Help retrofitting on 2013 Touareg TDI
tamorgen
C?ID=9595
Good evening,
I've been wanting to retrofit several features on my 2013 Touareg TDI Exec. A while ago, I installed the Area View camera, and that went pretty well. The big project I've been waiting on is the Lane Assist camera. A few weeks ago, I finally got the rock hit that insurance paid for the window to be replaced, as well as calibrating the lane assist system, so I got the correct windshield for the Lane Assist, and wired it up according to ELSA, or at least I thought I did...
I'm also trying to retrofit ACC, and I took this opportunity to do the wiring at the same time. That's all wired up with the factory bumper harness, and then there are 4 wires that run back...power, two Flex-ray wires, and ground, which I grounded to the wall in the engine bay.
I installed the Camera itself, 7P6 907 217 B, the Image Processor, and the Pitch sensor, all straight out of EKTA.
I though that I had gotten it right, but the coding may be wrong. I'm not sure at this point.
As a baseline, here is my original coding, at least going back to the Area View retrofit.
Thursday,25,May,2017,16:26:49:03710
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86(VMWare)
VCDS Version 17.1.3.0
VIN: WVGEP9BP7DD004878   License Plate: MAMATANK
Mileage: 153430km-95336mi   Repair Order:
Chassis Type: BP (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 47 52 53 55 56
          5F 62 65 69 6C 6D 72
VIN: WVGEP9BP7DD004878   Mileage: 153430km-95336miles
Address 01: Engine (J623-CNRA)       Labels: 059-907-401-V2.clb
   Part No SW: 7P0 907 401 K    HW: 7P0 907 401 K
   Component: 3.0TDI EDC17  H19 0003
   Revision: 56H19---
   Coding: 292A4012233600050000
   Shop #: WSC 05072 444 11327
   ASAM Dataset: EV_ECM30TDI0117P0907401K 001004
   ROD: EV_ECM30TDI0117P0907401K.rod
   VCID: 3777DDCE8E43FAF918-8063
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 AK    HW: 0C8 927 750 AK
   Component: AL1000 AISIN  001 2269
   Coding: 001368
   Shop #: WSC 43979 001 1048576
   ASAM Dataset: EV_TCMAL991031 002114
   ROD: EV_TCMAL991031_002.rod
   VCID: 75EB17C6D4CF48E9CA-8021
Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
   Part No SW: 7P0 907 379 M    HW: 7P0 907 379 A
   Component: MK25A         H36 0436
   Revision: --------    Serial number: 420720010EC815
   Coding: 5B7613C349242557DAFCC89A92DAA4407700
   Shop #: WSC 31414 790 00001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4797AD0EFEA38A7968-8013
   Part No SW: 4H0 907 064 CK    HW: 4H0 907 064 CK
   Component: BCM2 2.0      H32 0421
   Coding: 0D860016000000000000
   VCID: 74ED2AC2D7B551E1FD-8021
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2312000154943013
Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: B686200A80
   VCID: 7EF908EAE1F90BB19B-802B
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0111
   Revision: 15012002    Serial number: 00000001586921
   Coding: 26001012933C5D010020180300005D0C431C660882010261000000020000
   VCID: 73EF29DED2BB56D9E4-8027
   Component: WWS    120711  31  0020
   Serial number: 90243400120719131750
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10420600
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
   Component: E1 - LDS  H02 0040
   Serial number: 00000000002304140008
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R16DW07
Address 10: Park/Steer Assist (J446)       Labels: 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28261219601184
   Coding: 510501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 4281BC1AD581AF51BF-8017
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag025 H05 0025
   Revision: --------    Serial number: 003L0004ACDK
   Coding: 000000000000000000000000000000003235
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 4183B316D087B449A6-8015
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R1242708U3B
   Serial number: 3575LRB40511G1DOBH33
   Serial number: 3585LRB405L1G1DM9HFW
   Serial number: 3515RRB405J1D2ASDHN%
   Serial number: 3525RRB405J1D2ASMGM7
   Serial number: 3555NRB405R1GCDMCOFF
   Serial number: 3565NRB40631GCDM3PJW
