Adaptation Problem in 8E central electronics -09 with HEX V2 adapter
The Passat's CCM is quite different than the Audi's.
I would try increasing Blk_Int more. I believe VCDS will accept values as high as 500 or thereabouts. Note that leaving it like that will make things dog-slow in all control modules, so you probably don't want to leave it that way, but it would sure be interesting to know if a higher value fixes the problem in that CCM, and if so, how high the value needs to be.
Ar393
C?ID=398414
So it will take values from 25 to 750 based on the little pop-up.
Of the 30 or so tries I attempted with changing the values from 25 to 500, either address 046 by itself or with an auto-scan of multiple addresses, I only once got it to give me all 4 sub systems.
The value of Blk_Int was 25. it was an auto-scan of the single address.
Sunday,24,May,2020,12:38:26:62646
VIN: WAUVT68E73A346543   License Plate:
Chassis Type: 8E (46 only)
Scan: 46
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1311
   Coding: 26444
   Shop #: WSC 12345
   VCID: 72BDDC5E6DB06AFB556-4B00
   Component: Tõrsteuer.FS BRM 0003
   Component: Tõrsteuer.BF BRM 0003
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0003
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0003
01134 - Alarm Horn (H12)
            29-00 - Short to Ground
01561 - Rear left door
01562 - Rear right door
End----------(Elapsed Time: 00:19, VBatt start/end: 13.4V/13.4V)-----------
Thanks.
AR
