Hex-Net Mobile
BatManv8v
South Africa
C?ID=355187
I have just received my Hex-Net Interface order and have it up and running on both the Infrastructure and Access Point modes.
However, once I have logged on through VCDS-Mobile, I get a message across the screen in red stating" SD Critical Error! Please contact Ross-Tech for support".
It does not seem to hamper functionality and I have run a full scan and played with Advanced Measuring Blocks and the Dashboard.
I do get a message when I go into Advanced Measuring Values that it cannot find the label file.
I am not sure if this is related to the error on the main screen?
Try a hard reset.
With the interface powered up (either from USB or a car, it doesn't matter), press and hold the red button for 45-50 seconds. Use a timepiece! When you release it, you should hear a short confirmation beep. Now leave the interface powered up for a few minutes while it re-inistializes things. Then re-boot it by removing power for a while.
BatManv8v
South Africa
C?ID=355187
Try a hard reset.
Thanks Uwe - that has worked and I no longer have the error message.
I still have the problem on "Advanced Measuring Values" where it states that "no label file found" - see image below:
Here is my latest scan from VCDS Mobile just in case you need it.
#hndoc:?docid=00005003&xt=hnh:B6EB18E05A75FAB814706340F00447974E96377EF852B1D3617E7EFC7FF37670
VCDS Mobile 0.4505.0.4
Scan: 01 02 03 05 06 07 08 09 11 15 16 17 19 1E 34 36 37 38 42 46
	 47 4F 52 53 55 56 61 62 67 69 6C 72 76 77
1E-Media Player 2 -- Status: Communication Error 1010
67-Voice Control -- Status: Malfunction 0010
Address 01: Engine	Labels: None
	Part No SW: 4E0 910 552 B	HW: 4E0907552
	Component: 5.2L V10/4V FSI    ª0050
	Revision: 5AH11---	Serial Number: AUX3Z0FN110921
	Coding: 01060000190F0960
	Shop #: WSC 00000 000 02400
	VCID: 21057687E960FA2C385CF7-8074
No fault codes found.
Address 02: Auto Trans	Labels: 4E-02.lbl
	Part No SW: 4E1 910 156 K	HW: 09E927156B
	Component: AG6 09E 5,2 FSI RdW  0020
	Revision: --H01---	Serial Number:        0096360
	Shop #: WSC 02313 785 00200
	VCID: 2B1994AF9BAC207C92A045-807E
Address 03: ABS Brakes	Labels: 4E0-910-517.lbl
	Part No SW: 4E0 910 517 D	HW: 4E0614517AB
	Component: ESP 5.7 allrad  H46  0500
	Coding: 0001627
	Shop #: WSC 02313 000 00000
	VCID: 240B7F93F672EF04537A16-8071
Address 05: Acc/Start Auth.	Labels: 4E0-910-131.lbl
	Part No SW: 4E0 910 131	HW: 4E0909131G
	Component:     FBS AUDID3  H10  0190
	Revision: 01904910	Serial Number: AUX3Z0FN110921
	Coding: 0265216
	Shop #: WSC 02311 785 00200
	VCID: D8F39B637ABAFBE48F62D2-808D
	Subsystem 1 - 	Part No SW: XXX-XXX-XXX-XX
	Component: ELV                  XXXX
Address 06: Seat Mem. Pass	Labels: None
	Part No SW: 4E0 910 760 D	HW: 4E0959760B
	Component: Sitzmemory BFS H02   0010
	Revision: 00000000	Serial Number: 5DS 008 795-03
	Coding: 4063328
Address 07: Control Head	Labels: 4E0-910-7xx-07.lbl
	Part No SW: 4E0 910 769 A	HW: 4E2919612
	Component: Interfacebox    H43  3450
	Revision: 00000000	Serial Number: 300KW067575826
	VCID: 2A1791AB9456397469B648-807F
	Subsystem 1 - 	Part No SW: 4E0-910-611
	Component: E0380 BedienteilH01  0040
	Serial Number: 00000000024086
00003 - Control Module
Address 08: Auto HVAC	Labels: None
	Part No SW: 4E0 910 043 B	HW: 4E0820043G