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372LLB000VA
   Coding: 000C15
   Shop #: WSC 09145 444 103404
   VCID: 3875DEF28B5DF58111-FFFF
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  0027
   Serial number: H0
Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 981 F    HW: 7P6 920 981 F
   Component: Kombi         H13 0318
   Revision: 13240077    Serial number: 658100812592019
   Coding: 8B7733022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001017
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 4085B612DB8DBD41A9-8015
   Part No SW: 7P6 907 530 F    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H11 6028
   Revision: --------    Serial number: 00000000639722
   Coding: 0001037500
   Shop #: WSC 49771 001 1048576
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3B7FC1FEB26BDE99FC-806F
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650867664
   Revision: AA000000    Serial number: 00000035065047
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 346DEAC2973511E13D-8061
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7P6 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH02 0110
   Revision: 00H02000    Serial number: 6PZ 010 316-01
   Coding: 0010151
   Shop #: WSC 01730 666 44235
   VCID: 7EF908EA29F90BB19B-802B
   Subsystem 1 - Part No: 7P6 907 568
   Component: J770  SWA Slave H01 0110
   Subsystem 2 - Serial number: 6PZ 010 316-21
   Subsystem 3 - Serial number: 5F26.09.0900H010003C520076ÿ
   Subsystem 4 - Serial number: 520076ÿ
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000129655805
   Coding: 011D17205E00453005080000
   VCID: 448DBA02C795A1618D-8011
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Component: BCM2 2.0      H32 BCM2 2.0      H32 04210421
   Revision: 00002001    Serial number: 0180526694
   Coding: 0186123A28B9509580A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 1981215567
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO17640530
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Coding: 191100
No Faults Found
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H01 0090
   Revision: 00001001    Serial number: 10811001712705
   VCID: 75EB17C6DCCF48E9CA-8021
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000129629168
   VCID: 3B7FC1FEBA6BDE99FC-806F
Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1272700340
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 3669D0CA894903F103-8063
   Slave 3:
   Coding: 010A00010F000400
   VCID: 7CFD02E2F7E519A1B5-8029
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 130000
   Revision: AB001007    Serial number: 156G10C7618771
   Coding: 020007010000000001
   VCID: 244D1A8227D58161AD-8071
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 7P6 035 664 D    HW: 7P6 035 664
   Component: H-BN-NA       H45 0706
   Revision: --------    Serial number: 445HB0C7538995
   Coding: 020200050040E1EF41022B0E00000003F00001030000000000
   VCID: 3973DBF6B057EC89EE-806D
   Subsystem 1 - Part No: 7P6 060 884 D
   Component: NAR 2016  1302
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9M7900D6L
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000129597274
   Coding: 011C17200000253005080000
   VCID: 3A71C4FAB551E791E7-806F
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000088981
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3F87B5EEA673C2B9D0-806B
Address 69: Trailer (J345)       Labels: None
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000179994560
   Coding: 020D000000000000
Address 6C: Back-up Cam. (J928)       Labels: 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 D    HW: 7P6 907 441 D_
   Component: TopView       H05 0097
   Revision: 11001001    Serial number: 82330010114027
   Coding: 0100000000010002010102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
   VCID: 3A71C4FABD51E791E7-806F
10489856 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 119
                    Mileage: 153430 km
                    Date: 2017.05.25
                    Time: 16:13:59
                    Voltage terminal 30: 14.2 V
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 192200284
