID=18137
Finally sorted
OK Finally got to the end of this and am surprised others didn't trip over the same issue. To recap, my lane assist required me to fit the image processing module but the camera was already in the car for matrix beam. After completing the install the lane assist indicator sometimes flickered and the MMI showed Lane Assist not Active Lane Assist and also regularly went to grey (unavailable).
The problem was the camera coding which within VCDS has a dropdown box to select lane assist. If you use the shortcut to enable or disable lane assist it will set byte 0 bits 0 and 1 either to 00 (not installed) or 01 (installed). However by looking at a number of other cars including my own A8 these cars had a bit setting of 10 which is not a configurable option within VCDS. Have chosen this setting and removing all my other efforts Lane Assist is now fully working. I hope this helps someone, took me a month to resolve. Done with retrofits for a bit having had a similar nightmare with Kessy, will do another post on that one outcome successful.
   #24
hadez16
C?ID=289891
I am sure that the experimental labels that are accessible with a new generation Interface will reveal what Hex 10 does mean in the camera coding.
I did not notice that difference.....sorry....
Thank you very much for the resolution
   #25
QBAelectric
Poland
C?ID=71800
I have an Audi A6 2013.
I also have an issue with the Lane Assist icon flickering for a long time.
Can you confirm the problem is with the coding as in the attached photos? Instead of the encoding that I have 01111001 it should be 01111010?
   #26
QBAelectric
Poland
C?ID=71800
I confirm, changing the coding solved the problem. Vcds has a problem with this.
   #28
ahmedmph
Dubai, UAE
C?ID=234898
Greetings All
I have a 2016 A7 and I am retrofitting Active Lane Assist + Traffic sign recognition, I have Led Matrix lights and adaptive headlights so have the camera in the windscreen . I installed the loom from KUFATEC and a used 8E-Image Processing unit and stalk and new steering slip ring.
all codings are accepted as it should be, but still both Active Lane Assist + Traffic sign recognition still not working
i have video cable error in Image processing control unit which i think is the main reason, cable was provided by KUFATE
here is my full car scan maybe coding is wrong somewhere if any one can help
Tuesday,20,December,2022,15:24:52:27351
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
VIN: WAUSGCFC2GN020932   License Plate:
Mileage: 137949km-85717mi   Repair Order:
Gateway Installation List:  4G8 907 468
17-Instruments -- Status: Cannot be reached 0100
82-Head Up Display -- Status: OK 0000
Tuesday,20,December,2022,15:30:22:27351
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 52
          53 55 5F 62 6C 6D 72 82 85 88 89 8E 8F 90 47
VIN: WAUSGCFC2GN020932   Mileage: 137949km-85717miles
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G2 907 551 B    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0002
   Revision: --H10---    CVN: 800590BF
   Coding: 1A2500340526010B3000
   ASAM Dataset: EV_ECM30TFS0214G2907551B 002002
   ROD: EV_ECM30TFS0214G2907551B_002.rod
   VCID: 2A0D0E5EBC79842B956-807E
   VINID: 9D19635D3593097780080243086C356868
Readiness: 1010 0001
   Part No SW: 4G0 927 166 D    HW: 0B5 927 156 K
   Component: 0B5 30TFSIRdW H03 0011
   Revision: --H03---    CVN: 00009481
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2E05024E8091E80B49E-807A
   Coding: 44A68E43226571C29B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF49F2210F6773A4C-8014
   Part No SW: 4H0 907 064 FT    HW: 4H0 907 064 ET
   Component: BCM2 2.0      H36 0560
   Coding: 05AA6F0E000000000000
   VCID: 00598CF66A05AE7BEB2-8054
   Part No SW: 4G8 959 760 B    HW: 4G8 959 760 B
   Component: MEM-BFS       H04 0157
   Revision: AA000000    Serial number: 00000139490519
   Coding: 0018320000006201000001010101112030303333283333
   VCID: 392F2112495F3FB3ECC-806C
   Part No SW: 4G0 820 043 CC    HW: 4G0 820 043 CC
   Serial number: 22031700041642
   Coding: 660331783D0000
   Shop #: WSC 00046 000 00000
   VCID: 629DA67E84C91C6B9D6-8036
   Part No SW: 4H0 907 063 DF    HW: 4H0 907 063 AF
   Revision: 13020001    Serial number: 00001047371701
   Coding: 0105C01440349FE0C1014080A0001800CF9CC3082E0802010000089461011302004000010B0000
   Shop #: WSC 00046 123 12345
   VCID: 6FBBDF4A479BA103028-803A
   Component: WWS57X 150412  H37 0080
   Serial number:         150415151900
   Coding: 0045F7
   Serial number: 23926181
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 15 04 2015  00000842
   Serial number: E04845A7000000000001
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0070
   Revision: --------    Serial number: 56291509901611
   Coding: B82310
   ASAM Dataset: EV_EPHVA2CAU64X0000 001011
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 35372D2265C7DBD3084-8060
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1004G0FL
   Coding: 30333046313130313233554A304C34473853
   VCID: 3B233B1A43E30DA3FE0-806E
   Serial number: 3575HRB404R3761S5H7C
   Serial number: 3585HRB404R3761S8H4D
   Serial number: 3515JRB405P370PI70IB
   Serial number: 3525JRB4059370PIIGHM
   Serial number: 3554VRB405T36RTAAOI-
   Serial number: 3564VRB405R36RTAJ8FP
   Revision: --------    Serial number: 90372NAD000C8
   Coding: 0000F4
   VCID: 38292416725526BB132-806C
   Serial number: 24 03 2015  10078355
   Part No SW: 4G8 920 933 N    HW: 4G8 920 933 N
   Component: TBenRdw       H08 0106
   Revision: 04001037    Serial number: 658230415596008
   Coding: 13BF11024B478008010500
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
Address 19: CAN Gateway (J533)       Labels:| 4H0-907-468.clb
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001820607
   Coding: C0CF073018
   GVL: FFA1E84CDCA368CD40040000
   ASAM Dataset: EV_GatewPkoUDS 001024
   VCID: 75B7ED2225479BD3C84-8020
   Serial number: 5708916203
   Voltage stabilizer:
   Serial number: 150208000000000005BC
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 29041500040001
   Coding: 20
   VCID: 3D2735025DF70393C04-8068
   Component: MEM-FS        H04 0157
