Discover Pro service menu - possible to reset update logs?
Drive
Norway
C?ID=177241
Is it possible to remove the logs from the service menu? To get there hold MENU for 5 seconds then choose software/updates.
You will basically see a list of all updates made to the Discover Pro unit, including firmware, patches and map upgrades.
Can we use VCDS to reset this list somehow?
Regards,
Drive
PetrolDave
Westbury, UK
C?ID=1423
Can I ask why you would want to delete this list from your Discover Pro?
Drive
Norway
C?ID=177241
Because Im downgrading an update and the upgrade-entry wont go away. It creates confusion. No way to do this, Ross-tech developers?
Drive
Norway
C?ID=177241
No one? Not possible to clear logs on the MIB?
Do we have any scan data showing exactly what "Discover Pro" you have?
Maybe this Basic Setting?
IDE08813-ENG117470 -- Formatting partitions of internal memory
There should be number of sub-choices with that:
; Navigation Data Base,
; Jukebox,
; Data base backup,
; GracenoteDB,
; Speech dialog system,
; Online Services,
; Logbook,
; Cover cache memory,
; Address book,
; Google Earth,
; Over The Air Update,
But I do not know if any of them will have the effect you desire, and if you play with this, it's entirely at your own risk.
Spacewalker
Poland
C?ID=159607
not possible via VCDS, but possible via root access
Drive
Norway
C?ID=177241
How can I get root access? Can you help?
In IDE08813-ENG117470 -- Formatting partitions of internal memory - What is the "logbook" entry for?
TBAx
C?ID=287144
The driver's logbook, I don't know if it is used outside of Germany, where it is named "Fahrtenbuch".
However I have never seen this function "in the wild" so I am not sure, if this even does anything.
Spacewalker
Poland
C?ID=159607
:thumbs:
not a time, not a place.