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D7BCFE6AC7FD0A9C2-8069
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000129584962
End-------------------------(Elapsed Time: 06:47)--------------------------
This is my current coding:
Friday,21,June,2019,21:51:30:03710
VCDS Version: 19.6.0.2 (x64)
VIN: WVGEP9BP7DD004878   License Plate: LANE-TAKE3
Mileage: 244482km-151914mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
          5F 62 65 69 6C 6D 72 85 8E
VIN: WVGEP9BP7DD004878   Mileage: 244482km-151914miles
10-Park/Steer Assist -- Status: Not registered 0001
85-On Board Cam. -- Status: Not registered 0011
8E-Image Processing -- Status: Cannot be reached 0100
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Component: 3.0TDI FSA    H19 0011
   Revision: 56H19---
   Shop #: WSC 09145 444 00000
   ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
   VCID: 3777DDCE8E43FAF760-8062
4332 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [039] - -
                    Mileage: 244482 km
                    Date: 2019.06.21
                    Time: 21:45:27
                    Engine speed: 759.00 /min
                    Normed load value: 40.8 %
                    Coolant temperature: 89 °C
                    Intake air temperature: 49 °C
                    Voltage terminal 30: 13.640 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 6
                    Active brake system error status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 3
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_RUNNING
   Component: AL1000 AISIN  001 3398
   Coding: 001368
   Shop #: WSC 26340 002 1048576
   ASAM Dataset: EV_TCMAL991031 002115
   VCID: 75EB17C6D4CF48E7B2-8020
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   VCID: 4797AD0EFEA38A7710-8012
   VCID: 74ED2AC2D7B551EF85-8020
   Coding: B686200A80
   VCID: 7EF908EAE1F90BBFE3-802A
   VCID: 73EF29DED2BB56D79C-8026
   Coding: 004DBD
   Coding: 025223
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 120
                    Mileage: 244482 km
                    Date: 2019.06.21
                    Time: 21:45:00
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Coding: 510501
   VCID: 4281BC1AD581AF5FC7-8016
   VCID: 4183B316D087B447DE-8014
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372PL900040
   Coding: 000CDD
   Shop #: WSC 12345 123 12345
   VCID: 3875DEF28B5DF58F69-806C
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0201679
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 4085B612DB8DBD4FD1-8014
   Coding: 0001037500
   VCID: 3B7FC1FEB26BDE9784-806E
0276 - FlexRay Databus
          U1032 00 [009] - Initialization Failed
                    Reset counter: 120
                    Mileage: 244482 km
                    Date: 2019.06.21
                    Time: 21:45:28
                    Voltage terminal 30: 13.6 V
                    Voltage terminal 15: 13.7 V
                    Control Module temperature: 42 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
0021 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 120
                    Mileage: 244482 km
                    Date: 2019.06.21
                    Time: 21:45:32
                    Voltage terminal 30: 13.7 V
                    Voltage terminal 15: 13.8 V
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   VCID: 346DEAC2973511EF45-8060
   Coding: 0010151
   VCID: 7EF908EA29F90BBFE3-802A
   VCID: 448DBA02C795A16FF5-8010
03021 - Local databus 3
                    Fault Status: 01101100
                    Reset counter: 120
                    Mileage: 244482 km
                    Date: 2019.06.21
                    Time: 21:45:31
   VCID: 75EB17C6DCCF48E7B2-8020
   VCID: 3B7FC1FEBA6BDE9784-806E
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 3669D0CA894903FF7B-8062
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   VCID: 7CFD02E2F7E519AFCD-8028
   Coding: 130000
   Coding: 130000
   VCID: 244D1A8227D5816FD5-8070
   VCID: 3973DBF6B057EC8796-806C
   VCID: 3A71C4FAB551E79F9F-806E
   VCID: 3F87B5EEA673C2B7A8-806A
Address 69: Trailer (J345)       Labels: Redir Fail!