   Revision: AA000000    Serial number: 00000139490516
   Coding: 00183B0000016201000001010101112030303333203333
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8209CXKZ
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 36352A2E78C1D0CB01E-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H06 0060
   Serial number: 0365807371
   Coding: 040211
   VCID: 392F211249DF3FB3ECC-806C
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0060
   Serial number: 0366540028
   Coding: 040211
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F5F035E00628202080412
   VCID: 45D75DE235A74B53984-8010
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0015720471
   Coding: 101101010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0366940821
   Coding: 01000E3820B9B085C3300A840A030D470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST00090LRL00000
   Coding: 901F02
   Subsystem 2 - Part No SW: 4G0 947 135 F    HW: 4G0 947 135
   Serial number: 0000000AP00012714567
   Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA120634000012835917
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93496837
03615 - Rear Right Reading Light
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:59
   Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
   Component: TSG BF        H04 0507
   Coding: 011F5F035E00628202080402
   VCID: 44D140E63E9D725B8FA-8010
   Revision: --------    Serial number: 00000001444079
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D0705428D979313704-8078
   Coding: 05FA02202A100200
   VCID: 343110266EBDC2DB3FA-8060
   Left LED Headlamp Power Output Stage 1:
   Coding: E02100
   Right LED Headlamp Power Output Stage 1:
   Coding: E02100
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E02100
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E02100
   Part No SW: 4G1 035 046 M    HW: 4G1 035 046
   Component: MU-H-LN-RW    041 1425
   Serial number: A592D0F7515077
   Coding: 0175030C0000000013110002004F00102F010CE4F17087007E
   VCID: 2B030B5AB3839D236E0-807E
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 803 BM    HW: -----------
   Component: ROW 2022/2023  --- 0101
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Serial number: AUZ8Z9FY801DJY
   Multimedia system control head:
   Serial number: 90349ODL000MP
   Compact disc data bank:
   Component: Gracenote2  --- 4013
7182 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Mirror (0x0E) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:24:01
                    Voltage terminal 30: 13.9 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
   Coding: 010F1D024000628202080002
   VCID: 47CB57EA0FAB59436A8-8012
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0223449
   Coding: 0217000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   ROD: EV_CamerSysteTopViewAUDI.rod
9616786 - Surroundings Camera Front
          B127C F0 [009] - Calibration Failed
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:57
                    Voltage terminal 30: 13.6 V
9616787 - Surroundings Camera Rear
          B127D F0 [009] - Calibration Failed
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:57
10489856 - No Basic Setting
          B2010 00 [009] - -
          [TopView system not calibrated]
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:57
   Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
   Component: HDSG-Modul    H14 0049
   Revision: 11014001    Serial number: 110500560
   Coding: 0A3305C022
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 45D75DE235274B53984-8010
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G8 919 604 M    HW: 4G8 919 604 M
   Component: HeadUpDisplay H07 0306
   Coding: A78000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7.rod
   Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
   Component: DPC-SG        H27 0081
   Coding: 72160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C010846B68D9A1B67A-8078
   Part No SW: 4G8 881 073     HW: 4G8 881 073
   Component: P2G           H02 0032
   Serial number: 0F4F2AE
   Coding: 662FF0
   ASAM Dataset: EV_P2GDriveSideFrnt 001006
   ROD: EV_P2GDriveSideFrnt.rod
   VCID: 6E85C24E4011A80B09E-803A
   Valve block 1 in front seat driver side:
   Subsystem 1 - Part No SW: 4G8 907 181     HW: 4G8 907 181
   Component: PSLB  H02 0023
   Serial number: 00000000000000F3G3PB
   Serial number: 0F482XA
   Coding: 262FF0
   ASAM Dataset: EV_P2GPasseSideFrnt 001006
   ROD: EV_P2GPasseSideFrnt.rod
   Valve block 1 in front seat passenger side:
   Serial number: 00000000000000F3U2NV
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0092
   Serial number: 005000621311157
   Coding: 0340B11A1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0148 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [QSP_Timeout]
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:59
                    Outside temperature: 30.0 °C
                    Voltage terminal 15: 13.6 V
                    Control Module temperature: 47.0 °C
0161 - Video Cable for Image Processing
          C1107 02 [009] - Signal Failure
          [No_camera_found_on_startup]
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:24:07
                    Outside temperature: 30.5 °C
                    Voltage terminal 15: 13.7 V
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F193291AFF7F354C-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323D163E94A9CCEB2D6-8066
   Part No SW: 4G5 035 223 E    HW: 4G5 035 223
   Component: MIB2_amp_P    H02 0440
   Serial number: 00000000033587
   Coding: 0175030A018AF02A5A0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
   VCID: 2411E066DE5D525BAFA-8070
1635 - Data Set Implausible
          B2012 00 [009] - -
          [Steuergerät (DatensatzDownload) - Datensatz unplausibel für ANC]
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:57
                    Voltage terminal 30: 12.3 V
1632 - Active Noise Cancellation
          B1765 F0 [009] - Engine Speed Implausible
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:24:02
End----------(Elapsed Time: 02:23, VBatt start/end: 13.7V/13.8V)-----------
