2014 SQ5 Tow package retrofit - Module works, ACC and Brake Guard does not.
Jaxen
Canada
C?ID=37587
As per the title, my ACC stopped working with the retrofit and coding of the tow module.
Any help would be greatly appreciated... I've lived without the benefits of this $2k option for too long now. :-)
Wednesday,27,February,2019,16:19:35:26405
VCDS Version: 18.9.1.0 (x64)
Workshop Code: 444 06208 000000
VIN: WA1LGCFP2EA023693   License Plate:
Mileage: 101610km-63137mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 36 3C 42 44 46 47 52 53 56
          5F 62 69 6C 6D 72 A9
VIN: WA1LGCFP2EA023693   Mileage: 101610km-63137miles
Address 01: Engine (J623-CTUD)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8R0 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0006
   Revision: --H07---
   Coding: 2A2A0034055600060000
   Shop #: WSC 06208 444 00000
   ASAM Dataset: EV_ECM30TFS0218R0907551G 001006
   ROD: EV_ECM30TFS0218R0907551G.rod
   VCID: 3C7CB99FB70C82AAC1-8068
6628 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
                    Mileage: 101618 km
                    Date: 2019.02.27
                    Time: 16:04:32
                    Coolant temperature: 6 °C
                    Intake air temperature: 6 °C
                    Voltage terminal 30: 11.882 V
                    Engine speed: actual: 0 /min
                    MAF_ENVD: 0.00000 mg/stroke
                    Coolant temperature (unfiltered): 6.00 °C
                    Engine: operating status: ES
                    Engine load: 0.000000 %
                    Vehicle speed: actual: 0 km/h
7193 - Function Restriction due to Faults in Other Modules
          U1113 00 [037] - -
                    Mileage: 101618 km
                    Date: 2019.02.27
                    Time: 16:04:32
                    Coolant temperature (unfiltered): 18.75 °C
Readiness: 1110 1101
   Part No SW: 8R0 927 158 AB    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1003
   Revision: --H16---
   Coding: 000001
   VCID: 7DFA749BEC964BA2B6-8028
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AM    HW: 8R0 907 379 AM
   Component: ESP8 quattro  H09 0030
   Coding: 309D1801
   VCID: 0B1E2A43AA227512B8-805E
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H12 0633
   Coding: 0D854040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 040C017F877C3A6AF9-8050
   Serial number: 2313000123533007
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01150720131216
   Coding: 6601228000
   Shop #: WSC 43975 001 1048576
   VCID: 3972A08BB03EB782DA-806C
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000645898502
   Coding: 26008096863CAFE2010048C300003D0D0F9CE708A2090221000008004400010200040034000000
   VCID: 7AF07F87F5B87C9A93-802E
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 130626  H11 0050
   Serial number: 90243014130615180006
   Coding: 01D513
   Serial number: 21520145
   Coding: 03005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000507131354
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R6WAX02
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 53284AB6000000000001
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0100
   Coding: 003337
   VCID: 3776A6B3862AA1F22C-8062
                    Reset counter: 179
                    Mileage: 101618 km
                    Date: 2019.02.27
                    Time: 16:04:21
                    Temperature: 6.0°C
                    Voltage: 11.78 V
                    Hex Value: 0x005C
                    Lateral Accel.: 0.00 m/s^2
                    Fault Status: 00101101
                    Reset counter: 219
                    Mileage: 101618 km
                    Date: 2019.02.27
                    Time: 16:04:21
                    Temperature: 6.0°C
                    Voltage: 11.78 V
                    Hex Value: 0x00BD
                    Reset counter: 219
                    Mileage: 101618 km
                    Date: 2019.02.27
                    Time: 16:04:21
                    Temperature: 6.0°C
                    Voltage: 11.78 V
                    Hex Value: 0x00C0
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003GPDB05U9Q
   Coding: 30373431343230303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 4796D673FECAD1725C-8012
   Serial number: 6334MSME7C0222020
   Serial number: 6344MSME7C022167B
   Serial number: 6352QSME48330878I
   Serial number: 6362QSME51343D76K
   Serial number: 63732SME5F350E705
   Serial number: 63832SME5F350360.