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   VCID: 3A71C4FABD51E79F9F-806E
          B2010 00 [009] - -
                    Reset counter: 120
                    Mileage: 244482 km
                    Date: 2019.06.21
                    Time: 21:45:28
                    Voltage terminal 30: 13.8 V
   Coding: 0533314003
   VCID: 3D7BCFE6AC7FD0A7BA-8068
   Part No SW: 7P6 907 217 B    HW: 7P6 907 217
   Component: DPC-SG        H24 0035
   Coding: 4D070000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 3973DBF6B857EC8796-806C
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000007056214_4330
0719 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 120
                    Mileage: 244482 km
                    Date: 2019.06.21
                    Time: 21:45:29
                    Outside air temperature: -36.5 °C
                    Control Module temperature: 41.0 °C
0706 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 120
                    Mileage: 244482 km
                    Date: 2019.06.21
                    Time: 21:45:29
0724 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 120
                    Mileage: 244482 km
                    Date: 2019.06.21
                    Time: 21:45:29
0734 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 120
                    Mileage: 244482 km
                    Date: 2019.06.21
                    Time: 21:45:29
Address 8E: Image Processing
End-------------------------(Elapsed Time: 05:30)--------------------------
I'm getting some odd errors, in particular the engine malfunction code, which shouldn't have been affected by my installation. Obviously the CAN Gateway malfunction and Central Conv. malfunctions are a concern, as the coding may not be quite right with them as of yet. There are some Not Registered errors as well... the on-board cam, which I know has to be calibrated, so I'm assuming that's the issue, but I don't know.
I plan on going back this weekend and verifying the wiring from the Image Processor and the Pitch Sensor. I was pretty careful. All the wiring matched ELSA's color coding, and I checked the pinouts several times. Only thing I can think of is that a pin may have gotten pulled loose.
I know this is a lot, but I would appreciate any help. I know this is possible. There is a thread here where someone did it to a Q5, which is really just a more expensive Touareg.
I'd fix the "Not Registered" stuff first.
[Select]
[19-CAN Gateway]
[Installation List]
Scroll down to the modules that show Not Registered and put a check-mark next to each of them.
[Save Coding]
Once you've done that, post a fresh scan.
A Q5 is a similar, but there are differences. Here's a 2015 T'Reg TDI Exec that came with much of the stuff you're retrofitting installed from the factory for comparison:
Thursday,12,March,2015,17:33:51:15495
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WVGEP9BP9FD003413   License Plate: 20157P-HUC
Mileage: 130km-80mi   Repair Order: 14.10.2
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 52 53 55
          56 5F 62 65 69 6C 6D 72 85 8B 8E
VIN: WVGEP9BP9FD003413   Mileage: 130km-80miles
Address 01: Engine (J623-CNRB)       Labels: None
   Part No SW: 7P1 907 401 B    HW: 7P0 907 401 K
   Component: 3.0TDI EDC17  H21 0001
   Revision: 56H21---
   Coding: 292A4012237600050000
   ASAM Dataset: EV_ECM30TDI0117P1907401B 001002
   ROD: EV_ECM30TDI0117P1907401B.rod
   VCID: 2F66D8207621CB59C75-807A
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 0C8 927 755     HW: 0C8 927 755
   Component: AL1000 AISIN  100 2817
   Coding: 010200000C008400000000000000000000000000
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_VW52.rod
   VCID: 6ED80524B1AB82518C3-803B
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 42794437538579
   Coding: 5B7613C349246F56DAF8C89492D5F6607301
   ASAM Dataset: EV_MK25AXT 010001
   VCID: 4C9CAFACE7F79041C27-8019
   Slave 1:
   Part No SW: 4H0 907 064 FK    HW: 4H0 907 064 EK
   Component: BCM2 2.0      H36 0551
   VCID: 77F62040C6F1C3995F5-8022
   Part No SW: 7P6 907 040 CD    HW: 7P6 907 040 CD
   Component: Klima 2 Zonen H23 1406
   Coding: B686200A80
   VCID: 78F4237CC3EFCCE156F-802D
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Revision: 22020001    Serial number: 00000929331501
   Coding: 26000096963C5D010020480300005D4C431C6608A2014261000000008040110000000000000000
   VCID: 6AD0093485436E71D0B-803F
   Component: WWS    141012  033 0021
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AC    HW: 7P6 941 431 AC
   Component: USHL4.2  H30 0030
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28201429301726
   Coding: 510D04
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   VCID: 448C878CCFA758010A7-8011
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 7P6 907 561 C    HW: 7P6 907 561
   Component: ACC3          H21 0400
   Coding: 3701010101
   ASAM Dataset: EV_AdaptCruisContrVW526 002012
   ROD: EV_AdaptCruisContrVW526.rod
   VCID: 3C7CFF6CB75720C1727-8069
   Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
   Component: VW10Airbag04Z H10 0043
   Revision: --------    Serial number: 003NK001DWFL
   Coding: 00000000000000000000000000000000345A
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526.rod
   VCID: 438E8490CAA95F3933D-8016
   Serial number: 5850000R146270L8LY
   Serial number: 3575LRB404P2RDNM6H8F
   Serial number: 3585LRB40512R8PG60JL
   Serial number: 3517ARB40532T8H4LPT$
   Serial number: 3527ARB40512T8H410U.
