Caddy speed limiter
njautos
C?ID=295493
Hi guys
Hopefully I have posted this in the right place sorry if not. I have a 2014 Volkswagen caddy and customer has asked me to put a 70mph speed limiter on it. His has a few of these for his staff but wants to no if it can then be removed again when he come to sell the van? Could anyone tell me if this is possible and how I would go about doing it?
Thanks
Without seeing an Auto-Scan it's impossible to accurately answer your question.
Having said that, I do remember that when a similar question was asked a while ago the response was that once the limiter was set it couldn't be removed - but my memory may be wrong :cry:
njautos
C?ID=295493
Hi guys I am trying to add a auto scan but struggling to do it I have it saved on my laptop but can’t seem to get it to up load I have watched the video that shows how to up load straight from vdcs is there a different way I need to do it from just being saved on my laptop ? I have also checked the adaptions in engine Ecu today and give me the option to add a static speed limiter I am guessing that’s it ? Surly if I want to remove it I can just set it higher ?
njautos
C?ID=295493
Auto scan for caddy
Thursday,13,June,2019,17:08:42:39123
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
Dealer/Shop Name: Nj Autos
VIN: WV1ZZZ2KZEX133234   License Plate: GL14 XEN
Mileage: 112230km-69736mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 77
VIN: WV1ZZZ2KZEX133234   Mileage: 112230km-69736miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 TF    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9979
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114014030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023TF 003003
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 7DA4F38F7D78E3DFA17-8028
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 433C400D092503FDC20D02E7901DC081A0000020
   Shop #: WSC 35110 377 08192
   VCID: 7EA6F48370FEF8C7B8D-802A
   Part No SW: 7N0 907 426 CH    HW: 7N0 907 426 CH
   Component: AC Manuell    H20 0606
   Revision: 00001002
   Coding: 0010004002
   ROD: EV_ACManueBHBVW36X_VW32.rod
   VCID: 7CA2FE8B6662EAD7969-8028
   Part No SW: 5K0 937 085 AA    HW: 5K0 937 085 AA
   Component: BCM PQ35 B+   122 0173
   Revision: BB122001
   Coding: 411A583A8025182A08880082900000640301728852028060648000000040
   VCID: 72BED0B334A6ACA7CC5-8026
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 13031  26  0512
   Coding: 009795
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag02Q H07 0013
   Revision: --------    Serial number: 003HL00NW6N$
   Coding: 000000000000000000000000000000003251
   VCID: 35342BAF05C8FB9F297-8060
   Part No SW: 1K5 953 521 BH    HW: 5K0 953 569 AC
   Revision: FF010042    Serial number: 20140328300585
   Coding: 4080060000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 74B2D6AB4E32A297DE9-8020
   Part No SW: 2K0 920 976 A    HW: 2K0 920 976 A
   Component: KOMBI         H04 0811
   Coding: 481800
   VCID: 2F3819C7E794C14F63B-807A
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 010414F2000036
   Coding: 357401
   VCID: 79ACE79F69D0DFFF8DF-802C
   Component: IMMO          H04 0811
   VCID: 6A8EC8D31CF66467745-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 04 0174
   Coding: 0000000
   VCID: 76B6ECA354CEB087E0D-8022
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 392C279F25501FFFCDF-806C
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75B4EBAF49C8BB9FE97-8020
   Part No SW: 5K0 035 156 A    HW: 5K0 035 156 A
   Component: Radio         H54 0107
   Revision: R0000000    Serial number: VWZAZ1P6571146
   Coding: 0500020001
   VCID: 2514FBEFB5E88B1F997-8070
00856 - Radio Antenna
                    Fault Status: 00100111
                    Reset counter: 254
                    Mileage: 112041 km
                    Date: 2019.06.08
                    Time: 15:47:26
                    Fault Status: 00101011
                    Reset counter: 254
                    Mileage: 112041 km
                    Date: 2019.06.08
                    Time: 15:47:38
   Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
   Component: TELEFON       H15 4217
   Revision: 1B001001    Serial number: 00007666021719
   Coding: 0A01010001010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3C223E8B26E22AD7D69-8068
End----(Elapsed Time: 00:46, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
njautos
C?ID=295493
Finally worked out how to post auto scan sorry its the first one I have ever uploaded so took me a while
OK, in that particular ECU, there are several Adaptation Channels:
IDE02247 -- Static maximum speed limit (km/h)
IDE02248 -- Individually adjustable maximum speed limit (km/h)
IDE02632 -- Activation of static maximum speed limit (OFF, On)
IDE02633-ENG101613 -- Deactivation of static maximum speed limit (Bytefield_Value,HEXBYTES)
I think that "Individually adjustable" one can probably be adjusted up or down as you desire, but the Static one requires some super-secret Hexadecimal incantation to turn off.
Note the emphasis in my words. I don't recommend changing any of these until others chime in to confirm or correct my thoughts.
njautos
C?ID=295493
Hi Uwe
Thanks for the reply so the static one may not be able to be removed after it has been set ? I did see this in the adaptations for the ECU but didn't see any of the other ways you listed where would the others be located ?
Thanks
mtl
Slovenia
C?ID=153305
I have tested individual speed limit on a few cars (NOT on a similar to yours) and it was possible to adjust it also back to higher speed.
So, I would suggest that you try with for example speed limit 200 and then go back to 250. If it will accept it will MOST LIKELY allow you to change it also from 70 to more...
I would go then for a 150 and try it and then back to 155 for example...
PS: My numbers are in kph :).
njautos
C?ID=295493
This is a good idea thanks a lot was it the static speed limter you adjusted ? in engine ECU adaptions ?
mtl
Slovenia
C?ID=153305
No, it was INDIVIDUAL speed limit.
Dukedesmo
C?ID=288946
Late to this thread but found it whilst searching for info on how to remove a 70mph speed limiter on a Friend's T5.
I can confirm that, on this vehicle at least, the: IDE02248 -- Individually adjustable maximum speed limit (km/h) is the operational figure.
This van had it set to 110 by the previous (company) owner and it would cut out at an indicated 70mph making overtaking nigh on impossible/downright dangerous, simply changing this figure to 255 allowed the van to reach it's top speed - sadly not 255kmh though...:(
Static was set to 300, presumably by VW?