	Component: KLIMAAUTOMAT    017  0450
	Revision: 00000032	Serial Number: 00000000108991
	Coding: 0057409
	VCID: 1C7B4773CE02D7C4EB0AAE-8049
Address 09: Cent. Elect.	Labels: 4E0-910-279.lbl
	Part No SW: 4E0 910 279 Q	HW: 4E0955559C
	Component: ILM Fahrer      H15  0230
	Coding: 0133122
	VCID: 362FB5DB50EE6D94FD0ECC-8063
	Subsystem 1 - 	Part No SW: 4E2-910-113-C
	Component: Wischer WWS D3  H60  0440
	Coding: 0000037
	Subsystem 2 - 	Part No SW: 4E0-910-557-A	Labels: 8K0-955-559.clb
	Component: REGENLICHTSENSORH13  0090
	Coding: 0139548
Address 11: Engine II	Labels: None
Address 15: Airbags	Labels: 4E0-910-655-94.lbl
	Part No SW: 4E0 910 655 D	HW: 4E0959655H
	Component:    Airbag 9.41  H13  3710
	Revision: 91H13371	Serial Number: 0037P0G04ME5
	Coding: 0430707
	VCID: 2711689F8744041C769829-8072
	Subsystem 1 - 	Serial Number: 63328RB4019F4384M
	Subsystem 2 - 	Serial Number: 63428RB4019F4C76X
	Subsystem 3 - 	Serial Number: 63528RB4019F4C7B$
	Subsystem 4 - 	Serial Number: 63628RB4019F442CS
	Subsystem 5 - 	Serial Number: 63729RB401B843D8V
	Subsystem 6 - 	Serial Number: 63829RB401B834CD-
Address 16: Steering wheel	Labels: 4E0-910-549.lbl
	Part No SW: 4E0 910 549	HW: 4E0953549
	Component: Lenksäulenmodul H14 0040
	Coding: 0112141
	VCID: E58DA2973DC8560C04E443-80B0
	Component: Lenkradmodul    H07  0090
Address 17: Instruments	Labels: 4E0-910-xxx-17.lbl
	Part No SW: 4E0 910 901 D	HW: 4E0920901D
	Component: KOMBIINSTR. VDO H82  0530
	Revision: D04     	Serial Number: AUDID3FN000832
	Coding: 0032813
	Shop #: WSC 99999 999 99999
Address 19: CAN Gateway	Labels: 4L0-910-468.clb
	Part No SW: 4L0 910 468	HW: 4L0907468
	Component: J533__Gateway   H06  0040
	Revision: 00H06000	Serial Number: 0900B06A308039
	Coding: F7D1DFFF50720E
	VCID: EC9BD7B3DE2267445B2ABE-80B9
02077 - Media Player Position 2 (R119)
Address 1E: Media Player 2	Labels: 4E0-910-111.lbl
	Part No SW: 4E0 910 110 A	HW: 4E0035110A
	Component: MP3-Changer     H44  0270
	Revision: 00044000	Serial Number: AUZ5ZBF3113485
	VCID: 166F555B302E8D94DDCE6C-8043
02084 - Component Protection
Address 34: Level Control	Labels: 4E0-910-553.lbl
	Part No SW: 4E0 910 553 J	HW: 4E0907553F
	Component: LUFTFDR.-CDC    H06  6310
	Coding: 0015520
Address 36: Seat Mem. Drvr	Labels: None
	Component: Sitzmemory FS  H02   0010
	Coding: 4063330
Address 37: Navigation	Labels: 4E0-910-88x-37.lbl
	Part No SW: 4E0 910 888 P	HW: 4E0919887L
	Component: MNS ECE         H48  1060
	Revision: 00000000	Serial Number: 364KO067613122
	Shop #: WSC 01642 996 72817
	VCID: 3B39A4EF6BCCB0FC024015-806E
Address 38: Roof Electronics	Labels: 4E0-910-135.lbl
	Part No SW: 4E0 910 135 A	HW: 4E0907135A
	Component: Dachknoten D3   H05  0090
	Serial Number: 00000629800011
	Coding: 0036004
	VCID: 1D7D4A77D518DECC1C34DB-8048
Address 42: Door Elect, Driver	Labels: 4E1-910-802-42.lbl
	Part No SW: 4E1 910 802 B	HW: 4E2959802D
	Component: Türsteuer.FS BRM005 0180
	Coding: 0027054
	VCID: 20037383E26AF3243752FA-8075
Address 46: Central Conv.	Labels: 4E0-910-289.lbl
	Part No SW: 4E0 910 289 D	HW: 4E0907289D
	Component: Komfortgeraet   H07  0010
	Revision: 00100007	Serial Number:  W040611210098
	Coding: 0005868
	Shop #: WSC 04632 996 86463
	Subsystem 1 - 	Part No SW: 4E0-910-853
	Component: Heckdeckel   P14H06  0070
01134 - Alarm Horn (H12)