   Serial number: 3557BRB404T2T32GFHS3
   Serial number: 3567BRB404V2T32GFA7L
   Part No SW: 4H0 953 568 M    HW: 7P6 953 507 AJ
   Component: Lenks.Modul   H06 0005
   Revision: --------    Serial number: 01374NJN0000Z
   Coding: 000CDD
   VCID: 3D7AF268A44D29C9459-8068
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Part No SW: 7P6 920 983 D    HW: 7P6 920 983 D
   Component: Kombi         H13 0515
   Revision: 13240300    Serial number: 658171014592006
   Coding: 8B5733026F08CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001022
   VCID: 40848B9CDBBF44212EF-8015
   Part No SW: 7P6 907 530 N    HW: 7P6 907 530 G
   Component: GW-CAN-L-FR-M H13 6042
   Revision: --------    Serial number: 00000001607498
   Coding: 000103AD00
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 31282026205701913065
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000123120683
   VCID: 346CD74C9707E881BA7-8061
Address 3C: Lane Change (J769)       Labels: None
   Part No SW: 7P6 907 566 A    HW: 4H0 907 566 F
   Component: SWA Master    H06 0021
   Serial number: 0350237749
   Coding: 030221
   ROD: EV_LaneChangAssis.rod
   VCID: 3F868860A6413BD9575-806A
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000124285069
   Coding: 011D17205E00453005080001
   VCID: 7AF03974F5E3DEF120B-802F
   Revision: 00002001    Serial number: 0350252359
   Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719 A    HW: 7P6 959 719 A
   Component: GTO BT  H20 0059
   Component: J245 PS30.062  H01 0008
   Coding: 191100
   Component: J394 PS30.062  H01 0008
   Coding: 191100
   Subsystem 5 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Revision: 00001001    Serial number: 10811002077008
   VCID: 75EA2A48DCFDB1894D9-8020
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000123832039
   VCID: 489493BCFB8F7C61E6F-801D
   Revision: 00000000    Serial number: C14A2500033
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 3668ED44897BFA91843-8063
   Slave 3:
   Component: AFS-ECU       H01 0091
   Coding: 012A02010B000400
   Component: LeiMo links  H01 0005
   Coding: B00000
   Component: LeiMo rechts  H01 0005
   Coding: B00000
   Revision: AB001007    Serial number: 156J00E8084038
   VCID: 244C270C27E778012A7-8071
   Part No SW: 7P6 035 664 G    HW: 7P6 035 664 A
   Component: H-BN-NA       H40 0881
   Revision: --------    Serial number: 273J-0EB003703
   Coding: 020200050040E9EF79022B0E00000003F00001030000000000
   VCID: 3C7CFF6CBF5720C1727-8069
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Subsystem 2 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
   Component: DU8 SV Touch  H52 0046
   Subsystem 3 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
   Component: CD-Database  5950
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000123848537
   Coding: 011817200000253005080000
   Part No SW: 7P6 907 273 H    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0002
   Serial number: 40000000003661
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_VW37.rod
   VCID: 41828E98D0B54D29211-8014
   Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
   Component: Anhaenger     H14 0137
   Revision: 7C001001    Serial number: 0349218696
   Coding: 0200000202000000
   ROD: EV_TrailFunctGener2Hella.rod
   VCID: 3776E0408E7103999F5-8062
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 7P6 907 441 G    HW: 7P6 907 441 G
   Component: TopView       H08 0115
   Revision: 11001001    Serial number: 82330JF0185592
   Coding: 0100000000010000010102000000
   VCID: 3D7AF268AC4D29C9459-8068
9617697 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 42
                    Mileage: 32 km
                    Date: 2015.02.27
                    Time: 14:28:29
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 293400833
   Coding: 0533314003
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000124486407
Address 85: On Board Cam. (J852)       Labels: None
   Component: DPC-SG        H26 0035
   Coding: 69020000
   VCID: 3972E678B86515E9691-806C
   Slave 1:
   Subsystem 1 - Part No: 7P6 .90 7.6 58
   Serial number: 000000007063072_4249