   Revision: --------    Serial number: 90372MG4000XL
   Coding: 00003F
   VCID: 448CC17FC7FCFA6AB9-8010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 981 M    HW: 8R0 920 981 M
   Component: KOMBIINSTR.   H35 0563
   Revision: 00400000    Serial number: WYJ44FR6E
   Coding: 8BBF22000F010008020000
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z1362301B7
   Coding: 80C103FF00
   VCID: 4C9CE95FEFAC322A71-8018
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 40186B28291461704038
            000 -  -  - Intermittent
                    Reset counter: 219
                    Mileage: 101618 km
                    Date: 2019.02.27
                    Time: 16:04:22
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000067372015
   Coding: 00581B00000000000000
   Shop #: WSC 11220 002 1048576
   VCID: 4280C767DDE8F45A8B-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H04 0060
   Serial number: 0310702113
   Coding: 010221
   VCID: 3F86CE93A61A99B2E4-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H04 0060
   Serial number: 0310815038
   Coding: 000102
   Component: TSG FA        H02 0508
   Revision:             Serial number: 0000067995110
   Coding: 011D13205E00440004
   VCID: 4FA6FE531EBA093214-801A
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H38 0510
   Revision: 00001000    Serial number: 0030633315
   Coding: 100000010000
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 458ADC7BC4C6C362AE-8010
   Revision: 00002001    Serial number: 0310787019
   Coding: 0126023A20FA709584B0053200040000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000702699
   Component: J245EE20SKB13  H05 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H05 0220
   Revision: 00005001    Serial number: 94813017358503
   VCID: 2D5A84DB74761B2246-8078
   Component: TSG BF        H02 0508
   Revision:             Serial number: 0000068010053
   VCID: 4E98E35719B0003A1F-801A
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 20000000303981
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3972A08BB83EB782DA-806C
   Component: Radio U SIRIU H60 0133
   Revision: AB001007    Serial number: 156G00D7827317
   Coding: 020007010000000001
   VCID: 244C61FF27BCDA6A99-8070
   Part No SW: 8R1 035 664 D    HW: 8R1 035 664 D
   Component: H-BN-NA       H40 0738
   Revision: --------    Serial number: 203G-0D7525196
   Coding: 1A0200060205EBEF74028F4E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Component: DU7 High  H42 0104
   Serial number: A130GY0D2780782
   Serial number: 00000001566507
   Component: CD-Database  5298
                    Reset counter: 179
                    Mileage: 101618 km
                    Date: 2019.02.27
                    Time: 16:04:28
                    Bin. Bits: 00000001 00000000
                    Bin. Bits: 00000000 00000000
   Revision:             Serial number: 0000068177253
   Coding: 010C13204000240004
   VCID: 4688DB77F1C0C87AA7-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H12 0100
   Revision: 1A001001    Serial number: 00000411100413
   Coding: 0200000000000000
   VCID: 3668ABB7812058FA37-8062
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H08---    Serial number: 525PA8-J35A345
   Coding: 1030010
   VCID: 346C91BF575C4AEA09-8060
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B7EBA83BA028592C8-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Serial number: 8R0827852B
   Revision:             Serial number: 0000068177254
   Part No SW: 8R0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 130612200972
   VCID: 3A70BF87BD38BC9AD3-806E
End-------------------------(Elapsed Time: 04:44)--------------------------
Jaxen
Canada
C?ID=37587
Am I that much of a noob?
I thought I had posted this in the "Retrofits" forum - my apologies.
Mods, please move or delete this post.
NEtech
C?ID=56995
I guess you have changed ACC Coding [13] ?
If so what was it before ?
Moved to Retrofits.
Jaxen
Canada
C?ID=37587
Looks like it was originally 003348:
   Coding: 003348
   VCID: 3776A6B3862AA1A0D11
NEtech
C?ID=56995
First write numbers (not zero's) for wsc, importer, device no. described here
[Save]
[Close VCDS]
Start VCDS
Use 003341