Address 47: Sound System	Labels: 4E0-910-223.lbl
	Part No SW: 4E0 910 223 Q	HW: 4E0035223G
	Component: DSP-High D3     H03  0110
	Revision: PROD_01 	Serial Number: 00000000000419
	Coding: 0000027
Address 4F: Centr. Electr. II	Labels: None
	Part No SW: 4E0 910 280 A	HW: 4E0907280B
	Component: ILM Beifahrer   H11  0070
	Revision:         	Serial Number: 00000000002775
	Coding: 0010101
	VCID: 1E7F4D7BD81EC5D4053ED4-804B
Address 52: Door Elect, Pass.	Labels: 4E1-910-802-52.lbl
	Part No SW: 4E1 910 802 B	HW: 4E2959801D
	Component: Türsteuer.BF BRM005 0180
	Coding: 0027054
Address 53: Parking Brake	Labels: 4E0-910-801.clb
	Part No SW: 4E0 910 801 C	HW: 4E0907801A
	Component: EPB  A32C0220   H02  0220
	Revision: A32C0220
	Coding: 0000731
	Shop #: WSC 30115 001 1048576
	VCID: 1F01707FDF14CCDC0E28C1-804A
Address 55: Xenon Range	Labels: 4F0-910-357.lbl
	Part No SW: 4F0 910 357 F	HW: 4F0907357F
	Component: AFS 1           H01  0020
	Revision: 00000001	Serial Number:
	Coding: 0000018
	VCID: 29156EA79150326C608C5F-807C
	Subsystem 1 - 	Part No SW: 4F0-941-329-B	Labels: 3D0-941-329.clb
	Component: AFS-Modul links H02  0020
	Subsystem 2 - 	Part No SW: 4F0-941-329-B	Labels: 3D0-941-329.clb
	Component: AFS-Modul rechtsH02  0020
Address 56: Radio	Labels: 4E0-910-541.lbl
	Part No SW: 4E0 910 541 M	HW: 4E0035541P
	Component: TUNER EU/US/RDW H42  0570
	Revision: 00000000	Serial Number: 396K5067549466
Address 61: Battery Regul.	Labels: 4E0-910-181.lbl
	Part No SW: 4E0 910 181 C	HW: 4E0915181C
	Component: J0644 BEM       H12  0550
	Revision: 00000000	Serial Number: 00000000024173
	Coding: 0000000
	Shop #: WSC 00000 128 00289
	Subsystem 1 - 	Part No SW: 4E0-915-105-A
	Component: von VA0  2611130045
Address 62: Door, Rear Left	Labels: 4E0-910-802.lbl
	Part No SW: 4E0 910 802 A	HW: 4E0959801D
	Component: Türsteuer.HL BRM005 0180
	Coding: 0027054
Address 67: Voice Control	Labels: 4E0-910-75x-67.lbl
	Part No SW: 4E0 910 754 S	HW: 4E0035753A
	Component: SDS 3502 UK     H45  0630
	Revision: 00000000	Serial Number: 00000611060119
	Shop #: WSC 12336 024 394758
01715 - Conversation Mode; Telephone
Address 69: Trailer	Labels: 4E0-910-383.lbl
	Part No SW: 4E0 910 383 C	HW: 4E0907383C
	Component: ANHAENGERELEKTR 004  0060
Address 6C: Back-up Cam.	Labels: 4E0-910-441.clb
	Part No SW: 4E0 910 441	HW: 4L0907441A
	Component: J772__Rearview       0050
	Revision: --H12---	Serial Number: 525PA8-J6910U2
	Coding: 1031302
	VCID: DCFB87730E8217C4AB8AEE-8089
Address 72: Door, Rear Right	Labels: 4E0-910-802.lbl
	Part No SW: 4E0 910 802 A	HW: 4E0959802D
	Component: Türsteuer.HR BRM005 0180
	Coding: 0027054
Address 76: Park Assist	Labels: 4E0-910-283.lbl
	Part No SW: 4E0 910 283 C	HW: 4E0919283C
	Component: Parkhilfe 8-Kan H12  0040
	Revision: 00H12000	Serial Number: 08730630407528
	Coding: 0231008
	VCID: 23097C8FF37CE83C2A701D-8076
02069 - Front Parking Aid Sensors
End--(Elapsed Time: 03:29, VBatt start/end: 14.0/14.0 Vign: 0.0)-
Does the Windows based VCDS have a label file for your ECU?
BatManv8v
South Africa
C?ID=355187
Yes I am. I actually went to check to make sure before answering you.
_Val
Latvia
C?ID=356659
07L-910-552-BSM1.CLB missing in english version.
And there are some differences in spacing...
VCDS mobile:
VCDS "standart"
   Part No SW: 4E0 910 552 B    HW: 4E0 907 552