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 7P6 907 541 C    HW: 7P6 907 541
   Coding: 3701010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 002011
   ROD: EV_AdaptCruisContr2VW526.rod
   VCID: 3A70F974BD631EF160B-806F
Address 8E: Image Processing (J851)       Labels: None
   Part No SW: 7P6 907 107 B    HW: 7P6 907 107
   Component: BV-SG         H32 0035
   Serial number: 005000012609147
   Coding: 0AA118040000
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR.rod
End-------------------------(Elapsed Time: 05:39)--------------------------
tamorgen
C?ID=9595
Thanks Uwe, I'll check all that tonight.
On another note, what's the deal with: [New feature! Extended UDS fault detail is only supported by current gen. interfaces]?
I know there is a Hex-Net2, but is it needed for my generation of Touareg? I'd never seen that prior to the current VCDS release.
Do you need it? No.
Does it provide more/better information (that even the dealers' software does not!)? Yes.
tamorgen
C?ID=9595
I've made significant headway thanks to your 15 TDI Exec reference scan. I'm still not getting communication with 8B ACC2 or 8E Image processor. I'll need to make sure the connections are all correct, unless there is still just something wrong with my coding. I still don't understand the error message on 01 Engine either. I haven't made any changes to the engine or transmission coding.
          P1647 00 [039] - -
Monday,24,June,2019,21:36:39:03710
VIN: WVGEP9BP7DD004878   License Plate: CODING-UPDATE-6-24
Mileage: 244732km-152069mi   Repair Order:
VIN: WVGEP9BP7DD004878   Mileage: 244732km-152069miles
8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
   Revision: 56H19---
          P1647 00 [039] - -
                    Mileage: 244732 km
                    Date: 2019.06.24
                    Time: 21:30:28
                    Engine speed: 760.00 /min
                    Normed load value: 43.1 %
                    Coolant temperature: 90 °C
                    Intake air temperature: 53 °C
                    Voltage terminal 30: 14.120 V
   Coding: 001368
   Coding: B686200A80
   Coding: 004DBD
   Coding: 025223
   Coding: 510501
   Coding: 000CDD
   Coding: 8B7733026B08CF05020004
   Coding: 000103AD00
                    Reset counter: 124
                    Mileage: 244732 km
                    Date: 2019.06.24
                    Time: 21:30:27
                    Voltage terminal 30: 14.0 V
                    Voltage terminal 15: 14.1 V
                    Control Module temperature: 47 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Coding: 0010151
   Coding: 0187123A68B9509580A00620210000000000000000000000000000000000
   Coding: 191100
   Serial number:     WOO1745124+
   Coding: 191100
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 3:
   Coding: 130000
   Coding: 130000
                    Reset counter: 124
                    Mileage: 244732 km
                    Date: 2019.06.24
                    Time: 21:30:35
                    Bin. Bits: 00000000 00100000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
8389633 - Radio Frequency Interference
          C105C 00 [009] - -
                    Reset counter: 124
                    Mileage: 244732 km
                    Date: 2019.06.24
                    Time: 20:57:34
          B2010 00 [009] - -
                    Reset counter: 124
                    Mileage: 244732 km
                    Date: 2019.06.24
                    Time: 21:30:29
                    Voltage terminal 30: 14.1 V
   Coding: 0533314003
   Coding: 49020000
   Slave 1:
          U1111 00 [009] - -
                    Reset counter: 124
                    Mileage: 244732 km
                    Date: 2019.06.24
                    Time: 21:30:28
                    Outside air temperature: -35.0 °C
                    Control Module temperature: 50.0 °C
End-------------------------(Elapsed Time: 05:20)--------------------------
Coding problems generally won't result in a total lack of communications, and.. I don't see a 13-Auto Dist. Reg in that scan either.
I wouldn't worry about that before you get the rest squared away. In the end though, I would expect the ECU itself will need to be told the car has ACC.
tamorgen
C?ID=9595
I wouldn't expect coding to provide a total lack of comms either, but you never know. I'll have to check the Installation List. I must have missed 13-Auto Dist. Reg in my comparison. The Touareg has a master and slave ACC sensor. It might be possible that if the 13-Auto Dist. Reg isn't enabled in the Instatllation List, the 8B ACC2 (slave I'm assuming) won't have communications, but I won't know for sure until I correct the installation list. More to report this evening after work.
Seems to me that if 13 were talking at all, it would also show up in the Installation List as "Not Registered". So my money is on wiring or power problems.
tamorgen
C?ID=9595
I would tend to agree with that assumption.
  • I pulled off the front bumper cover, verified that I didn't do something stupid like putting the wrong module on the wrong side. They are correct.
  • I've verified the pinout inside the engine compartment from the OEM harness for the ACC, to the manufactured harness from that housing to the firewall. Unless VW didn't make the OEM harness correct (always possible), then that's not it. I verified there was power at that harness point (reads 12V, but I might not be getting a good connection on the pin.) ELSA indicates it should be 15V from SB49.
  • I've verified the pinout at the image processing control module as well. Getting 15V at that connection.
That leads me to digging back into getting at the CAN Gateway (J533), and making sure those 4 FlexRay connections are pinned correctly. It's pretty much the only thing left.
The other possibility, is that this CAN Gateway doesn't support ACC or the Image Processor, although I've sort of ruled that one out, since I can add them in the Installation List. I also know it's a higher end one, since my car has KESSY.
Only option I have left is to cool off, have some dinner, and become a contortionist again and pull out the CAN Gateway from behind the steering column.
tamorgen
C?ID=9595
Well, I went through the wiring at the CAN Gateway, and everything appears to be correct based upon the ELSA wiring diagrams. All the wires are secure in their correct locations. No change. This isn't making any sense.
darkchina811
ITALY
C?ID=333184
there is no point in any car where you should read 15 Volts. if Elsa is talking about a Terminal 15, it means it is a switched feed, so you should read 12V only when ignition is on.
tamorgen
C?ID=9595
Yeah, I thought about that later. I may have just been tired when I read the fluke.
tamorgen
C?ID=9595
So, I was looking in the Green Menu, and I came across a portion of the menu where you can set what CANBUS interface a module is on. Is it possible I’m not seeing those modules because of the settings in the green menu?
view
view
tamorgen
C?ID=9595
Yeah, trying to do this from my phone. The links should now work, but it won’t embed the images. I’ll try and fix when I get home.
tamorgen
C?ID=9595
Okay, here's another question.... I'm assuming that the modules I'm trying to communicate with may have Component Protection. Would they show up on the scan if the component protection was enabled?
Yes, they would.
darkchina811
ITALY
C?ID=333184
Component Protection just prevents the module from fully functioning. you can see it in the scan, you can change coding and adaptations too.
darkchina811
ITALY
C?ID=333184
I know for sure that Elsa diagrams are not always 100% correct. a friend of mine went crazy when retrofitting an Audi rear camera, and at the end of the game the two Can Bus wires were swapped on the schematic.
so maybe if you ruled out all other options, try swapping your Can Bus on one end and check if the module shows up...
